fstab
UUID=DF4C-3EF6 /boot/efi vfat umask=0077 0 2
#Internal SSD chip
UUID=2d64975e-0469-4806-9920-f8d58dcf648a / ext4 noatime 0 1
UUID=ba7cb6b7-a319-4d4a-868f-bdca4fc94f3e /home ext4 noatime 0 2
UUID=040e631a-349b-4735-bec8-07df04ff8342 /Videos ext4 noatime 0 2
UUID=1045fc46-4a83-4180-9150-8c997a230e99 /home/1234/Partitions/VA btrfs noatime,space_cache,autodefrag 0 2
UUID=a52f518e-0fe2-47a2-b313-dfb938dc1c8e /home/1234/Partitions/VB ext4 noatime 0 2
UUID=e9c78e78-522b-4a18-ad6e-1192c600cbf9 /home/1234/Partitions/VC ext4 noatime 0 2
UUID=0d7b716a-dd90-497b-9976-8118372c6cad /home/1234/Partitions/VD ext4 noatime 0 2
UUID=67b66f14-cdb8-4c12-94eb-b0eb14a2bb13 /home/1234/Partitions/VE ext4 noatime 0 2
UUID=75e8521b-f184-403c-819e-6a4916e0007d /home/1234/Partitions/VF ext4 noatime 0 2
UUID=637f7c1e-7231-4616-aea4-338d74a9b637 /home/1234/Partitions/VG btrfs noatime,space_cache,autodefrag 0 2
#External removeable SSD
UUID=132b10ff-f475-42bb-ad35-b4f362590bcd /home/1234/Partitions/EVB btrfs noafail,noatime,x-systemd.automount,x-systemd.x-systemd.idle-timeout=1min,space_cache,noautodefrag,ssd,ssd_spread,discard,norecovery 0 0
findmnt
findmnt
TARGET SOURCE FSTYPE OPTIONS
**/ /dev/nvme1n1p2 ext4 rw,noatime**
ββ/proc proc proc rw,nosuid,nodev,noexec,relatime
β ββ/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pip
β ββ/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
ββ/sys sys sysfs rw,nosuid,nodev,noexec,relatime
β ββ/sys/firmware/efi/efivars efivarfs efivarfs rw,nosuid,nodev,noexec,relatime
β ββ/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime
β ββ/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
β ββ/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime
β ββ/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700
β ββ/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime
β ββ/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime
β ββ/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime
β ββ/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime
ββ/dev dev devtmpfs rw,nosuid,relatime,size=8047340k,nr_inodes=2011835,mode=755,inode64
β ββ/dev/shm tmpfs tmpfs rw,nosuid,nodev,inode64
β ββ/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
β ββ/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime
β ββ/dev/hugepages hugetlbfs hugetlbfs rw,relatime,pagesize=2M
ββ/run run tmpfs rw,nosuid,nodev,relatime,mode=755,inode64
β ββ/run/credentials/systemd-sysusers.service
β β ramfs ramfs ro,nosuid,nodev,noexec,relatime,mode=700
β ββ/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=1621712k,nr_inodes=405428,mode=700,ui
β ββ/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1001
β ββ/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd- rw,nosuid,nodev,relatime,user_id=1000,group_id=1001
ββ/tmp tmpfs tmpfs rw,nosuid,nodev,size=8108572k,nr_inodes=1048576,inode64
ββ/Videos /dev/sda2 ext4 rw,noatime
ββ/home /dev/sda1 ext4 rw,noatime
β ββ/home/bryans/Partitions/EVB /dev/sdb1 btrfs rw,relatime,space_cache=v2,subvolid=5,subvol=/
ββ/boot/efi /dev/nvme1n1p1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,sho
β ββ/home/1234/Partitions/EVB /dev/sdb1 btrfs rw,relatime,space_cache=v2,subvolid=5,subvol=/
β ββ/home/1234/Partitions/VB /dev/sda4 ext4 rw,noatime
β ββ/home/1234/Partitions/VD /dev/sda6 ext4 rw,noatime
β ββ/home/1234/Partitions/VC /dev/sda5 ext4 rw,noatime
β ββ/home/1234/Partitions/VE /dev/sda7 ext4 rw,noatime
β ββ/home/1234/Partitions/VF /dev/sda9 ext4 rw,noatime
β ββ/home/1234/Partitions/VA /dev/sda3 btrfs rw,noatime,space_cache,autodefrag,subvolid=5,subvol=/
β ββ/home/1234/Partitions/VG /dev/sda8 btrfs rw,noatime,space_cache,autodefrag,subvolid=5,subvol=/
ββ/boot/efi /dev/nvme1n1p1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shor
/home/1234/Partitions/EVB mounts only manually. This tells me that I have done something stupid in my fstab setup. Objective is to save the SSD drive as long as I can and to be able to unmount and mount when I wantβ¦
The / partition is also an SSD and I would also love to save it for as long as possible. Is the noatime option all I need?
