Hi,
As the title says, fresh install, no audio. I believe, from my travels through the forum, that the source of the problem is the wrong audio driver. I could be off track here as well of course…
From the system dump I have the snd_soc_skl installed but from similar posts there seems to be a better driver specific to my Apollo Lake chip set: snd_sof_pci_intel_apl.
2 questions,
- am I on the right track?
- if so, is it a relatively simple matter to update the driver?
Thanks,
Jeff
$ inxi -Fazy
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=0e5394e0-28d4-4f28-83e2-60e60ba2e240 rw quiet splash
resume=UUID=7907932d-3957-4470-945e-7e04f44bcb51 udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Google product: Babytiger v: rev5 serial: <filter>
Chassis: type: 9 serial: N/A
Mobo: Google model: Babytiger v: rev5 serial: <filter> UEFI: coreboot
v: MrChromebox-4.20.0 date: 05/15/2023
ID-1: BAT0 charge: 26.3 Wh (79.9%) condition: 32.9/37.9 Wh (86.7%) volts: 7.9
min: 7.9 model: AS1GTGE C523-50 type: Li-ion serial: <filter>
status: discharging cycles: 104
Info: model: Intel Celeron N3350 bits: 64 type: MCP arch: Goldmont level: v2
built: 2016 process: Intel 14nm family: 6 model-id: 0x5C (92) stepping: 9
microcode: 0x48
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 791 high: 796 min/max: 800/2400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 796 2: 786 bogomips: 4378
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 500 driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 00:02.0 chip-ID: 8086:5a85 class-ID: 0380
Device-2: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0408:3090
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e6 built: 2016 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
driver: snd_soc_skl v: kernel alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:5a98 class-ID: 0401
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0a2a
class-ID: e001
Local Storage: total: 58.31 GiB used: 11.03 GiB (18.9%)
ID-1: /dev/mmcblk1 maj-min: 179:0 vendor: Kingston model: TA2964
size: 58.31 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> fw-rev: 0x8 scheme: GPT
ID-1: / raw-size: 49.85 GiB size: 49.79 GiB (99.87%) used: 10.55 GiB (21.2%)
fs: xfs block-size: 512 B dev: /dev/mmcblk1p2 maj-min: 179:2
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/mmcblk1p1
maj-min: 179:1
ID-1: swap-1 type: partition size: 8.16 GiB used: 492.2 MiB (5.9%)
priority: -2 dev: /dev/mmcblk1p3 maj-min: 179:3
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 192 Uptime: 9h 25m wakeups: 32145 Memory: available: 3.71 GiB
used: 2.24 GiB (60.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1056 libs: 342 tools: pamac Shell: Zsh (su) v: 5.9 running-in: kitty
inxi: 3.3.27
