Just did a software upgrade to my Toshiba Satellite C655-S5307 (Intel CORE 13) and now the laptop freezes on ‘Preparing…’ when you ask the software install/upgrade program to do anything. You cannot ‘x’ out of the software install/upgrade program, you cannot quit it using right-click, the program just freezes in a permanent ‘Preparing…’ posture with elevated CPU/fan acceleration noises, but when you go into System Monitor it shows elevated CPU usage (30-50% for all 3 CPUs) but no processes are associated with the elevated CPU/fan activity; just freezes with elevated sound from the fan/CPU. Is there some way to uninstall the recent upgrade or to see what is freezing the laptop? You can still do stuff on the internet, but the only way to close the software install/upgrade program is to power off the laptop. Thanks.
And what will happen if you do
sudo pacman-mirrors -f && sudo pacman -Syu
“there is nothing to do” at the end of the process. Says it is current.
The next thing will be to disable AUR if enabled
sudo sed -Ei '/CheckAURUpdates/s/^/#/' /etc/pamac.conf
Try to open it. If it is still stuck the next will be to delete the cache. The process btw, if you have to kill it is
killall pamac-manager
Thanks for your help. Killing the process terminates the install freeze, but if you try again to install anything the freeze reignites. Am wondering if there is just some weird death-spiral between the CPUs and the software; not sure what else to think. Thanks again for your help. Is there a way to uninstall and reinstall everything via the terminal ?
Maybe something is stuck in the cache…
I have seen this once but i cannot remember exactly…i thought it was aur connected.
If you want you can try to clean the caches. Nuke everything inside:
/var/cache/pacman/pkg/
/var/cache/pamac/
Thanks. Nuked the pkg but still stalls. Thanks again for your help. Will wait and see for the time being.
What happens when you use pamac on the command line? For example:
pamac update
or
pamac install <the-package-name>
with pamac update it said nothing to do and the installer still stalls. Thinking about upgrading my laptop; it’s about time. Thanks.
I don’t think that would be the cause of the issue.
Try opening a terminal and running the command pamac-manager. Do any messages appear in the terminal before or when pamac-manager freezes? Please copy & paste any messages that appear into this topic.
Another possibility could be the polkit issue that has occurred on systems running older kernels after a recent update. Maybe pamac-manager, which relies on polkit when asking for your password, is locking up due to the authorisation not completing.
Could you please confirm your running kernel by posting the output of:
uname -r
More detailed system info could also be very helpful. Please provide the output of:
inxi --filter --verbosity=8
inxi -zv8
- inxi man pages (Arch Manual)
Running `inxi` in `chroot`
Note that any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions: ![]()
[MiniHowTo] Present code or command output
Note: Grave accent (or, backtick) characters are used. ![]()
- for example, typing: `code here` will display the text as
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
(pamac-manager:4717): Gtk-WARNING **: 19:53:49.083: Unable to acquire session bus: Error spawning command line “dbus-launch --autolaunch=1cae114c76e946cfa5577f05cc95e8dc --binary-syntax --close-stderr”: Child process exited with code 1
Then it stalls.
5.15.197-1-MANJARO
for inxi --filter --verbosity=8
Kernel: 5.15.197-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=fcd0c138-1f42-4222-84ba-038656beb11a rw quiet splash apparmor=1
Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 43.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: TOSHIBA product: Satellite C655 v: PSC2EU-00502H
serial: <filter>
Mobo: TOSHIBA model: Portable PC serial: N/A part-nu: PSC2EU-00502H
uuid: a0e8aecd-aff9-e011-a07e-00266ce2f02c Firmware: BIOS vendor: INSYDE
v: 1.30 date: 11/21/2011
ID-1: BAT0 charge: 32 Wh (100%) condition: 32/47.5 Wh (67.2%) volts: 10.8
min: 10.8 model: PA3817U-1BRS type: Li-ion serial: <filter> charging:
status: full cycles: N/A
Device-1: hidpp_battery_0 model: Logitech M510 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 4 GiB available: 3.78 GiB used: 2.28 GiB (60.2%)
igpu: 32 MiB
Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
max-module-size: 8 GiB
Device-1: DIMM0 type: DDR3 detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471B5773CHS-CH9 serial: <filter>
Device-2: DIMM1 type: DDR3 detail: synchronous size: 2 GiB
Message: No PCI Slot data found.
Info: model: Intel Core i3-2330M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x dies: 1 cores: 2 threads: 4 tpc: 2 smt: enabled cache:
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 min/max: 800/2200 base/boost: 2200/4000 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.3 V ext-clock: 1333 MHz
cores: 1: 798 2: 798 3: 798 4: 798 bogomips: 17567
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibpb_exit_to_user ibrs lahf_lm lm
mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp
rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
prctl and seccomp
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Toshiba driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1 empty: VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: Importek TOSHIBA Web Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:4 chip-ID: 10f1:1a34
Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
compositor: gnome-shell driver: gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: LVDS-1 model: Seiko Epson 0x5541 built: 2009 res:
mode: 1366x768 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2 chroma: red:
x: 0.620 y: 0.357 green: x: 0.298 y: 0.580 blue: x: 0.149 y: 0.090 white:
x: 0.314 y: 0.329 size: 340x190mm (13.39x7.48") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
drv: crocus inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 25.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) device-ID: 8086:0116 memory: 1.46 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
vendor: Toshiba driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
API: ALSA v: k5.15.197-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with: wireplumber
status: active tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0-98-gb096 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Qualcomm Atheros AR8152 v2.0 Fast Ethernet vendor: Toshiba
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 01:00.0 chip-ID: 1969:2062 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
chip-ID: 10ec:8176 class-ID: 0280
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Local Storage: total: 495.01 GiB used: 72.21 GiB (14.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK5076GSXN
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1M scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Lexar model: USB Flash Drive
size: 29.25 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1100 scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW TS-L633F rev: TF01
dev-links: cdrom
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 72.21 GiB (15.8%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: fcd0c138-1f42-4222-84ba-038656beb11a
ID-1: /dev/sdb1 maj-min: 8:17 size: 8 GiB fs: vfat label: TAILS
uuid: 66FB-1BA1
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.1:3 info: Realtek RTS5138 Card Reader Controller
type: mass storage driver: ums-realtek interfaces: 1 rev: 2.0
chip-ID: 0bda:0138 class-ID: 0806 serial: <filter>
Device-2: 1-1.3:4 info: Importek TOSHIBA Web Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 10f1:1a34 class-ID: 0e02
serial: <filter>
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 2-1.2:3 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 2-1.2.2:4 info: Lexar USB Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 21c4:0cd1 class-ID: 0806
serial: <filter>
Device-2: 2-1.2.3:5 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1526 pm: pacman pkgs: 1516 libs: 399
tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 pm: snap pkgs: 10
1: https://mirror.fcix.net/manjaro/stable/$repo/$arch
2: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
4: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
5: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
10: https://mirrors2.manjaro.org/stable/$repo/$arch
11: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
13: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
14: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://muug.ca/mirror/manjaro/stable/$repo/$arch
17: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
20: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
22: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
23: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
24: https://mirrors.manjaro.org/repo/stable/$repo/$arch
25: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
26: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
27: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
28: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
30: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
31: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
32: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
33: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
35: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
36: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
37: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
38: https://mirror.init7.net/manjaro/stable/$repo/$arch
39: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
40: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
41: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
42: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
43: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
44: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
45: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
46: https://mirror.koddos.net/manjaro/stable/$repo/$arch
47: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
48: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
49: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
50: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
51: https://mirror.23m.com/manjaro/stable/$repo/$arch
52: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
53: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
54: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
55: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
56: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
57: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
58: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
59: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
60: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
61: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
62: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
63: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
64: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
65: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
66: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
67: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
68: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
69: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
70: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
71: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
72: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
73: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
74: https://mirror.dc.uz/manjaro/stable/$repo/$arch
75: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
76: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
77: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
78: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
79: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
80: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
81: https://linorg.usp.br/manjaro/stable/$repo/$arch
82: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
83: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
84: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
85: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
86: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
87: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
88: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
89: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
90: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
91: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
92: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
93: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
94: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
95: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
96: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
97: https://manjaro.ynh.ovh/stable/$repo/$arch
98: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
99: https://mirror.easyname.at/manjaro/stable/$repo/$arch
100: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
101: https://manjaro.grena.ge/stable/$repo/$arch
102: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
103: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
104: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
105: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 243
1: cpu: 50.0% command: ps pid: 5349 mem: 4.11 MiB (0.1%)
2: cpu: 18.2% command: firefox pid: 2678 mem: 424.0 MiB (10.9%)
3: cpu: 13.4% command: firefox pid: 2885 mem: 298.1 MiB (7.7%)
4: cpu: 8.7% command: gnome-shell pid: 1069 mem: 270.5 MiB (6.9%)
5: cpu: 3.6% command: localsearch-extractor-3 pid: 5328
mem: 39.7 MiB (1.0%)
Memory top: 5 of 243
1: mem: 424.0 MiB (10.9%) command: firefox pid: 2678 cpu: 18.2%
2: mem: 303.2 MiB (7.8%) command: soffice.bin pid: 3897 cpu: 2.4%
3: mem: 298.1 MiB (7.7%) command: firefox pid: 2885 cpu: 13.4%
4: mem: 270.5 MiB (6.9%) command: gnome-shell pid: 1069 cpu: 8.7%
5: mem: 255.3 MiB (6.5%) command: manjaro-hello started-by: python3
pid: 1229 cpu: 0.6%
Processes: 243 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.5 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: N/A Shell: Sudo (sudo) v: 1.9.17p2 default: Bash v: 5.3.9
running-in: gnome-terminal inxi: 3.3.40
Is there any specific reason why you are running such an old kernel?
Anyway, to eliminate polkit as being the cause of the issue please try switching to kernel 6.6 or later. You have 3 LTS kernels currently available that will work with the polkit changes.
To install kernel 6.6:
sudo mhwd-kernel -i linux66
or kernel 6.12:
sudo mhwd-kernel -i linux612
or the recently LTS-listed kernel 6.18:
sudo mhwd-kernel -i linux618
After the new kernel is installed, reboot and see if pamac-manager now works.
Note that this issue was covered in the " Known issues and solutions" section of the most recent update announcement:
Also, your inxi output is unreadable due to it not being formatted as code. Please click the
icon at the bottom of the post and edit it according to these instructions:
code here.
What is a Quark?
Worked like a charm. Thank you so much, very appreciated.
Groovy!!!
