Hi,
Thought I would try KDE today, but it’s a hot mess…
I changed the mouse cursor, but it does not stay to what I changed it to?
I guess I should stay with Xfce?
Jesse
Hi,
Jesse
Hello,
Please don’t gaslight in the forum !
Is that on live environment from the installer media or you installed it? If you use your old home, from since you had another DE, then there might be some conflicts.
That is up to you. Each DE has their quirks and learning curve to get used with, grasp their way to do things.
Seems to have worked itself out, thanks!
Usually logging out and back in fixes it - certainly restarting apps which often ‘remember’ the cursor long after you changed it.
