Fresh install: black screen with cursor after logging in
Hi
I’m currently making an other attempt at switching from windows to linux. I’ve installed a fresh instance of Manjaro (KDE Plasma). After I’ve rebooted after the install I’m greeted with the usual login-screen from manjaro. After successfully logging in I’m greeted by a black screen with a functioning cursor and the welcome-app from Manjaro. Everything else (like taskbar, …) is missing.
I can use TTY (CTRL + ALT + F4). If I call startx from the TTY-Session the Desktop seems to start (but most apps like Add/Remove Software, nvidia-settings, …) just load a while and never open. Other things like Firefox or Settings work without any problems.
I’ve already tried reinstalling Manjaro but sadly the problem still occurs.
Hardware:
GPU: NVIDIA RTX 2080 Ti
CPU: AMD Ryzen 9 5900X
There is - literally - dozens upon dozens of similar topics - please use the search function - top right corner :mag:
I’ve already looked through them before posting this. Most of them are about having this problem after making some changes to the system. In my case it’s a fresh install and I haven’t changed anything. Sadly none of them resolved my issue or helped me to identify the cause of my problem. I can only offer to submit additional information about my system and some logs.
Output from inxi -Fazy:
  Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=d885d169-1613-414e-8b43-0e529100c8ae rw quiet splash
    resume=UUID=c65fd2e0-b7c3-4487-9011-b897c94677ad udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 4
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4408
    date: 10/27/2022
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2200 min/max: 2200/4950 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
    21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177682
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: ASUSTeK
    driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 0b:00.0 chip-ID: 10de:1e07 class-ID: 0300
  Display: server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3 compositors:
    1: kwin_wayland 2: kwin_x11 driver: X: loaded: nvidia gpu: nvidia
    display-ID: :2 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 80 s-size: 1626x457mm (64.02x17.99")
    s-diag: 1689mm (66.5") monitors: <missing: xrandr>
  Monitor-1: Unknown-1 size-res: N/A modes: 3840x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia wayland: drv: zink
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
    memory: 10.74 GiB
  API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 2080 Ti driver: nvidia v: 545.29.06 device-ID: 10de:1e07
    surfaces: xcb,xlib
  Device-1: NVIDIA TU102 High Definition Audio vendor: ASUSTeK
    bus-ID: 0b:00.1 chip-ID: 10de:10f7 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: FiiO K5 Pro driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-3:3 chip-ID: 2972:0047
    class-ID: fe01
  Device-4: Elgato Systems GmbH Wave:3 driver: snd-usb-audio type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-4:4 chip-ID: 0fd9:0070
  API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:12 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 11.37 TiB used: 9.25 GiB (0.1%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 970 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 44.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST10000VN0008-2JJ101
    size: 9.1 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: MBR
  ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%) used: 9.25 GiB (2.1%)
    fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
    dev: /dev/nvme1n1p3 maj-min: 259:8
  System Temperatures: cpu: 41.0 C mobo: 43.0 C
  Fan Speeds (rpm): N/A
  Processes: 421 Uptime: 20m wakeups: 0 Memory: total: 64 GiB note: est.
  available: 62.71 GiB used: 4.45 GiB (7.1%) Init: systemd v: 255
  Packages: pm: pacman pkgs: 1131 libs: 323 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Output from journalctl --boot=-1 --priority=3 --catalog --no-pager: http://sprunge.us/tO02Qq
Maybe try selecting X11 instead of Wayland. You should see the option at the bottom of the login screen if I remember correctly.
Thanks for the input. It works fine with X11, so it only seems to be a problem with wayland.
