Hello togheter
I’ve installed my new notebook (Tuxedo Pulse 14 Gen3) with manjaro xfce 23.1.4.
Because I want to use the notebook for business I’ve chosen LUKS for root and SWAP. When booting, after entering the key, the following messages appear:
error: attempt to read or write outside of disk cryptouuid/d21317...
Are you using grub2 to boot the system?
Check /etc/default/grub if GRUB_DEFAULT=saved is set and possibly disable that followed by update-grub to regenerate /boot/grub/grub.cfg.
Yes. I’ve grub2. After your change, the error message is the same.
Here my /etc/default/grub
# GRUB boot loader configuration
#GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet cryptdevice=UUID=d2131788-c1b8-46cd-ba6c-1617706c8483:luks-d2131788-c1b8-46cd-ba6c-1617706c8483 root=/dev/mapper/luks-d2131788-c1b8-46cd-ba6c-1617706c8483 splash resume=/dev/mapper/luks-5e256057-ece0-4835-b9f0-922b70eaa081 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
The error message is only after i enter the passphrase, can’t find anything about it in logs (dmes, journalctl).
[lucarelli@marco-tuxedopulse14gen3 Documents]$ ./checkpartitionsalignment.sh
ERR: no device specified
usage: checkpartitionsalignment.sh /dev/sdX
INFO: for your convenience, invoking 'lsblk'...
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 931.5G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
├─nvme0n1p2 259:2 0 899.1G 0 part
│ └─luks-d2131788-c1b8-46cd-ba6c-1617706c8483 254:0 0 899.1G 0 crypt /
└─nvme0n1p3 259:3 0 32.1G 0 part
└─luks-5e256057-ece0-4835-b9f0-922b70eaa081 254:1 0 32.1G 0 crypt [SWAP]
[lucarelli@marco-tuxedopulse14gen3 Documents]$ ./checkpartitionsalignment.sh /dev/nvme0n1p1
what does the parted utility say about /dev/nvme0n1p1 partitions alignment?
1 aligned
OK, seems to be all right, but...
let's check manually alignment to 4096B (necessary in case of SSD HDD):
Number Start End Size File system Flags
1 0 % 4096 = 0 314572799(+1) % 4096 = 0 314572800 % 4096 = 0
OK, everything divisible by 4096, lucky you! :)
[lucarelli@marco-tuxedopulse14gen3 Documents]$ ./checkpartitionsalignment.sh /dev/nvme0n1p2
Error: /dev/nvme0n1p2: unrecognised disk label
what does the parted utility say about /dev/nvme0n1p2 partitions alignment?
[lucarelli@marco-tuxedopulse14gen3 Documents]$ ./checkpartitionsalignment.sh /dev/nvme0n1p3
Error: /dev/nvme0n1p3: unrecognised disk label
what does the parted utility say about /dev/nvme0n1p3 partitions alignment?
what does the parted utility say about /dev/nvme0n1 partitions alignment?
1 aligned
2 aligned
3 not aligned: 1886186108s % 2048s != 0s
Number Start End Size File system Name Flags
1 2097152 % 4096 = 0 316669951(+1) % 4096 = 0 314572800 % 4096 = 0
2 316669952 % 4096 = 0 965727287295(+1) % 4096 = 2048 965410617344 % 4096 = 2048
3 965727287296 % 4096 = 2048 1000202273279(+1) % 4096 = 512 34474985984 % 4096 = 2560
WARNING: not divisible by 4096*:
* on color terminals printed in color
INFO: why this might be a problem? https://superuser.com/questions/393914/what-is-partition-alignment-and-why-whould-i-need-it
