Hi all, I’m having issues with this new hardware (at least less than I expect). I have a AMD Renoir / NVIDIA 3060.
I`m using the ‘video-hybrid-amd-nvidia-470xx-prime’ driver but I’m unable to switch the between GPU’s with the ‘optimus-manager --switch NVIDIA’ but after the system relogin the GPU still the same. It seems stuck, the ‘optimus-manager --status’ shows that the switch will be applied next login, but it’s not working.
For now I’m switching graphics installing (which defaults to AMD renoir) / uninstalling (which defaults to NVIDIA). But even with this not ideal workaround the 2 GPU are rendering differently from one another.
Any I idea how I do to my NVIDIA GPU do render same as the integrated (amdgpu)?
Thanks for the help man, as I said I’ll have to uninstall the package so I can the other GPU info.
AMDGPU:
Optimus Manager (Client) version 1.4
Current GPU mode : integrated
GPU mode requested for next login : no change
GPU at startup : integrated
Temporary config path: no
I am not really familiar with optimus-manager, but basically it just replaces the xorg config and restart the Display-Manager (relogin). The config must contain the correct DisplaySize or DPI.
Hi man, you were right about the DPI issue.
In my case I discovered that the optimus needed some love:
/etc/optimus-manager.conf needed the ignore_abi parameter to ‘yes’
[Had to do with NVIDIA drivers not working properly with Xorg 1.21]
/etc/sddm.conf comment out the lines with DisplayCommand and DisplayStopCommand as pointed out in here
[This one was about KDE messing with some configs that optimus relied on]
After all that the GPU optimus-manager --switch started to work (yay!). optimus-manager.conf had already the correct DPI parameters (96) by default, which was just not loading because of my bad configuration.
