Fresh install, unresponsive system (Kernel bug?)
I just did a fresh install on a system that was working 100%, but needed a cleanup after several tests.
I haven’t install almost anything that the default programs, I did the installation with the Open Source drivers and I am experience constant freezes, especially when accessing hard drives or opening applications. Even opening Terminal, freezes the system for around 10 seconds.
Tried with Kernels 6.6, 6.9, 6.10 and all have the same behavior.
Journal reports a Kernel bug…
inix -F
  Host: wizzy-am5-manjaro-kde Kernel: 6.10.5-1-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro Linux
  Type: Desktop System: Gigabyte product: X670E AORUS MASTER v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X670E AORUS MASTER serial: <superuser required>
    UEFI: American Megatrends LLC. v: F30 date: 05/22/2024
  Info: 16-core model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP MCM cache:
    L2: 16 MiB
  Speed (MHz): avg: 1009 min/max: 545/5759 cores: 1: 545 2: 545 3: 545
    4: 545 5: 3389 6: 545 7: 545 8: 545 9: 545 10: 545 11: 545 12: 545 13: 545
    14: 3598 15: 545 16: 545 17: 3501 18: 545 19: 545 20: 545 21: 545 22: 545
    23: 545 24: 545 25: 545 26: 545 27: 545 28: 545 29: 3600 30: 3485 31: 545
    32: 545
  Device-1: NVIDIA AD103 [GeForce RTX 4080] driver: nouveau v: kernel
  Device-2: AMD Raphael driver: amdgpu v: kernel
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    dri: nouveau,radeonsi gpu: nouveau,amdgpu resolution: 1: 3440x1440
    2: 1440x2560
  API: EGL v: 1.5 drivers: kms_swrast,nouveau,radeonsi,swrast
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 24.1.6-arch1.1
    renderer: NV193
  API: Vulkan v: 1.3.279 drivers: nvk,radv surfaces: xcb,xlib,wayland
  Device-1: NVIDIA driver: snd_hda_intel
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB
  Device-3: Creative Sound Blaster X5
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB
  Device-4: KTMicro USB_Audio_Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB
  API: ALSA v: k6.10.5-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.2.2 status: active
  Device-1: Intel 82576 Gigabit Network driver: igb
  IF: enp12s0f0 state: up speed: 1000 Mbps duplex: full
    mac: 98:b7:85:01:e3:3e
  Device-2: Intel 82576 Gigabit Network driver: igb
  IF: enp12s0f1 state: down mac: 98:b7:85:01:e3:3f
  Device-3: Intel Ethernet I225-V driver: igc
  IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: 74:56:3c:4b:74:7e
  Device-4: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
  IF: wlp14s0 state: down mac: 32:ee:84:c3:25:20
  Device-5: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
  IF: enp22s0u1u2u3 state: up speed: 1000 Mbps duplex: full
    mac: 34:1b:22:83:0f:1f
  Device-1: Intel AX210 Bluetooth driver: btusb type: USB
  Local Storage: total: 5.52 TiB used: 1.15 TiB (20.8%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SKC3000D2048G size: 1.86 TiB
  ID-2: /dev/nvme1n1 vendor: Seagate model: XPG GAMMIX S50 Lite
  ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO 500GB
  ID-4: /dev/sda vendor: Crucial model: CT2000BX500SSD1 size: 1.82 TiB
  ID-5: /dev/sdb vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
  ID-1: / size: 390.21 GiB used: 10.84 GiB (2.8%) fs: ext4 dev: /dev/nvme2n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
    dev: /dev/nvme2n1p1
  ID-1: swap-1 type: partition size: 67.94 GiB used: 37.5 MiB (0.1%)
    dev: /dev/nvme2n1p3
  System Temperatures: cpu: 41.4 C mobo: N/A gpu: amdgpu temp: 36.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 64 GiB note: est. available: 61.76 GiB used: 6.7 GiB (10.8%)
  Processes: 552 Uptime: 14m Shell: Zsh inxi: 3.3.35
journalctl --since ‘3 min ago’ (ran just after a freeze)
Aug 30 16:50:26 wizzy-am5-manjaro-kde systemd[1202]: app-org.kde.kate@680ecdf549f14ccf9f9eae3e6d8d9b1f.service: Consumed 784ms CPU time, 64.5M memory peak.
Aug 30 16:50:29 wizzy-am5-manjaro-kde kwin_wayland[1245]: This plugin does not support raise()
Aug 30 16:50:31 wizzy-am5-manjaro-kde systemd[1202]: Started Kate - Advanced Text Editor.
Aug 30 16:50:36 wizzy-am5-manjaro-kde kwin_wayland[1245]: kwin_wayland_drm: Pageflip timed out! This is a kernel bug
Aug 30 16:50:41 wizzy-am5-manjaro-kde kwin_wayland[1245]: kwin_wayland_drm: Pageflip timed out! This is a kernel bug
Aug 30 16:50:46 wizzy-am5-manjaro-kde kwin_wayland[1245]: kwin_wayland_drm: Pageflip timed out! This is a kernel bug
Aug 30 16:50:51 wizzy-am5-manjaro-kde kwin_wayland[1245]: kwin_wayland_drm: Pageflip timed out! This is a kernel bug
Aug 30 16:50:56 wizzy-am5-manjaro-kde kwin_wayland[1245]: kwin_wayland_drm: Pageflip timed out! This is a kernel bug
Aug 30 16:51:02 wizzy-am5-manjaro-kde plasmashell[1373]: error creating screencast "Could not find window id 0"
Aug 30 16:51:03 wizzy-am5-manjaro-kde systemd[1202]: Started Konsole - Terminal.
Aug 30 16:51:03 wizzy-am5-manjaro-kde plasmashell[1373]: error creating screencast "Could not find window id 0"
Aug 30 16:51:09 wizzy-am5-manjaro-kde kwin_wayland[1245]: kwin_wayland_drm: Pageflip timed out! This is a kernel bug
Aug 30 16:51:41 wizzy-am5-manjaro-kde rtkit-daemon[1278]: Supervising 9 threads of 6 processes of 1 users.
Aug 30 16:51:58 wizzy-am5-manjaro-kde rtkit-daemon[1278]: Supervising 9 threads of 6 processes of 1 users.
Aug 30 16:52:06 wizzy-am5-manjaro-kde rtkit-daemon[1278]: Supervising 9 threads of 6 processes of 1 users.
Aug 30 16:52:28 wizzy-am5-manjaro-kde baloo_file_extractor[1652]: "Error: Mismatch between font type and embedded font file"
Aug 30 16:52:33 wizzy-am5-manjaro-kde baloo_file_extractor[1652]: "Error: Can't get Fields array<0a>"
Aug 30 16:52:52 wizzy-am5-manjaro-kde baloo_file_extractor[1652]: "Error: not an ICC profile, invalid signature"
Aug 30 16:52:52 wizzy-am5-manjaro-kde baloo_file_extractor[1652]: "Error: read ICCBased color space profile error"
dmesg
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:11:00.0: ROM [mem 0xa1700000-0xa177ffff pref]: assigned
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:11:00.0: BAR 5 [mem 0xa1780000-0xa17803ff]: assigned
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:0d.0: PCI bridge to [bus 11]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:0d.0:   bridge window [mem 0xa1700000-0xa17fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:09:00.0: PCI bridge to [bus 0a-11]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:09:00.0:   bridge window [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:09:00.0:   bridge window [mem 0xa0000000-0xa17fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:08.0: PCI bridge to [bus 09-11]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:08.0:   bridge window [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:08.0:   bridge window [mem 0xa0000000-0xa17fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:12:00.0: BAR 0 [mem 0xa1800000-0xa1807fff 64bit]: assigned
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:0c.0: PCI bridge to [bus 12]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:0c.0:   bridge window [mem 0xa1800000-0xa18fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:13:00.0: ROM [mem 0xa1900000-0xa197ffff pref]: assigned
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:13:00.0: BAR 5 [mem 0xa1980000-0xa19803ff]: assigned
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:0d.0: PCI bridge to [bus 13]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:0d.0:   bridge window [mem 0xa1900000-0xa19fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:03:00.0: PCI bridge to [bus 04-13]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:03:00.0:   bridge window [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:03:00.0:   bridge window [mem 0xa0000000-0xa19fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:02.1: PCI bridge to [bus 03-13]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:02.1:   bridge window [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:02.1:   bridge window [mem 0xa0000000-0xa19fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:02.2: PCI bridge to [bus 14]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:02.2:   bridge window [mem 0xf6500000-0xf65fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.1: PCI bridge to [bus 15]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.1:   bridge window [io  0xd000-0xdfff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.1:   bridge window [mem 0xf6000000-0xf63fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.1:   bridge window [mem 0xfce0000000-0xfcf01fffff 64bit pref]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.3: PCI bridge to [bus 16]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.3:   bridge window [mem 0xf6400000-0xf64fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:00: resource 9 [mem 0xa0000000-0xf6ffffff window]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:00: resource 10 [mem 0x1060000000-0xfcffffffff window]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:01: resource 0 [io  0xf000-0xffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:01: resource 1 [mem 0xf3000000-0xf40fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:01: resource 2 [mem 0xfcc0000000-0xfcd1ffffff 64bit pref]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:02: resource 1 [mem 0xf6600000-0xf66fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:03: resource 1 [mem 0xa0000000-0xa19fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:04: resource 0 [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:04: resource 1 [mem 0xa0000000-0xa19fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:09: resource 0 [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:09: resource 1 [mem 0xa0000000-0xa17fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:0a: resource 0 [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:0a: resource 1 [mem 0xa0000000-0xa17fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:0c: resource 0 [io  0xe000-0xefff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:0c: resource 1 [mem 0xa0000000-0xa11fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:0d: resource 1 [mem 0xa1200000-0xa13fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:0e: resource 1 [mem 0xa1400000-0xa14fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:0f: resource 1 [mem 0xa1500000-0xa15fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:10: resource 1 [mem 0xa1600000-0xa16fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:11: resource 1 [mem 0xa1700000-0xa17fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:12: resource 1 [mem 0xa1800000-0xa18fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:13: resource 1 [mem 0xa1900000-0xa19fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:14: resource 1 [mem 0xf6500000-0xf65fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:15: resource 0 [io  0xd000-0xdfff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:15: resource 1 [mem 0xf6000000-0xf63fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:15: resource 2 [mem 0xfce0000000-0xfcf01fffff 64bit pref]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:16: resource 1 [mem 0xf6400000-0xf64fffff]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: PCI: CLS 64 bytes, default 64
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Trying to unpack rootfs image as initramfs...
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:01.0: Adding to iommu group 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:01.1: Adding to iommu group 1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:01.2: Adding to iommu group 2
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:02.0: Adding to iommu group 3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:02.1: Adding to iommu group 4
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:02.2: Adding to iommu group 5
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:03.0: Adding to iommu group 6
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:04.0: Adding to iommu group 7
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.0: Adding to iommu group 8
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.1: Adding to iommu group 9
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:08.3: Adding to iommu group 10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:14.0: Adding to iommu group 11
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:14.3: Adding to iommu group 11
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:18.0: Adding to iommu group 12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:18.1: Adding to iommu group 12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:18.2: Adding to iommu group 12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:18.3: Adding to iommu group 12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:18.4: Adding to iommu group 12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:18.5: Adding to iommu group 12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:18.6: Adding to iommu group 12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:00:18.7: Adding to iommu group 12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:01:00.0: Adding to iommu group 13
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:01:00.1: Adding to iommu group 13
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:02:00.0: Adding to iommu group 14
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:03:00.0: Adding to iommu group 15
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:00.0: Adding to iommu group 16
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:04.0: Adding to iommu group 17
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:05.0: Adding to iommu group 18
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:06.0: Adding to iommu group 19
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:08.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:0c.0: Adding to iommu group 21
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:04:0d.0: Adding to iommu group 22
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:09:00.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:00.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:04.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:06.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:07.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:08.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:0c.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0a:0d.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0c:00.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0c:00.1: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0d:00.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0e:00.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:0f:00.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:10:00.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:11:00.0: Adding to iommu group 20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:12:00.0: Adding to iommu group 21
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:13:00.0: Adding to iommu group 22
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:14:00.0: Adding to iommu group 23
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:15:00.0: Adding to iommu group 24
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:15:00.2: Adding to iommu group 25
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:15:00.3: Adding to iommu group 26
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:15:00.4: Adding to iommu group 27
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci 0000:16:00.0: Adding to iommu group 28
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: AMD-Vi: Extended features (0x246577efa2254afa, 0x0): PPR NX GT [5] IA GA PC GA_vAPIC
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: AMD-Vi: Interrupt remapping enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: AMD-Vi: Virtual APIC enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: software IO TLB: mapped [mem 0x000000006c5ca000-0x00000000705ca000] (64MB)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: LVT offset 0 assigned for vector 0x400
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: perf: AMD IBS detected (0x00000bff)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Initialise system trusted keyrings
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Key type blacklist registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: workingset: timestamp_bits=41 max_order=24 bucket_order=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: zbud: loaded
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: fuse: init (API version 7.40)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: integrity: Platform Keyring initialized
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: integrity: Machine keyring initialized
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Key type asymmetric registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Asymmetric key parser 'x509' registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: io scheduler mq-deadline registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: io scheduler kyber registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: io scheduler bfq registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pcieport 0000:00:01.1: PME: Signaling with IRQ 28
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pcieport 0000:00:01.2: PME: Signaling with IRQ 29
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pcieport 0000:00:02.1: PME: Signaling with IRQ 30
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pcieport 0000:00:02.2: PME: Signaling with IRQ 31
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pcieport 0000:00:08.1: PME: Signaling with IRQ 32
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pcieport 0000:00:08.3: PME: Signaling with IRQ 33
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: button: Power Button [PWRB]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: button: Power Button [PWRF]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1214
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Monitor-Mwait will be used to enter C-1 state
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C000: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C002: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C004: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C006: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C008: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C00A: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C00C: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C00E: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C010: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C012: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C014: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C016: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C018: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C01A: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C01C: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C01E: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C001: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C003: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C005: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C007: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C009: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C00B: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C00D: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C00F: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C011: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C013: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C015: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C017: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C019: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C01B: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C01D: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: \_SB_.PLTF.C01F: Found 3 idle states
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Non-volatile memory driver v1.3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Linux agpgart interface v0.103
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: bus type drm_connector registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Freeing initrd memory: 86800K
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:11:00.0: version 3.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:11:00.0: SSS flag set, parallel bus scan disabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:11:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:11:00.0: 4/6 ports implemented (port mask 0xf)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:11:00.0: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host0: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host1: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host2: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host3: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host4: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host5: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata1: SATA max UDMA/133 abar m1024@0xa1780000 port 0xa1780100 irq 47 lpm-pol 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata2: SATA max UDMA/133 abar m1024@0xa1780000 port 0xa1780180 irq 47 lpm-pol 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata3: SATA max UDMA/133 abar m1024@0xa1780000 port 0xa1780200 irq 47 lpm-pol 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata4: SATA max UDMA/133 abar m1024@0xa1780000 port 0xa1780280 irq 47 lpm-pol 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata5: DUMMY
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata6: DUMMY
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:13:00.0: SSS flag set, parallel bus scan disabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:13:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:13:00.0: 4/6 ports implemented (port mask 0xf)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:13:00.0: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host6: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host7: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host8: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host9: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host10: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi host11: ahci
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata7: SATA max UDMA/133 abar m1024@0xa1980000 port 0xa1980100 irq 48 lpm-pol 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata8: SATA max UDMA/133 abar m1024@0xa1980000 port 0xa1980180 irq 48 lpm-pol 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata9: SATA max UDMA/133 abar m1024@0xa1980000 port 0xa1980200 irq 48 lpm-pol 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata10: SATA max UDMA/133 abar m1024@0xa1980000 port 0xa1980280 irq 48 lpm-pol 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata11: DUMMY
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata12: DUMMY
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver usbserial_generic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbserial: USB Serial support registered for generic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: rtc_cmos 00:02: RTC can wake from S4
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: rtc_cmos 00:02: registered as rtc0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: rtc_cmos 00:02: setting system clock to 2024-08-30T15:42:26 UTC (1725032546)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ledtrig-cpu: registered to indicate activity on CPUs
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Console: switching to colour frame buffer device 128x48
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid: raw HID events driver (C) Jiri Kosina
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: drop_monitor: Initializing network drop monitor service
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: NET: Registered PF_INET6 protocol family
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Segment Routing with IPv6
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RPL Segment Routing with IPv6
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: In-situ OAM (IOAM) with IPv6
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: NET: Registered PF_PACKET protocol family
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: microcode: Current revision: 0x0a601206
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: resctrl: L3 allocation detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: resctrl: MB allocation detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: resctrl: SMBA allocation detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: resctrl: L3 monitoring detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: IPI shorthand broadcast: enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sched_clock: Marking stable (704684597, 410620)->(710376743, -5281526)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: registered taskstats version 1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Loading compiled-in X.509 certificates
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Loaded X.509 cert 'Build time autogenerated kernel key: a9ac224f14d59ca612f91c954ddf7dde9c247fbf'
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: zswap: loaded using pool zstd/zsmalloc
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Demotion targets for Node 0: null
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Key type .fscrypt registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Key type fscrypt-provisioning registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: PM:   Magic number: 4:543:741
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: workqueue writeback: hash matches
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RAS: Correctable Errors collector initialized.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata1: SATA link down (SStatus 0 SControl 330)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata7.00: LPM support broken, forcing max_power
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata7.00: ATA-10: CT2000BX500SSD1, M6CR061, max UDMA/133
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata7.00: 3907029168 sectors, multi 1: LBA48 NCQ (depth 32), AA
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata7.00: Features: Dev-Sleep
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata7.00: configured for UDMA/133
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ahci 0000:13:00.0: port does not support device sleep
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata2: SATA link down (SStatus 0 SControl 330)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata3: SATA link down (SStatus 0 SControl 330)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: tsc: Refined TSC clocksource calibration: 4199.928 MHz
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3c8a1d52032, max_idle_ns: 440795389779 ns
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: clocksource: Switched to clocksource tsc
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata4: SATA link down (SStatus 0 SControl 330)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi 6:0:0:0: Direct-Access     ATA      CT2000BX500SSD1  061  PQ: 0 ANSI: 5
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 6:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 6:0:0:0: [sda] Write Protect is off
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 6:0:0:0: [sda] Mode Sense: 00 3a 00 00
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 6:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 6:0:0:0: [sda] Preferred minimum I/O size 512 bytes
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  sda: sda1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 6:0:0:0: [sda] Attached SCSI disk
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata8: SATA link down (SStatus 0 SControl 300)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata9.00: supports DRM functions and may not be fully accessible
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata9.00: ATA-9: Samsung SSD 850 EVO 500GB, EMT02B6Q, max UDMA/133
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata9.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata9.00: Features: Trust Dev-Sleep NCQ-sndrcv
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata9.00: configured for UDMA/133
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: scsi 8:0:0:0: Direct-Access     ATA      Samsung SSD 850  2B6Q PQ: 0 ANSI: 5
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 8:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 8:0:0:0: [sdb] Write Protect is off
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 8:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 8:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 8:0:0:0: [sdb] Preferred minimum I/O size 512 bytes
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  sdb: sdb1 sdb2 sdb3 sdb4
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 8:0:0:0: [sdb] supports TCG Opal
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sd 8:0:0:0: [sdb] Attached SCSI disk
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ata10: SATA link down (SStatus 0 SControl 300)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: clk: Disabling unused clocks
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: PM: genpd: Disabling unused power domains
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Freeing unused decrypted memory: 2028K
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Freeing unused kernel image (initmem) memory: 3444K
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Write protecting the kernel read-only data: 32768k
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Freeing unused kernel image (rodata/data gap) memory: 816K
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: rodata_test: all tests were successful
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Run /init as init process
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:   with arguments:
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:     /init
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:   with environment:
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:     HOME=/
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:     TERM=linux
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:     BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pcieport 0000:0a:04.0: bridge has subordinate 0c but max busn 0d
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pci_bus 0000:04: Allocating resources
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: video: Video Device [VGA] (multi-head: yes  rom: no  post: no)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/LNXVIDEO:00/input/input2
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:10:00.0: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:10:00.0: new USB bus registered, assigned bus number 1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme 0000:02:00.0: platform quirk: setting simple suspend
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme0: pci function 0000:02:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme1: pci function 0000:0f:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme2: pci function 0000:14:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme0: D3 entry latency set to 10 seconds
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme2: missing or invalid SUBNQN field.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme2: D3 entry latency set to 8 seconds
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme0: 32/0/0 default/read/poll queues
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  nvme0n1: p1 p2
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme2: 32/0/0 default/read/poll queues
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  nvme2n1: p1 p2 p3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:10:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000200000010
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:10:00.0: new USB bus registered, assigned bus number 2
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:10:00.0: Host supports USB 3.2 Enhanced SuperSpeed
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb1: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb1: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb1: SerialNumber: 0000:10:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 1-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 1-0:1.0: 12 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb2: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb2: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb2: SerialNumber: 0000:10:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 2-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 2-0:1.0: 5 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:12:00.0: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:12:00.0: new USB bus registered, assigned bus number 3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:12:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000200000010
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:12:00.0: new USB bus registered, assigned bus number 4
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:12:00.0: Host supports USB 3.2 Enhanced SuperSpeed
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb3: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb3: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb3: SerialNumber: 0000:12:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-0:1.0: 12 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb4: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb4: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb4: SerialNumber: 0000:12:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 4-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 4-0:1.0: 5 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.3: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.3: new USB bus registered, assigned bus number 5
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.3: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000010
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.3: new USB bus registered, assigned bus number 6
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.3: Host supports USB 3.1 Enhanced SuperSpeed
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb5: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb5: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb5: SerialNumber: 0000:15:00.3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 5-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 5-0:1.0: 2 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb6: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb6: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb6: SerialNumber: 0000:15:00.3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 6-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 6-0:1.0: 2 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.4: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.4: new USB bus registered, assigned bus number 7
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.4: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000010
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.4: new USB bus registered, assigned bus number 8
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:15:00.4: Host supports USB 3.1 Enhanced SuperSpeed
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb7: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb7: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb7: SerialNumber: 0000:15:00.4
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 7-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 7-0:1.0: 2 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb8: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb8: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb8: SerialNumber: 0000:15:00.4
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 8-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 8-0:1.0: 2 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:16:00.0: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:16:00.0: new USB bus registered, assigned bus number 9
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:16:00.0: USB3 root hub has no ports
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:16:00.0: hcc params 0x0110ffc5 hci version 0x120 quirks 0x0000000200000010
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:16:00.0: new USB bus registered, assigned bus number 10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:16:00.0: Host supports USB 3.0 SuperSpeed
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb9: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb9: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb9: SerialNumber: 0000:16:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-0:1.0: 1 port detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb10: Product: xHCI Host Controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb10: Manufacturer: Linux 6.10.5-1-MANJARO xhci-hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb usb10: SerialNumber: 0000:16:00.0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 10-0:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 1-9: new full-speed USB device number 2 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1: new high-speed USB device number 2 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5: new high-speed USB device number 2 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1: Product: USB2.0 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 2.01
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5: Product: USB2.1 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5: Manufacturer: Generic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-5:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-5:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 1-9: New USB device found, idVendor=8087, idProduct=0032, bcdDevice= 0.00
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 4-5: new SuperSpeed USB device number 2 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 4-5: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 2.01
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 4-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 4-5: Product: USB3.2 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 4-5: Manufacturer: Generic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 4-5:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 4-5:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2: new high-speed USB device number 3 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2: Product: USB2.1 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2: Manufacturer: GenesysLogic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-6: new full-speed USB device number 3 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1: new high-speed USB device number 4 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5.4: new high-speed USB device number 4 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-6: New USB device found, idVendor=048d, idProduct=5702, bcdDevice= 0.01
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-6: Product: ITE Device
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-6: Manufacturer: ITE Tech. Inc.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1: Product: USB2.1 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1: Manufacturer: GenesysLogic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2.1:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2.1:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5.4: config 1 interface 2 altsetting 0 bulk endpoint 0x82 has invalid maxpacket 256
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5.4: New USB device found, idVendor=041e, idProduct=3265, bcdDevice=10.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=7
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5.4: Product: Sound Blaster X5
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5.4: Manufacturer: Creative Technology Ltd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-5.4: SerialNumber: 9BE3ADD73F9BB8AD
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2: new full-speed USB device number 5 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12: new high-speed USB device number 5 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2: New USB device found, idVendor=0b95, idProduct=6804, bcdDevice= 0.12
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2: Product: AX68004
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2: Manufacturer: ASIX Electronics
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2: SerialNumber: 00000003
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2.2:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2.2:1.0: 7 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1: new high-speed USB device number 6 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1: Product: USB2.1 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1: Manufacturer: GenesysLogic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.36
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12: Product: 4-Port USB 2.0 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12: Manufacturer: Generic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-12:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-12:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2.1.1:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2.1.1:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.3: new high-speed USB device number 7 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.3: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.3: Product: USB 10/100/1000 LAN
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.3: Manufacturer: Realtek
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.3: SerialNumber: 001000001
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.2: new high-speed USB device number 8 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.1: new high-speed USB device number 6 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.2: Product: USB2.1 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.2: Manufacturer: GenesysLogic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2.1.2:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 9-1.2.1.2:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.1: new full-speed USB device number 9 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.1: New USB device found, idVendor=feed, idProduct=1225, bcdDevice= 0.01
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.1: Product: KNIGHT
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.1: Manufacturer: X-BOWS
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.1: new full-speed USB device number 10 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.1: New USB device found, idVendor=1e7d, idProduct=afca, bcdDevice= 1.07
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.1: Product: ROCCAT Kone Air
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.1: Manufacturer: ROCCAT
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.1: SerialNumber: 000000000000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme1: 15/0/0 default/read/poll queues
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.4: new full-speed USB device number 11 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.4: Product: USB Serial
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nvme nvme1: Ignoring bogus Namespace Identifiers
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  nvme1n1: p1 p2
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.6: new full-speed USB device number 12 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver usbhid
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbhid: USB HID core driver
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.6: New USB device found, idVendor=0b95, idProduct=6801, bcdDevice= 0.02
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.6: Product: AX68004
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.6: Manufacturer: ASIX Electronics
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.2.6: SerialNumber: 00000003
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Console: switching to colour dummy device 80x25
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:048D:5702.0001: hiddev96,hidraw0: USB HID v1.12 Device [ITE Tech. Inc. ITE Device] on usb-0000:12:00.0-6/input0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: Creative Technology Ltd Sound Blaster X5 as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-5/3->
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.4: new full-speed USB device number 13 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ASIX Electronics AX68004 as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.6/9-1.2.2.6:1.0/0003:0>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:041E:3265.0002: input,hidraw1: USB HID v1.10 Device [Creative Technology Ltd Sound Blaster X5] on usb-0000:12:00.0-5.>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: X-BOWS KNIGHT as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.0/0003:FEED:1225.00>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:0B95:6801.0009: input,hidraw2: USB HID v1.10 Keyboard [ASIX Electronics AX68004] on usb-0000:16:00.0-1.2.2.6/input0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ASIX Electronics AX68004 as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.6/9-1.2.2.6:1.1/0003:0>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.4: New USB device found, idVendor=31b2, idProduct=0011, bcdDevice= 1.00
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.4: Product: USB_Audio_Device
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.4: Manufacturer: KTMicro
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.1.1.4: SerialNumber: 214b206000000178
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:FEED:1225.0003: input,hidraw3: USB HID v1.11 Keyboard [X-BOWS KNIGHT] on usb-0000:16:00.0-1.2.2.1/input0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ASIX Electronics AX68004 System Control as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.6/9-1.2>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: X-BOWS KNIGHT Mouse as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.1/0003:FEED:1>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ASIX Electronics AX68004 Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.6/9-1>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: X-BOWS KNIGHT System Control as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.1/00>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:0B95:6801.000A: input,hidraw4: USB HID v1.10 Mouse [ASIX Electronics AX68004] on usb-0000:16:00.0-1.2.2.6/input1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nouveau 0000:01:00.0: vgaarb: deactivate vga console
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nouveau 0000:01:00.0: NVIDIA AD103 (193000a1)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: KTMicro USB_Audio_Device as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.1/9-1.2.1.1/9-1.2.1.1.4/9-1.2.1.>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: X-BOWS KNIGHT Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.1/>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:31B2:0011.000B: input,hidraw5: USB HID v1.10 Device [KTMicro USB_Audio_Device] on usb-0000:16:00.0-1.2.1.1.4/input3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: X-BOWS KNIGHT Keyboard as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.1/0003:FEE>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:FEED:1225.0004: input,hidraw6: USB HID v1.11 Mouse [X-BOWS KNIGHT] on usb-0000:16:00.0-1.2.2.1/input1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ROCCAT ROCCAT Kone Air as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.1/9-1.2.1.1/9-1.2.1.1.1/9-1.2.1.1.>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:1E7D:AFCA.0005: input,hidraw7: USB HID v1.11 Mouse [ROCCAT ROCCAT Kone Air] on usb-0000:16:00.0-1.2.1.1.1/input0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ROCCAT ROCCAT Kone Air Keyboard as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.1/9-1.2.1.1/9-1.2.1.1.1/9>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:1E7D:AFCA.0006: input,hiddev97,hidraw8: USB HID v1.11 Keyboard [ROCCAT ROCCAT Kone Air] on usb-0000:16:00.0-1.2.1.1.1>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:1E7D:AFCA.0007: hiddev98,hidraw9: USB HID v1.11 Device [ROCCAT ROCCAT Kone Air] on usb-0000:16:00.0-1.2.1.1.1/input2
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:1E7D:AFCA.0008: hiddev99,hidraw10: USB HID v1.11 Device [ROCCAT ROCCAT Kone Air] on usb-0000:16:00.0-1.2.1.1.1/input3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nouveau 0000:01:00.0: bios: version 95.03.2b.00.b3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] amdgpu kernel modesetting enabled.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu: ATPX version 1, functions 0x00000000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu: Virtual CRAT table created for CPU
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu: Topology: Add CPU node
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: enabling device (0006 -> 0007)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] initializing kernel modesetting (IP DISCOVERY 0x1002:0x164E 0x1458:0xD000 0xC9).
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] register mmio base: 0xF6300000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] register mmio size: 524288
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 0 <nv_common>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 1 <gmc_v10_0>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 2 <navi10_ih>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 3 <psp>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 4 <smu>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 5 <dm>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 6 <gfx_v10_0>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 7 <sdma_v5_2>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 8 <vcn_v3_0>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] add ip block number 9 <jpeg_v3_0>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: Fetched VBIOS from VFCT
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu: ATOM BIOS: 102-RAPHAEL-008
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] VCN(0) decode is enabled in VM mode
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] VCN(0) encode is enabled in VM mode
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] JPEG decode is enabled in VM mode
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] Detected VRAM RAM=512M, BAR=512M
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] RAM width 128bits DDR5
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] amdgpu: 512M of VRAM memory ready
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] amdgpu: 31622M of GTT memory ready.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] GART: num cpu pages 262144, num gpu pages 262144
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F41FC00000).
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] Loading DMUB firmware via PSP: version=0x05001A00
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] use_doorbell being set to: [true]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] Found VCN firmware Version ENC: 1.31 DEC: 3 VEP: 0 Revision: 2
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: Will use PSP to load VCN firmware
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: reserve 0xa00000 from 0xf41e000000 for PSP TMR
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: RAS: optional ras ta ucode is not available
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: RAP: optional rap ta ucode is not available
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: SMU is initialized successfully!
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] Seamless boot condition check passed
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] Display Core v3.2.281 initialized on DCN 3.1.5
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] DP-HDMI FRL PCON supported
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] DMUB hardware initialized: version=0x05001A00
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ------------[ cut here ]------------
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: WARNING: CPU: 0 PID: 408 at drivers/gpu/drm/amd/amdgpu/../display/dc/link/protocols/link_dp_capability.c:1532 dp_retrieve_lttpr_cap+0x>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Modules linked in: hid_generic amdgpu(+) nouveau(+) drm_gpuvm amdxcp mxm_wmi i2c_algo_bit drm_ttm_helper ttm usbhid drm_suballoc_helpe>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: CPU: 0 PID: 408 Comm: (udev-worker) Not tainted 6.10.5-1-MANJARO #1 0876f2d0f51929af2c131e199a27e6238e0c6c5f
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Hardware name: Gigabyte Technology Co., Ltd. X670E AORUS MASTER/X670E AORUS MASTER, BIOS F30 05/22/2024
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RIP: 0010:dp_retrieve_lttpr_cap+0x121/0x1e0 [amdgpu]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Code: 48 21 c8 48 c1 e2 38 48 09 d0 48 89 85 98 02 00 00 f6 85 c4 02 00 00 02 74 42 e8 3a ed ff ff 84 c0 75 39 48 8b 85 d8 01 00 00 <0>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RSP: 0018:ffffa84fc0a2f5b0 EFLAGS: 00010246
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RAX: ffff96a39326b000 RBX: 0000000000000001 RCX: 00ffffffffffffff
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RDX: 0000000000000007 RSI: ffff96a382f180c8 RDI: 0000000000000000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RBP: ffff96a396f80000 R08: ffff96a3a4218020 R09: 00000000000f0000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000001
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: R13: ffff96a3aa000000 R14: 0000000000000000 R15: ffff96a396f80000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: FS:  00007d5259912880(0000) GS:ffff96b27dc00000(0000) knlGS:0000000000000000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: CR2: 000056b56738a018 CR3: 0000000117e02000 CR4: 0000000000f50ef0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: PKRU: 55555554
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Call Trace:
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  <TASK>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? dp_retrieve_lttpr_cap+0x121/0x1e0 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? __warn.cold+0x8e/0xe8
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? report_bug+0xff/0x140
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? handle_bug+0x3c/0x80
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? exc_invalid_op+0x17/0x70
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? asm_exc_invalid_op+0x1a/0x20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  retrieve_link_cap+0x79/0xd90 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  detect_link_and_local_sink+0xc08/0x10b0 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  link_detect+0x37/0x500 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? dal_gpio_destroy_irq+0x25/0x40 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? query_hpd_status+0x6e/0xa0 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  amdgpu_dm_init.isra.0+0xda6/0x1da0 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? __pfx_enable_assr+0x10/0x10 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? __pfx_update_config+0x10/0x10 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  dm_hw_init+0x12/0x30 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  amdgpu_device_init.cold+0x18fe/0x218d [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  amdgpu_driver_load_kms+0x19/0x70 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  amdgpu_pci_probe+0x18d/0x400 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  local_pci_probe+0x42/0x90
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  pci_device_probe+0xbd/0x290
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? sysfs_do_create_link_sd+0x6e/0xe0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  really_probe+0xdb/0x340
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? pm_runtime_barrier+0x54/0x90
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? __pfx___driver_attach+0x10/0x10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  __driver_probe_device+0x78/0x110
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  driver_probe_device+0x1f/0xa0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  __driver_attach+0xba/0x1c0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  bus_for_each_dev+0x8c/0xe0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  bus_add_driver+0x112/0x1f0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  driver_register+0x72/0xd0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? __pfx_amdgpu_init+0x10/0x10 [amdgpu 1a53af7ed5c8bd54d74910dba2709e006685d6f0]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  do_one_initcall+0x58/0x310
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  do_init_module+0x60/0x220
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  init_module_from_file+0x89/0xe0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  idempotent_init_module+0x121/0x320
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  __x64_sys_finit_module+0x5e/0xb0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  do_syscall_64+0x82/0x190
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? do_syscall_64+0x8e/0x190
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  ? __irq_exit_rcu+0x4a/0xb0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RIP: 0033:0x7d525a0e91fd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <4>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RSP: 002b:00007ffd1ef588d8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RAX: ffffffffffffffda RBX: 000056b5673225b0 RCX: 00007d525a0e91fd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RDX: 0000000000000004 RSI: 00007d525990c061 RDI: 000000000000002f
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RBP: 00007ffd1ef58990 R08: 0000000000000001 R09: 00007ffd1ef58920
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: R10: 0000000000000040 R11: 0000000000000246 R12: 00007d525990c061
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: R13: 0000000000020000 R14: 000056b56733efe0 R15: 000056b567345500
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel:  </TASK>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ---[ end trace 0000000000000000 ]---
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nouveau 0000:01:00.0: DRM: VRAM: 16376 MiB
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] kiq ring mec 2 pipe 1 q 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] JPEG decode initialized successfully.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu: Virtual CRAT table created for GPU
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu: Topology: Add dGPU node [0x164e:0x1002]
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kfd kfd: amdgpu: added device 1002:164e
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 2, active_cu_number 2
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: amdgpu: Runtime PM not available
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:15:00.0 on minor 1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] DSC precompute is not needed.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: [drm] Initialized nouveau 1.4.0 20120801 for 0000:01:00.0 on minor 0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.1: New USB device found, idVendor=046d, idProduct=082d, bcdDevice= 0.11
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.1: Product: HD Pro Webcam C920
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.1: SerialNumber: DBEEDE1F
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.3: new full-speed USB device number 7 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Console: switching to colour frame buffer device 160x45
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: fbcon: nouveaudrmfb (fb1) is primary device
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: fbcon: Remapping primary device, fb1, to tty 1-63
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: nouveau 0000:01:00.0: [drm] fb1: nouveaudrmfb frame buffer device
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.3: New USB device found, idVendor=1e7d, idProduct=2cb6, bcdDevice= 1.07
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.3: Product: ROCCAT Kone XP Air Dongle
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.3: Manufacturer: ROCCAT
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.3: SerialNumber: 682E4ED09317C911
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ROCCAT ROCCAT Kone XP Air Dongle as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-12/3-12.3/3->
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:1E7D:2CB6.000C: input,hidraw11: USB HID v1.10 Mouse [ROCCAT ROCCAT Kone XP Air Dongle] on usb-0000:12:00.0-12.3/input0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:1E7D:2CB6.000D: input,hidraw12: USB HID v1.10 Keyboard [ROCCAT ROCCAT Kone XP Air Dongle] on usb-0000:12:00.0-12.3/in>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ROCCAT ROCCAT Kone XP Air Dongle System Control as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: ROCCAT ROCCAT Kone XP Air Dongle Consumer Control as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/us>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hid-generic 0003:1E7D:2CB6.000E: input,hiddev100,hidraw13: USB HID v1.10 Device [ROCCAT ROCCAT Kone XP Air Dongle] on usb-0000:12:00.0>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4: new high-speed USB device number 8 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.36
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4: Product: 4-Port USB 2.0 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4: Manufacturer: Generic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-12.4:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-12.4:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: PM: Image not found (code -22)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: EXT4-fs (nvme2n1p2): mounted filesystem 1fbf1f0a-bb55-4da1-bd28-cde61de72e13 r/w with ordered data mode. Quota mode: none.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: systemd 256.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL >
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Detected architecture x86-64.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Hostname set to <wizzy-am5-manjaro-kde>.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4.1: new high-speed USB device number 9 using xhci_hcd
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: bpf-restrict-fs: LSM BPF program attached
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4.1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.39
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4.1: Product: USB2.1 Hub
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.4.1: Manufacturer: Generic
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-12.4.1:1.0: USB hub found
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: hub 3-12.4.1:1.0: 4 ports detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Queued start job for default target Graphical Interface.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/dirmngr.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/getty.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/gpg-agent.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/gpg-agent-browser.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/gpg-agent-extra.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/gpg-agent-ssh.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/keyboxd.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/modprobe.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice Slice /system/systemd-fsck.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Created slice User and Session Slice.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Expecting device /dev/disk/by-uuid/48abad2d-b25b-412e-9002-aee69ade5523...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Expecting device /dev/disk/by-uuid/54cbc6e5-f67c-4410-9d37-8f9df49aadb4...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Expecting device /dev/disk/by-uuid/96DC-382A...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Expecting device /dev/disk/by-uuid/e709cf55-e838-42dd-800f-7219b6b9e3a5...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Reached target Login Prompts.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Reached target Local Integrity Protected Volumes.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Reached target Slice Units.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Reached target Local Verity Protected Volumes.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on Device-mapper event daemon FIFOs.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on LVM2 poll daemon socket.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on Process Core Dump Socket.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on Credential Encryption/Decryption.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on Journal Socket (/dev/log).
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on Journal Sockets.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on udev Control Socket.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on udev Kernel Socket.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Listening on User Database Manager Socket.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounting Huge Pages File System...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounting POSIX Message Queue File System...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounting Kernel Debug File System...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounting Kernel Trace File System...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Create List of Static Device Nodes...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Load Kernel Module configfs...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Load Kernel Module dm_mod...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Load Kernel Module drm...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Load Kernel Module fuse...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Load Kernel Module loop...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/>
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Journal Service...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Load Kernel Modules...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Remount Root and Kernel File Systems...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Load udev Rules from Credentials...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Coldplug All udev Devices...
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: loop: module loaded
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Virtual Console Setup...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounted Huge Pages File System.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: device-mapper: uevent: version 1.0.3
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounted POSIX Message Queue File System.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounted Kernel Debug File System.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounted Kernel Trace File System.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Create List of Static Device Nodes.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: modprobe@configfs.service: Deactivated successfully.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Load Kernel Module configfs.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Load Kernel Module dm_mod.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd-journald[592]: Collecting audit messages is disabled.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: modprobe@drm.service: Deactivated successfully.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Load Kernel Module drm.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: modprobe@fuse.service: Deactivated successfully.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Load Kernel Module fuse.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: modprobe@loop.service: Deactivated successfully.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Load Kernel Module loop.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Load udev Rules from Credentials.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: i2c_dev: i2c /dev entries driver
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounting FUSE Control File System...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounting Kernel Configuration File System...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Load Kernel Modules.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting Apply Kernel Variables...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounted FUSE Control File System.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Mounted Kernel Configuration File System.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Virtual Console Setup.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Finished Apply Kernel Variables.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Starting User Database Manager...
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd[1]: Started Journal Service.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: EXT4-fs (nvme2n1p2): re-mounted 1fbf1f0a-bb55-4da1-bd28-cde61de72e13 r/w. Quota mode: none.
Aug 30 16:42:35 wizzy-am5-manjaro-kde systemd-journald[592]: Received client request to flush runtime journal.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: raid6: skipped pq benchmark and selected avx512x4
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: raid6: using avx512x2 recovery algorithm
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: xor: automatically using best checksumming function   avx
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: mousedev: PS/2 mouse device common for all mice
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: dca service started, version 1.12.1
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pps_core: LinuxPPS API ver. 1 registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: cdc_acm 3-5.4:1.1: ttyACM0: USB ACM device
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: PTP clock support registered
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver cdc_acm
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: mc: Linux media interface: v0.10
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Intel(R) 2.5G Ethernet Linux Driver
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Copyright(c) 2018 Intel Corporation.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igc 0000:0d:00.0: PCIe PTM not supported by PCIe bus/controller
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ccp 0000:15:00.2: enabling device (0000 -> 0002)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA>
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ACPI: OSL: Resource conflict; ACPI support missing from driver?
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb: Intel(R) Gigabit Ethernet Network Driver
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb: Copyright (c) 2007-2014 Intel Corporation.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.0: enabling device (0000 -> 0002)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ccp 0000:15:00.2: tee enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ccp 0000:15:00.2: psp enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: pps pps0: new PPS source ptp0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igc 0000:0d:00.0 (unnamed net_device) (uninitialized): PHC added
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igc 0000:0d:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igc 0000:0d:00.0 eth0: MAC: 74:56:3c:4b:74:7e
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Adding 71240140k swap on /dev/nvme2n1p3.  Priority:-2 extents:1 across:71240140k SS
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: Core ver 2.22
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: NET: Registered PF_BLUETOOTH protocol family
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: HCI device and connection manager initialized
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: HCI socket layer initialized
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: L2CAP socket layer initialized
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: SCO socket layer initialized
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: videodev: Linux video capture interface: v2.00
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: PC Speaker as /devices/platform/pcspkr/input/input22
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver ch341
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbserial: USB Serial support registered for ch341-uart
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: ch341 9-1.2.4:1.0: ch341-uart converter detected
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: gigabyte-wmi DEADBEEF-2001-0000-00A0-C90629100000: No temperature sensors usable
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Btrfs loaded, zoned=yes, fsverity=yes
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 9-1.2.4: ch341-uart converter now attached to ttyUSB0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igc 0000:0d:00.0 enp13s0: renamed from eth0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: cryptd: max_cpu_qlen set to 1000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbcore: registered new device driver r8152-cfgselector
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: AVX2 version of gcm_enc/dec engaged.
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Intel(R) Wireless WiFi driver for Linux
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: enabling device (0000 -> 0002)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: AES CTR mode by8 optimization enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: PCI dev 2725/0024, rev=0x420, rfid=0x10d000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usb 3-12.1: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver btusb
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: loaded firmware version 89.202a2f7b.0 ty-a0-gf-a0-89.ucode op_mode iwlmvm
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Firmware timestamp 2024.18 buildtype 1 build 81528
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Firmware SHA1: 0xa8bb3f39
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Boot Address: 0x100800
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Firmware Version: 120-18.24
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Firmware already loaded
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Fseq status: Success (0x00)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Fseq executed: 00.00.02.41
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: Bluetooth: hci0: Fseq BT Top: 00.00.02.41
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1/input23
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1/input24
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1/input25
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.0: added PHC on eth0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1/input26
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.0: Intel(R) Gigabit Ethernet Network Connection
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 98:b7:85:01:e3:3e
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.0: eth0: PBA No: E43709-003
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.0: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.1: enabling device (0000 -> 0002)
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver uvcvideo
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kvm_amd: TSC scaling supported
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kvm_amd: Nested Virtualization enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kvm_amd: Nested Paging enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kvm_amd: LBR virtualization supported
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kvm_amd: Virtual VMLOAD VMSAVE supported
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kvm_amd: Virtual GIF supported
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: kvm_amd: Virtual NMI enabled
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: WRT: Invalid buffer destination
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: intel_rapl_common: Found RAPL domain package
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: intel_rapl_common: Found RAPL domain core
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: AMD Address Translation Library initialized
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: WFPM_AUTH_KEY_0: 0x90
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: loaded PNVM version 35148b80
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: Detected RF GF, rfid=0x10d000
Aug 30 16:42:35 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0: base HW address: f0:d4:15:03:8e:cd
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: r8152-cfgselector 9-1.2.3: reset high-speed USB device number 7 using xhci_hcd
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.1: added PHC on eth1
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.1: Intel(R) Gigabit Ethernet Network Connection
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.1: eth1: (PCIe:2.5Gb/s:Width x1) 98:b7:85:01:e3:3f
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.1: eth1: PBA No: E43709-003
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.1: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.1 enp12s0f1: renamed from eth1
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: iwlwifi 0000:0e:00.0 wlp14s0: renamed from wlan0
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.0 enp12s0f0: renamed from eth0
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: EXT4-fs (nvme1n1p2): mounted filesystem 54cbc6e5-f67c-4410-9d37-8f9df49aadb4 r/w with ordered data mode. Quota mode: none.
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: r8152 9-1.2.3:1.0 eth0: v1.12.13
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver r8152
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver cdc_ether
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver r8153_ecm
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: r8152 9-1.2.3:1.0 enp22s0u1u2u3: renamed from eth0
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: EXT4-fs (sda1): mounted filesystem e709cf55-e838-42dd-800f-7219b6b9e3a5 r/w with ordered data mode. Quota mode: none.
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: Bluetooth: BNEP filters: protocol multicast
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: Bluetooth: BNEP socket layer initialized
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: Bluetooth: MGMT ver 1.22
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: NET: Registered PF_ALG protocol family
Aug 30 16:42:36 wizzy-am5-manjaro-kde kernel: NET: Registered PF_QIPCRTR protocol family
Aug 30 16:42:37 wizzy-am5-manjaro-kde kernel: usbcore: registered new interface driver snd-usb-audio
Aug 30 16:42:37 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Aug 30 16:42:38 wizzy-am5-manjaro-kde kernel: igb 0000:0c:00.0 enp12s0f0: igb: enp12s0f0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
Aug 30 16:42:39 wizzy-am5-manjaro-kde kernel: igc 0000:0d:00.0 enp13s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Aug 30 16:42:39 wizzy-am5-manjaro-kde kernel: r8152 9-1.2.3:1.0 enp22s0u1u2u3: carrier on
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: netfs: FS-Cache loaded
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: Key type dns_resolver registered
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: Key type cifs.spnego registered
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: Key type cifs.idmap registered
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: enabling forceuid mount option implicitly because uid= option is specified
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Wizzy/Desktop
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Wizzy/Documents
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Wizzy/Downloads
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Wizzy/Videos
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Download
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Public
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Family
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Cinema
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Music
Aug 30 16:42:44 wizzy-am5-manjaro-kde kernel: CIFS: Attempting to mount //192.168.50.41/Wizzy/Pictures
Aug 30 16:42:45 wizzy-am5-manjaro-kde kernel: nouveau 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
Aug 30 16:42:45 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
Aug 30 16:42:47 wizzy-am5-manjaro-kde kernel: block nvme0n1: No UUID available providing old NGUID
Aug 30 16:43:09 wizzy-am5-manjaro-kde kernel: usb 3-12.1: reset high-speed USB device number 6 using xhci_hcd
Aug 30 16:43:09 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Aug 30 16:43:10 wizzy-am5-manjaro-kde kernel: Bluetooth: RFCOMM TTY layer initialized
Aug 30 16:43:10 wizzy-am5-manjaro-kde kernel: Bluetooth: RFCOMM socket layer initialized
Aug 30 16:43:10 wizzy-am5-manjaro-kde kernel: Bluetooth: RFCOMM ver 1.11
Aug 30 16:43:12 wizzy-am5-manjaro-kde kernel: sched: RT throttling activated
Aug 30 16:43:13 wizzy-am5-manjaro-kde kernel: amdgpu 0000:15:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Aug 30 16:43:14 wizzy-am5-manjaro-kde kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Aug 30 16:56:25 wizzy-am5-manjaro-kde kernel: xhci_hcd 0000:10:00.0: xHC error in resume, USBSTS 0x401, Reinit
Aug 30 16:56:25 wizzy-am5-manjaro-kde kernel: usb usb1: root hub lost power or was reset
Aug 30 16:56:25 wizzy-am5-manjaro-kde kernel: usb usb2: root hub lost power or was reset
Aug 30 16:56:25 wizzy-am5-manjaro-kde kernel: usb 1-9: reset full-speed USB device number 2 using xhci_hcd
Aug 30 17:00:00 wizzy-am5-manjaro-kde kernel: BTRFS: device label Timeshift devid 1 transid 7358 /dev/nvme1n1p1 (259:8) scanned by mount (5891)
Aug 30 17:00:00 wizzy-am5-manjaro-kde kernel: BTRFS info (device nvme1n1p1): first mount of filesystem 3d42b7b8-cb3c-4663-8736-ce9796a1da69
Aug 30 17:00:00 wizzy-am5-manjaro-kde kernel: BTRFS info (device nvme1n1p1): using crc32c (crc32c-intel) checksum algorithm
Aug 30 17:00:00 wizzy-am5-manjaro-kde kernel: BTRFS info (device nvme1n1p1): using free-space-tree
Aug 30 17:00:00 wizzy-am5-manjaro-kde kernel: BTRFS info (device nvme1n1p1): last unmount of filesystem 3d42b7b8-cb3c-4663-8736-ce9796a1da69
In your case it’s most likely just “Baloo” doing its indexing, you can disable that. Search the subject in the forum and you will find more answers.
Also have a look here:
Thank you for your reply.
I have read that thread, I have made the changes, but it only made it less frequent, didn’t solve it.
The only BTRFS partition I have is the one I am using for Timeshift. I can delete it and make it ext4. Would that make big difference?
Also, Baloo is set to index only one physical partition, cause most of my personal folders are on NAS and not local, and it looks like it has finished (100% - paused).
Should I disabled it?
But you updated your system first and restarted before you did the additional changes?
So you using a BTRFS Timeshift Partition for ext4 root?
Is there are reason for that?
I mean less differend filesystems in use maybe less possible bugs… but if this the reason for your freezes… I wouldn’t count on it.
Have done multiple restarts since the initial setup.
I created the BTRFS partition for the Timeshift, couldn’t use it, I think because I need the root to be in BTRFS too, and then I am using RSYNC, on that partition. But this was the same setup yesterday where it was working fine…
What was your previous setup, same? I doubt.
My experience, I just made a fresh install a couple days ago with BTRFS, KDE, stable, minimal iso and LTS kernels.
I simply followed the defaults till finished installation.
For snapshotting I used Snapper, BTRFS assistant and another app (sorry can’t remember the name) to get snapshots in Grub to boot to earlier snapshots from Grub.
If you have lots of files locally Baloo can take some time to index.
My system is working perfectly without issues.
May I think of the “usual suspect” Nvidia?
I’d better leave this to the experts.
If I am in your place I would do a fresh install with BTRFS with defaults and snapper, … etc as I explained.
I hope this helps.
Do you experience the same in both X11 and Wayland?
I do suspect it’s Baloo related, though. Perhaps disable it completely for a few days, and see if that makes any marked difference.
Cheers.
I was thinking about, that you maybe changed to many stuff and delayed a restart. I also think its important after a fresh reinstall, just update your system and reboot before you keep changing stuff.
If you booted after that, multiple times… doesn’t cure it, when something went wrong, because of that.
Performance Tipps:
Using 3 NVMe drives does also means, you have a lot IRQ’s stolen around your system.
Specially when this drives each takes 2-4 IRQ Lanes… the Motherboard manual will probably show you which NVMe Slot steal IRQ’s from other devices, so that they are running with less efficiency.
But its total differend between all this Motherboard Vendor’s.
Additional performance tipp: Specially Samsung SSD’s are famous for the situation that the drives much faster, the emptier they are.
Golden rule is, never fill it above 80%, better below 60%.
Another performance tipp is, to enable Trim:
sudo systemctl start fstrim.timer
systemctl enable --now fstrim.timer
check if Trim enabled:
systemctl status fstrim.timer
It still could be, that your SSD’s wearlevel had reached a critical state… after a reinstall, but who really knows :man_shrugging:
systemctl status fstrim.timer         ✔
● fstrim.timer - Discard unused filesystem blocks once a week
     Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; enabled; preset: disabled)
     Active: active (waiting) since Sat 2024-08-31 15:15:43 IST; 8min ago
 Invocation: 3cf0138b5277488a8b6cbc983c24824d
    Trigger: Mon 2024-09-02 00:35:30 IST; 1 day 9h left
   Triggers: ● fstrim.service
       Docs: man:fstrim
Notice: journal has been rotated since unit was started, output may be incomplete.
As I said, I had the same hardware a day ago, was running fine, I just did so many tests with drivers, etc, that I wanted a clean setup. No problems before.
My steps are, install, update, create Timeshift Snapshot, and then start configuring and adding application. I noticed the freezes while trying to configure (mostly colours, icons, folder display, etc) and I haven’t done anything else, cause if it cannot be fixed I might try another fresh install.
The only thing I am not sure of, is if previous install was done with Open source, or Propriety drivers.
Turns out the problem was the “Open Source Drivers”.
I still had the issue after doing all the suggested solutions, so I decided to do another fresh install and select “Propriety Drivers”.
I had that before, but since my previous installation was months ago, I didn’t remember the case. Now I know.
Btw, this is a generic issue with AM5 and iGPU (probably when there is another dGPU installed), cause the main reason I had to do a clean install, is because I was doing lots of testing with drivers, etc., trying to solve this issue.
Uff my bad, i wasn’t checking that you still has Open Source Driver (nouveau) installed, of course the driver is terrible for a new nvidia 4080.
Nouveau should mainly used for older nvidia cards around the nvidia 10x0 Gen and below.
Could you provide more information on this for the benefit of others in the same predicament?
Perhaps a few links to wherever this generic issue (and hopefully solutions) might be documented.
Sure, but it is well known and to be honest, really surprised that about a year later nothing has been done to solve it.
My original post when I got my AM5 system.
Blog post with solutions (not working for me)
Wendell’s post with lots of people complaining
So, no actual bug reports;
but then, they might be difficult to identify in any case.
Thanks for that, nonetheless.
It will no doubt help someone along the way.
Cheers.
I did try to add a Kernel bug report, but they were asking so much information, I dropped it… It feels strange though, that people like Wendell, who have direct connections with Linux community, haven’t, or at least I don’t know.
