I seem to be having issues with sound only with the onboard ALC1220. Sound coming from all other sources seem to be working fine. I am not sure what else to check or if its a kernel issue.
http://alsa-project.org/db/?f=2e77bcf0cbf857cb4e498a5022cc8434ecb2ff71
inxi -Fxzc0
Device-2: NVIDIA TU102 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: RODE Microphones RODE NT-USB type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.1:21
Device-4: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.4.1:11
Device-5: Yamaha AG06/AG03 type: USB driver: snd-usb-audio bus-ID: 1-4.1:23
Device-6: Corsair ST100 Headset Output type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-7.1:20
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Kernel: 5.10.42-1-MANJARO
DE: Gnome 3.38.4
Update 1:
So I found the issue it seems like my nvidia audio card was clashing with my on board sound.
/proc/asound/modules returned
0 snd_hda_intel
1 snd_hda_intel
2 snd_usb_audio
3 snd_usb_audio
4 snd_usb_audio
5 snd_usb_audio
after editing/creating /etc/modprobe.d/modprobe.conf
added the line:
options snd_hda_intel enable=1,0
took a guess with which one to enable and disable
and that seems to have sorted the issue but removed the option to select output via HDMI…
