First off i apologize if this isn’t the correct place to put this, I’m a newbie in basically everything concerning linux and forums and i couldn’t even post on the introduce yourself thing.
I installed manjaro 21.0.7 KDE alongside windows 10 earlier this morning and i tried to set it up for all the things i need it for. Everything works except corectrl, i read the readme on the gitlab page and added the boot parameter to allow all advanced features, however upon rebooting those features are not unlocked, i even double checked to see if i forgot to save the file or something but the parameter is still there.
I checked a youtube video and everything i did was the same except a few lines after the command
sudo update-grub
the output was the same except these lines:
Found Windows Boot Manager on /dev/sda2@/EFI/Microsoft/Boot/bootmgfw.efi
I’m not sure what the problem is
The whole output is this:
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
done
this is the grub line where i added the parameter
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff"
I’m running kernel version 5.4.131-1
Thank you in advance
