Computer Info: HP 15-ab034tx - i7 5500U 2.4GHz - 8GB RAM - 1TB HDD - Nvidia 940m 2GB Dedicated Graphics
uname -a: Linux hackesta 5.8.16-2-MANJARO #1 SMP PREEMPT Mon Oct 19 11:33:03 UTC 2020 x86_64 GNU/Linux
Problem: Since the past few days, I am getting frequent kernel panics, after 10-15 minutes of use. I used journalctl
to find the cause and libpython3.8.so.1.0
is the most common error before the panic. (I will attach a couple of the outputs at the end).
I ran memtest86+
twice. One three days ago (3 passes, 0 errors) and one today (5 passes, 0 errors). I have no idea about what can cause this.
I didn’t try kdump yet as I might need to compile a kernel for that, and that is something I haven’t done yet.
I hope this will be resolved here.
journalctl output 1
journalctl output 2
can you return
inxi -Fza --no-host
can you install theses kernels
sudo mhwd-kernel -i linux54
sudo mhwd-kernel -i linux419
then reboot , press Esc to see grub and in advanced select other kernel
Here’s the output to inxi -FZA --no-host
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=af174167-9ca5-453e-8249-4830583ba2d5 rw quiet
resume=UUID=8be806bf-2b77-49a7-8713-fd2da86f23de
Desktop: i3 4.18.2 info: polybar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP Pavilion Notebook v: Type1ProductConfigId serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 8096 v: 89.33 serial: <filter> UEFI [Legacy]: Insyde v: F.91 date: 08/20/2019
Battery: ID-1: BAT0 charge: 25.1 Wh condition: 25.1/25.1 Wh (100%) volts: 16.8/14.8 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter> charge: 55% (should be ignored)
CPU: Topology: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP arch: Broadwell family: 6 model-id: 3D (61)
stepping: 4 microcode: 2F L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19162
Speed: 2893 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 2893 2: 2913 3: 2893 4: 2916
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1616
Device-2: NVIDIA GM108M [GeForce 940M] vendor: Hewlett-Packard driver: N/A alternate: nouveau bus ID: 0a:00.0
chip ID: 10de:1347
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo bus ID: 1-3:3 chip ID: 04f2:b50d serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: compton driver: intel FAILED: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2") s-diag: 1052mm (41.4")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:9ca0
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8723be v: kernel
port: 5000 bus ID: 08:00.0 chip ID: 10ec:b723
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
bus ID: 09:00.0 chip ID: 10ec:8136
Drives: Local Storage: total: 2.73 TiB used: 185.43 GiB (6.6%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-60JC3T0 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-2: /dev/sdb type: USB vendor: Western Digital model: WD Elements 25A2 size: 1.82 TiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: 1021 scheme: GPT
Partition: ID-1: / raw size: 242.96 GiB size: 238.15 GiB (98.02%) used: 185.43 GiB (77.9%) fs: ext4 dev: /dev/sda9
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 6.07 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda8
Sensors: System Temperatures: cpu: 66.0 C mobo: N/A
Info: Processes: 248 Uptime: 52m Memory: 7.71 GiB used: 1.56 GiB (20.3%) Init: systemd v: 246
Compilers: gcc: 10.2.0
clang: 10.0.1 Packages: pacman: 1871 lib: 472 flatpak: 0 Shell: Zsh v: 5.8 running in: guake inxi: 3.1.05
Which kernel should I boot into?
Edit:
I have booted into the 5.4 Kernel. I will update if I face any more issues.
Meanwhile, I have a few additional questions:
- Why the
linux54
and linux419
kernels? What’s special about them?
- If
linux54
works for me, how do I make it the default and prevent it from changing during pacman -Syu
- If
linux54
works, what’s wrong with the one I currently have?
you have mixed MBR and GPT disks
you have installed UEFI[Legacy]
you have to do a fsck on your disk sda2
you have errors on wifi
other error with
sudo journalctl -b0 -p4
1.Mixed Disks: sda is my internal hard disk (MBR), and sdb is an external HDD (connected over USB).
2. Is that an issue?
3. Ok I will. It is a 260MB FAT32 partition created by Windows during it’s installation.
4. Hmm. I will look into it as well.
Do you need the output of the command? One of the important things I notice is that I am missing bbswitch
for some reason.
Also, I am on linux54 since 3 hours and it hasn’t had any issues
