Galaxy book flex internal speaker not working
Hi everyone,
I would like to ask support in troubleshooting audio.
I installed manjaro GNOME on a Samsung Galaxy Book Flex, everything is working fine including the S pen!
Problem
The only problem is about audio, in particular from internal speakers; bluetooth headphones (Galaxy Buds Pro) work fine.
I tried:
  • reproduction of youtube videos on google chrome and on firefox
  • speaker-test command
  • gnome settings test
Speakers are not working in all mentioned cases.
Built-in microphone is working!!
System info
I try to attach all you need to reason on the problem.
inxi -v7azy
Output
  Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=d911b9b5-3e16-45ba-a37c-805ce2a6557b rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
  Type: Convertible System: SAMSUNG product: 930QCG v: P11AJB
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: SAMSUNG model: SAMSUNG_NP_930QCG
    v: SAMSUNG_SW_REVISION_12345+0.0.0000 serial: <superuser required>
    UEFI: American Megatrends v: P11AJB.053.210517.MK date: 05/17/2021
  ID-1: BAT1 charge: 48.1 Wh (70.9%) condition: 67.8/67.0 Wh (101.1%)
    volts: 15.6 min: 15.4 model: SAMSUNG Electronics SR Real Battery type: Li-ion
    serial: <filter> status: discharging cycles: 222
  RAM: total: 11.46 GiB used: 2.92 GiB (25.5%)
  Info: model: Intel Core i5-1035G4 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 1374 high: 1500 min/max: 400/3700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1300 2: 1500 3: 1301
    4: 1301 5: 1293 6: 1500 7: 1500 8: 1300 bogomips: 23968
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
    avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
    est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Iris Plus Graphics G4 vendor: Samsung Co driver: i915
    v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
    active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:8a5a
    class-ID: 0300
  Device-2: Generic 720p HD Camera type: USB driver: uvcvideo bus-ID: 3-6:4
    chip-ID: 2b7e:0134 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x087a built: 2020 res: 1920x1080
    dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Iris Plus Graphics
    (ICL GT1.5) direct render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Samsung Co
    driver: sof-audio-pci-intel-icl
    alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
    chip-ID: 8086:34c8 class-ID: 0401
  Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.63 running: yes
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
    chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 476.94 GiB used: 11.29 GiB (2.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000
    lanes: 4 type: SSD serial: <filter> rev: EXF71K2Q temp: 28.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
    used: 11.29 GiB (2.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: d911b9b5-3e16-45ba-a37c-805ce2a6557b
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 6890-5B78
  ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-4: /var/cache raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-5: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-5:3 info: Samsung Fingerprint Sensor Device - 730B
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 04e8:730b class-ID: 0000
  Device-2: 3-6:4 info: Generic 720p HD Camera type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 2b7e:0134
  Device-3: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
  Src: /sys System Temperatures: cpu: 38.0 C mobo: N/A
  Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
  Processes: 382 Uptime: 2h 36m wakeups: 4769 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1222 libs: 312 tools: gnome-software,pamac,yay
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
pacmd list-cards
Output
1 card(s) available.
    index: 0
	driver: <module-alsa-card.c>
	owner module: 6
	properties:
		alsa.card = "0"
		alsa.card_name = "sof-hda-dsp"
		alsa.long_card_name = "SAMSUNGELECTRONICSCO.LTD.-930QCG-P11AJB-SAMSUNG_NP_930QCG"
		alsa.driver_name = "snd_soc_skl_hda_dsp"
		device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "34c8"
		device.product.name = "Ice Lake-LP Smart Sound Technology Audio Controller"
		device.string = "0"
		device.description = "Ice Lake-LP Smart Sound Technology Audio Controller"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	profiles:
		HiFi: Play HiFi quality Music (priority 40768, available: unknown)
		off: Spento (priority 0, available: unknown)
	active profile: <HiFi>
	sinks:
		alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink/#0: Ice Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output
		alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink/#1: Ice Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output
		alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink/#2: Ice Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output
		alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink/#3: Ice Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones
	sources:
		alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor/#0: Monitor of Ice Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output
		alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor/#1: Monitor of Ice Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output
		alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor/#2: Monitor of Ice Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output
		alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor/#3: Monitor of Ice Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones
		alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source/#4: Ice Lake-LP Smart Sound Technology Audio Controller Headphones Stereo Microphone
		alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source/#5: Ice Lake-LP Smart Sound Technology Audio Controller Digital Microphone
	ports:
		[Out] HDMI3: HDMI / DisplayPort 3 Output (priority 700, latency offset 0 usec, available: no)
			properties:
		[Out] HDMI2: HDMI / DisplayPort 2 Output (priority 600, latency offset 0 usec, available: no)
			properties:
		[Out] HDMI1: HDMI / DisplayPort 1 Output (priority 500, latency offset 0 usec, available: no)
			properties:
		[Out] Speaker: Speaker (priority 100, latency offset 0 usec, available: unknown)
			properties:
		[Out] Headphones: Headphones (priority 200, latency offset 0 usec, available: no)
			properties:
		[In] Mic2: Headphones Stereo Microphone (priority 200, latency offset 0 usec, available: no)
			properties:
		[In] Mic1: Digital Microphone (priority 100, latency offset 0 usec, available: unknown)
			properties:
uname -r
Output
6.1.1-1-MANJARO
sudo dmesg | grep snd
Output
[    6.605093] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    6.605288] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[    7.411857] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC298: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[    7.411862] snd_hda_codec_realtek ehdaudio0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.411863] snd_hda_codec_realtek ehdaudio0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    7.411864] snd_hda_codec_realtek ehdaudio0D0:    mono: mono_out=0x0
[    7.411865] snd_hda_codec_realtek ehdaudio0D0:    inputs:
[    7.411866] snd_hda_codec_realtek ehdaudio0D0:      Mic=0x18
[    7.455278] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[    7.455286] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
What I tried to solve the problem
Trying to solve the problem I followed the guide: how to set up the audio card in samsung galaxy book (forum is not allowing me to share the url) in this forum, but speakers are still not working.
Actually I was not able to follow all the steps in the guide, because the alsa-base file, mentioned in step 6, does not exist.
I tried to further search on the forum, but all the post I found proposed solutions already involved in the previously linked guide.
alsamixer
On alsamixer sof-hda-dsp is available as audio card and after selecting it I raised all the volumes, but still no sound.
I hope that what I provided is enough for you to give some suggestions.
Thanks in advance!!
Having the exact same issue on exact same system running Linux Mint. Hoping something comes out of this.
Yup. Exactly the same problem here. Actually it doesn’t matter which linux distribution you have, sound speakers won’t work. Also not sure who should fix this… samsung or linux community?
hope someone fix it asap !
I also got the same issue on galaxy book 3 pro
I tried Arch, Manjaro and NuTyX and lots of forums tips but nothing seems to work
File /etc/modprobe.d/alsa-base.conf exists on Mint and Ubuntu but not on Arch or Arch-based distributions
Original tutorial from 2020 using TO912.sh script and ionsound.service is not needed for some Samsung Galaxy models that have been patched in Kernel
patch_realtek.c - sound/pci/hda/patch_realtek.c - Linux source code v6.1.35 - Bootlin Elixir Cross Referencer
SND_PCI_QUIRK(0x144d, 0xc189, Samsung Galaxy Flex Book (NT950QCG-X716), ALC298_FIXUP_SAMSUNG_AMP),>```
SND_PCI_QUIRK(0x144d, 0xc18a, Samsung Galaxy Book Ion (NP930XCJ-K01US), ALC298_FIXUP_SAMSUNG_AMP),
SND_PCI_QUIRK(0x144d, 0xc1a3, Samsung Galaxy Book Pro (NP935XDB-KC1SE), ALC298_FIXUP_SAMSUNG_AMP),
SND_PCI_QUIRK(0x144d, 0xc1a6, Samsung Galaxy Book Pro 360 (NP930QBD), ALC298_FIXUP_SAMSUNG_AMP),
SND_PCI_QUIRK(0x144d, 0xc830, Samsung Galaxy Book Ion (NT950XCJ-X716A), ALC298_FIXUP_SAMSUNG_AMP),
SND_PCI_QUIRK(0x144d, 0xc832, Samsung Galaxy Book Flex Alpha (NP730QCJ), ALC256_FIXUP_SAMSUNG_HEADPHONE_VERY_QUIET),
SND_PCI_QUIRK(0x144d, 0xca03, Samsung Galaxy Book2 Pro 360 (NP930QED), ALC298_FIXUP_SAMSUNG_AMP),
SND_PCI_QUIRK(0x144d, 0xc868, Samsung Galaxy Book2 Pro (NP930XED), ALC298_FIXUP_SAMSUNG_AMP),
Kernel also has a model alias name for ALC298_FIXUP_SAMSUNG_AMP patch for other systems
ALSA developers at bugzilla.kernel.org can create a Kernel patch if the modprobe model option works
or if there is a working sequence of hda-verbs
ALSA developers cannot work out the correct hda-verbs needed for every laptop model
Users with unpatched hardware can get a working configuration of hda-verbs from a Windows sound driver running in a virtual machine
