Hi Manjaro Team,
Happy new year!
This is some general feedback about a fresh install on a new SSD (870 EVO) inside a Thinkpad T60, 64Bit, Core 2 Duo T5500, Intel Graphics i915, 2GB RAM only. So maybe a little bit under-specced.
Manjaro KDE 23.1.2 Vulcan, Kernel 6.6, installed via minimal ISO on bootable USB.
Ideal goal: a minimalistic KDE only system, which is easy on HW.
Installation:
- After manual partition with GPT/BIOS, the installer froze at the warning popup about the unformatted 8GB partition. Pulling the plug and restarting solved the problem.
- Just by selecting Amsterdam as the city in the time zone dialogue, I ended up with Dutch language. Locale was expected to be set to British. Correcting language/locale was a total mess and needed several reboots/login-cycles.
- Graphics and especially external USB-Audio did work out of the box.
User Experience:
- This T60 is partially overwhelmed by the HW requirements, especially …
- RFE: for KDE there should be button for a minimum of animations, minimum stress on the GPU, it took ages to click through all the KDE Workspace / Window / Animation dialogues, that could be an option of the installer.
- “Add/Remove Software”, starting from “Minimum ISO”:
- Search is saturating the OS for a minute, RAM requirements are enormous! ;(
- Mirrors needed to be set manually to the local ones, that caused some extra delays
- Firefox is a hog,
- Manjaro Forums does not run in Konqueror or Falkon,
- RFE: KDE Falkon is not included in the minimum ISO; highly recommended.
- QTWebEngine is going haywire sometimes at 100% CPU for no apparent reason.
- "kioslave5 (Disk Sleep) " was blocking one single random file (which was not touched before) according to lsof, as a consequence of which was preventing an external USB-HDD from ejecting. The HDD was mounted and fully functional in Dolphin. Only a reboot could solve this.
In general the 23.1.2 Vulcan system on the new SSD is running a bit faster with less odd bugs, fe. the “old” and updated Konqueror was exhibiting previously.
HTH
