Hey there friends.
I was just messing around with the KDE taskbar settings, dragging new widgets in etc., and was suddenly kicked out of the edit menu and the whole thing locked up. I immediately rebooted and that did not fix the issue, the taskbar(s) are there but completely uninteractable, even the clock is stopped. Right-clicking on the desktop doesn’t pull up a context menu to re-enter the edit mode, and the Alt+D, Alt+S shortcut I found online isn’t working either. Certain other global shortcuts seem to be broken too, but not all of them. How can I get out of this? Thanks in advance.
Pic:
Bottom half of the right edge is supposed to have an auto-hide taskbar.
Side-note can someone explain what the grouping widget is supposed to do? None of the widgets I put into it actually function. Kinda feeling it might have caused the crash as well.
System Info
Kernel: 5.10.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=b372f6d7-b299-4755-bfeb-f9b21ff8ab3c rw quiet apparmor=1
security=apparmor resume=UUID=e8af64ed-62a4-40f2-b41d-f3e0ce63bfe1
udev.log_priority=3 intel_iommu=on
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: X570 Phantom Gaming 4S
serial: <superuser required> UEFI: American Megatrends v: P2.60
date: 04/08/2020
RAM: total: 15.62 GiB used: 3.21 GiB (20.6%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2267 high: 3598 min/max: 2200/4335:4461:4208:4714:4588
boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores:
1: 2235 2: 1976 3: 2169 4: 2211 5: 2194 6: 2197 7: 3598 8: 2032 9: 2009
10: 2200 11: 2200 12: 2192 bogomips: 86439
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0c:00.0
chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Acer SB220Q serial: <filter>
built: 2020 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.40.0
5.10.109-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: snd_emu10k1 v: kernel bus-ID: 05:00.0 chip-ID: 1102:0008
class-ID: 0401
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: JMTek LLC. TKGOU PnP USB Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:4 chip-ID: 0c76:1467
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.109-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
