Fresh installation of Manjaro Xfce (Kernel 6.1, recent official ISO) mostly does not boot
Hi folks :slightly_smiling_face:,
After I did a fresh install of Manjaro (Sikaris) Xfce a few days ago due to renewal and restructuring of my SSDs, it gets stuck at the new Manjaro boot screen almost every time (see attachment). however the dots continue moving but nothing else happens. Sometimes a warm boot with Ctrl + Alt + Del helps.
I used the latest ISO from the Manjaro website. The installation itself worked smoothly, as I am used to from Manjaro, the UEFI is configured correctly, as well as the controllers of the SSDs.
Although this machine is a desktop PC, I performed the installation with LUKS full encryption. The first reboot after the installation worked as usual, on subsequent boots it did not continue booting or at least starting the Display Manager.
The problem does not occur when LUKS encryption is not installed, nor did it occur when I upgraded normally from previous installations. Also, only kernel 6.1 seems to be affected, with kernel 5.15 the system boots normally.
This machnie also has Windows 11 installed on a separate SSD, which I only sometimes use for testing purposes. Grub recognizes the Windows system and creates a menu entry accordingly, but that probably shouldn’t matter, it’s been that way since I started using this computer.
The mashine’s specs:
  Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=26f5bdc2-60fb-415a-a508-1f4f8ae73aad rw rootflags=subvol=@ quiet
    cryptdevice=UUID=927efa36-ca3c-4b07-8da8-48f10235f01a:luks-927efa36-ca3c-4b07-8da8-48f10235f01a
    root=/dev/mapper/luks-927efa36-ca3c-4b07-8da8-48f10235f01a splash
  Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: B.G0
    date: 07/26/2022
  RAM: total: 15.54 GiB used: 3.13 GiB (20.2%)
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
    desc: 2x16 MiB
  Speed (MHz): avg: 2308 high: 3598 min/max: 2200/4208 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3598 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2246 7: 2200 8: 2200 9: 2058 10: 2200 11: 2200
    12: 2200 bogomips: 86432
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Sapphire
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 2b:00.0 chip-ID: 1002:73ff
    class-ID: 0300
  Device-2: Mimaki Engineering HD WEB CAMERA type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 1-3.2:4 chip-ID: 0a50:6100
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: BenQ M2700HD serial: <filter>
    built: 2010 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    bus-ID: 1-3.2:4 chip-ID: 0a50:6100 gen: 4 speed: 16 GT/s class-ID: 0102
    lanes: 16 serial: <filter> bus-ID: 2b:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Mimaki Engineering HD WEB CAMERA type: USB
  Device-4: JMTek LLC. Hex type: USB driver: hid-generic,snd-usb-audio,usbhid
    bus-ID: 1-4:3 chip-ID: 0c76:16c8 class-ID: 0300
  Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.64 running: yes
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp37s0 state: down mac: <filter>
  Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
    bus-ID: 3-1:2 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
  IF: wlp45s0f3u1 state: up mac: <filter>
  Device-1: luks-927efa36-ca3c-4b07-8da8-48f10235f01a maj-min: 254:0
    type: LUKS dm: dm-0 size: 476.64 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 476.64 GiB
  Local Storage: total: 4.54 TiB used: 85.74 GiB (1.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Innovation IT model: N/A
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 9A0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8480G
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 62B3 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HUS724040ALE641
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: A5F0 scheme: GPT
  Optical-1: /dev/sr0 vendor: ASUS model: DRW-24D5MT rev: 2.00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
    used: 85.74 GiB (18.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-927efa36-ca3c-4b07-8da8-48f10235f01a label: N/A
    uuid: 26f5bdc2-60fb-415a-a508-1f4f8ae73aad
    used: 752 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 8B35-307B
  ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-4: /swap raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-5: /var/cache raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-6: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  ID-1: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
    uuid: 187B-4247
  ID-2: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sdb3 maj-min: 8:19 size: 446.41 GiB fs: ntfs label: Winroot
    uuid: 46707C15707C0E45
  ID-4: /dev/sdb4 maj-min: 8:20 size: 619 MiB fs: ntfs label: N/A
    uuid: 4432C26C32C26292
  ID-5: /dev/sdc1 maj-min: 8:33 size: 3.64 TiB fs: ntfs label: HDD
    uuid: 40C566FC10D41882
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Hub-2: 1-3:2 info: MStar USB HUB ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1b20:0501 class-ID: 0900
  Device-1: 1-3.2:4 info: Mimaki Engineering HD WEB CAMERA type: Video,Audio
    power: 500mA chip-ID: 0a50:6100 class-ID: 0102 serial: <filter>
  Device-2: 1-4:3 info: JMTek LLC. Hex type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 0c76:16c8 class-ID: 0300
  Device-3: 1-7:5 info: ROCCAT HORDE type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 1e7d:300c class-ID: 0300
  Device-4: 1-8:6 info: ROCCAT Burst Pro Air Dongle type: HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 1e7d:2ca6 class-ID: 0300 serial: <filter>
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Realtek RTL88x2bu [AC1200 Techkey] type: Network
    driver: rtl88x2bu interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
  Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 40.2 C mobo: N/A gpu: amdgpu temp: 33.0 C
    mem: 30.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 333 Uptime: 1h 44m wakeups: 0 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1132 libs: 344 tools: pamac pm: flatpak pkgs: 0
  Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
Hi @LinKostik,
Do you know how to chroot? Because I think getting logs from there would be splendid.
Yes, I know how chroot works, however, the affected system just started correctly for once. What logs do you need exactly?
Cool. So provide the output of:
journalctl --priority=4 --boot-1 --no-pager
Where:
  • --priority=4 limits the output to warning and errors only;
  • --boot=-1 limits the messages to the previous boot. Feel free to adjust this as necessary:
    -1 for the previous boot, -2 for the one before that, -3 for the one before that, and so on and so forth. Limit the messages to a failed boot please;
  • --no-pager provides output in a suitable format for providing here, on the forums.
If there is a problem, this command can also be run from within the chroot environment.
While I really don’t know if it’ll be me that van help, the info would be necessary for anyone trying to help.
Edit:
P.S.: Sounds like a failing drive, or even faulty RAM to me…
Once the system is started, it apparently runs flawlessly. Likewise, the Windows tinkering and test installation on the separate SSD works without crashing. Likewise, the error does not occur when installing without LUKS or when booting with kernel 5.15. Quite strange. Here is the output:
journalctl --priority=4 --boot=1 --no-pager
Feb 03 22:24:25 constantin-pc kernel:   #7  #8  #9 #10 #11
Feb 03 22:24:25 constantin-pc kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Feb 03 22:24:25 constantin-pc kernel: blacklist: Problem blacklisting hash (-13)
Feb 03 22:24:28 constantin-pc kernel: amdgpu 0000:2b:00.0: amdgpu: PSP runtime database doesn't exist
Feb 03 22:24:28 constantin-pc kernel: usb 1-4: Warning! Unlikely big volume range (=1008), cval->res is probably wrong.
Feb 03 22:24:28 constantin-pc kernel: usb 1-4: [49] FU [PCM Playback Volume] ch = 2, val = -16129/-1/16
Feb 03 22:24:28 constantin-pc kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
Feb 03 22:24:28 constantin-pc kernel: usb 1-4: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
Feb 03 22:24:28 constantin-pc kernel: usb 1-4: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
Feb 03 22:24:28 constantin-pc kernel: usb 1-3.2: 3:1: cannot get freq at ep 0x84
Feb 03 22:24:29 constantin-pc bluetoothd[941]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Feb 03 22:24:29 constantin-pc bluetoothd[941]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 03 22:24:29 constantin-pc bluetoothd[941]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Feb 03 22:24:29 constantin-pc bluetoothd[941]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 03 22:24:29 constantin-pc bluetoothd[941]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Feb 03 22:24:29 constantin-pc bluetoothd[941]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 03 22:24:30 constantin-pc kernel: amdgpu 0000:2b:00.0: amdgpu: SMU driver if version not matched
Feb 03 22:24:30 constantin-pc kernel: amdgpu: SRAT table not found
Feb 03 22:24:31 constantin-pc kernel: kauditd_printk_skb: 239 callbacks suppressed
Feb 03 22:24:37 constantin-pc lightdm[1331]: gkr-pam: unable to locate daemon control file
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: /home/constantinb/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: Configuration file /home/constantinb/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: Configuration file /home/constantinb/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: /home/constantinb/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: /home/constantinb/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: /home/constantinb/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: /home/constantinb/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: /home/constantinb/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Feb 03 22:24:37 constantin-pc systemd-xdg-autostart-generator[1351]: /home/constantinb/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Feb 03 22:24:38 constantin-pc kernel: usb 1-3.2: 3:1: cannot get freq at ep 0x84
Feb 03 22:24:38 constantin-pc xfconfd[1404]: Error parsing xfconf config file "/home/constantinb/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-desktop.xml": Fehler in Zeile 22, Zeichen 11: Element »channel« wurde geschlossen, aber das derzeit offene Element ist »property«
Feb 03 22:24:39 constantin-pc tumblerd[1486]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
Feb 03 22:24:39 constantin-pc xdg-desktop-por[1588]: Theme parser error: gtk.css:6084:3-36: No property named "-GtkTreeView-horizontal-separator"
Feb 03 22:24:39 constantin-pc xdg-desktop-por[1588]: Theme parser error: gtk.css:6085:3-34: No property named "-GtkTreeView-vertical-separator"
Feb 03 22:24:39 constantin-pc xdg-desktop-por[1588]: Theme parser error: gtk.css:6143:3-29: No property named "-GtkTreeView-expander-size"
Feb 03 22:24:39 constantin-pc xdg-desktop-por[1588]: Theme parser error: gtk.css:6176:3-37: No property named "-GraniteWidgetsPopOver-arrow-width"
Feb 03 22:24:39 constantin-pc xdg-desktop-por[1588]: Theme parser error: gtk.css:6177:3-38: No property named "-GraniteWidgetsPopOver-arrow-height"
Feb 03 22:24:39 constantin-pc xdg-desktop-por[1588]: Theme parser error: gtk.css:6178:3-39: No property named "-GraniteWidgetsPopOver-border-radius"
Feb 03 22:24:39 constantin-pc xdg-desktop-por[1588]: Theme parser error: gtk.css:6179:3-38: No property named "-GraniteWidgetsPopOver-border-width"
Feb 03 22:24:39 constantin-pc xdg-desktop-por[1588]: Theme parser error: gtk.css:6180:3-37: No property named "-GraniteWidgetsPopOver-shadow-size"
Feb 03 22:24:39 constantin-pc pipewire[1676]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Feb 03 22:24:39 constantin-pc pipewire[1676]: mod.rt: found session bus but no portal
Feb 03 22:24:39 constantin-pc pulseaudio[1442]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Feb 03 22:24:48 constantin-pc kernel: kauditd_printk_skb: 17 callbacks suppressed
Feb 03 22:28:11 constantin-pc kernel: kauditd_printk_skb: 12 callbacks suppressed
Feb 03 22:28:34 constantin-pc kernel: kauditd_printk_skb: 52 callbacks suppressed
Feb 03 22:29:02 constantin-pc kernel: kauditd_printk_skb: 12 callbacks suppressed
Feb 03 22:29:00 constantin-pc pulseaudio[1442]: ICE I/O error handler called
Feb 03 22:29:00 constantin-pc systemd[1344]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Feb 03 22:29:00 constantin-pc systemd-coredump[12831]: Failed to connect to coredump service: Connection refused
Feb 03 22:29:00 constantin-pc systemd[1344]: xdg-desktop-portal-gnome.service: Failed with result 'exit-code'.
Feb 03 22:29:00 constantin-pc systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Feb 03 22:29:00 constantin-pc systemd[1]: udisks2.service: Failed with result 'core-dump'.
Feb 03 22:29:03 constantin-pc pulseaudio[1442]: Error opening PCM device hw:3: Datei oder Verzeichnis nicht gefunden
Feb 03 22:29:03 constantin-pc pulseaudio[1442]: Error opening PCM device hw:2: Datei oder Verzeichnis nicht gefunden
Thanks for this!
I believe I read somewhere that LUKS and the kernel 6.x series is problematic, gives errors. And this would seem to confirm it.
I don’t know what the cause or the solution is, if any, since I don’t use LUKS.
Makes me love my ext4 partition all the more.
I also assume that this has to do with the LUKS encryption. Anyway, the machine is a desktop computer and my notebooks have Manjaro and Arch installed for a long time, so the problem does not occur there, despite LUKS, precisely because of the earlier installation with older kernel. As reported, it works there even after upgrade. I think I will just re-install the affected system without LUKS. Thank you for your help!!
We offer the install media also with other Kernels: Manjaro 22.0 Sikaris released
