Fresh Manjaro installation buggy after updates
Hi all,
after installing Manjaro, everything works fine. However, as soon as I run all the available updates, following symptoms appear:
  • the boot time after logging in takes a long time
  • after syspending the system, it does not wake up anymore
  • seemingly random things take a very long time to complete or hang completely, e.g. sudo desg or inxi --full --admin --filter --width (only running inxi works fine
I would be very happy about any suggestions of how to solve these problems.
Here are a few infos about my system.
inxi --full --admin --filter --width         QUIT ✘  25s 
  Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=2af16c25-4ce7-4283-9d8c-1834f2d55f95 rw quiet splash apparmor=1
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
  Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
    UEFI: American Megatrends v: 3057 date: 10/29/2024
  Info: model: AMD Ryzen 7 9700X bits: 64 type: MT MCP arch: N/A level: v4
    note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
    microcode: 0xB404023
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2991 min/max: 600/5581 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2991 2: 2991 3: 2991
    4: 2991 5: 2991 6: 2991 7: 2991 8: 2991 9: 2991 10: 2991 11: 2991 12: 2991
    13: 2991 14: 2991 15: 2991 16: 2991 bogomips: 121427
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
This is where the command stops.
systemd-analyze blame         INT ✘  1m 15s 
7min 30.811s fprintd.service
     30.755s upower.service
      5.347s plymouth-quit-wait.service
      2.302s systemd-fsck@dev-disk-by\x2duuid-47dca427\x2da852\x2d41f9\x2db636\x2d4dfbbfaa68df.service
      2.029s systemd-journald.service
       727ms NetworkManager.service
       258ms dev-nvme0n1p3.device
       146ms user@1000.service
       140ms apparmor.service
       124ms lvm2-monitor.service
       122ms systemd-tmpfiles-setup-dev-early.service
       120ms systemd-udev-trigger.service
        85ms udisks2.service
        71ms power-profiles-daemon.service
        67ms systemd-remount-fs.service
        66ms systemd-journal-flush.service
        65ms colord.service
        64ms systemd-tmpfiles-setup.service
        61ms systemd-userdbd.service
        60ms systemd-timesyncd.service
        54ms systemd-random-seed.service
        54ms systemd-journal-catalog-update.service
        54ms accounts-daemon.service
        52ms pamac-daemon.service
        51ms home.mount
        51ms systemd-update-utmp.service
        50ms systemd-timedated.service
        46ms ldconfig.service
        45ms modprobe@dm_mod.service
        45ms bluetooth.service
        45ms modprobe@loop.service
        42ms user-runtime-dir@1000.service
        41ms rtkit-daemon.service
        37ms systemd-fsck@dev-disk-by\x2duuid-9BC3\x2dF721.service
        36ms systemd-rfkill.service
        36ms boot-efi.mount
        32ms dev-disk-by\x2ddiskseq-3\x2dpart2.swap
        30ms ModemManager.service
        29ms tmp.mount
        28ms systemd-vconsole-setup.service
        24ms systemd-udevd.service
        22ms wpa_supplicant.service
        21ms polkit.service
        16ms plymouth-start.service
        15ms dbus-broker.service
        14ms systemd-logind.service
        14ms systemd-hostnamed.service
        13ms systemd-sysusers.service
        12ms plymouth-read-write.service
         9ms systemd-modules-load.service
         9ms cups.service
         7ms ufw.service
         7ms systemd-tmpfiles-setup-dev.service
         7ms dev-hugepages.mount
         7ms dev-mqueue.mount
         6ms sys-kernel-debug.mount
         6ms gdm.service
         6ms sys-kernel-tracing.mount
systemd-analyze critical-chain upower.service         ✔  29s 
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
upower.service +30.755s
└─basic.target @3.180s
  └─dbus-broker.service @3.164s +15ms
    └─dbus.socket @3.163s
      └─sysinit.target @3.161s
        └─systemd-timesyncd.service @3.101s +60ms
          └─systemd-tmpfiles-setup.service @3.035s +64ms
            └─run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount @3.083s
systemd-analyze critical-chain fprintd.service         ✔
fprintd.service +7min 30.811s
Running
sudo systemctl status run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount
takes a long time and returns
Unit run-credentials-systemdx2dtmpfilesx2dsetup.service.mount could not be found.
This is already the second time I installed Manjaro. The first time, everything looked very similar, except for the fprintd.service not taking so much time.
Thank you in advance for any recommendations!
EDIT:
After some more digging, it might have to do something with a faulty swap configuration?
sudo swapon --show
NAME           TYPE       SIZE USED PRIO
/dev/nvme0n1p2 partition 19,5G   0B   -2
Takes a long time to finally show the output.
Filesystem      Size  Used Avail Use% Mounted on
dev              16G     0   16G   0% /dev
run              16G  2,3M   16G   1% /run
efivarfs        128K   33K   91K  27% /sys/firmware/efi/efivars
/dev/nvme0n1p3  209G   11G  187G   6% /
tmpfs            16G     0   16G   0% /dev/shm
tmpfs           1,0M     0  1,0M   0% /run/credentials/systemd-journald.service
tmpfs           1,0M     0  1,0M   0% /run/credentials/systemd-udev-load-credentials.service
tmpfs           1,0M     0  1,0M   0% /run/credentials/systemd-tmpfiles-setup-dev-early.service
tmpfs           1,0M     0  1,0M   0% /run/credentials/systemd-sysctl.service
tmpfs           1,0M     0  1,0M   0% /run/credentials/systemd-sysusers.service
tmpfs           1,0M     0  1,0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
tmpfs           1,0M     0  1,0M   0% /run/credentials/systemd-vconsole-setup.service
tmpfs            16G   18M   16G   1% /tmp
/dev/nvme0n1p1  511M  292K  511M   1% /boot/efi
/dev/nvme1n1p1  1,8T  583G  1,2T  34% /home
tmpfs           1,0M     0  1,0M   0% /run/credentials/systemd-tmpfiles-setup.service
tmpfs           3,1G  308K  3,1G   1% /run/user/1000
I don’t think I have seen so many tmpfs filesystems on my old Manjaro installation.
And this is my /etc/fstab file
# <SNIP>
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=9BC3-F721                            /boot/efi      vfat    umask=0077 0 2
UUID=2af16c25-4ce7-4283-9d8c-1834f2d55f95 /              ext4    defaults,noatime 0 1
UUID=47dca427-a852-41f9-b636-4dfbbfaa68df /home          ext4    defaults,noatime 0 2
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
not likely its related to swap, but you never know…
post full inxi output:
inxi -zav7
and when hangs happen, post logs:
journalctl -b0 -p5 --no-pager
also try different kernels, the 6.12, and with the 6.1
Just mentioning fprintd is dbus access for fingerprint readers.
I dont think its included by default.
The /run/credentials/... tmpfs mounts are generic and come from
https://systemd.io/CREDENTIALS/
Thank you for your responses and sorry for my late reply.
I had to do a fresh installation and before applying any updates, I could switch the kernel to 6.6. With that kernel version everything works like a charm.
I will post inxi -zav7’s output anyway, as in the future I would like to upgrade the kernel and it would be great to know what causes all these problems.
Regarding the fprintd, that’s strange, I don’t have a fingerprint scanner and the system was completely fresh, with only the updates applied.
Now, with the older kernel version, I don’t have fprintd running anymore.
Thanks again, your help is very much appreciated!
  Kernel: 6.6.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=c255d4ef-bd1a-4ab4-b305-cebc074241c3 rw quiet splash apparmor=1
    base: Arch Linux
  System RAM: total: 32 GiB available: 30.5 GiB used: 4.51 GiB (14.8%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G Skill Intl
    part-no: F5-6000J3038F16G serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Speed (MHz): avg: 600 min/max: 600/5581 scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 600 2: 600 3: 600 4: 600 5: 600 6: 600 7: 600
    8: 600 9: 600 10: 600 11: 600 12: 600 13: 600 14: 600 15: 600 16: 600
    bogomips: 121419
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
    osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip
    vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xsaves
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Micro-Star MSI driver: amdgpu
    v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
    pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
    DVI-D-1, HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 36.0 C
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
    vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none empty: DP-3,HDMI-A-3 bus-ID: 0d:00.0
    chip-ID: 1002:13c0 class-ID: 0300 temp: 36.0 C
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: DP-2 model: BenQ SW2700 serial: <filter> built: 2018
    res: 2560x1440 dpi: 109 gamma: 1.2 size: 596x335mm (23.46x13.19")
    diag: 684mm (26.9") ratio: 16:9 modes: max: 2560x1440 min: 720x400
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 LLVM 18.1.8 DRM 3.54 6.6.63-1-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.3.295 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 24.2.8-arch1.1
    device-ID: 1002:67df surfaces: xcb,xlib,wayland device: 1
    type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 24.2.8-arch1.1 device-ID: 1002:13c0
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
    chip-ID: 0b05:1a52 class-ID: 0300
  API: ALSA v: k6.6.63-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:125c
    class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 09:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp9s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7
    chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 4.35 TiB used: 707.36 GiB (15.9%)
    model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
    fw-rev: 1B2QEXM7 temp: 30.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620361WD temp: 25.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX001-1CM164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 vendor: Verbatim model: STORE N GO
    size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: PMAP scheme: MBR
  ID-1: / raw-size: 212.85 GiB size: 208.45 GiB (97.93%)
    used: 30.99 GiB (14.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: c255d4ef-bd1a-4ab4-b305-cebc074241c3
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 9BC3-F721
  ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 676.38 GiB (36.9%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:5
    label: N/A uuid: 47dca427-a852-41f9-b636-4dfbbfaa68df
  ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 1297190d-4fa0-4dda-b6d5-4b021cd2a2a9
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: 66BC-BEF7
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 465.12 GiB fs: ntfs label: N/A
    uuid: 10DEC3C5DEC3A0F8
  ID-4: /dev/sda4 maj-min: 8:4 size: 538 MiB fs: ntfs label: N/A
    uuid: 42EA523CEA522D03
  ID-5: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ext4 label: N/A
    uuid: 7f6bb7a6-e2ac-4c43-9e2f-6760f3a830b1
  ID-6: /dev/sdd1 maj-min: 8:49 size: 3.82 GiB fs: iso9660
  ID-7: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 8ABA-389A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: ASUSTek USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-2: 1-7:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Hub-2: 1-8:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-9:5 info: Logitech G403 Prodigy Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c083 class-ID: 0300
    serial: <filter>
  Device-2: 1-10:6 info: Lemokey Link type: mouse,HID,keyboard
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 362d:d030 class-ID: 0301
  Device-3: 1-11:7 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Device-4: 1-12:8 info: Verbatim Flash Drive (StorenGo) type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 498mA chip-ID: 18a5:0243 class-ID: 0806
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 5-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Hub-8: 5-2.4:3 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 5-2.4.4:4 info: Future Devices USB <-> Serial Cable
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 0403:7a58 class-ID: 0000
  Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-10: 6-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-11: 6-2.4:3 info: Genesys Logic hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0616
  Device-1: 6-2.4.1:4 info: Realtek Card Reader type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0307 class-ID: 0806
    serial: <filter>
  Hub-12: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-13: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 39.4 C mobo: 28.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 37.0 C fan: 197 watts: 7.02 device: amdgpu
    temp: 36.0 C
  Processes: 415 Power: uptime: 22m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.18 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1504 libs: 451 tools: gnome-software,pamac
    pm: flatpak pkgs: 0 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.36
Please consider using btrfs and Timeshift or Snapper.
This has become the preferred method for resolving otherwise unsolvable problems after an update or configuration change or after a power outage.
Instead of doing a fresh install, you can then revert to the previous state at any time. This only takes a few seconds and you retain all previous settings of the installation.
:footprints:
Thanks for the tip. After my first installation I actually set up Timeshift, but the problems persisted even after reverting back to the state before the updates (I hope that doesn’t sound too crazy).
And the problems showed up immediately after I ran the first set of updates, so except for the installation itself, I didn’t waste too much time.
What you included is not the full output of that command. Please post the full output to help us help you.
Please see:
I had trouble with AMD CPU(Ryzen 9 5900HX) like random reboots and freezes.
I clean-installed Manjaro Sway but the problem persisted.
But installing AUR/disable-c6-systemd and enabling disable-c6.service has stabilized the system, no random reboots and freezes.
It wouldve been easier to just put the boot option
processor.max_cstate=5
If indeed thats the best workaround.
See all of
https://wiki.archlinux.org/title/Ryzen#Troubleshooting
