I have file with content - part of ISO grub configuration - the interesting part is the last 8 lines ( the whole file is provided - in case the context matters )
for kk in /boot/vmlinu*-*64; do
if [ "$kk" != "/boot/vmlinu*-*64" ]; then
have64="true"
if cpuid -l; then
have_kernel="true"
else
have_kernel="false"
fi
fi
done
for kk in /boot/vmlinu*-*86; do
if [ "$kk" != "/boot/vmlinu*-*86" ]; then
have32="true"
have_kernel="true"
fi
done
if [ "${have_kernel}" != "true" ]; then
menuentry --class=find.none "NO SUITABLE KERNELS AVAILABLE" {echo $@ echo "There are no kernels suitable for this machine available."
echo ""
if ! cpuid -l; then
echo "This machine is NOT 64bit capable."
echo ""
fi
echo "There are no suitable kernels available"
if [ "${have64}" == "true" ]; then
echo ""
echo "It appears you are trying to boot a 64bit release on a 32bit machine"
echo "This cannot work!"
fi
echo ""
echo "Press Escape to return to the main menu"
sleep --interruptible 9999
menu_reload
else
title=""
for kopt in x86_64 $kopts misobasedir=manjaro misolabel=MANJARO_BOBRESCUEM_2314 quiet systemd.show_status=1 splash; do
if [ -n "$title" ] ; then
title="$title $kopt";
else
title="$kopt";
fi;
done
menuentry "Boot Manjaro Live Rescue" --class=Manjaro.x86_64 "$title" {# set arguments above with the editor
linux /boot/vmlinuz-$2 driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
initrd /boot/amd_ucode.img /boot/intel_ucode.img /boot/initramfs-x86_64.img
menuentry "Boot with proprietary drivers" --class=Manjaro.x86_64 "$title" {# set arguments above with the editor
linux /boot/vmlinuz-$2 driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
fi
have64="true"
if cpuid -l; then
have_kernel="true"
else
have_kernel="false"
fi
fi
done
have32="true"
have_kernel="true"
fi
done
echo ""
if ! cpuid -l; then
echo ""
fi
echo ""
fi
echo ""
menu_reload
else
title=""
else
title="$kopt";
fi;
done
menuentry "Boot with open source drivers" --class=Manjaro.x86_64 "$title" {# set arguments above with the editor
fi
mod-iso-menu.sh
#!/usr/bin/env bash
usage(){
echo "usage: sudo mod-iso-menu.sh <profile> 'Boot Live ISO'"
exit 1
if [[ ${EUID} != 0 || -z "$1" || -z "$2" ]]; then
usage
fi
LIBDIR="/usr/lib/manjaro-tools/"
USERCONFDIR="/home/fh/.config/manjaro-tools"
user_cfg="${USERCONFDIR}/manjaro-tools.conf"
# shellcheck source=/dev/null
[[ -r ${LIBDIR}/util-msg.sh ]] && source ${LIBDIR}/util-msg.sh
import ${LIBDIR}/util.sh
chroots_dir=
load_config ${user_cfg}
kernels_cfg="${chroots_dir}/buildiso/${1}/iso/boot/grub/kernels.cfg"
if ! [[ -d "${chroots_dir}/buildiso/${1}" ]]; then
echo "'${1}' has not been build"
exit 1
fi
msg "Modifying live '$1' bootloader menu '$2'"
# change entry for opensource gpu driver
info "Change menu name to ${2}"
sed -i "s/Boot with open source drivers/${2}/g" "${kernels_cfg}"
# remove entry for proprietary gpu drivers
info "Remove proprietary driver menu"
sed -i '/menuentry \"Boot with proprietary drivers\"/,+3d' "${kernels_cfg}"
msg "Modified '$1' with '$2'"
The purpose is to modify my ISO removing one menu and altering another.
I have this script - which takes two arguments - the iso profile to modify and the string to be used when modifying the menu.
The sed -i argument is removed for debugging purpose.
The first part work as intended - removing the menu providing proprietary drivers
sed '/menuentry \"Boot with proprietary drivers\"/,+3d' "${kernels_cfg}"
I use double quotes because I want the second argument to be expanded - and it does expand - but sed does not edit the file and I cannot figure out why
echo sed "s/Boot with open source drivers/${2}/g" "${kernels_cfg}"
if I run grep on the file - I get the line
$ grep -e 'Boot with open source drivers' <buildroot>/buildiso/<profile>/iso/boot/grub/kernels.cfg
