Games can crash whole system(can't even call ctrl+f2)
When I’m playing games(CIv 6, for example) it has a chance to just freeze. If I like I might be able to close it via ctrl+shift+esc or atleast open ctrl+f2(or was it f3) and initiate reboot, but most of the time I can’t even do that.
I don’t know what the problem is, it isn’t related to the exact game.
Maybe someone had this problem.
inxi -Fza and logs afrer reboot:
  Kernel: 5.15.72-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=b11151cf-968d-43ca-b20e-de830fdcd43d rw rootflags=subvol=@
    quiet udev.log_priority=3
  Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Acer product: Swift SF314-43 v: V1.04
    serial: <superuser required>
  Mobo: LN model: Sake_CA v: V1.04 serial: <superuser required>
    UEFI: Insyde v: 1.04 date: 07/28/2021
  ID-1: BAT1 charge: 53.2 Wh (100.0%) condition: 53.2/53.2 Wh (99.9%)
    volts: 13.1 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
    status: full
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7
    (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608102
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 2363 high: 2870 min/max: 1400/4056 boost: enabled
    scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2092 2: 2870
    3: 2245 4: 2385 5: 1799 6: 2018 7: 2547 8: 2498 9: 2433 10: 2388 11: 2679
    12: 2407 bogomips: 50327
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    prctl and seccomp
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
    v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0
    chip-ID: 1002:164c class-ID: 0300 temp: 40.0 C
  Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-3:2
    chip-ID: 0408:a094 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x683d built: 2019
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.42 5.15.72-1-MANJARO)
    v: 4.6 Mesa 22.1.7 direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Acer Incorporated
    ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Acer Incorporated
    ALI driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x,snd_pci_acp5x pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound API: ALSA v: k5.15.72-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.58 running: yes
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF-ID-1: tap-easytether state: down mac: <filter>
  Device-1: Lite-On Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 1-4:3 chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 205.57 GiB (43.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFK0S03
    temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 205.57 GiB
    (43.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB
    (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 205.57
    GiB (43.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 205.57
  System Temperatures: cpu: 45.6 C mobo: N/A gpu: amdgpu temp: 41.0 C
  Processes: 361 Uptime: 3h 26m wakeups: 57102 Memory: 14.98 GiB used: 6.74
  GiB (45.0%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1361
  libs: 405 tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: yakuake inxi: 3.3.22
    ~  journalctl -b 4438204cca084bdc83c6e41364f70e97         INT ✘
Oct 12 17:51:04 swift-sf314-43 kernel: Linux version 5.15.72-1-MANJARO (builduser@fv-az41-528) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT Thu Oct 6 07:30:22 UTC 2022
Oct 12 17:51:04 swift-sf314-43 kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=b11151cf-968d-43ca-b20e-de830fdcd43d rw rootflags=subvol=@ quiet udev.log_priority=3
Oct 12 17:51:04 swift-sf314-43 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Oct 12 17:51:04 swift-sf314-43 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Oct 12 17:51:04 swift-sf314-43 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Oct 12 17:51:04 swift-sf314-43 kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Oct 12 17:51:04 swift-sf314-43 kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
Oct 12 17:51:04 swift-sf314-43 kernel: signal: max sigframe size: 1776
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-provided physical RAM map:
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000bffff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000099fffff] usable
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x0000000009a00000-0x0000000009dfffff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x0000000009e00000-0x0000000009efffff] usable
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x0000000009f00000-0x0000000009f0efff] ACPI NVS
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x0000000009f0f000-0x00000000b99e8fff] usable
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000b99e9000-0x00000000babe8fff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000babe9000-0x00000000c8dfefff] usable
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000c8dff000-0x00000000c9dfefff] type 20
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000c9dff000-0x00000000cbdfefff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000cbdff000-0x00000000cdf7efff] ACPI NVS
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000cdf7f000-0x00000000cdffefff] ACPI data
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000cdfff000-0x00000000cdffffff] usable
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000ce000000-0x00000000cfffffff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000fde00000-0x00000000fdefffff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe0fffff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec01fff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000fec20000-0x00000000fec20fff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed81fff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x0000000100000000-0x000000040f33ffff] usable
lines 1-34...skipping...
Oct 12 17:51:04 swift-sf314-43 kernel: BIOS-e820: [mem 0x000000040f340000-0x000000042fffffff] reserved
Oct 12 17:51:04 swift-sf314-43 kernel: NX (Execute Disable) protection: active
Oct 12 17:51:04 swift-sf314-43 kernel: efi: EFI v2.70 by INSYDE Corp.
lines 1-37...skipping...
Oct 12 17:51:04 swift-sf314-43 kernel: efi: ACPI=0xcdffe000 ACPI 2.0=0xcdffe014 TPMFinalLog=0xcced8000 SMBIOS=0xca58a000 SMBIOS 3.0=0xca588000 ESRT=0xb456cd18
lines 1-38...skipping...
Oct 12 17:51:04 swift-sf314-43 kernel: SMBIOS 3.3.0 present.
lines 1-39...skipping...
Oct 12 17:51:04 swift-sf314-43 kernel: DMI: Acer Swift SF314-43/Sake_CA, BIOS V1.04 07/28/2021
lines 1-40...skipping...
Oct 12 17:51:04 swift-sf314-43 kernel: tsc: Fast TSC calibration using PIT
lines 1-41...skipping...
Oct 12 17:51:04 swift-sf314-43 kernel: tsc: Detected 2096.122 MHz processor
lines 1-42...skipping...
Oct 12 17:51:04 swift-sf314-43 kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
I had the same problem with my 8GB RAM: most games froze PC until rebooting it by button only can help. To fix this I needed to simply create swap partition as the RAM was running out. I am still not an expert at reading journalctl, but I can guess you have the same situation by:
  1. Most of the output contains RAM map info;
Recommend creating a swap partition with up to 16-20GB on your SSD. To create it these links should help you (but I used them only to activate it as I created it with GParted GUI):
https://wiki.archlinux.org/title/Swap
Well… That’s something I guess, thanks.
Although I can’t quite understand why games crash the whole system when they don’t have enough RAM, while in windows they’ll:
  1. Freeze without drugging the system with them
  2. Will have enough RAM in 16gb(At least the games I play).
Maybe it’s somehow related to KDE(only manjaro KDE, among 4 systems I tried) detecting only 14.98 ram out of 16384, while others detect about 15.6-15.8.
I hope someone knows, swap will be a temporary solution for now.
Disclaimer: I can exaggerate something, but this is all how I understand it.
I don’t think System can have RAM for specific types of software. Its more global, so whats going on: game processes take all of the RAM and System tries to handle every one, but it cannot as there is no reserved place for it. So, totally, the System cannot process every call and when it tries to free space even with errors — the game is still creating a new one and may flood it, thus we have the total crash.
Swap space is like additional RAM which is used when the physical one is full or almost there. Why doesn’t this happen on Windows? Well, most recourses have its priority and whatever call it would be — System’s one will always have the highest, so when an app “wants” to take more space — Windows will stop or even kill it to keep its own processes running whatever user runs. Also as far as I know, Windows automatically creates a swap file when the OS is installed and changes its size if needed (by itself). And I don’t say if Microsoft made its own proprietary “smart algorythm” for RAM/swap space usage and etc. Additionally, Windows always wants us not to try dig into it and make everything “great” pre-installed for the common user.
And the only thing I don’t understand — if I am mostly right — is why Manjaro does not create swap at the end of its installation? Or is this like some “trend” in Linux world like “breaking bottle on ship”? As for a user friendly distro this is no actually “friendly” anyway, but thankfully easy fixable.
Windows do the same thing. For example, Windows and Linux both always detect my 8GB RAM as 7.7GB. There is interesting discussion about it on this forum with explanations, but you have already seen it :upside_down_face:
Yeah, I know some part is always reserved, that problem is more about why only manjaro KDE reserver 1.5GB, while others do about 600-800mb.
I know what SWAP is, just didn’t use it yet, cause I never had problems with 16GB on Windows(my old machine, that feature like a Swap was turned off too, although not always). So I didn’t see much use in it. Maybe I just forgot that I did had that last time(different installations) or maybe games with proton eat hell of a lot more RAM.
Also I had no idea that linux cant prioritize itself over some app by default(like windows does) to just crash that app.
Thanks for the memory refreshement :slight_smile:
