Hey, today I ran into another problem. When I start manjaro fsck runs like normal but stops at:
/dev/sdb2: clean, 316578/59908096 files, 8104443/239611109 blocks
and I need to hard reset the pc.
I tried to run the command from a live iso, but it stops at the same point. However I’m still able to chroot into the system and mount the drive.
inxi (from live iso):
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=de tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2121 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B450 AORUS PRO v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450 AORUS PRO-CF serial: <superuser required>
UEFI: American Megatrends v: F60c date: 10/29/2020
RAM: total: 15.61 GiB used: 2.78 GiB (17.8%)
RAM Report:
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1939 high: 2393 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2393 2: 1829
3: 1713 4: 1907 5: 2063 6: 1884 7: 1886 8: 2136 9: 2302 10: 1747 11: 1791
12: 1757 13: 1957 14: 1887 15: 1885 16: 1889 bogomips: 118218
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:687f class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus-ID: 0a:00.1 chip-ID: 1002:aaf8 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3.1:15 chip-ID: 08bb:2902
class-ID: 0300
Device-4: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid bus-ID: 3-3.2.4:18
chip-ID: 0d8c:0014 class-ID: 0300
Device-5: C-Media MAXTER 7.1 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3.4:17 chip-ID: 0d8c:0012
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter
driver: bcma-pci-bridge v: N/A modules: bcma bus-ID: 06:00.0
chip-ID: 14e4:43a0 class-ID: 0280
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-2:2 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 1.14 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 023 scheme: MBR
ID-2: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A02 scheme: GPT
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 3.58 GiB fs: iso9660
ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 8078-6038
ID-3: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ext4 label: Data
uuid: 113df865-827c-4ba3-ae32-274e88f0fb8b
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-2:2 info: ASUSTek Broadcom BCM20702A0 Bluetooth
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: [Maxxter] Optical gaming mouse type: Mouse,Keyboard
power: 100mA chip-ID: 18f8:0f99 class-ID: 0301
Device-2: 3-2:3 info: Trust GXT 860 Keyboard type: Keyboard,Mouse
power: 100mA chip-ID: 145f:0218 class-ID: 0301
Hub-4: 3-3:14 info: Super Top 4-Port hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 14cd:8601 class-ID: 0900
Device-1: 3-3.1:15 info: Texas Instruments PCM2902 Audio Codec
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 08bb:2902 class-ID: 0300
Hub-5: 3-3.2:16 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-3.2.4:18 info: C-Media Audio Adapter (Unitek Y-247A)
type: Audio,HID driver: cmedia_hs100b,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0014 class-ID: 0300
Device-2: 3-3.4:17 info: C-Media MAXTER 7.1 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 0d8c:0012 class-ID: 0300
serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 46.8 C mobo: N/A gpu: amdgpu temp: 41.0 C
mem: 39.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 895
Processes: 362 Uptime: 13m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1228 lib: 331 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.12 running-in: yakuake inxi: 3.3.11
if you can chroot , check
journalctl -b -1
Bus error (core dumped)
I think that isn’t normal :c
And now it says bash: /usr/bin/ls: Input/output error
after I tried to execute commands:
[manjaro /]# ls
Looks like a physical damage.
Take a look the the smart info:
sudo smartctl --all /dev/sda
Make a badblock scan (read-only: fast, but less accurate):
sudo badblocks -v /dev/sda
I’ll try, but I think you mean /dev/sdb instead of /dev/sda
Update:
badblocks -v /dev/sdb spams:
143... badblocks: Invalid argument during seek
the number is increased each time
smartctl:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.12-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Crucial/Micron Client SSDs
Device Model: CT1000BX500SSD1
Serial Number: 2113E591C5FD
LU WWN Device Id: 5 00a075 1e591c5fd
Firmware Version: M6CR030
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 4
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Jan 22 15:31:52 2022 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 120) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 0
5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 1262
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 356
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
173 Ave_Block-Erase_Count 0x0032 100 100 000 Old_age Always - 11
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 183
180 Unused_Reserve_NAND_Blk 0x0033 100 100 000 Pre-fail Always - 12
183 SATA_Interfac_Downshift 0x0032 100 100 000 Old_age Always - 239
184 Error_Correction_Count 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 068 042 000 Old_age Always - 32 (Min/Max 20/58)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_ECC_Cnt 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 1
202 Percent_Lifetime_Remain 0x0030 100 100 001 Old_age Offline - 0
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
210 Success_RAIN_Recov_Cnt 0x0032 100 100 000 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 5086577985
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 158955562
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 79934336
249 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 0
250 Read_Error_Retry_Rate 0x0032 100 100 000 Old_age Always - 141220
251 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 0
252 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 0
253 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 16
254 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 67
223 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 3
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 3
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 51 00 00 00 00 a0 Error: ICRC, ABRT at LBA = 0x00000000 = 0
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 50 00 00 00 00 00 00:00:00.000 READ FPDMA QUEUED
60 08 78 20 6a 70 00 00 00:00:00.000 READ FPDMA QUEUED
Error -1 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
00 00 00 00 00 00 00 at LBA = 0x00000000 = 0
61 08 88 d8 83 8d 00 00 00:00:00.000 WRITE FPDMA QUEUED
61 08 28 38 79 89 00 00 00:00:00.000 WRITE FPDMA QUEUED
Error -2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
60 00 78 08 72 89 00 00 00:00:00.000 READ FPDMA QUEUED
60 21 98 1d 1e 1f 00 00 00:00:00.000 READ FPDMA QUEUED
60 d0 d8 00 68 70 00 00 00:00:00.000 READ FPDMA QUEUED
Error -3 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
60 f8 60 08 11 00 00 00 00:00:00.000 READ FPDMA QUEUED
60 08 48 00 08 00 00 00 00:00:00.000 READ FPDMA QUEUED
Error -4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
e5 00 00 00 00 00 00 08 00:00:00.000 CHECK POWER MODE
b0 d1 01 01 4f c2 00 08 00:00:00.000 SMART READ ATTRIBUTE THRESHOLDS [OBS-4]
b0 da 00 00 4f c2 00 08 00:00:00.000 SMART RETURN STATUS
b0 d5 01 00 4f c2 00 08 00:00:00.000 SMART READ LOG
b0 d5 01 01 4f c2 00 08 00:00:00.000 SMART READ LOG
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
Joe_Ge
22 January 2022 15:31
6
Maybe you give fsck more time.
I had the same once, that fsck seems didnt move anymore, but it finnished after a while
fsck -y assume yes on repair options.
~ sudo fsck -y /dev/sdb2 8 ✘
fsck from util-linux 2.37.2
e2fsck 1.46.4 (18-Aug-2021)
/dev/sdb2: recovering journal
the process finishs, but didn’t clean all files (when booting, the emergency console opens after some time)
There is nothing more to say here. Replace the SSD, since the lifetime exceeded.
Interesting, I just bought it half a year ago, well then it gets sent back. Thank you guys here!
Google says this ssd has a lifetime of 1500000 hours, but the ssd was only powered on for 1262h (kde partition manager - SMART Properties: Power-On-Hourse 1262:00:00)
Joe_Ge
22 January 2022 16:50
10
Hm.
Smartctl show errors different to me, with a timestamp.
Its for me unusual, that you have it at 0 Days 0 h
My smartctl. That hdd has some 7200h now.
Maybe its one from your Ram modules, what says byebye?
Try a short memtest?
Error 43 occurred at disk power-on lifetime: 6105 hours (254 days + 9 hours)
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
60 00 08 ff ff ff 4f 00 01:04:01.783 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 01:04:01.782 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 a0 00 01:04:01.781 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 01:04:01.781 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 01:04:01.781 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 42 occurred at disk power-on lifetime: 6105 hours (254 days + 9 hours)
Error 40 occurred at disk power-on lifetime: 6102 hours (254 days + 6 hours)
Mhh, I‘m currently not on the pc. But I don‘t think so, because manjaro rans fine on another ssd. I couldn‘t install manjaro directly on this ssd either, I had to clone it from another. So that really sounds like a hardware defective for me.
I can try it on another pc tomorrow
Joe_Ge
22 January 2022 20:16
12
Another hm.
Why does your inxi say
but your smartctl
goldmensch:
User Capacity: 1,000,204,886,016 bytes **[1.00 TB]
Just asking, because i bought lately a manipulated drive too, where it seems they changed the firmware.
Ah, the inxi is taken from the live iso on the 250gb ssd mounted to sda.The 1tb drive (CT1000…) is mounted to sdb.
