Nov 26 15:58:05 manjarmageddon kernel: rtl8192cu: Tx queue select: 0
Nov 26 16:03:40 manjarmageddon kernel: audit: type=1106 audit(1606401000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pasudo" hostname=? addr=? terminal=/dev/pts/0 res=success’
Nov 26 16:03:40 manjarmageddon kernel: audit: type=1104 audit(1606401000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success’
Nov 26 16:03:44 manjarmageddon kernel: audit: type=1106 audit(160640000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pamudo" hostname=? addr=? terminal=/dev/pts/1 res=success’
Nov 26 16:03:44 manjarmageddon kernel: audit: type=1104 audit(160640000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_esr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success’
Nov 26 16:04:04 manjarmageddon kernel: audit: type=1101 audit(160640id=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time aco" hostname=? addr=? terminal=/dev/pts/1 res=success’
Nov 26 16:04:04 manjarmageddon kernel: audit: type=1110 audit(1606401000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success’
Nov 26 16:04:04 manjarmageddon kernel: audit: type=1105 audit(1606401000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pamudo" hostname=? addr=? terminal=/dev/pts/1 res=success’
Nov 26 16:04:04 manjarmageddon kernel: audit: type=1106 audit(1606401000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pasudo" hostname=? addr=? terminal=/dev/pts/1 res=success’
Nov 26 16:04:04 manjarmageddon kernel: audit: type=1104 audit(1606401000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success’
Nov 26 16:04:35 manjarmageddon kernel: audit: type=1101 audit(1606403075.512:73): pid=45037 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:35 manjarmageddon kernel: audit: type=1110 audit(1606403075.512:74): pid=45037 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:35 manjarmageddon kernel: audit: type=1105 audit(1606403075.522:75): pid=45037 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:35 manjarmageddon kernel: bus: ‘hid’: remove device 0003:1038:1430.0009
Nov 26 16:04:35 manjarmageddon kernel: PM: Removing info for No Bus:event6
Nov 26 16:04:35 manjarmageddon kernel: PM: Removing info for No Bus:mouse0
Nov 26 16:04:35 manjarmageddon kernel: PM: Removing info for No Bus:input31
Nov 26 16:04:35 manjarmageddon kernel: device: ‘hidraw2’: device_unregister
Nov 26 16:04:35 manjarmageddon kernel: PM: Removing info for No Bus:hidraw2
Nov 26 16:04:35 manjarmageddon kernel: device: ‘hidraw2’: device_create_release
Nov 26 16:04:35 manjarmageddon kernel: PM: Removing info for hid:0003:1038:1430.0009
Nov 26 16:04:35 manjarmageddon kernel: audit: type=1106 audit(1606403075.569:76): pid=45037 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:35 manjarmageddon kernel: audit: type=1104 audit(1606403075.569:77): pid=45037 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:46 manjarmageddon kernel: audit: type=1101 audit(1606403086.679:78): pid=46017 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:46 manjarmageddon kernel: audit: type=1110 audit(1606403086.679:79): pid=46017 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:46 manjarmageddon kernel: audit: type=1105 audit(1606403086.682:80): pid=46017 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:46 manjarmageddon kernel: bus: ‘hid’: remove device 0003:1038:1430.000A
Nov 26 16:04:46 manjarmageddon kernel: device: ‘hiddev2’: device_unregister
Nov 26 16:04:46 manjarmageddon kernel: PM: Removing info for No Bus:hiddev2
Nov 26 16:04:46 manjarmageddon kernel: device: ‘hiddev2’: device_create_release
Nov 26 16:04:46 manjarmageddon kernel: device: ‘hidraw3’: device_unregister
Nov 26 16:04:46 manjarmageddon kernel: PM: Removing info for No Bus:hidraw3
Nov 26 16:04:46 manjarmageddon kernel: device: ‘hidraw3’: device_create_release
Nov 26 16:04:46 manjarmageddon kernel: PM: Removing info for hid:0003:1038:1430.000A
Nov 26 16:04:46 manjarmageddon kernel: audit: type=1106 audit(1606403086.685:81): pid=46017 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:46 manjarmageddon kernel: audit: type=1104 audit(1606403086.685:82): pid=46017 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
echo 11-3:1.1 | sudo tee /sys/bus/usb/drivers/xpad/bindNov 26 16:04:55 manjarmageddon kernel: audit: type=1101 audit(1606403095.979:83): pid=46028 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:55 manjarmageddon kernel: audit: type=1110 audit(1606403095.982:84): pid=46028 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:55 manjarmageddon kernel: audit: type=1105 audit(1606403095.985:85): pid=46028 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:55 manjarmageddon kernel: audit: type=1106 audit(1606403095.989:86): pid=46028 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:55 manjarmageddon kernel: audit: type=1104 audit(1606403095.989:87): pid=46028 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:04:59 manjarmageddon kernel: rtl8192cu: MAC auto ON okay!
Nov 26 16:04:59 manjarmageddon kernel: rtl8192cu: Tx queue select: 0x05
Nov 26 16:05:05 manjarmageddon kernel: audit: type=1101 audit(1606403105.892:88): pid=47000 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:05:05 manjarmageddon kernel: audit: type=1110 audit(1606403105.892:89): pid=47000 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:05:05 manjarmageddon kernel: audit: type=1105 audit(1606403105.892:90): pid=47000 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:05:05 manjarmageddon kernel: audit: type=1106 audit(1606403105.895:91): pid=47000 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 16:05:05 manjarmageddon kernel: audit: type=1104 audit(1606403105.899:92): pid=47000 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
