I am trying to launch the native version of Victoria 3 and after this recent update it seems to crash while loading. It seems to only take up 8gb of ram before crashing. The error logs say it ran out of memory, but I definitely have much more. They recommend having 16gb of ram which I have plus a swap of 8gb.
I made a post on their forum, but it seems like I am the only one having a problem like this. Any ideas on how to, I guess, allow it to take more ram? Seems like a very strange problem. I am able to play using proton, but I would like to run the native version because in the past it has had much better performance for me.
Any ideas?
inxi -Fazy ✔
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=3e6e4c0f-26d2-4b14-af4a-9bee693e02f7 rw nvidia-drm.modeset=1
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: H.H0 date: 05/19/2022
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB
desc: 1x96 MiB
Speed (MHz): avg: 3585 high: 4433 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3541 2: 4433
3: 3572 4: 3429 5: 3551 6: 3343 7: 3092 8: 3692 9: 3233 10: 4374 11: 3608
12: 3517 13: 3581 14: 3070 15: 3512 16: 3817 bogomips: 108859
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire PULSE driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-2,HDMI-A-2 empty: HDMI-A-1,Writeback-1
bus-ID: 2f:00.0 chip-ID: 1002:744c class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,left res: 2560x1440 size: N/A modes: N/A
Monitor-3: HDMI-A-2 pos: right res: 2560x1440 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
navi31 LLVM 17.0.6 DRM 3.57 6.9.3-3-MANJARO) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.0.9-manjaro1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab30
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 619.15 GiB (33.2%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 26.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 3B2QEXM7 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 922.93 GiB size: 907.36 GiB (98.31%)
used: 619.08 GiB (68.2%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 8.29 GiB used: 72 MiB (0.8%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3
System Temperatures: cpu: 39.0 C mobo: 44.0 C gpu: amdgpu temp: 60.0 C
mem: 67.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 713 fan-3: 0 fan-4: 657 fan-5: 808
fan-6: 913 fan-7: 705 gpu: amdgpu fan: 325
Memory: total: 16 GiB available: 15.54 GiB used: 5.76 GiB (37.1%)
Processes: 330 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1737 pm: dpkg pkgs: 0 pm: pacman pkgs: 1721 libs: 478
tools: pamac pm: flatpak pkgs: 16 Compilers: clang: 17.0.6 gcc: 14.1.1
alt: 11 Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.35
