Hello! Here’s another post about front audio not working. I’ve read and tried a lot of things but none of them seem to work for me. Sound is working great through HDMI and headphones when connecting them in the back of my PC, but not in the front panel.
Sorry for bringing here a common topic… Hope you can help.
lspci -v | grep -A7 -i "audio"
26:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
Subsystem: ASRock Incorporation Device aaf0
Flags: bus master, fast devsel, latency 0, IRQ 99, IOMMU group 18
Memory at fce60000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Legacy Endpoint, MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
28:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Device cb85
Flags: bus master, fast devsel, latency 0, IRQ 100, IOMMU group 23
Memory at fc800000 (32-bit, non-prefetchable) [size=32K]
Capabilities: [64] Express Endpoint, MSI 00
pacmd list-sinks
2 sink(s) available.
index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9030
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Estéreo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 1999,82 ms
card: 0 <alsa_card.pci-0000_26_00.1>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "HDMI 3"
alsa.id = "HDMI 3"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "9"
alsa.card = "0"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xfce60000 irq 99"
device.bus_path = "pci-0000:26:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "aaf0"
device.product.name = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]"
device.string = "hdmi:0,3"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "hdmi-stereo-extra3"
device.profile.description = "Digital Stereo (HDMI 4)"
device.description = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 4)"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: yes)
properties:
device.product.name = "VX3211-2K"
active port: <hdmi-output-3>
* index: 14
flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY
state: RUNNING
suspend cause: (none)
priority: 9038
balance 0,00
volume steps: 65537
muted: no
current latency: 100,86 ms
max request: 17 KiB
max rewind: 17 KiB
monitor source: 23
Estéreo
used by: 1
linked by: 1
fixed latency: 100,14 ms
card: 1 <alsa_card.pci-0000_28_00.4>
module: 7
properties:
device.api = "alsa"
alsa.name = "ALC1220 Digital"
alsa.id = "ALC1220 Digital"
alsa.device = "1"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfc800000 irq 100"
device.bus_path = "pci-0000:28:00.4"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:28:00.4/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1487"
device.product.name = "Starship/Matisse HD Audio Controller"
device.string = "iec958:1"
device.buffering.buffer_size = "17664"
device.buffering.fragment_size = "2944"
device.access_mode = "mmap"
device.profile.name = "iec958-stereo"
device.profile.description = "Estéreo Digital (IEC958)"
device.description = "Starship/Matisse HD Audio Controller Estéreo Digital (IEC958)"
ports:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
active port: <iec958-stereo-output>
inxi -Fxz
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: GNOME 3.38.2 Distro: Manjaro Linux
Type: Desktop System: Micro-Star product: MS-7B85 v: 1.0 serial: <filter>
Mobo: Micro-Star model: B450 GAMING PRO CARBON MAX WIFI (MS-7B85) v: 1.0
serial: <filter> UEFI: American Megatrends v: 2.20 date: 06/10/2020
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
rev: 0 L2 cache: 3 MiB
bogomips: 86438
Speed: 2053 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2053 2: 3599 3: 2062 4: 2005 5: 2059 6: 3346 7: 1929 8: 1990 9: 2056
10: 3598 11: 2053 12: 3165
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: ASRock Phantom Gaming D driver: amdgpu v: kernel bus ID: 26:00.0
Display: wayland server: X.org 1.20.10 compositor: gnome-shell
driver: amdgpu note: n/a (using device driver) - try sudo/root
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.39.0
5.9.16-1-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.3.1 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: ASRock driver: snd_hda_intel v: kernel bus ID: 26:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 28:00.4
Sound Server: ALSA v: k5.9.16-1-MANJARO
System Temperatures: cpu: 43.8 C mobo: N/A gpu: amdgpu temp: 22.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1324
