Fuse doesn't mount Ntfs after testing update 16/03/2024
Since yesterday update ( using unstable ) and using the latest 6.8.1 Kernel I am unable to mount any NTFS drive.
I do not use the fstab file , as I mount the HDDs as required (external USB HDDs) …
Nonetheless despite calling explicitly “mount.ntfs-3g” or “mount.ntfs” , I was unable to mount or read any of the filesystems.
I noticed the modprobe blacklisting setup but at this thins point I do not which one is being used …
How can I check which one is being called ?
Edit: I forgot that I was in the unstable branch;
So after returning to the Testing branch apparently the problem disappeared and is now working correctly …
Here is an older thread which has very recently received renewed interest. You may find some discussion relevant to you in that thread:
