Some time ago I played the demo of a game from Steam under Manjaro (Planet Crafter). The full version of this game is now installed. But the game no longer starts. I have installed Arch Linux in a parallel partition and use the same ext4 partition for the games so that I don’t have to install the games twice. So the same data is used everywhere. The game starts without any problems under Arch. No special start parameters are passed anywhere. I use GE-Proton 9.20 in both cases. Other games do run fine, without any issue. I have checked ProtonDB, but didnt find any useful information. It should run, thats all.
I have also started Steam from the bash shell to see if there are any errors. But no error message is displayed.
How can I find out why the game won’t start? I suspect that there might be some libraries missing under Manjaro, but I can’t see anywhere which ones they should be…
Kobold
13 December 2024 21:14
2
All other steam games under Manjaro running fine?
System info’s please.
It’s a Lenovo Laptop with intel CPU, 32GB Memory , 2 SSD, intel iGPU and Nvidia 1650 gpu. No NTFS Partition, because no Windows. 1 dedicated gaming library Partition accessible for both, Arch and Manjaro, a 64GB SWAP. I think that’s all important i can remember so far.
In Arch the same game has no issues. On Manjaro all other games run fine. Better as on Arch. On Arch i have a lot of lags and the game "No man’s sky " is freezing after some random time. I don’t have this issue on Manjaro. Package wise, in context for games, both differ only by kernel version and nvidia drivers version. But that’s a completely other strange story.
I can pull more detailed sysinfo tomorrow, if this will help.
Kobold:
System information, please
It’s always preferable (and expected) that you ask your system for the information requested by other Members.
Output of the following command formatted according to forum requirements (see links below) will be much more useful for those wishing to help, than your best guesses :
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Kobold
14 December 2024 10:31
5
Yeah, more system info’s are important here:
inxi --admin --verbosity=5 --filter --no-host --width
Double post your system info’s (output from above command) from Manjaro and Arch.
That we can compare them.
For example: It is possible that you use X11 on Arch and Wayland under Manjaro? And you need to switch it or something like that.
Kernel: 6.6.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a0674f41-beba-49e4-969c-091ec4171bb7 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
wm: kwin_x11 vt: 2 dm: 1: GDM v: 47.0 2: SDDM note: stopped Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 81LL v: Lenovo IdeaPad L340-17IRH
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad L340-17IRH
Mobo: LENOVO model: INVALID v: SDK0K17763 WIN serial: <superuser required>
part-nu: LENOVO_MT_81LL_BU_idea_FM_IDEAPAD uuid: <superuser required>
UEFI: LENOVO v: BGCN36WW date: 05/24/2022
ID-1: BAT0 charge: 37.8 Wh (97.4%) condition: 38.8/45.0 Wh (86.3%)
volts: 12.6 min: 11.5 model: Celxpert L18C3PF1 type: Li-poly serial: <filter>
status: not charging cycles: 50
System RAM: total: 16 GiB available: 15.49 GiB used: 3.05 GiB (19.7%)
Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
Device-1: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2400 MT/s volts: curr: 1 min: 1.25 max: 2 width (bits): data: 64
total: 64 manufacturer: Kingston part-no: MSI24D4S7D8MB-16 serial: <filter>
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 38408
vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 13d3:5415
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x05b9 built: 2017 res: 1920x1080 hz: 60
dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
device-ID: 8086:3e9b memory: 7.56 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 550.135 device-ID: 10de:1f91
surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
API: ALSA v: k6.6.63-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 07:00.0 chip-ID: 10ec:c821
class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 0bda:c024
Local Storage: total: 2.29 TiB used: 924.78 GiB (39.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8L
lanes: 4 tech: SSD serial: <filter> fw-rev: L02C temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-1: / raw-size: 274.62 GiB size: 269.24 GiB (98.04%)
used: 50.11 GiB (18.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: a0674f41-beba-49e4-969c-091ec4171bb7
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 156 MiB (60.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: F888-DD92
ID-1: swap-1 type: partition size: 17.95 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5 label: SWAP
uuid: 44f88d31-a1b3-4cf7-a160-4cb5efc5d65c
System Temperatures: cpu: 41.0 C pch: 45.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 297 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1744 libs: 428 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
I have Steam installed along with a few free games which I’ve personally never had issue starting. That is the extent of my engagement with Steam. I mention this only to enhance that I likely have no direct solutions.
Let’s explore some other details that might help others:
1. Did you install the game while in Arch or Manjaro?
2. This seems a fair question:
Kobold:
I notice from your system information that the Manjaro installation is using X11 – are both Arch and Manjaro using the same?
3. Any other known differences between the two environments might also be useful.
Kobold
14 December 2024 17:19
8
GoGRaDaN:
class-ID: 0300
Could it be possible that you use differend Launch Parameters, within Steam from Manjaro and Arch?
Possible the game using your Intel iGPU instead the nvidia one.
We still need Arch System info’s.
Are the other Steam games using also GE-Proton 9.20 as Planet Crafter?
No, I have tried some parameters, just for playing with them. But in the end, i dont use any parameters. However, I have found that using gamemoderun %command% sometimes can start the game. GE-Proton is absolutely identical, in both OS. On Arch i dont need startparameters. When i use gamemoderun %command%, on Arch, this doesnt change anything.
Some hours ago, I could start the game on Manjaro with gamemoderun %command%. Then i had to stop the game, for cooking the launch. Now it crashes directly after the start. I have no idea, where i can find the crash log. All i see, is a Unity Window which seems to generate some crash report.
