Hi!
I’m using X11, but tried Wayland briefly. These are bugs, that I discovered:
- system hung couple of times about two minutes after login (pointer did not move). Only hardware reset woke system up.
- mpv media player was out of screen borders, when maximize.
- SMplayer was totally black, when palying videos.
- file drag and drop from file manager (at least from Nemo) to mpv did not work.
- when woke up system from sleep, screen was corrupted. Picture in attachment.
I’m not using Wayland, but X11, so these are not critical problems to me.
My system:
Kernel: 5.17.1-3-MANJARO
Plasma: 5.24.4
Type: Desktop Mobo: ASUSTeK model: M4A87TD/USB3 v: Rev 1.xx
serial: BIOS: American Megatrends v: 2001
date: 03/08/2011
RAM: total: 15.62 GiB used: 4.58 GiB (29.3%)
RAM Report:
Info: quad core model: AMD Athlon II X4 640 bits: 64 type: MCP cache:
L2: 2 MiB
Speed (MHz): avg: 800 min/max: 800/3000 cores: 1: 800 2: 800 3: 800
4: 800
Device-1: AMD Juniper PRO [Radeon HD 5750] driver: radeon v: kernel
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1 driver:
X: loaded: radeon unloaded: modesetting gpu: radeon
resolution: 1680x1050~60Hz
OpenGL: renderer: AMD JUNIPER (DRM 2.50.0 / 5.17.1-3-MANJARO LLVM 13.0.1)
v: 3.3 Mesa 21.3.8
