Hello guys!
Recently, I purchased a Samsung Galaxy 4 PRO notebook and replaced Windows with Manjaro. I’ve noticed that the camera isn’t being recognized and external audio isn’t working, though it functions perfectly with headphones! Does anyone know how to resolve these issues?
Thank you
inxi:
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-6.9-x86_64
root=UUID=bcdd0861-7ecf-41a3-8576-22e8978515f4 rw quiet splash apparmor=1
Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro
base: Arch Linux
Type: Laptop System: SAMSUNG product: 940XGK v: P07VAG
Mobo: SAMSUNG model: NP940XGK-KG1BR
v: SGLB586A1Z-C01-G001-S0003+10.0.22631 serial: <superuser required>
part-nu: SCAI-PROT-A5A5-MTLH-PVAG uuid: <superuser required> UEFI: American
Megatrends LLC. v: P07VAG.670.240207.03 date: 02/07/2024
ID-1: BAT1 charge: 19.6 Wh (31.1%) condition: 63.1/62.0 Wh (101.9%)
volts: 14.8 min: 15.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: discharging cycles: 1
System RAM: total: 16 GiB available: 15.2 GiB used: 2.92 GiB (19.2%)
Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
max-module-size: 2 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 2 GiB speed: 7467 MT/s volts: curr: 0.5 min: 0.5 max: 0.5
width (bits): data: 16 total: 16 manufacturer: Samsung
part-no: K3KL8L80CM-MGCT serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x1C
Topology: cpus: 1x cores: 16 mt: 5 tpc: 2 st: 11 threads: 21 smt: enabled
cache: 24 MiB note: check
Speed (MHz): avg: 689 high: 2000 min/max: 400/4500:4800:3800:2500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 2000 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 2000 11: 400 12: 1939 13: 400
14: 400 15: 1746 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400
bogomips: 125832
bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Samsung Co
driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 4 (7nm+)
built: 2023+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4189 built: 2023 res: 2880x1800 dpi: 242
gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue:
x: 0.137 y: 0.047 white: x: 0.306 y: 0.322 size: 302x189mm (11.89x7.44")
diag: 356mm (14") ratio: 16:10 modes: 2880x1800
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 14.84 GiB unified: yes display-ID: :0.0
Device-1: Intel vendor: Samsung Co driver: N/A bus-ID: 00:05.0
chip-ID: 8086:7d19 class-ID: 0480
Device-2: Intel Meteor Lake-P HD Audio vendor: Samsung Co
driver: sof-audio-pci-intel-mtl
alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: off 3: pipewire-alsa type: plugin
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 476.94 GiB used: 10.19 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL4512HBLU-00B
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: HXC7AK1Q temp: 23.9 C
scheme: GPT
ID-1: / raw-size: 117.52 GiB size: 115.11 GiB (97.95%) used: 9.63 GiB (8.4%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: bcdd0861-7ecf-41a3-8576-22e8978515f4
ID-2: /boot raw-size: 1 GiB size: 1023 MiB (99.80%)
used: 171.7 MiB (16.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: E4FE-15CD
ID-3: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: E4EC-1EC9
ID-4: /home raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
used: 400.2 MiB (0.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 9bebb5b3-d815-4b60-92dc-0bbf2321c30f
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 1024 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-5:2 info: LighTuning ETU905A80-E type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 1c7a:05a1 class-ID: ff00 serial: <filter>
Device-2: 3-10:3 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 32.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1152 libs: 307 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirrors2.manjaro.org/stable/$repo/$arch
2: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
3: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
5: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 403
1: cpu: 16.9% command: firefox pid: 2713 mem: 414.4 MiB (2.6%)
2: cpu: 6.1% command: gnome-shell pid: 965 mem: 278.8 MiB (1.7%)
3: cpu: 5.7% command: firefox pid: 4814 mem: 248.6 MiB (1.5%)
4: cpu: 3.3% command: firefox pid: 5343 mem: 213.4 MiB (1.3%)
5: cpu: 1.8% command: firefox pid: 3199 mem: 47.4 MiB (0.3%)
Memory top: 5 of 403
1: mem: 414.4 MiB (2.6%) command: firefox pid: 2713 cpu: 16.9%
2: mem: 278.8 MiB (1.7%) command: gnome-shell pid: 965 cpu: 6.1%
3: mem: 248.6 MiB (1.5%) command: firefox pid: 4814 cpu: 5.7%
4: mem: 213.4 MiB (1.3%) command: firefox pid: 5343 cpu: 3.3%
5: mem: 168.5 MiB (1.0%) command: firefox pid: 5111 cpu: 1.1%
Processes: 403 Power: uptime: 16m states: freeze,mem,disk suspend: s2idle
image: 6.06 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.35
lspci
00:00.0 Host bridge: Intel Corporation Device 7d01 (rev 04)
DeviceName: Onboard - Other
Subsystem: Samsung Electronics Co Ltd Device ca07
Kernel driver in use: igen6_edac
Kernel modules: igen6_edac
00:02.0 VGA compatible controller: Intel Corporation Meteor Lake-P [Intel Arc Graphics] (rev 08)
DeviceName: Onboard - Video
Kernel driver in use: i915
Kernel modules: i915, xe
00:04.0 Signal processing controller: Intel Corporation Device 7d03 (rev 04)
Kernel driver in use: proc_thermal_pci
Kernel modules: processor_thermal_device_pci
00:05.0 Multimedia controller: Intel Corporation Device 7d19 (rev 04)
DeviceName: Onboard - Sound
00:06.0 PCI bridge: Intel Corporation Device 7ecb (rev 10)
Kernel driver in use: pcieport
00:07.0 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 02)
00:07.1 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #1 (rev 02)
00:08.0 System peripheral: Intel Corporation Device 7e4c (rev 20)
00:0a.0 Signal processing controller: Intel Corporation Device 7d0d (rev 01)
Kernel driver in use: intel_vsec
Kernel modules: intel_vsec
00:0b.0 Processing accelerators: Intel Corporation Meteor Lake NPU (rev 04)
Kernel modules: intel_vpu
00:0d.0 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 USB Controller (rev 02)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:0d.2 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #0 (rev 02)
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
00:0d.3 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #1 (rev 02)
00:12.0 Serial controller: Intel Corporation Device 7e45 (rev 20)
Kernel driver in use: intel_ish_ipc
Kernel modules: intel_ish_ipc
00:14.0 USB controller: Intel Corporation Meteor Lake-P USB 3.2 Gen 2x1 xHCI Host Controller (rev 20)
00:14.2 RAM memory: Intel Corporation Device 7e7f (rev 20)
00:14.3 Network controller: Intel Corporation Meteor Lake PCH CNVi WiFi (rev 20)
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Wi-Fi 6E AX211 160MHz
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:15.0 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #0 (rev 20)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #1 (rev 20)
00:15.2 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #2 (rev 20)
00:15.3 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #3 (rev 20)
00:16.0 Communication controller: Intel Corporation Device 7e70 (rev 20)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1f.0 ISA bridge: Intel Corporation Device 7e02 (rev 20)
00:1f.3 Multimedia audio controller: Intel Corporation Meteor Lake-P HD Audio Controller (rev 20)
Kernel driver in use: sof-audio-pci-intel-mtl
Kernel modules: snd_hda_intel, snd_sof_pci_intel_mtl
00:1f.4 SMBus: Intel Corporation Meteor Lake-P SMBus Controller (rev 20)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Meteor Lake-P SPI Controller (rev 20)
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9B1 (DRAM-less) (rev 02)
Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller PM9B1 (DRAM-less)
Kernel driver in use: nvme
Kernel modules: nvme
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 1c7a:05a1 LighTuning Technology Inc. ETU905A80-E
Bus 003 Device 003: ID 8087:0033 Intel Corp. AX211 Bluetooth
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
unamea
Linux piter-galaxy-book 6.9.3-3-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Jun 10 09:50:04 UTC 2024 x86_64 GNU/Linux
