as new to manjaro and linux from windows, i need step by step commnd how to install driver for my laptop wifi driver…thanks in advance
- Get an internet connection by some other means (like ethernet).
- Install kernel headers for your kernel.
- Install
rtl8821ce-dkms-gitfrom AUR. - Reboot. Wifi should now work.
yes i find scratch from the internet step like you said…but seem doesnt work…btw im using wired connection from android phone
@djoe Have you searched the forum for your device? IIRC, there have been a number of threads about that particular one.
Hi! I’m a beginner too.
On this forum was an excellent thread for installing this and other wifi drivers too.
It was on the link:
Realtek WiFi Driver Installation (AUR) - Technical Issues and Assistance / Tutorials - Manjaro Linux Forum
Unfortunately is not accessible anymore…
I’ve bookmarked , but unfortunately it has gone.
If someone have a link which works I would be very helpful.
Links that I find are all broken
It is accessible if you add “archived” at the front:
https://archived.forum.manjaro.org/t/realtek-wifi-driver-installation-aur/85429/3
What happened to the old forum is explained here:
At what step does it fail, and can you post the error you get?
Thank you very very much
I can’t find it on AUR.
Did you try the link I posted in the second post of this thread? That’s the package in AUR.
Do I need to install kernal headers for that package?
Short and long asnwer: Yes.
Thanks so much.
Thanx a lot! It worked perfectly!!!
