-- Logs begin at Sat 2019-12-28 22:35:40 CET, end at Sat 2020-11-14 10:32:48 CET. --
Nov 14 10:30:57 peacemaker kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Nov 14 10:30:57 peacemaker kernel: #3
Nov 14 10:30:57 peacemaker kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 14 10:30:57 peacemaker kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Nov 14 10:30:57 peacemaker kernel: usb: port power management may be unreliable
Nov 14 10:30:57 peacemaker systemd-modules-load[228]: Failed to find module 'vboxdrv'
Nov 14 10:30:57 peacemaker systemd-modules-load[228]: Failed to find module 'vboxnetadp'
Nov 14 10:30:57 peacemaker systemd-modules-load[228]: Failed to find module 'vboxnetflt'
Nov 14 10:30:58 peacemaker kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Nov 14 10:30:58 peacemaker kernel: elan_i2c i2c-ELAN0618:00: supply vcc not found, using dummy regulator
Nov 14 10:30:59 peacemaker kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Nov 14 10:30:59 peacemaker kernel: kauditd_printk_skb: 23 callbacks suppressed
Nov 14 10:30:59 peacemaker kernel: asus_wmi: ASUS Management GUID not found
Nov 14 10:30:59 peacemaker kernel: pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Nov 14 10:30:59 peacemaker kernel: pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
Nov 14 10:30:59 peacemaker kernel: pcieport 0000:00:1c.4: [ 0] RxErr (First)
Nov 14 10:30:59 peacemaker kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Nov 14 10:31:00 peacemaker kernel: pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Nov 14 10:31:00 peacemaker kernel: pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
Nov 14 10:31:00 peacemaker kernel: pcieport 0000:00:1c.4: [ 0] RxErr (First)
Nov 14 10:31:00 peacemaker NetworkManager[452]: <warn> [1605346260.5886] sup-iface[5354b128fc3544b0,0,wlp2s0]: call-p2p-cancel: failed with P2P cancel failed
Nov 14 10:31:04 peacemaker kernel: kauditd_printk_skb: 25 callbacks suppressed
Nov 14 10:31:47 peacemaker lightdm[819]: gkr-pam: unable to locate daemon control file
Nov 14 10:31:47 peacemaker kernel: pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Nov 14 10:31:47 peacemaker kernel: pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
Nov 14 10:31:47 peacemaker kernel: pcieport 0000:00:1c.4: [ 0] RxErr (First)
Nov 14 10:31:47 peacemaker kernel: pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
Nov 14 10:31:47 peacemaker kernel: pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000040/00002000
Nov 14 10:31:47 peacemaker kernel: pcieport 0000:00:1c.4: [ 6] BadTLP
Nov 14 10:31:48 peacemaker kernel: pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Nov 14 10:31:48 peacemaker kernel: pcieport 0000:00:1c.4: device [8086:9d14] error status/mask=00000001/00002000
Nov 14 10:31:48 peacemaker kernel: pcieport 0000:00:1c.4: [ 0] RxErr (First)
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanType” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanWindow” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanType” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanWindow” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRLinkSupervisionTimeout” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRPageTimeout” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRMinSniffInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRMaxSniffInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEMinAdvertisementInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEMaxAdvertisementInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEMultiAdvertisementRotationInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAutoConnect” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAutoConnect” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalSuspend” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowSuspend” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalDiscovery” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowDiscovery” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAdvMonitor” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAdvMonitor” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
Nov 14 10:31:48 peacemaker bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
Nov 14 10:31:50 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:123:146: Expected a valid selector
Nov 14 10:31:50 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:9319:2: '/*' in comment block
Nov 14 10:31:50 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:9320:20: Expected semicolon
Nov 14 10:31:50 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:13298:18: Invalid name of pseudo-class
Nov 14 10:31:50 peacemaker blueman-mechani[1325]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Nov 14 10:31:51 peacemaker gnome-keyring-daemon[1020]: asked to register item /org/freedesktop/secrets/collection/login/10, but it's already registered
Nov 14 10:31:54 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:123:146: Expected a valid selector
Nov 14 10:31:54 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:9319:2: '/*' in comment block
Nov 14 10:31:54 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:9320:20: Expected semicolon
Nov 14 10:31:54 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:13298:18: Invalid name of pseudo-class
Nov 14 10:31:57 peacemaker kernel: kauditd_printk_skb: 17 callbacks suppressed
Nov 14 10:32:09 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:123:146: Expected a valid selector
Nov 14 10:32:09 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:9319:2: '/*' in comment block
Nov 14 10:32:09 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:9320:20: Expected semicolon
Nov 14 10:32:09 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:13298:18: Invalid name of pseudo-class
Nov 14 10:32:14 peacemaker kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:3c:a6:2f:7c:2b:3b:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=15842 DF PROTO=2
Nov 14 10:32:33 peacemaker kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=00:bb:60:74:73:e0:5c:49:79:2c:f6:cc:08:00 SRC=192.168.178.26 DST=192.168.178.22 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=1103 DF PROTO=TCP SPT=56975 DPT=80 WINDOW=14600 RES=0x00 SYN URGP=0
Nov 14 10:32:34 peacemaker kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=00:bb:60:74:73:e0:5c:49:79:2c:f6:cc:08:00 SRC=192.168.178.26 DST=192.168.178.22 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=1104 DF PROTO=TCP SPT=56975 DPT=80 WINDOW=14600 RES=0x00 SYN URGP=0
Nov 14 10:32:34 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:123:146: Expected a valid selector
Nov 14 10:32:34 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:9319:2: '/*' in comment block
Nov 14 10:32:34 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:9320:20: Expected semicolon
Nov 14 10:32:34 peacemaker bamfdaemon[1272]: Theme parsing error: gtk.css:13298:18: Invalid name of pseudo-class
Nov 14 10:32:36 peacemaker kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=00:bb:60:74:73:e0:5c:49:79:2c:f6:cc:08:00 SRC=192.168.178.26 DST=192.168.178.22 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=1105 DF PROTO=TCP SPT=56975 DPT=80 WINDOW=14600 RES=0x00 SYN URGP=0
Nov 14 10:32:40 peacemaker kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=00:bb:60:74:73:e0:5c:49:79:2c:f6:cc:08:00 SRC=192.168.178.26 DST=192.168.178.22 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=1106 DF PROTO=TCP SPT=56975 DPT=80 WINDOW=14600 RES=0x00 SYN URGP=0
1 kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
2 systemd-modules-load[228]: Failed to find module 'vbox'...
3 pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
4 bluetoothd[1140]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanType” in group “Controller”
5 bamfdaemon[1272]: Theme parsing error: gtk.css:123:146: Expected a valid selector
1 can concerns touchpad if not working
2 can you provide
sudo mhwd-kernel -li
3 add this on boot pci=noaer , in boot line kernel
is there on this command in diff number ( by linux version )
Sorry i didnt realize that you need the output.
pacman -Qs linux57-
local/linux57-headers 5.7.19-2
Header files and scripts for building modules for Linux57 kernel
local/linux57-virtualbox-host-modules 6.1.16-1 (linux57-extramodules)
Host kernel modules for VirtualBox
pacman -Qs linux58-
local/linux58-headers 5.8.18-1
Header files and scripts for building modules for Linux58 kernel
local/linux58-virtualbox-host-modules 6.1.16-3 (linux58-extramodules)
pacman -Qs linux59-
local/linux59-headers 5.9.3-1
Header files and scripts for building modules for Linux59 kernel
local/linux59-virtualbox-host-modules 6.1.16-3 (linux59-extramodules)
i had some depency error bs mhwd-kernel -r linux58 with linux-latest linux-latest-headers and so on. I uninstalled them seperatly and finally i removed the kernel
hmm i think there is really something with this bamfdaemon:
Boot to 5.9 has this entries:
dbus-daemon[1040]: [session uid=1000 pid=1040] Activating via systemd: service name='org.ayatana.bamf' unit='bamfdaemon.service' requested by ':1.25' (uid=1000 pid=1166 comm="plank " label="unconfined")
systemd[1018]: Starting BAMF Application Matcher Framework...
bamfdaemon[1296]: bamfdaemon: Fatal IO error 11 (Die Ressource ist zur Zeit nicht verfügbar) on X server :0.
On 5.4 its seems to work (so no Fatal IO error)
But… i dont find this service?
sudo systemctl status bamfdaemon.service
Unit bamfdaemon.service could not be found.
