Fresh install + Timeshift
Hello,
First I’ve searched and read some topics on the subject. Still confused.
I need to do a clean install of the latest Manjaro XFCE (previous installation is no more).
On this old laptop I have installed on sda1 MX Linux with it’s GRUB (also in sda1).
On sda2 I want install fresh Manjaro XFCE and I want it’s GRUB to manage the dual boot (like I had before). Visually I like the Manjaro GRUB.
The main thing:
I have a Timeshift snapshot from October from Manjaro in an external HDD.
Can I make a fresh installation of Manjaro and do a Timeshift in order to recover all my configs./settings?
What is the best procedure in order to have all my configs back?
This configs/settings (apart from the apps installed) are mainly cosmetic/visual.
What I want is both OS (MX Linux and Manjaro) to look the same (I had this on my previous Manjaro installation).
Since MX Linux is also XFCE would copying the /home folder over to Manjaro carry over the configs./setttings?
Thank you for any guidance
The default setting of timeshift is not to include home and settings. Check what is in your backup first.
I had that included when I made the TS.
Timeshift will recover your old system - unless you deliberately set it to include everything else, or (as you say) to only include your settings etc.
I used to do it this way, and whilst it’s possible to restore the system this way, it also imports all documents and images - possibly overwriting any work you did recently…
So now, my solution is:
  • Timeshift for system
  • Back-in-Time to backup home.
You can browse your Timeshift snapshots to see what is included there…
The reason I changed is that I had some issues as my snapshots got too unweildy, taking 20 minutes to scan before even getting started on a restoration and it got to the stage where the restoration failed.
Still, worth a try.
In my experience, it probably succeeds 96% of the time.
There are rare cases where it doesn’t work.
If it were me.
In this pattern, I would run it after taking backups other than timeshift (I won’t cry even if I fall).
dd / partclone.
