Gamepad stopped working
Hello everyone, first time here
Last week my gamepad (a SteelSeries Stratus Duo) stopped working, this was after working for some time out of the box.
After plugging it in, the gamepad starts flashing and does not seem to do anything.
evtest shows no activity when pushing buttons:
Select the device event number [0-29]: 6
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x1038 product 0x1430 version 0x111
Input device name: "SteelSeries Stratus Duo"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 272 (BTN_LEFT)
    Event code 273 (BTN_RIGHT)
    Event code 274 (BTN_MIDDLE)
    Event code 275 (BTN_SIDE)
    Event code 276 (BTN_EXTRA)
  Event type 2 (EV_REL)
    Event code 0 (REL_X)
    Event code 1 (REL_Y)
    Event code 8 (REL_WHEEL)
    Event code 11 (REL_WHEEL_HI_RES)
  Event type 4 (EV_MSC)
    Event code 4 (MSC_SCAN)
Properties:
Testing ... (interrupt to exit)
<blank>
dmesg output after plugging it in seems to show that a mouse driver is being loaded instead of xpad.
[11067.800116] usb 11-3: new full-speed USB device number 6 using ohci-pci
[11067.988832] usb 11-3: New USB device found, idVendor=1038, idProduct=1430, bcdDevice= 1.75
[11067.988840] usb 11-3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[11067.988844] usb 11-3: Product: SteelSeries Stratus Duo
[11067.995713] input: SteelSeries Stratus Duo as /devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.1/0003:1038:1430.000F/input/input34
[11067.995982] hid-generic 0003:1038:1430.000F: input,hidraw2: USB HID v1.11 Mouse [SteelSeries Stratus Duo] on usb-0000:00:16.0-3/input1
[11067.999653] hid-generic 0003:1038:1430.0010: hiddev2,hidraw3: USB HID v1.11 Device [SteelSeries Stratus Duo] on usb-0000:00:16.0-3/input2
Any help with this would be great!
What happens if you run sudo modprobe -r xpad ; sudo modprobe xpad?
Running sudo modprobe -r xpad ; sudo modprobe xpad shows this watching dmesg:
[14699.263434] audit: type=1101 audit(1606392458.983:164): pid=268775 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="stormageddon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.263996] audit: type=1110 audit(1606392458.983:165): pid=268775 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.270020] audit: type=1105 audit(1606392458.987:166): pid=268775 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.273739] usbcore: deregistering interface driver xpad
[14699.308213] audit: type=1106 audit(1606392459.027:167): pid=268775 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.308248] audit: type=1104 audit(1606392459.027:168): pid=268775 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.320745] audit: type=1101 audit(1606392459.040:169): pid=268779 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="stormageddon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.320959] audit: type=1110 audit(1606392459.040:170): pid=268779 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.324036] audit: type=1105 audit(1606392459.043:171): pid=268779 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.333266] usbcore: registered new interface driver xpad
[14699.333927] audit: type=1106 audit(1606392459.053:172): pid=268779 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
[14699.333931] audit: type=1104 audit(1606392459.053:173): pid=268779 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/4 res=success'
FWIW: the output of lsusb -v:
Bus 011 Device 006: ID 1038:1430 SteelSeries ApS SteelSeries Stratus Duo
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol       255
  bMaxPacketSize0         8
  idVendor           0x1038 SteelSeries ApS
  idProduct          0x1430
  bcdDevice            1.75
  iManufacturer           0
  iProduct                2 SteelSeries Stratus Duo
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0062
    bNumInterfaces          3
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         0
      bInterfaceSubClass      0
      bInterfaceProtocol      1
      iInterface              0
      ** UNRECOGNIZED:  10 21 10 01 01 24 81 14 03 00 03 13 06 00 03 00
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
      Synch Type               None
      Usage Type               Data
    wMaxPacketSize     0x0020  1x 32 bytes
    bInterval               8
    bLength                 7
    bDescriptorType         5
    bEndpointAddress     0x06  EP 6 OUT
    bmAttributes            3
      Synch Type               None
      Usage Type               Data
    bInterval               8
  bLength                 9
  bDescriptorType         4
  bInterfaceNumber        1
  bAlternateSetting       0
  bNumEndpoints           1
  bInterfaceClass         3 Human Interface Device
  bInterfaceProtocol      0
  iInterface              0
    HID Device Descriptor:
      bLength                 9
      bDescriptorType        33
      bcdHID               1.11
      bCountryCode            0 Not supported
      bNumDescriptors         1
      bDescriptorType        34 Report
      wDescriptorLength      62
     Report Descriptors:
       ** UNAVAILABLE **
    bLength                 7
    bDescriptorType         5
    bEndpointAddress     0x82  EP 2 IN
    bmAttributes            3
      Synch Type               None
      Usage Type               Data
    wMaxPacketSize     0x0010  1x 16 bytes
    bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      30
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
can't get debug descriptor: Resource temporarily unavailable
Device Status:     0x0002
  (Bus Powered)
  Remote Wakeup Enabled
What’s the output of ls -lR /sys/bus/hid/?
/sys/bus/hid:
total 0
drwxr-xr-x 2 root root    0 Nov 26 13:20 devices
drwxr-xr-x 3 root root    0 Nov 26 13:20 drivers
-rw-r--r-- 1 root root 4096 Nov 26 13:20 drivers_autoprobe
--w------- 1 root root 4096 Nov 26 13:20 drivers_probe
--w------- 1 root root 4096 Nov 26 13:20 uevent
/sys/bus/hid/devices:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:20 0003:03F0:094A.0005 -> ../../../devices/pci0000:00/0000:00:12.0/usb8/8-2/8-2:1.0/0003:03F0:094A.0005
lrwxrwxrwx 1 root root 0 Nov 26 13:20 0003:045E:0745.0006 -> ../../../devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.0/0003:045E:0745.0006
lrwxrwxrwx 1 root root 0 Nov 26 13:20 0003:045E:0745.0007 -> ../../../devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.1/0003:045E:0745.0007
lrwxrwxrwx 1 root root 0 Nov 26 13:20 0003:045E:0745.0008 -> ../../../devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.2/0003:045E:0745.0008
lrwxrwxrwx 1 root root 0 Nov 26 13:20 0003:1038:1430.000F -> ../../../devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.1/0003:1038:1430.000F
lrwxrwxrwx 1 root root 0 Nov 26 13:20 0003:1038:1430.0010 -> ../../../devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.2/0003:1038:1430.0010
lrwxrwxrwx 1 root root 0 Nov 26 13:20 0003:1B1C:1B3F.0001 -> ../../../devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.0/0003:1B1C:1B3F.0001
lrwxrwxrwx 1 root root 0 Nov 26 13:20 0003:1B1C:1B3F.0002 -> ../../../devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.1/0003:1B1C:1B3F.0002
/sys/bus/hid/drivers:
total 0
drwxr-xr-x 2 root root 0 Nov 26 13:20 hid-generic
/sys/bus/hid/drivers/hid-generic:
total 0
lrwxrwxrwx 1 root root    0 Nov 26 13:20 0003:03F0:094A.0005 -> ../../../../devices/pci0000:00/0000:00:12.0/usb8/8-2/8-2:1.0/0003:03F0:094A.0005
lrwxrwxrwx 1 root root    0 Nov 26 13:20 0003:045E:0745.0006 -> ../../../../devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.0/0003:045E:0745.0006
lrwxrwxrwx 1 root root    0 Nov 26 13:20 0003:045E:0745.0007 -> ../../../../devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.1/0003:045E:0745.0007
lrwxrwxrwx 1 root root    0 Nov 26 13:20 0003:045E:0745.0008 -> ../../../../devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.2/0003:045E:0745.0008
lrwxrwxrwx 1 root root    0 Nov 26 13:20 0003:1038:1430.000F -> ../../../../devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.1/0003:1038:1430.000F
lrwxrwxrwx 1 root root    0 Nov 26 13:20 0003:1038:1430.0010 -> ../../../../devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.2/0003:1038:1430.0010
lrwxrwxrwx 1 root root    0 Nov 26 13:20 0003:1B1C:1B3F.0001 -> ../../../../devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.0/0003:1B1C:1B3F.0001
lrwxrwxrwx 1 root root    0 Nov 26 13:20 0003:1B1C:1B3F.0002 -> ../../../../devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.1/0003:1B1C:1B3F.0002
--w------- 1 root root 4096 Nov 26 13:20 bind
lrwxrwxrwx 1 root root    0 Nov 26 13:20 module -> ../../../../module/hid_generic
--w------- 1 root root 4096 Nov 26 13:20 new_id
--w------- 1 root root 4096 Nov 26 13:20 unbind
Ahh, sorry, I meant to write ls -lR /sys/bus/usb/. Moreover, can you try sudo modprobe -r xpad ; sudo modprobe -r hid-generic ; sudo modprobe xpad ; sudo modprobe hid-generic?
The output of ls -lR /sys/bus/usb/
 /sys/bus/usb/:
total 0
drwxr-xr-x  2 root root    0 Nov 26 13:25 devices
drwxr-xr-x 11 root root    0 Nov 26 13:06 drivers
-rw-r--r--  1 root root 4096 Nov 26 13:26 drivers_autoprobe
--w-------  1 root root 4096 Nov 26 13:26 drivers_probe
--w-------  1 root root 4096 Nov 26 13:26 uevent
/sys/bus/usb/devices:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 10-0:1.0 → …/…/…/devices/pci0000:00/0000:00:14.5/usb10/10-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 1-0:1.0 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 1-1 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1
lrwxrwxrwx 1 root root 0 Nov 26 13:25 11-0:1.0 → …/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 1-1:1.0 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1/1-1:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 1-1:1.1 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1/1-1:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:25 1-1:1.2 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1/1-1:1.2
lrwxrwxrwx 1 root root 0 Nov 26 13:25 1-1:1.3 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1/1-1:1.3
lrwxrwxrwx 1 root root 0 Nov 26 13:25 11-3 → …/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-3
lrwxrwxrwx 1 root root 0 Nov 26 13:25 11-3:1.0 → …/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 11-3:1.1 → …/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:25 11-3:1.2 → …/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.2
lrwxrwxrwx 1 root root 0 Nov 26 13:25 1-3 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-3
lrwxrwxrwx 1 root root 0 Nov 26 13:25 1-3:1.0 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-3/1-3:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 2-0:1.0 → …/…/…/devices/pci0000:00/0000:00:05.0/0000:03:00.0/usb2/2-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 3-0:1.0 → …/…/…/devices/pci0000:00/0000:00:05.0/0000:03:00.0/usb3/3-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 4-0:1.0 → …/…/…/devices/pci0000:00/0000:00:13.2/usb4/4-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 5-0:1.0 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 5-1 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-1
lrwxrwxrwx 1 root root 0 Nov 26 13:25 5-1:1.0 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-1/5-1:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 5-1:1.1 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-1/5-1:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:25 5-1:1.2 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-1/5-1:1.2
lrwxrwxrwx 1 root root 0 Nov 26 13:25 5-2 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2
lrwxrwxrwx 1 root root 0 Nov 26 13:25 5-2:1.0 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 5-2:1.1 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:25 6-0:1.0 → …/…/…/devices/pci0000:00/0000:00:16.2/usb6/6-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 7-0:1.0 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb7/7-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 8-0:1.0 → …/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 8-2 → …/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-2
lrwxrwxrwx 1 root root 0 Nov 26 13:25 8-2:1.0 → …/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-2/8-2:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 8-4 → …/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-4
lrwxrwxrwx 1 root root 0 Nov 26 13:25 8-4:1.0 → …/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 8-4:1.1 → …/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:25 8-4:1.2 → …/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.2
lrwxrwxrwx 1 root root 0 Nov 26 13:25 9-0:1.0 → …/…/…/devices/pci0000:00/0000:00:13.0/usb9/9-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb1 → …/…/…/devices/pci0000:00/0000:00:12.2/usb1
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb10 → …/…/…/devices/pci0000:00/0000:00:14.5/usb10
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb11 → …/…/…/devices/pci0000:00/0000:00:16.0/usb11
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb2 → …/…/…/devices/pci0000:00/0000:00:05.0/0000:03:00.0/usb2
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb3 → …/…/…/devices/pci0000:00/0000:00:05.0/0000:03:00.0/usb3
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb4 → …/…/…/devices/pci0000:00/0000:00:13.2/usb4
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb5 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb6 → …/…/…/devices/pci0000:00/0000:00:16.2/usb6
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb7 → …/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb7
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb8 → …/…/…/devices/pci0000:00/0000:00:12.0/usb8
lrwxrwxrwx 1 root root 0 Nov 26 13:25 usb9 → …/…/…/devices/pci0000:00/0000:00:13.0/usb9
/sys/bus/usb/drivers:
total 0
drwxr-xr-x 2 root root 0 Nov 26 13:26 hub
drwxr-xr-x 2 root root 0 Nov 26 13:26 rtl8192cu
drwxr-xr-x 2 root root 0 Nov 26 13:26 snd-usb-audio
drwxr-xr-x 2 root root 0 Nov 26 13:26 usb
drwxr-xr-x 2 root root 0 Nov 26 13:26 usbfs
drwxr-xr-x 2 root root 0 Nov 26 13:26 usbhid
drwxr-xr-x 2 root root 0 Nov 26 13:26 usbserial_generic
drwxr-xr-x 2 root root 0 Nov 26 13:26 uvcvideo
drwxr-xr-x 2 root root 0 Nov 26 13:07 xpad
/sys/bus/usb/drivers/hub:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 10-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:14.5/usb10/10-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 1-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 11-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 2-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:05.0/0000:03:00.0/usb2/2-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 3-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:05.0/0000:03:00.0/usb3/3-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 4-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:13.2/usb4/4-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 5-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 6-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:16.2/usb6/6-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 7-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb7/7-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 8-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-0:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 9-0:1.0 → …/…/…/…/devices/pci0000:00/0000:00:13.0/usb9/9-0:1.0
–w------- 1 root root 4096 Nov 26 13:26 bind
lrwxrwxrwx 1 root root 0 Nov 26 13:26 module → …/…/…/…/module/usbcore
-rw-r–r-- 1 root root 4096 Nov 26 13:26 new_id
-rw-r–r-- 1 root root 4096 Nov 26 13:26 remove_id
–w------- 1 root root 4096 Nov 26 13:26 uevent
–w------- 1 root root 4096 Nov 26 13:26 unbind
/sys/bus/usb/drivers/rtl8192cu:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 1-3:1.0 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-3/1-3:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 module → …/…/…/…/module/rtl8192cu
/sys/bus/usb/drivers/snd-usb-audio:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 1-1:1.2 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1/1-1:1.2
lrwxrwxrwx 1 root root 0 Nov 26 13:26 1-1:1.3 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1/1-1:1.3
lrwxrwxrwx 1 root root 0 Nov 26 13:26 5-1:1.0 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-1/5-1:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 5-1:1.1 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-1/5-1:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:26 5-1:1.2 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-1/5-1:1.2
lrwxrwxrwx 1 root root 0 Nov 26 13:26 module → …/…/…/…/module/snd_usb_audio
/sys/bus/usb/drivers/usb:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 1-1 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1
lrwxrwxrwx 1 root root 0 Nov 26 13:26 11-3 → …/…/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-3
lrwxrwxrwx 1 root root 0 Nov 26 13:26 1-3 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-3
lrwxrwxrwx 1 root root 0 Nov 26 13:26 5-1 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-1
lrwxrwxrwx 1 root root 0 Nov 26 13:26 5-2 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2
lrwxrwxrwx 1 root root 0 Nov 26 13:26 8-2 → …/…/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-2
lrwxrwxrwx 1 root root 0 Nov 26 13:26 8-4 → …/…/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-4
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb1 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb10 → …/…/…/…/devices/pci0000:00/0000:00:14.5/usb10
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb11 → …/…/…/…/devices/pci0000:00/0000:00:16.0/usb11
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb2 → …/…/…/…/devices/pci0000:00/0000:00:05.0/0000:03:00.0/usb2
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb3 → …/…/…/…/devices/pci0000:00/0000:00:05.0/0000:03:00.0/usb3
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb4 → …/…/…/…/devices/pci0000:00/0000:00:13.2/usb4
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb5 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb6 → …/…/…/…/devices/pci0000:00/0000:00:16.2/usb6
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb7 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb7
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb8 → …/…/…/…/devices/pci0000:00/0000:00:12.0/usb8
lrwxrwxrwx 1 root root 0 Nov 26 13:26 usb9 → …/…/…/…/devices/pci0000:00/0000:00:13.0/usb9
/sys/bus/usb/drivers/usbfs:
total 0
/sys/bus/usb/drivers/usbhid:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 11-3:1.1 → …/…/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:26 11-3:1.2 → …/…/…/…/devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.2
lrwxrwxrwx 1 root root 0 Nov 26 13:26 5-2:1.0 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 5-2:1.1 → …/…/…/…/devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:26 8-2:1.0 → …/…/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-2/8-2:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 8-4:1.0 → …/…/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 8-4:1.1 → …/…/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:26 8-4:1.2 → …/…/…/…/devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.2
lrwxrwxrwx 1 root root 0 Nov 26 13:26 module → …/…/…/…/module/usbhid
/sys/bus/usb/drivers/usbserial_generic:
total 0
/sys/bus/usb/drivers/uvcvideo:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 1-1:1.0 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1/1-1:1.0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 1-1:1.1 → …/…/…/…/devices/pci0000:00/0000:00:12.2/usb1/1-1/1-1:1.1
lrwxrwxrwx 1 root root 0 Nov 26 13:26 module → …/…/…/…/module/uvcvideo
/sys/bus/usb/drivers/xpad:
total 0
lrwxrwxrwx 1 root root 0 Nov 26 13:26 module → …/…/…/…/module/xpad
–w------- 1 root root 4096 Nov 26 13:07 uevent
No change after sudo modprobe -r xpad ; sudo modprobe -r hid-generic ; sudo modprobe xpad ; sudo modprobe hid-generic
[16059.813570] audit: type=1101 audit(1606393819.533:206): pid=273294 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16059.813939] audit: type=1110 audit(1606393819.533:207): pid=273294 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16059.817378] audit: type=1105 audit(1606393819.537:208): pid=273294 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16059.822441] usbcore: deregistering interface driver xpad
[16059.869817] audit: type=1106 audit(1606393819.590:209): pid=273294 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16059.869893] audit: type=1104 audit(1606393819.590:210): pid=273294 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16059.893500] audit: type=1101 audit(1606393819.613:211): pid=273298 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16059.894115] audit: type=1110 audit(1606393819.613:212): pid=273298 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16059.899186] audit: type=1105 audit(1606393819.617:213): pid=273298 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16060.467916] audit: type=1106 audit(1606393820.187:214): pid=273298 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16060.467973] audit: type=1104 audit(1606393820.187:215): pid=273298 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/4 res=success’
[16060.484995] usbcore: registered new interface driver xpad
[16060.505442] input: Corsair Corsair Gaming K68 Keyboard as /devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.0/0003:1B1C:1B3F.0001/input/input47
[16060.559836] input: Corsair Corsair Gaming K68 Keyboard Consumer Control as /devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.0/0003:1B1C:1B3F.0001/input/input48
[16060.559912] input: Corsair Corsair Gaming K68 Keyboard as /devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.0/0003:1B1C:1B3F.0001/input/input49
[16060.559981] input: Corsair Corsair Gaming K68 Keyboard as /devices/pci0000:00/0000:00:07.0/0000:05:00.0/usb5/5-2/5-2:1.0/0003:1B1C:1B3F.0001/input/input50
[16060.560175] hid-generic 0003:1B1C:1B3F.0001: input,hiddev0,hidraw0: USB HID v1.11 Keyboard [Corsair Corsair Gaming K68 Keyboard] on usb-0000:05:00.0-2/input0
[16060.561971] hid-generic 0003:1B1C:1B3F.0002: hiddev1,hidraw1: USB HID v1.11 Device [Corsair Corsair Gaming K68 Keyboard] on usb-0000:05:00.0-2/input1
[16060.562133] input: PixArt HP USB Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb8/8-2/8-2:1.0/0003:03F0:094A.0005/input/input51
[16060.562242] hid-generic 0003:03F0:094A.0005: input,hidraw2: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-0000:00:12.0-2/input0
[16060.562530] input: Microsoft Microsoft® 2.4GHz Transceiver v6.0 as /devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.0/0003:045E:0745.0006/input/input52
[16060.617057] hid-generic 0003:045E:0745.0006: input,hidraw3: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v6.0] on usb-0000:00:12.0-4/input0
[16060.622138] input: Microsoft Microsoft® 2.4GHz Transceiver v6.0 Mouse as /devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.1/0003:045E:0745.0007/input/input53
[16060.622271] input: Microsoft Microsoft® 2.4GHz Transceiver v6.0 Consumer Control as /devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.1/0003:045E:0745.0007/input/input54
[16060.676375] hid-generic 0003:045E:0745.0007: input,hidraw4: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v6.0] on usb-0000:00:12.0-4/input1
[16060.676998] input: Microsoft Microsoft® 2.4GHz Transceiver v6.0 Consumer Control as /devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.2/0003:045E:0745.0008/input/input55
[16060.733105] input: Microsoft Microsoft® 2.4GHz Transceiver v6.0 System Control as /devices/pci0000:00/0000:00:12.0/usb8/8-4/8-4:1.2/0003:045E:0745.0008/input/input57
[16060.733290] hid-generic 0003:045E:0745.0008: input,hiddev2,hidraw5: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v6.0] on usb-0000:00:12.0-4/input2
[16060.733559] input: SteelSeries Stratus Duo as /devices/pci0000:00/0000:00:16.0/usb11/11-3/11-3:1.1/0003:1038:1430.000F/input/input58
[16060.733798] hid-generic 0003:1038:1430.000F: input,hidraw6: USB HID v1.11 Mouse [SteelSeries Stratus Duo] on usb-0000:00:16.0-3/input1
[16060.734295] hid-generic 0003:1038:1430.0010: hiddev3,hidraw7: USB HID v1.11 Device [SteelSeries Stratus Duo] on usb-0000:00:16.0-3/input2
What’s the output of lsusb -t?
lsusb -t
/: Bus 11.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/4p, 12M
|__ Port 3: Dev 6, If 0, Class=, Driver=, 12M
|__ Port 3: Dev 6, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 6, If 2, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 10.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/2p, 12M
/: Bus 09.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/5p, 12M
/: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/5p, 12M
|__ Port 2: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 3, If 2, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/4p, 480M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
|__ Port 1: Dev 4, If 0, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 1: Dev 4, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 1: Dev 4, If 2, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 2: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/5p, 480M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/5p, 480M
|__ Port 1: Dev 2, If 3, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 1: Dev 2, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 3: Dev 4, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
Output of lsusb:
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 011 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 010 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 0df6:0077 Sitecom Europe B.V. 802.11n WLAN Adapter
Bus 001 Device 002: ID 046d:09a4 Logitech, Inc. QuickCam E 3500
Bus 008 Device 003: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 008 Device 002: ID 03f0:094a HP, Inc Optical Mouse [672662-001]
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 1b1c:1b3f Corsair Corsair Gaming K68 Keyboard
Bus 005 Device 004: ID 1686:0365 ZOOM Corporation Q2n USB Audio
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  • The gamepad
  • WLAN adapter
  • Microphone
  • Webcam
  • Keyboard
  • Mouse
echo 11-3:1.1 | sudo tee /sys/bus/usb/drivers/usbhid/unbind
echo 11-3:1.2 | sudo tee /sys/bus/usb/drivers/usbhid/unbind
echo 11-3:1.1 | sudo tee /sys/bus/usb/drivers/xpad/bind
echo 11-3:1.2 | sudo tee /sys/bus/usb/drivers/xpad/bind
~ >>> echo 11-3:1.1 | sudo tee /sys/bus/usb/drivers/usbhid/unbind
11-3:1.1
~ >>> echo 11-3:1.2 | sudo tee /sys/bus/usb/drivers/usbhid/unbind
11-3:1.2
~ >>> echo 11-3:1.1 | sudo tee /sys/bus/usb/drivers/xpad/bind
tee: /sys/bus/usb/drivers/xpad/bind: No such file or directory
11-3:1.1
~ >>> echo 11-3:1.2 | sudo tee /sys/bus/usb/drivers/xpad/bind                                      [1]
11-3:1.2
Post the output of inxi -Fazy, and modinfo xpad.
~ >>> inxi -Fazy        [130]
  Kernel: 5.4.78-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=424f89e6-ad45-4bc6-a916-490a26669e78 rw quiet udev.log_priority=3
  resume=/dev/disk/by-uuid/424f89e6-ad45-4bc6-a916-490a26669e78
  resume_offset=34816
  Desktop: i3 4.19 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: M5A99X EVO v: Rev 1.xx serial: <filter>
  BIOS: American Megatrends v: 1708 date: 04/10/2013
  Info: Quad Core model: AMD Phenom II X4 955 bits: 64 type: MCP arch: K10
  family: 10 (16) model-id: 4 stepping: 3 microcode: 10000C8
  L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 27750
  Speed: 800 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800
  Type: spec_store_bypass status: Not affected
  Type: spectre_v2
  mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: AMD Curacao PRO [Radeon R7 370 / R9 270/370 OEM]
  vendor: XFX Pine Trinidad driver: radeon v: kernel alternate: amdgpu
  bus ID: 01:00.0 chip ID: 1002:6811
  Display: x11 server: X.Org 1.20.9 compositor: picom v: git-dac85
  driver: ati,radeon unloaded: modesetting alternate: fbdev,vesa
  display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: DVI-1 res: 1920x1080 hz: 60 dpi: 96 size: 510x290mm (20.1x11.4")
  diag: 587mm (23.1")
  OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.4.78-1-MANJARO LLVM 11.0.0)
  v: 4.5 Mesa 20.2.2 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: ASUSTeK M4A89GTD PRO/USB3
  driver: snd_hda_intel v: kernel bus ID: 00:14.2 chip ID: 1002:4383
  Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
  Series]
  vendor: XFX Pine driver: snd_hda_intel v: kernel bus ID: 01:00.1
  chip ID: 1002:aab0
  Device-3: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 100
  driver: snd_virtuoso v: kernel bus ID: 07:04.0 chip ID: 13f6:8788
  Device-4: ZOOM Q2n USB Audio type: USB driver: snd-usb-audio bus ID: 4-1:2
  chip ID: 1686:0365
  Device-5: Logitech QuickCam E 3500 type: USB driver: snd-usb-audio,uvcvideo
  bus ID: 3-1:2 chip ID: 046d:09a4 serial: <filter>
  Sound Server: ALSA v: k5.4.78-1-MANJARO
  vendor: ASUSTeK P8P67 and other motherboards driver: r8168 v: 8.048.03-NAPI
  modules: r8169 port: d000 bus ID: 02:00.0 chip ID: 10ec:8168
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Sitecom Europe B.V. 802.11n WLAN Adapter type: USB
  driver: rtl8192cu bus ID: 3-3:4 chip ID: 0df6:0077 serial: <filter>
  IF: wlp0s18f2u3 state: down mac: <filter>
  Local Storage: total: 1.87 TiB used: 1.12 TiB (59.9%)
  ID-1: /dev/sda vendor: OCZ model: VERTEX2 size: 55.90 GiB block size:
  physical: 512 B logical: 512 B speed: 1.5 Gb/s serial: <filter> rev: 1.32
  scheme: MBR
  ID-2: /dev/sdb vendor: Seagate model: ST2000DM001-1CH164 size: 1.82 TiB
  block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: CC24 scheme: GPT
  ID-1: / raw size: 55.40 GiB size: 54.28 GiB (97.98%) used: 27.96 GiB (51.5%)
  fs: ext4 dev: /dev/sda2
  Kernel: swappiness: 10 (default 60) cache pressure: 50 (default 100)
  ID-1: swap-1 type: file size: 7.74 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  System Temperatures: cpu: 32.5 C mobo: N/A gpu: radeon temp: 38.0 C
  Processes: 184 Uptime: 35m Memory: 7.80 GiB used: 1.74 GiB (22.3%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1265 pacman: 1259
  lib: 362 snap: 6 Shell: Zsh v: 5.8 running in: urxvtd inxi: 3.1.08
~ >>> modinfo xpad
filename: /lib/modules/5.4.78-1-MANJARO/kernel/drivers/input/joystick/xpad.ko.xz
license: GPL
description: X-Box pad driver
author: Marko Friedemann mfr@bmx-chemnitz.de
srcversion: D8474DB98A6A28D76AA138B
alias: usb:v24C6pddcdscdpicFFisc47ipD0in
alias: usb:v24C6pddcdscdpicFFisc5Dip81in
alias: usb:v24C6pddcdscdpicFFisc5Dip01in
alias: usb:v1BADpddcdscdpicFFisc5Dip81in
alias: usb:v1BADpddcdscdpicFFisc5Dip01in
alias: usb:v1689pddcdscdpicFFisc5Dip81in
alias: usb:v1689pddcdscdpicFFisc5Dip01in
alias: usb:v162EpddcdscdpicFFisc5Dip81in
alias: usb:v162EpddcdscdpicFFisc5Dip01in
alias: usb:v15E4pddcdscdpicFFisc5Dip81in
alias: usb:v15E4pddcdscdpicFFisc5Dip01in
alias: usb:v1532pddcdscdpicFFisc47ipD0in
alias: usb:v1532pddcdscdpicFFisc5Dip81in
alias: usb:v1532pddcdscdpicFFisc5Dip01in
alias: usb:v146BpddcdscdpicFFisc5Dip81in
alias: usb:v146BpddcdscdpicFFisc5Dip01in
alias: usb:v1430pddcdscdpicFFisc5Dip81in
alias: usb:v1430pddcdscdpicFFisc5Dip01in
alias: usb:v12ABpddcdscdpicFFisc5Dip81in
alias: usb:v12ABpddcdscdpicFFisc5Dip01in
alias: usb:v11C9pddcdscdpicFFisc5Dip81in
alias: usb:v11C9pddcdscdpicFFisc5Dip01in
alias: usb:v1038pddcdscdpicFFisc5Dip81in
alias: usb:v1038pddcdscdpicFFisc5Dip01in
alias: usb:v0F0DpddcdscdpicFFisc47ipD0in
alias: usb:v0F0DpddcdscdpicFFisc5Dip81in
alias: usb:v0F0DpddcdscdpicFFisc5Dip01in
alias: usb:v0E6FpddcdscdpicFFisc47ipD0in
alias: usb:v0E6FpddcdscdpicFFisc5Dip81in
alias: usb:v0E6FpddcdscdpicFFisc5Dip01in
alias: usb:v07FFpddcdscdpicFFisc5Dip81in
alias: usb:v07FFpddcdscdpicFFisc5Dip01in
alias: usb:v0738pddcdscdpicFFisc47ipD0in
alias: usb:v0738p4540ddcdscdpiciscipin
alias: usb:v0738pddcdscdpicFFisc5Dip81in
alias: usb:v0738pddcdscdpicFFisc5Dip01in
alias: usb:v06A3pddcdscdpicFFisc5Dip81in
alias: usb:v06A3pddcdscdpicFFisc5Dip01in
alias: usb:v056EpddcdscdpicFFisc5Dip81in
alias: usb:v056EpddcdscdpicFFisc5Dip01in
alias: usb:v046DpddcdscdpicFFisc5Dip81in
alias: usb:v046DpddcdscdpicFFisc5Dip01in
alias: usb:v045EpddcdscdpicFFisc47ipD0in
alias: usb:v045EpddcdscdpicFFisc5Dip81in
alias: usb:v045EpddcdscdpicFFisc5Dip01in
alias: usb:v044FpddcdscdpicFFisc5Dip81in
alias: usb:v044FpddcdscdpicFFisc5Dip01in
alias: usb:v0079pddcdscdpicFFisc5Dip81in
alias: usb:v0079pddcdscdpicFFisc5Dip01in
alias: usb:vpddcdscdpic58isc42ip00in*
depends: ff-memless
retpoline: Y
intree: Y
vermagic: 5.4.78-1-MANJARO SMP preempt mod_unload modversions
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 6A:2F:4A:97:1F:C8:F5:7B:8F:5B:52:B5:E1:CD:EF:3F:C9:3B:C7:47
sig_hashalgo: sha512
signature: D9:AD:C0:DE:2A:B2:0D:A1:9C:08:9C:16:E9:DC:D7:31:64:DC:70:6A:
3B:D3:39:62:BB:9C:20:E7:D0:FC:90:DB:52:D1:54:1A:0D:55:94:F6:
C3:FF:23:30:26:AB:96:A0:50:7A:A8:37:EC:28:50:DE:F1:03:79:8E:
28:25:17:1D:ED:85:8C:EA:EB:B5:44:6C:85:69:9A:58:4B:8F:BC:51:
F3:79:68:90:CA:CE:6A:CD:1E:E9:D4:EA:68:21:EE:03:31:C1:E6:EC:
2B:C3:35:B8:B2:C4:42:8A:93:5C:44:D2:C0:F4:78:2F:10:B5:4A:4B:
FF:09:21:C2:F5:AF:8E:7E:88:8B:2F:F7:44:07:1B:D0:F9:A0:99:86:
D6:88:A5:19:A7:7D:53:53:A4:4B:7A:2A:2F:D1:48:3D:88:DC:B9:F7:
C4:AB:D8:B2:1B:E6:E1:81:8E:7B:90:2D:60:FC:25:90:3D:16:59:F0:
B2:68:E1:88:94:E4:57:F8:B6:02:B4:2D:C5:E3:6A:C0:0E:69:75:90:
9E:A6:64:BD:64:E0:0F:63:2C:C2:37:FF:3C:C1:F5:A8:D8:ED:5F:A0:
21:E4:6C:EB:3F:CF:B9:C4:A8:FA:83:55:A2:FF:BF:68:30:E8:56:43:
DE:70:27:55:B9:48:3E:FB:77:35:6C:35:CC:89:FE:87:C0:05:53:A7:
69:F8:86:6A:0C:C1:AE:54:2D:CA:7C:4D:0E:90:4F:07:04:C9:B9:5C:
08:94:B1:7E:6F:FD:26:83:E4:C5:C5:7F:C9:D8:99:7D:D9:3E:5C:80:
DE:DF:72:D6:2F:FF:A7:B5:BB:EA:73:91:2F:74:49:8A:BB:04:2F:6A:
58:BE:8A:C3:28:85:38:48:56:C0:52:D7:4E:CA:05:F4:7F:D8:18:30:
BB:35:40:AD:7E:99:3F:A0:CC:96:8A:86:B4:4F:54:2A:6D:B5:E8:81:
BE:AE:58:78:44:E5:54:A0:82:4D:D7:D0:F7:8E:F3:F8:DD:6C:B0:0D:
C0:68:6F:A5:D7:D5:A1:28:02:A6:74:B5:54:37:6D:C0:DD:39:30:71:
E3:DA:5C:50:49:4C:2D:5C:BF:80:87:E4:93:2E:A0:8A:E4:14:AC:DA:
F4:CE:68:DD:63:9B:87:F1:80:18:3E:E7:D9:EF:B3:5D:F2:9B:9B:98:
D1:9D:2F:D1:DE:E7:7A:E9:51:AF:A9:CA:7C:D7:4E:D0:5E:6B:F7:8F:
82:13:71:F5:F4:03:6D:B5:F3:67:F5:C4:D3:AD:7E:B7:D5:3E:B8:84:
0C:5F:CC:F7:F8:5A:98:56:F0:C0:7C:2D:DB:A1:7C:40:04:FC:12:EA:
B3:AF:4A:A5:87:EB:D5:52:14:E5:CA:E5
parm: dpad_to_buttons:Map D-PAD to buttons rather than axes for unknown pads (bool)
parm: triggers_to_buttons:Map triggers to buttons rather than axes for unknown pads (bool)
parm: sticks_to_null:Do not map sticks at all for unknown pads (bool)
parm: auto_poweroff:Power off wireless controllers on suspend (bool)
Please run echo 'file drivers/base/* +p' | sudo tee /sys/kernel/debug/dynamic_debug/control, and then start journalctl -k --no-pager -f, then on a different terminal run
and then post what gets printed in journalctl.
Running the first command gives:
echo file drivers/base/* +p | sudo tee /sys/kernel/debug/dynamic_debug/control
zsh: no matches found: drivers/base/*
This is the journalctl output:
Nov 26 14:49:54 manjarmageddon kernel: audit: type=1101 audit(1606398594.712:127): pid=143052 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:49:54 manjarmageddon kernel: audit: type=1110 audit(1606398594.712:128): pid=143052 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:49:54 manjarmageddon kernel: audit: type=1105 audit(1606398594.715:129): pid=143052 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:49:54 manjarmageddon kernel: audit: type=1106 audit(1606398594.719:130): pid=143052 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:49:54 manjarmageddon kernel: audit: type=1104 audit(1606398594.719:131): pid=143052 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:01 manjarmageddon kernel: audit: type=1101 audit(1606398601.295:132): pid=143985 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:01 manjarmageddon kernel: audit: type=1110 audit(1606398601.299:133): pid=143985 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:01 manjarmageddon kernel: audit: type=1105 audit(1606398601.305:134): pid=143985 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:01 manjarmageddon kernel: audit: type=1106 audit(1606398601.309:135): pid=143985 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:01 manjarmageddon kernel: audit: type=1104 audit(1606398601.309:136): pid=143985 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:05 manjarmageddon kernel: audit: type=1101 audit(1606398605.922:137): pid=143993 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:05 manjarmageddon kernel: audit: type=1110 audit(1606398605.922:138): pid=143993 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:05 manjarmageddon kernel: audit: type=1105 audit(1606398605.925:139): pid=143993 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:05 manjarmageddon kernel: audit: type=1106 audit(1606398605.929:140): pid=143993 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:05 manjarmageddon kernel: audit: type=1104 audit(1606398605.929:141): pid=143993 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:10 manjarmageddon kernel: audit: type=1101 audit(1606398610.122:142): pid=144001 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:10 manjarmageddon kernel: audit: type=1110 audit(1606398610.122:143): pid=144001 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:10 manjarmageddon kernel: audit: type=1105 audit(1606398610.125:144): pid=144001 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:10 manjarmageddon kernel: audit: type=1106 audit(1606398610.129:145): pid=144001 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 14:50:10 manjarmageddon kernel: audit: type=1104 audit(1606398610.129:146): pid=144001 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Sorry, I mistyped the first command, now it’s fixed, please try it again.
From the first command:
From journalctl:
Nov 26 15:01:29 manjarmageddon kernel: audit: type=1101 audit(1606399289.432:152): pid=174367 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:29 manjarmageddon kernel: audit: type=1110 audit(1606399289.432:153): pid=174367 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:29 manjarmageddon kernel: audit: type=1105 audit(1606399289.435:154): pid=174367 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:29 manjarmageddon kernel: audit: type=1106 audit(1606399289.442:155): pid=174367 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:29 manjarmageddon kernel: audit: type=1104 audit(1606399289.442:156): pid=174367 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:45 manjarmageddon kernel: audit: type=1101 audit(1606399305.769:157): pid=175238 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:45 manjarmageddon kernel: audit: type=1110 audit(1606399305.769:158): pid=175238 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:45 manjarmageddon kernel: audit: type=1105 audit(1606399305.772:159): pid=175238 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:45 manjarmageddon kernel: audit: type=1106 audit(1606399305.775:160): pid=175238 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:45 manjarmageddon kernel: audit: type=1104 audit(1606399305.775:161): pid=175238 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:54 manjarmageddon kernel: audit: type=1101 audit(1606399313.999:162): pid=175246 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:54 manjarmageddon kernel: audit: type=1110 audit(1606399314.002:163): pid=175246 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:54 manjarmageddon kernel: audit: type=1105 audit(1606399314.009:164): pid=175246 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:54 manjarmageddon kernel: audit: type=1106 audit(1606399314.012:165): pid=175246 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:54 manjarmageddon kernel: audit: type=1104 audit(1606399314.012:166): pid=175246 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:57 manjarmageddon kernel: audit: type=1101 audit(1606399317.675:167): pid=175255 uid=1000 auid=1000 ses=1 msg=‘op=PAM:accounting grantors=pam_permit,pam_time acct=“stormageddon” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:57 manjarmageddon kernel: audit: type=1110 audit(1606399317.679:168): pid=175255 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:57 manjarmageddon kernel: audit: type=1105 audit(1606399317.682:169): pid=175255 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:57 manjarmageddon kernel: audit: type=1106 audit(1606399317.685:170): pid=175255 uid=0 auid=1000 ses=1 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Nov 26 15:01:57 manjarmageddon kernel: audit: type=1104 audit(1606399317.685:171): pid=175255 uid=0 auid=1000 ses=1 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct=“root” exe=“/usr/bin/sudo” hostname=? addr=? terminal=/dev/pts/2 res=success’
Additionally, this is what I find when i run, xpad doesnt seem to be there:
> ls /sys/bus/usb/drivers/
hub	   snd-usb-audio  usbfs   usbserial_generic
rtl8192cu  usb		  usbhid  uvcvideo
Did you run the other four commands too in a different terminal?
