Frequent GPU hangs with Kernel 6.5 (AMD)
Hey,
from Kernel 6.5 on, I get frequent GPU hangs on my AMD iGPU. It especially happens during high CPU loads. I’m also using KDE-Wayland, no idea if this might be related.
Does anyone have similar issues, know where I can report this, or how to even bisect this maybe?
My System
inxi -Fzzc0
  Kernel: 6.4.16-1-MANJARO arch: x86_64 bits: 64 Desktop: KDE Plasma v: 5.27.8
    Distro: Manjaro Linux
  Type: Convertible System: LENOVO product: 82RA v: IdeaPad Flex 5 16ALC7
    serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
    serial: <superuser required> UEFI: LENOVO v: JCCN36WW date: 06/09/2023
  ID-1: BAT0 charge: 52.5 Wh (98.1%) condition: 53.5/52.5 Wh (102.0%)
  Info: 6-core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
    type: MT MCP cache: L2: 3 MiB
  Speed (MHz): avg: 1664 min/max: 1400/4056 cores: 1: 1400 2: 1399 3: 1397
    4: 2077 5: 1400 6: 3111 7: 1400 8: 1400 9: 2100 10: 1455 11: 1433 12: 1400
  Device-1: AMD Lucienne driver: amdgpu v: kernel
  Device-2: Bison Integrated Camera driver: uvcvideo type: USB
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
    dri: radeonsi gpu: amdgpu resolution: 1707x1067
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.7-1 renderer: AMD
    Radeon Graphics (renoir LLVM 16.0.6 DRM 3.52 6.4.16-1-MANJARO)
  API: Vulkan v: 1.3.264 drivers: radv surfaces: xcb,xlib,wayland
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
  Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
  API: ALSA v: k6.4.16-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 0.3.80 status: active
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb
    type: USB
  Local Storage: total: 2.29 TiB used: 1.06 TiB (46.6%)
  ID-1: /dev/nvme0n1 vendor: Lenovo model: UMIS RPJTJ512MGE1QDY
  ID-2: /dev/sda vendor: Seagate model: FireCuda HDD size: 1.82 TiB
    type: USB
  ID-1: / size: 250.92 GiB used: 209.38 GiB (83.4%) fs: ext4
    dev: /dev/nvme0n1p5
  ID-2: /boot/efi size: 256 MiB used: 38.2 MiB (14.9%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: file size: 8 GiB used: 36.2 MiB (0.4%) file: /swapfile
  System Temperatures: cpu: 49.8 C mobo: N/A gpu: amdgpu temp: 45.0 C
  Fan Speeds (rpm): N/A
  Processes: 303 Uptime: 1h 5m Memory: total: 16 GiB note: est.
  available: 14.97 GiB used: 8.51 GiB (56.9%) Shell: Bash inxi: 3.3.30
But you use kernel 6.4:
  • Check journalctl $ journalctl -b err -b while GPU hang without reboot.
  • If you can reproduce this issue on Kernel 6.5, try to switch to 6.1 LTS.
Yes I’m currently using 6.4 because 6.5 is basically unusable. I’ll try to get a log soon’ish.
You could try switching to X11 (irrespective of why you chose Wayland) and then upgrade your kernel to 6.5 – 6.5 may be tolerable in X11. Otherwise, the current LTS kernel 6.1 should be sufficient for general computing tasks.
My take:- Unless there’s a specific need for a certain 6.5 kernel capability, leave the realm of bleeding-edge computing to super-enthusiasts and super-ego’s. Cheers.
So I managed to get this log, I hope it shows relevant information.
Okt 10 13:15:54 bernhard-82ra kernel: Linux version 6.5.5-1-MANJARO (builduser@fv-az204-561) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Sat Sep 23 12:48:15 UTC 2023
Okt 10 13:15:54 bernhard-82ra kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64 root=UUID=a9d48c06-1874-4312-bea0-70a2c1ae4c53 rw udev.log_priority=3
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-provided physical RAM map:
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009bfffff] usable
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x0000000009c00000-0x0000000009da0fff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x0000000009da1000-0x0000000009efffff] usable
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x0000000009f00000-0x0000000009f0efff] ACPI NVS
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x0000000009f0f000-0x00000000c6afcfff] usable
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000c6afd000-0x00000000c6cfcfff] type 20
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000c6cfd000-0x00000000cacfcfff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000cacfd000-0x00000000ccd7dfff] ACPI NVS
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000ccd7e000-0x00000000ccdfdfff] ACPI data
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000ccdfe000-0x00000000cdffffff] usable
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000ce000000-0x00000000cfffffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000fdc00000-0x00000000fdcfffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe0fffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x0000000100000000-0x000000040e2fffff] usable
Okt 10 13:15:54 bernhard-82ra kernel: BIOS-e820: [mem 0x000000040e300000-0x000000042fffffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: NX (Execute Disable) protection: active
Okt 10 13:15:54 bernhard-82ra kernel: efi: EFI v2.7 by Phoenix Technologies Ltd.
Okt 10 13:15:54 bernhard-82ra kernel: efi: ACPI=0xccdfd000 ACPI 2.0=0xccdfd014 SMBIOS=0xc8bd3000 SMBIOS 3.0=0xc8bc6000 TPMFinalLog=0xcbc20000 MEMATTR=0xc3f01018 ESRT=0xc3ee6c18
Okt 10 13:15:54 bernhard-82ra kernel: efi: Remove mem72: MMIO range=[0xfdc00000-0xfdcfffff] (1MB) from e820 map
Okt 10 13:15:54 bernhard-82ra kernel: e820: remove [mem 0xfdc00000-0xfdcfffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: efi: Remove mem73: MMIO range=[0xfe000000-0xfe0fffff] (1MB) from e820 map
Okt 10 13:15:54 bernhard-82ra kernel: e820: remove [mem 0xfe000000-0xfe0fffff] reserved
Okt 10 13:15:54 bernhard-82ra kernel: efi: Not removing mem74: MMIO range=[0xfed80000-0xfed80fff] (4KB) from e820 map
Okt 10 13:15:54 bernhard-82ra kernel: SMBIOS 3.3.0 present.
Okt 10 13:15:54 bernhard-82ra kernel: DMI: LENOVO 82RA/LNVNB161216, BIOS JCCN36WW 06/09/2023
Okt 10 13:15:54 bernhard-82ra kernel: tsc: Fast TSC calibration using PIT
Okt 10 13:15:54 bernhard-82ra kernel: tsc: Detected 2095.984 MHz processor
Okt 10 13:15:54 bernhard-82ra kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Okt 10 13:15:54 bernhard-82ra kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Okt 10 13:15:54 bernhard-82ra kernel: last_pfn = 0x40e300 max_arch_pfn = 0x400000000
Okt 10 13:15:54 bernhard-82ra kernel: MTRR map: 6 entries (3 fixed + 3 variable; max 20), built from 9 variable MTRRs
Okt 10 13:15:54 bernhard-82ra kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Okt 10 13:15:54 bernhard-82ra kernel: last_pfn = 0xce000 max_arch_pfn = 0x400000000
Okt 10 13:15:54 bernhard-82ra kernel: esrt: Reserving ESRT space from 0x00000000c3ee6c18 to 0x00000000c3ee6ca0.
Okt 10 13:15:54 bernhard-82ra kernel: e820: update [mem 0xc3ee6000-0xc3ee6fff] usable ==> reserved
Okt 10 13:15:54 bernhard-82ra kernel: Using GB pages for direct mapping
Okt 10 13:15:54 bernhard-82ra kernel: Secure boot disabled
Okt 10 13:15:54 bernhard-82ra kernel: RAMDISK: [mem 0x36d0d000-0x3767dfff]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Early table checksum verification disabled
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: RSDP 0x00000000CCDFD014 000024 (v02 LENOVO)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: XSDT 0x00000000CCDFB188 00013C (v01 LENOVO CB-01    00000003 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: FACP 0x00000000C7924000 000114 (v06 LENOVO CB-01    00000003 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: DSDT 0x00000000C7911000 00DCCF (v01 LENOVO AMD      00001000 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: FACS 0x00000000CB37F000 000040
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C8BFC000 0072B0 (v02 LENOVO AmdTable 00000002 MSFT 04000000)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C8BD4000 003BF1 (v01 LENOVO AMD AOD  00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: MSDM 0x00000000C8B41000 000055 (v03 LENOVO CB-01    00000000 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: BATB 0x00000000C8B2B000 00004A (v02 LENOVO CB-01    00000000 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: HPET 0x00000000C7923000 000038 (v01 LENOVO CB-01    00000001 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: APIC 0x00000000C7922000 000138 (v02 LENOVO CB-01    00000000 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: MCFG 0x00000000C7921000 00003C (v01 LENOVO CB-01    00000001 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SBST 0x00000000C7920000 000030 (v01 LENOVO CB-01    00000001 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: WSMT 0x00000000C791F000 000028 (v01 LENOVO CB-01    00000000 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: VFCT 0x00000000C7903000 00D884 (v01 LENOVO CB-01    00000001 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78FF000 003E88 (v02 LENOVO AmdTable 00000001 AMD  00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: CRAT 0x00000000C78FE000 000B80 (v01 LENOVO CB-01    00000001 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: CDIT 0x00000000C78FD000 000029 (v01 LENOVO CB-01    00000001 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78FC000 00053A (v01 LENOVO Tpm2Tabl 00009999 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: TPM2 0x00000000C78FB000 000038 (v04 LENOVO CB-01    00000002 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78FA000 000148 (v02 LENOVO ADebTabl 00001000 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: FPDT 0x00000000C78F9000 000034 (v01 LENOVO CB-01    00000002 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78F8000 000149 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78F7000 00065C (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78F6000 00064C (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78F4000 0014C3 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78F2000 0015A8 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78EE000 003B0E (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: BGRT 0x00000000C78ED000 000038 (v01 LENOVO CB-01    00000002 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78EC000 000058 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78EB000 00024D (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78EA000 000875 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C78E9000 00076B (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: UEFI 0x00000000CB37D000 00013E (v01 LENOVO CB-01    00000001 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: IVRS 0x00000000C78E8000 0001A4 (v02 LENOVO CB-01    00000001 LENO 00000001)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C8C08000 000090 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C8C07000 000445 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C8C06000 000E11 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: SSDT 0x00000000C8C05000 000929 (v01 LENOVO AmdTable 00000001 INTL 20180313)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving FACP table memory at [mem 0xc7924000-0xc7924113]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving DSDT table memory at [mem 0xc7911000-0xc791ecce]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving FACS table memory at [mem 0xcb37f000-0xcb37f03f]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc8bfc000-0xc8c032af]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc8bd4000-0xc8bd7bf0]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving MSDM table memory at [mem 0xc8b41000-0xc8b41054]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving BATB table memory at [mem 0xc8b2b000-0xc8b2b049]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving HPET table memory at [mem 0xc7923000-0xc7923037]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving APIC table memory at [mem 0xc7922000-0xc7922137]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving MCFG table memory at [mem 0xc7921000-0xc792103b]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SBST table memory at [mem 0xc7920000-0xc792002f]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving WSMT table memory at [mem 0xc791f000-0xc791f027]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving VFCT table memory at [mem 0xc7903000-0xc7910883]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78ff000-0xc7902e87]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving CRAT table memory at [mem 0xc78fe000-0xc78feb7f]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving CDIT table memory at [mem 0xc78fd000-0xc78fd028]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78fc000-0xc78fc539]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving TPM2 table memory at [mem 0xc78fb000-0xc78fb037]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78fa000-0xc78fa147]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving FPDT table memory at [mem 0xc78f9000-0xc78f9033]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78f8000-0xc78f8148]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78f7000-0xc78f765b]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78f6000-0xc78f664b]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78f4000-0xc78f54c2]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78f2000-0xc78f35a7]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78ee000-0xc78f1b0d]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving BGRT table memory at [mem 0xc78ed000-0xc78ed037]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78ec000-0xc78ec057]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78eb000-0xc78eb24c]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78ea000-0xc78ea874]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc78e9000-0xc78e976a]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving UEFI table memory at [mem 0xcb37d000-0xcb37d13d]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving IVRS table memory at [mem 0xc78e8000-0xc78e81a3]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc8c08000-0xc8c0808f]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc8c07000-0xc8c07444]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc8c06000-0xc8c06e10]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Reserving SSDT table memory at [mem 0xc8c05000-0xc8c05928]
Okt 10 13:15:54 bernhard-82ra kernel: No NUMA configuration found
Okt 10 13:15:54 bernhard-82ra kernel: Faking a node at [mem 0x0000000000000000-0x000000040e2fffff]
Okt 10 13:15:54 bernhard-82ra kernel: NODE_DATA(0) allocated [mem 0x40e2fb000-0x40e2fffff]
Okt 10 13:15:54 bernhard-82ra kernel: Zone ranges:
Okt 10 13:15:54 bernhard-82ra kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Okt 10 13:15:54 bernhard-82ra kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Okt 10 13:15:54 bernhard-82ra kernel:   Normal   [mem 0x0000000100000000-0x000000040e2fffff]
Okt 10 13:15:54 bernhard-82ra kernel:   Device   empty
Okt 10 13:15:54 bernhard-82ra kernel: Movable zone start for each node
Okt 10 13:15:54 bernhard-82ra kernel: Early memory node ranges
Okt 10 13:15:54 bernhard-82ra kernel:   node   0: [mem 0x0000000000001000-0x000000000009efff]
Okt 10 13:15:54 bernhard-82ra kernel:   node   0: [mem 0x0000000000100000-0x0000000009bfffff]
Okt 10 13:15:54 bernhard-82ra kernel:   node   0: [mem 0x0000000009da1000-0x0000000009efffff]
Okt 10 13:15:54 bernhard-82ra kernel:   node   0: [mem 0x0000000009f0f000-0x00000000c6afcfff]
Okt 10 13:15:54 bernhard-82ra kernel:   node   0: [mem 0x00000000ccdfe000-0x00000000cdffffff]
Okt 10 13:15:54 bernhard-82ra kernel:   node   0: [mem 0x0000000100000000-0x000000040e2fffff]
Okt 10 13:15:54 bernhard-82ra kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000040e2fffff]
Okt 10 13:15:54 bernhard-82ra kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Okt 10 13:15:54 bernhard-82ra kernel: On node 0, zone DMA: 97 pages in unavailable ranges
Okt 10 13:15:54 bernhard-82ra kernel: On node 0, zone DMA32: 417 pages in unavailable ranges
Okt 10 13:15:54 bernhard-82ra kernel: On node 0, zone DMA32: 15 pages in unavailable ranges
Okt 10 13:15:54 bernhard-82ra kernel: On node 0, zone DMA32: 25345 pages in unavailable ranges
Okt 10 13:15:54 bernhard-82ra kernel: On node 0, zone Normal: 8192 pages in unavailable ranges
Okt 10 13:15:54 bernhard-82ra kernel: On node 0, zone Normal: 7424 pages in unavailable ranges
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PM-Timer IO Port: 0x408
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Okt 10 13:15:54 bernhard-82ra kernel: IOAPIC[0]: apic_id 32, version 33, address 0xfec00000, GSI 0-23
Okt 10 13:15:54 bernhard-82ra kernel: IOAPIC[1]: apic_id 33, version 33, address 0xfec01000, GSI 24-55
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: HPET id: 0x43538210 base: 0xfed00000
Okt 10 13:15:54 bernhard-82ra kernel: e820: update [mem 0xc31cc000-0xc32ccfff] usable ==> reserved
Okt 10 13:15:54 bernhard-82ra kernel: smpboot: Allowing 12 CPUs, 0 hotplug CPUs
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0x09c00000-0x09da0fff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0x09f00000-0x09f0efff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xc31cc000-0xc32ccfff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xc3ee6000-0xc3ee6fff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xc6afd000-0xc6cfcfff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xc6cfd000-0xcacfcfff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xcacfd000-0xccd7dfff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xccd7e000-0xccdfdfff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xce000000-0xcfffffff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xf7ffffff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfed7ffff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
Okt 10 13:15:54 bernhard-82ra kernel: PM: hibernation: Registered nosave memory: [mem 0xfed81000-0xffffffff]
Okt 10 13:15:54 bernhard-82ra kernel: [mem 0xd0000000-0xf7ffffff] available for PCI devices
Okt 10 13:15:54 bernhard-82ra kernel: Booting paravirtualized kernel on bare hardware
Okt 10 13:15:54 bernhard-82ra kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Okt 10 13:15:54 bernhard-82ra kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:12 nr_cpu_ids:12 nr_node_ids:1
Okt 10 13:15:54 bernhard-82ra kernel: percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
Okt 10 13:15:54 bernhard-82ra kernel: pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
Okt 10 13:15:54 bernhard-82ra kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
Okt 10 13:15:54 bernhard-82ra kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64 root=UUID=a9d48c06-1874-4312-bea0-70a2c1ae4c53 rw udev.log_priority=3
Okt 10 13:15:54 bernhard-82ra kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64", will be passed to user space.
Okt 10 13:15:54 bernhard-82ra kernel: random: crng init done
Okt 10 13:15:54 bernhard-82ra kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: Fallback order for Node 0: 0
Okt 10 13:15:54 bernhard-82ra kernel: Built 1 zonelists, mobility grouping on.  Total pages: 3958741
Okt 10 13:15:54 bernhard-82ra kernel: Policy zone: Normal
Okt 10 13:15:54 bernhard-82ra kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Okt 10 13:15:54 bernhard-82ra kernel: software IO TLB: area num 16.
Okt 10 13:15:54 bernhard-82ra kernel: Memory: 15635580K/16086964K available (16384K kernel code, 2141K rwdata, 13028K rodata, 3400K init, 3856K bss, 451124K reserved, 0K cma-reserved)
Okt 10 13:15:54 bernhard-82ra kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
Okt 10 13:15:54 bernhard-82ra kernel: ftrace: allocating 48651 entries in 191 pages
Okt 10 13:15:54 bernhard-82ra kernel: ftrace: allocated 191 pages with 7 groups
Okt 10 13:15:54 bernhard-82ra kernel: Dynamic Preempt: full
Okt 10 13:15:54 bernhard-82ra kernel: rcu: Preemptible hierarchical RCU implementation.
Okt 10 13:15:54 bernhard-82ra kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=12.
Okt 10 13:15:54 bernhard-82ra kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Okt 10 13:15:54 bernhard-82ra kernel:         Trampoline variant of Tasks RCU enabled.
Okt 10 13:15:54 bernhard-82ra kernel:         Rude variant of Tasks RCU enabled.
Okt 10 13:15:54 bernhard-82ra kernel:         Tracing variant of Tasks RCU enabled.
Okt 10 13:15:54 bernhard-82ra kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Okt 10 13:15:54 bernhard-82ra kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
Okt 10 13:15:54 bernhard-82ra kernel: NR_IRQS: 20736, nr_irqs: 1064, preallocated irqs: 16
Okt 10 13:15:54 bernhard-82ra kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Okt 10 13:15:54 bernhard-82ra kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Okt 10 13:15:54 bernhard-82ra kernel: Console: colour dummy device 80x25
Okt 10 13:15:54 bernhard-82ra kernel: printk: console [tty0] enabled
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Core revision 20230331
Okt 10 13:15:54 bernhard-82ra kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
Okt 10 13:15:54 bernhard-82ra kernel: APIC: Switch to symmetric I/O mode setup
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR0, rdevid:160
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR1, rdevid:160
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR2, rdevid:160
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR3, rdevid:160
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: Using global IVHD EFR:0x206d73ef22254ade, EFR2:0x0
Okt 10 13:15:54 bernhard-82ra kernel: Switched APIC routing to physical flat.
Okt 10 13:15:54 bernhard-82ra kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Okt 10 13:15:54 bernhard-82ra kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1e365ec32fc, max_idle_ns: 440795244491 ns
Okt 10 13:15:54 bernhard-82ra kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4193.63 BogoMIPS (lpj=6986613)
Okt 10 13:15:54 bernhard-82ra kernel: Zenbleed: please update your microcode for the most optimal fix
Okt 10 13:15:54 bernhard-82ra kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Okt 10 13:15:54 bernhard-82ra kernel: LVT offset 1 assigned for vector 0xf9
Okt 10 13:15:54 bernhard-82ra kernel: LVT offset 2 assigned for vector 0xf4
Okt 10 13:15:54 bernhard-82ra kernel: process: using mwait in idle threads
Okt 10 13:15:54 bernhard-82ra kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
Okt 10 13:15:54 bernhard-82ra kernel: Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V2 : Mitigation: Retpolines
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V2 : Enabling Speculation Barrier for firmware calls
Okt 10 13:15:54 bernhard-82ra kernel: RETBleed: Mitigation: untrained return thunk
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V2 : Selecting STIBP always-on mode to complement retbleed mitigation
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V2 : User space: Mitigation: STIBP always-on protection
Okt 10 13:15:54 bernhard-82ra kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Okt 10 13:15:54 bernhard-82ra kernel: Speculative Return Stack Overflow: Mitigation: safe RET
Okt 10 13:15:54 bernhard-82ra kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Okt 10 13:15:54 bernhard-82ra kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Okt 10 13:15:54 bernhard-82ra kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Okt 10 13:15:54 bernhard-82ra kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Okt 10 13:15:54 bernhard-82ra kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
Okt 10 13:15:54 bernhard-82ra kernel: Freeing SMP alternatives memory: 40K
Okt 10 13:15:54 bernhard-82ra kernel: pid_max: default: 32768 minimum: 301
Okt 10 13:15:54 bernhard-82ra kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
Okt 10 13:15:54 bernhard-82ra kernel: landlock: Up and running.
Okt 10 13:15:54 bernhard-82ra kernel: Yama: becoming mindful.
Okt 10 13:15:54 bernhard-82ra kernel: LSM support for eBPF active
Okt 10 13:15:54 bernhard-82ra kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: smpboot: CPU0: AMD Ryzen 5 5500U with Radeon Graphics (family: 0x17, model: 0x68, stepping: 0x1)
Okt 10 13:15:54 bernhard-82ra kernel: RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
Okt 10 13:15:54 bernhard-82ra kernel: RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
Okt 10 13:15:54 bernhard-82ra kernel: RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
Okt 10 13:15:54 bernhard-82ra kernel: Performance Events: Fam17h+ core perfctr, AMD PMU driver.
Okt 10 13:15:54 bernhard-82ra kernel: ... version:                0
Okt 10 13:15:54 bernhard-82ra kernel: ... bit width:              48
Okt 10 13:15:54 bernhard-82ra kernel: ... generic registers:      6
Okt 10 13:15:54 bernhard-82ra kernel: ... value mask:             0000ffffffffffff
Okt 10 13:15:54 bernhard-82ra kernel: ... max period:             00007fffffffffff
Okt 10 13:15:54 bernhard-82ra kernel: ... fixed-purpose events:   0
Okt 10 13:15:54 bernhard-82ra kernel: ... event mask:             000000000000003f
Okt 10 13:15:54 bernhard-82ra kernel: signal: max sigframe size: 1776
Okt 10 13:15:54 bernhard-82ra kernel: rcu: Hierarchical SRCU implementation.
Okt 10 13:15:54 bernhard-82ra kernel: rcu:         Max phase no-delay instances is 1000.
Okt 10 13:15:54 bernhard-82ra kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Okt 10 13:15:54 bernhard-82ra kernel: smp: Bringing up secondary CPUs ...
Okt 10 13:15:54 bernhard-82ra kernel: smpboot: x86: Booting SMP configuration:
Okt 10 13:15:54 bernhard-82ra kernel: .... node  #0, CPUs:        #2  #4  #6  #8 #10
Okt 10 13:15:54 bernhard-82ra kernel: TSC synchronization [CPU#0 -> CPU#2]:
Okt 10 13:15:54 bernhard-82ra kernel: Measured 3675022419 cycles TSC warp between CPUs, turning off TSC clock.
Okt 10 13:15:54 bernhard-82ra kernel: tsc: Marking TSC unstable due to check_tsc_sync_source failed
Okt 10 13:15:54 bernhard-82ra kernel:   #1  #3  #5  #7  #9 #11
Okt 10 13:15:54 bernhard-82ra kernel: Spectre V2 : Update user space SMT mitigation: STIBP always-on
Okt 10 13:15:54 bernhard-82ra kernel: smp: Brought up 1 node, 12 CPUs
Okt 10 13:15:54 bernhard-82ra kernel: smpboot: Max logical packages: 1
Okt 10 13:15:54 bernhard-82ra kernel: smpboot: Total of 12 processors activated (50323.59 BogoMIPS)
Okt 10 13:15:54 bernhard-82ra kernel: devtmpfs: initialized
Okt 10 13:15:54 bernhard-82ra kernel: x86/mm: Memory block size: 128MB
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f0efff] (61440 bytes)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PM: Registering ACPI NVS region [mem 0xcacfd000-0xccd7dfff] (34082816 bytes)
Okt 10 13:15:54 bernhard-82ra kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Okt 10 13:15:54 bernhard-82ra kernel: futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: pinctrl core: initialized pinctrl subsystem
Okt 10 13:15:54 bernhard-82ra kernel: PM: RTC time: 11:15:50, date: 2023-10-10
Okt 10 13:15:54 bernhard-82ra kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Okt 10 13:15:54 bernhard-82ra kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Okt 10 13:15:54 bernhard-82ra kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Okt 10 13:15:54 bernhard-82ra kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Okt 10 13:15:54 bernhard-82ra kernel: audit: initializing netlink subsys (disabled)
Okt 10 13:15:54 bernhard-82ra kernel: audit: type=2000 audit(1696936550.166:1): state=initialized audit_enabled=0 res=1
Okt 10 13:15:54 bernhard-82ra kernel: thermal_sys: Registered thermal governor 'fair_share'
Okt 10 13:15:54 bernhard-82ra kernel: thermal_sys: Registered thermal governor 'bang_bang'
Okt 10 13:15:54 bernhard-82ra kernel: thermal_sys: Registered thermal governor 'step_wise'
Okt 10 13:15:54 bernhard-82ra kernel: thermal_sys: Registered thermal governor 'user_space'
Okt 10 13:15:54 bernhard-82ra kernel: thermal_sys: Registered thermal governor 'power_allocator'
Okt 10 13:15:54 bernhard-82ra kernel: cpuidle: using governor ladder
Okt 10 13:15:54 bernhard-82ra kernel: cpuidle: using governor menu
Okt 10 13:15:54 bernhard-82ra kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Okt 10 13:15:54 bernhard-82ra kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
Okt 10 13:15:54 bernhard-82ra kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved as E820 entry
Okt 10 13:15:54 bernhard-82ra kernel: PCI: Using configuration type 1 for base access
Okt 10 13:15:54 bernhard-82ra kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Okt 10 13:15:54 bernhard-82ra kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Okt 10 13:15:54 bernhard-82ra kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Okt 10 13:15:54 bernhard-82ra kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Okt 10 13:15:54 bernhard-82ra kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Added _OSI(Module Device)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Added _OSI(Processor Device)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Added _OSI(Processor Aggregator Device)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: 20 ACPI AML tables successfully acquired and loaded
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: EC: EC started
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: EC: interrupt blocked
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Interpreter enabled
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PM: (supports S0 S4 S5)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: Using IOAPIC for interrupt routing
Okt 10 13:15:54 bernhard-82ra kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Okt 10 13:15:54 bernhard-82ra kernel: PCI: Ignoring E820 reservations for host bridge windows
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.GPP4.WLAN.PWFR: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.GPP6.P0NV: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.GP17.XHC0.P0U0: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.GP17.XHC0.P3U0: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.GP17.XHC1.P0U1: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.GP17.XHC1.P3U1: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.GP17.XHC1.RHUB.PRT4.BTRS: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.GP18.P0SA: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PRWL: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PRWB: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_TZ_.FN00: New power resource
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Okt 10 13:15:54 bernhard-82ra kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Okt 10 13:15:54 bernhard-82ra kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
Okt 10 13:15:54 bernhard-82ra kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
Okt 10 13:15:54 bernhard-82ra kernel: acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
Okt 10 13:15:54 bernhard-82ra kernel: PCI host bridge to bus 0000:00
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000effff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfdffffff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: root bus resource [mem 0x430000000-0xffffffffff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:00.0: [1022:1630] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:00.2: [1022:1631] type 00 class 0x080600
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:01.0: [1022:1632] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:01.2: [1022:1634] type 01 class 0x060400
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.0: [1022:1632] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.2: [1022:1634] type 01 class 0x060400
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.4: [1022:1634] type 01 class 0x060400
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.4: PME# supported from D0 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.0: [1022:1632] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.1: [1022:1635] type 01 class 0x060400
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.1: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.0: [1022:1448] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.1: [1022:1449] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.2: [1022:144a] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.3: [1022:144b] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.4: [1022:144c] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.5: [1022:144d] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.6: [1022:144e] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.7: [1022:144f] type 00 class 0x060000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:01:00.0: [1217:8621] type 00 class 0x080501
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:01:00.0: reg 0x10: [mem 0xfd601000-0xfd601fff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:01:00.0: reg 0x14: [mem 0xfd600000-0xfd6007ff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:01:00.0: PME# supported from D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:01.2: PCI bridge to [bus 01]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:01.2:   bridge window [mem 0xfd600000-0xfd6fffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:02:00.0: [14c3:7961] type 00 class 0x028000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:02:00.0: reg 0x10: [mem 0x470200000-0x4702fffff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:02:00.0: reg 0x18: [mem 0x470300000-0x470303fff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:02:00.0: reg 0x20: [mem 0x470304000-0x470304fff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:02:00.0: supports D1 D2
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.2: PCI bridge to [bus 02]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.2:   bridge window [mem 0x470200000-0x4703fffff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:03:00.0: [1cc4:6303] type 00 class 0x010802
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:03:00.0: reg 0x10: [mem 0xfd500000-0xfd503fff 64bit]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:03:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:02.4 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.4: PCI bridge to [bus 03]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.4:   bridge window [mem 0xfd500000-0xfd5fffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: [1002:164c] type 00 class 0x030000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: reg 0x10: [mem 0x460000000-0x46fffffff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: reg 0x18: [mem 0x470000000-0x4701fffff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: reg 0x20: [io  0x1000-0x10ff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: reg 0x24: [mem 0xfd400000-0xfd47ffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: BAR 0: assigned to efifb
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.1: [1002:1637] type 00 class 0x040300
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.1: reg 0x10: [mem 0xfd4c8000-0xfd4cbfff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.1: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.1: PME# supported from D1 D2 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.2: [1022:15df] type 00 class 0x108000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.2: reg 0x18: [mem 0xfd300000-0xfd3fffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.2: reg 0x24: [mem 0xfd4ce000-0xfd4cffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.2: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.3: [1022:1639] type 00 class 0x0c0330
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.3: reg 0x10: [mem 0xfd000000-0xfd0fffff 64bit]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.3: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.3: PME# supported from D0 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.4: [1022:1639] type 00 class 0x0c0330
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.4: reg 0x10: [mem 0xfd100000-0xfd1fffff 64bit]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.4: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.4: PME# supported from D0 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.5: [1022:15e2] type 00 class 0x048000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.5: reg 0x10: [mem 0xfd480000-0xfd4bffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.5: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.5: PME# supported from D0 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.6: [1022:15e3] type 00 class 0x040300
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.6: reg 0x10: [mem 0xfd4c0000-0xfd4c7fff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.6: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.6: PME# supported from D0 D3hot D3cold
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.7: [1022:15e4] type 00 class 0x118000
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.7: reg 0x18: [mem 0xfd200000-0xfd2fffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.7: reg 0x24: [mem 0xfd4cc000-0xfd4cdfff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.7: enabling Extended Tags
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.1: PCI bridge to [bus 04]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.1:   bridge window [io  0x1000-0x1fff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.1:   bridge window [mem 0xfd000000-0xfd4fffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.1:   bridge window [mem 0x460000000-0x4701fffff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: IRQ 10 override to edge(!), high(!)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: IRQ 6 override to edge(!), high(!)
Okt 10 13:15:54 bernhard-82ra kernel: Low-power S0 idle used by default for system suspend
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: EC: interrupt unblocked
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: EC: event unblocked
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: EC: GPE=0x3
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC initialization complete
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: EC: Used to handle transactions and events
Okt 10 13:15:54 bernhard-82ra kernel: iommu: Default domain type: Translated
Okt 10 13:15:54 bernhard-82ra kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Okt 10 13:15:54 bernhard-82ra kernel: SCSI subsystem initialized
Okt 10 13:15:54 bernhard-82ra kernel: libata version 3.00 loaded.
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: bus type USB registered
Okt 10 13:15:54 bernhard-82ra kernel: usbcore: registered new interface driver usbfs
Okt 10 13:15:54 bernhard-82ra kernel: usbcore: registered new interface driver hub
Okt 10 13:15:54 bernhard-82ra kernel: usbcore: registered new device driver usb
Okt 10 13:15:54 bernhard-82ra kernel: pps_core: LinuxPPS API ver. 1 registered
Okt 10 13:15:54 bernhard-82ra kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Okt 10 13:15:54 bernhard-82ra kernel: PTP clock support registered
Okt 10 13:15:54 bernhard-82ra kernel: EDAC MC: Ver: 3.0.0
Okt 10 13:15:54 bernhard-82ra kernel: efivars: Registered efivars operations
Okt 10 13:15:54 bernhard-82ra kernel: NetLabel: Initializing
Okt 10 13:15:54 bernhard-82ra kernel: NetLabel:  domain hash size = 128
Okt 10 13:15:54 bernhard-82ra kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Okt 10 13:15:54 bernhard-82ra kernel: NetLabel:  unlabeled traffic allowed by default
Okt 10 13:15:54 bernhard-82ra kernel: mctp: management component transport protocol core
Okt 10 13:15:54 bernhard-82ra kernel: NET: Registered PF_MCTP protocol family
Okt 10 13:15:54 bernhard-82ra kernel: PCI: Using ACPI for IRQ routing
Okt 10 13:15:54 bernhard-82ra kernel: PCI: pci_cache_line_size set to 64 bytes
Okt 10 13:15:54 bernhard-82ra kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
Okt 10 13:15:54 bernhard-82ra kernel: e820: reserve RAM buffer [mem 0x09c00000-0x0bffffff]
Okt 10 13:15:54 bernhard-82ra kernel: e820: reserve RAM buffer [mem 0x09f00000-0x0bffffff]
Okt 10 13:15:54 bernhard-82ra kernel: e820: reserve RAM buffer [mem 0xc31cc000-0xc3ffffff]
Okt 10 13:15:54 bernhard-82ra kernel: e820: reserve RAM buffer [mem 0xc3ee6000-0xc3ffffff]
Okt 10 13:15:54 bernhard-82ra kernel: e820: reserve RAM buffer [mem 0xc6afd000-0xc7ffffff]
Okt 10 13:15:54 bernhard-82ra kernel: e820: reserve RAM buffer [mem 0xce000000-0xcfffffff]
Okt 10 13:15:54 bernhard-82ra kernel: e820: reserve RAM buffer [mem 0x40e300000-0x40fffffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: vgaarb: setting as boot VGA device
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: vgaarb: bridge control possible
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
Okt 10 13:15:54 bernhard-82ra kernel: vgaarb: loaded
Okt 10 13:15:54 bernhard-82ra kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
Okt 10 13:15:54 bernhard-82ra kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter
Okt 10 13:15:54 bernhard-82ra kernel: clocksource: Switched to clocksource hpet
Okt 10 13:15:54 bernhard-82ra kernel: VFS: Disk quotas dquot_6.6.0
Okt 10 13:15:54 bernhard-82ra kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Okt 10 13:15:54 bernhard-82ra kernel: pnp: PnP ACPI init
Okt 10 13:15:54 bernhard-82ra kernel: system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x0400-0x04cf] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x04d0-0x04d1] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x04d6] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x0c00-0x0c01] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x0c14] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x0c50-0x0c52] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x0c6c] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x0c6f] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:02: [io  0x0cd0-0x0cdb] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:03: [mem 0x000e0000-0x000fffff] could not be reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:03: [mem 0xff000000-0xffffffff] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:03: [mem 0xfec10000-0xfec1001f] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:03: [mem 0xfed00000-0xfed003ff] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:03: [mem 0xfed61000-0xfed613ff] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: system 00:03: [mem 0xfed80000-0xfed80fff] has been reserved
Okt 10 13:15:54 bernhard-82ra kernel: pnp: PnP ACPI: found 5 devices
Okt 10 13:15:54 bernhard-82ra kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Okt 10 13:15:54 bernhard-82ra kernel: NET: Registered PF_INET protocol family
Okt 10 13:15:54 bernhard-82ra kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: TCP: Hash tables configured (established 131072 bind 65536)
Okt 10 13:15:54 bernhard-82ra kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
Okt 10 13:15:54 bernhard-82ra kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Okt 10 13:15:54 bernhard-82ra kernel: NET: Registered PF_XDP protocol family
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: resource 4 [mem 0x000a0000-0x000effff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: resource 5 [mem 0xd0000000-0xf7ffffff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: resource 6 [mem 0xfc000000-0xfdffffff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: resource 7 [mem 0x430000000-0xffffffffff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: resource 8 [io  0x0000-0x0cf7 window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:00: resource 9 [io  0x0d00-0xffff window]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:01: resource 1 [mem 0xfd600000-0xfd6fffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:02: resource 2 [mem 0x470200000-0x4703fffff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:03: resource 1 [mem 0xfd500000-0xfd5fffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:04: resource 0 [io  0x1000-0x1fff]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:04: resource 1 [mem 0xfd000000-0xfd4fffff]
Okt 10 13:15:54 bernhard-82ra kernel: pci_bus 0000:04: resource 2 [mem 0x460000000-0x4701fffff 64bit pref]
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.1: D0 power state depends on 0000:04:00.0
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.3: extending delay after power-on from D3hot to 20 msec
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.4: extending delay after power-on from D3hot to 20 msec
Okt 10 13:15:54 bernhard-82ra kernel: PCI: CLS 32 bytes, default 64
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
Okt 10 13:15:54 bernhard-82ra kernel: Trying to unpack rootfs image as initramfs...
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:01.0: Adding to iommu group 0
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:01.2: Adding to iommu group 1
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.0: Adding to iommu group 2
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.2: Adding to iommu group 3
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:02.4: Adding to iommu group 4
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.0: Adding to iommu group 5
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:08.1: Adding to iommu group 6
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:14.0: Adding to iommu group 7
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:14.3: Adding to iommu group 7
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.0: Adding to iommu group 8
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.1: Adding to iommu group 8
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.2: Adding to iommu group 8
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.3: Adding to iommu group 8
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.4: Adding to iommu group 8
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.5: Adding to iommu group 8
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.6: Adding to iommu group 8
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:18.7: Adding to iommu group 8
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:01:00.0: Adding to iommu group 9
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:02:00.0: Adding to iommu group 10
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:03:00.0: Adding to iommu group 11
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.0: Adding to iommu group 12
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.1: Adding to iommu group 13
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.2: Adding to iommu group 14
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.3: Adding to iommu group 15
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.4: Adding to iommu group 16
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.5: Adding to iommu group 17
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.6: Adding to iommu group 18
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:04:00.7: Adding to iommu group 19
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:00.2: PCI INT A: not connected
Okt 10 13:15:54 bernhard-82ra kernel: pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: Extended features (0x206d73ef22254ade, 0x0): PPR X2APIC NX GT IA GA PC GA_vAPIC
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: Interrupt remapping enabled
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: X2APIC enabled
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: Virtual APIC enabled
Okt 10 13:15:54 bernhard-82ra kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Okt 10 13:15:54 bernhard-82ra kernel: software IO TLB: mapped [mem 0x00000000bdfdd000-0x00000000c1fdd000] (64MB)
Okt 10 13:15:54 bernhard-82ra kernel: LVT offset 0 assigned for vector 0x400
Okt 10 13:15:54 bernhard-82ra kernel: perf: AMD IBS detected (0x000003ff)
Okt 10 13:15:54 bernhard-82ra kernel: perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
Okt 10 13:15:54 bernhard-82ra kernel: Initialise system trusted keyrings
Okt 10 13:15:54 bernhard-82ra kernel: Key type blacklist registered
Okt 10 13:15:54 bernhard-82ra kernel: workingset: timestamp_bits=41 max_order=22 bucket_order=0
Okt 10 13:15:54 bernhard-82ra kernel: zbud: loaded
Okt 10 13:15:54 bernhard-82ra kernel: integrity: Platform Keyring initialized
Okt 10 13:15:54 bernhard-82ra kernel: integrity: Machine keyring initialized
Okt 10 13:15:54 bernhard-82ra kernel: jitterentropy: Initialization failed with host not compliant with requirements: 9
Okt 10 13:15:54 bernhard-82ra kernel: Key type asymmetric registered
Okt 10 13:15:54 bernhard-82ra kernel: Asymmetric key parser 'x509' registered
Okt 10 13:15:54 bernhard-82ra kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
Okt 10 13:15:54 bernhard-82ra kernel: io scheduler mq-deadline registered
Okt 10 13:15:54 bernhard-82ra kernel: io scheduler kyber registered
Okt 10 13:15:54 bernhard-82ra kernel: io scheduler bfq registered
Okt 10 13:15:54 bernhard-82ra kernel: pcieport 0000:00:01.2: PME: Signaling with IRQ 30
Okt 10 13:15:54 bernhard-82ra kernel: pcieport 0000:00:02.2: PME: Signaling with IRQ 31
Okt 10 13:15:54 bernhard-82ra kernel: pcieport 0000:00:02.4: PME: Signaling with IRQ 32
Okt 10 13:15:54 bernhard-82ra kernel: pcieport 0000:00:08.1: PME: Signaling with IRQ 33
Okt 10 13:15:54 bernhard-82ra kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: AC: AC Adapter [ADP1] (on-line)
Okt 10 13:15:54 bernhard-82ra kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: button: Power Button [PWRB]
Okt 10 13:15:54 bernhard-82ra kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: button: Lid Switch [LID0]
Okt 10 13:15:54 bernhard-82ra kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1501
Okt 10 13:15:54 bernhard-82ra kernel: Monitor-Mwait will be used to enter C-1 state
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C000: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C001: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C002: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C003: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C004: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C005: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C006: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C007: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C008: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C009: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C00A: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: \_SB_.PLTF.C00B: Found 3 idle states
Okt 10 13:15:54 bernhard-82ra kernel: thermal LNXTHERM:00: registered as thermal_zone0
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: thermal: Thermal Zone [TZS0] (60 C)
Okt 10 13:15:54 bernhard-82ra kernel: thermal LNXTHERM:01: registered as thermal_zone1
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: thermal: Thermal Zone [TZS1] (51 C)
Okt 10 13:15:54 bernhard-82ra kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: battery: Slot [BAT0] (battery present)
Okt 10 13:15:54 bernhard-82ra kernel: Non-volatile memory driver v1.3
Okt 10 13:15:54 bernhard-82ra kernel: Linux agpgart interface v0.103
Okt 10 13:15:54 bernhard-82ra kernel: tpm_crb MSFT0101:00: Disabling hwrng
Okt 10 13:15:54 bernhard-82ra kernel: AMD-Vi: AMD IOMMUv2 loaded and initialized
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: bus type drm_connector registered
Okt 10 13:15:54 bernhard-82ra kernel: [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
Okt 10 13:15:54 bernhard-82ra kernel: fbcon: Deferring console take-over
Okt 10 13:15:54 bernhard-82ra kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Okt 10 13:15:54 bernhard-82ra kernel: usbcore: registered new interface driver usbserial_generic
Okt 10 13:15:54 bernhard-82ra kernel: usbserial: USB Serial support registered for generic
Okt 10 13:15:54 bernhard-82ra kernel: rtc_cmos 00:01: RTC can wake from S4
Okt 10 13:15:54 bernhard-82ra kernel: rtc_cmos 00:01: registered as rtc0
Okt 10 13:15:54 bernhard-82ra kernel: rtc_cmos 00:01: setting system clock to 2023-10-10T11:15:51 UTC (1696936551)
Okt 10 13:15:54 bernhard-82ra kernel: rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
Okt 10 13:15:54 bernhard-82ra kernel: ledtrig-cpu: registered to indicate activity on CPUs
Okt 10 13:15:54 bernhard-82ra kernel: hid: raw HID events driver (C) Jiri Kosina
Okt 10 13:15:54 bernhard-82ra kernel: drop_monitor: Initializing network drop monitor service
Okt 10 13:15:54 bernhard-82ra kernel: Initializing XFRM netlink socket
Okt 10 13:15:54 bernhard-82ra kernel: NET: Registered PF_INET6 protocol family
Okt 10 13:15:54 bernhard-82ra kernel: Freeing initrd memory: 9668K
Okt 10 13:15:54 bernhard-82ra kernel: Segment Routing with IPv6
Okt 10 13:15:54 bernhard-82ra kernel: RPL Segment Routing with IPv6
Okt 10 13:15:54 bernhard-82ra kernel: In-situ OAM (IOAM) with IPv6
Okt 10 13:15:54 bernhard-82ra kernel: NET: Registered PF_PACKET protocol family
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU8: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU3: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU9: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU2: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU0: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU1: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU6: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU4: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU7: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU5: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU11: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: CPU10: patch_level=0x08608104
Okt 10 13:15:54 bernhard-82ra kernel: microcode: Microcode Update Driver: v2.2.
Okt 10 13:15:54 bernhard-82ra kernel: resctrl: L3 allocation detected
Okt 10 13:15:54 bernhard-82ra kernel: resctrl: MB allocation detected
Okt 10 13:15:54 bernhard-82ra kernel: resctrl: L3 monitoring detected
Okt 10 13:15:54 bernhard-82ra kernel: IPI shorthand broadcast: enabled
Okt 10 13:15:54 bernhard-82ra kernel: registered taskstats version 1
Okt 10 13:15:54 bernhard-82ra kernel: Loading compiled-in X.509 certificates
Okt 10 13:15:54 bernhard-82ra kernel: Loaded X.509 cert 'Build time autogenerated kernel key: b8f2ed7818dcaad565c912955651b7716d01b3cf'
Okt 10 13:15:54 bernhard-82ra kernel: zswap: loaded using pool zstd/zsmalloc
Okt 10 13:15:54 bernhard-82ra kernel: Key type .fscrypt registered
Okt 10 13:15:54 bernhard-82ra kernel: Key type fscrypt-provisioning registered
Okt 10 13:15:54 bernhard-82ra kernel: integrity: Loading X.509 certificate: UEFI:db
Okt 10 13:15:54 bernhard-82ra kernel: integrity: Loaded X.509 cert 'Lenovo UEFI CA 2014: 4b91a68732eaefdd2c8ffffc6b027ec3449e9c8f'
Okt 10 13:15:54 bernhard-82ra kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
Okt 10 13:15:54 bernhard-82ra kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
Okt 10 13:15:54 bernhard-82ra kernel: PM:   Magic number: 11:660:276
Okt 10 13:15:54 bernhard-82ra kernel: tty tty13: hash matches
Okt 10 13:15:54 bernhard-82ra kernel: RAS: Correctable Errors collector initialized.
Okt 10 13:15:54 bernhard-82ra kernel: Unstable clock detected, switching default tracing clock to "global"
                                      on the kernel command line
Okt 10 13:15:54 bernhard-82ra kernel: clk: Disabling unused clocks
Okt 10 13:15:54 bernhard-82ra kernel: Freeing unused decrypted memory: 2036K
Okt 10 13:15:54 bernhard-82ra kernel: Freeing unused kernel image (initmem) memory: 3400K
Okt 10 13:15:54 bernhard-82ra kernel: Write protecting the kernel read-only data: 30720k
Okt 10 13:15:54 bernhard-82ra kernel: Freeing unused kernel image (rodata/data gap) memory: 1308K
Okt 10 13:15:54 bernhard-82ra kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Okt 10 13:15:54 bernhard-82ra kernel: rodata_test: all tests were successful
Okt 10 13:15:54 bernhard-82ra kernel: Run /init as init process
Okt 10 13:15:54 bernhard-82ra kernel:   with arguments:
Okt 10 13:15:54 bernhard-82ra kernel:     /init
Okt 10 13:15:54 bernhard-82ra kernel:   with environment:
Okt 10 13:15:54 bernhard-82ra kernel:     HOME=/
Okt 10 13:15:54 bernhard-82ra kernel:     TERM=linux
Okt 10 13:15:54 bernhard-82ra kernel:     BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
Okt 10 13:15:54 bernhard-82ra kernel: fbcon: Taking over console
Okt 10 13:15:54 bernhard-82ra kernel: Console: switching to colour frame buffer device 160x50
Okt 10 13:15:54 bernhard-82ra kernel: i8042: PNP: PS/2 Controller [PNP0303:KBD0] at 0x60,0x64 irq 1
Okt 10 13:15:54 bernhard-82ra kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Okt 10 13:15:54 bernhard-82ra kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.3: xHCI Host Controller
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 1
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 2
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.3: Host supports USB 3.1 Enhanced SuperSpeed
Okt 10 13:15:54 bernhard-82ra kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
Okt 10 13:15:54 bernhard-82ra kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Okt 10 13:15:54 bernhard-82ra kernel: usb usb1: Product: xHCI Host Controller
Okt 10 13:15:54 bernhard-82ra kernel: usb usb1: Manufacturer: Linux 6.5.5-1-MANJARO xhci-hcd
Okt 10 13:15:54 bernhard-82ra kernel: usb usb1: SerialNumber: 0000:04:00.3
Okt 10 13:15:54 bernhard-82ra kernel: hub 1-0:1.0: USB hub found
Okt 10 13:15:54 bernhard-82ra kernel: hub 1-0:1.0: 4 ports detected
Okt 10 13:15:54 bernhard-82ra kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Okt 10 13:15:54 bernhard-82ra kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.05
Okt 10 13:15:54 bernhard-82ra kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Okt 10 13:15:54 bernhard-82ra kernel: usb usb2: Product: xHCI Host Controller
Okt 10 13:15:54 bernhard-82ra kernel: usb usb2: Manufacturer: Linux 6.5.5-1-MANJARO xhci-hcd
Okt 10 13:15:54 bernhard-82ra kernel: usb usb2: SerialNumber: 0000:04:00.3
Okt 10 13:15:54 bernhard-82ra kernel: hub 2-0:1.0: USB hub found
Okt 10 13:15:54 bernhard-82ra kernel: hub 2-0:1.0: 2 ports detected
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.4: xHCI Host Controller
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 3
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 4
Okt 10 13:15:54 bernhard-82ra kernel: xhci_hcd 0000:04:00.4: Host supports USB 3.1 Enhanced SuperSpeed
Okt 10 13:15:54 bernhard-82ra kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
Okt 10 13:15:54 bernhard-82ra kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Okt 10 13:15:54 bernhard-82ra kernel: usb usb3: Product: xHCI Host Controller
Okt 10 13:15:54 bernhard-82ra kernel: usb usb3: Manufacturer: Linux 6.5.5-1-MANJARO xhci-hcd
Okt 10 13:15:54 bernhard-82ra kernel: usb usb3: SerialNumber: 0000:04:00.4
Okt 10 13:15:54 bernhard-82ra kernel: hub 3-0:1.0: USB hub found
Okt 10 13:15:54 bernhard-82ra kernel: hub 3-0:1.0: 4 ports detected
Okt 10 13:15:54 bernhard-82ra kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Okt 10 13:15:54 bernhard-82ra kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.05
Okt 10 13:15:54 bernhard-82ra kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Okt 10 13:15:54 bernhard-82ra kernel: usb usb4: Product: xHCI Host Controller
Okt 10 13:15:54 bernhard-82ra kernel: usb usb4: Manufacturer: Linux 6.5.5-1-MANJARO xhci-hcd
Okt 10 13:15:54 bernhard-82ra kernel: usb usb4: SerialNumber: 0000:04:00.4
Okt 10 13:15:54 bernhard-82ra kernel: hub 4-0:1.0: USB hub found
Okt 10 13:15:54 bernhard-82ra kernel: hub 4-0:1.0: 2 ports detected
Okt 10 13:15:54 bernhard-82ra kernel: sdhci: Secure Digital Host Controller Interface driver
Okt 10 13:15:54 bernhard-82ra kernel: sdhci: Copyright(c) Pierre Ossman
Okt 10 13:15:54 bernhard-82ra kernel: nvme 0000:03:00.0: platform quirk: setting simple suspend
Okt 10 13:15:54 bernhard-82ra kernel: nvme nvme0: pci function 0000:03:00.0
Okt 10 13:15:54 bernhard-82ra kernel: sdhci-pci 0000:01:00.0: SDHCI controller found [1217:8621] (rev 1)
Okt 10 13:15:54 bernhard-82ra kernel: sdhci-pci 0000:01:00.0: enabling device (0000 -> 0002)
Okt 10 13:15:54 bernhard-82ra kernel: mmc0: SDHCI controller on PCI [0000:01:00.0] using ADMA
Okt 10 13:15:54 bernhard-82ra kernel: nvme nvme0: 12/0/0 default/read/poll queues
Okt 10 13:15:54 bernhard-82ra kernel:  nvme0n1: p1 p2 p3 p4 p5
Okt 10 13:15:54 bernhard-82ra kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
Okt 10 13:15:54 bernhard-82ra kernel: EXT4-fs (nvme0n1p5): mounted filesystem a9d48c06-1874-4312-bea0-70a2c1ae4c53 r/w with ordered data mode. Quota mode: none.
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-2: new full-speed USB device number 2 using xhci_hcd
Okt 10 13:15:54 bernhard-82ra kernel: usb 1-4: new high-speed USB device number 2 using xhci_hcd
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-2: New USB device found, idVendor=31b2, idProduct=0011, bcdDevice= 1.00
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-2: Product: Wavo POD
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-2: Manufacturer: JIAYZMicro
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-2: SerialNumber: 214b206000210611
Okt 10 13:15:54 bernhard-82ra kernel: usb 1-4: New USB device found, idVendor=5986, idProduct=214d, bcdDevice=57.08
Okt 10 13:15:54 bernhard-82ra kernel: usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Okt 10 13:15:54 bernhard-82ra kernel: usb 1-4: Product: Integrated Camera
Okt 10 13:15:54 bernhard-82ra kernel: usb 1-4: Manufacturer: SunplusIT Inc
Okt 10 13:15:54 bernhard-82ra kernel: usb 1-4: SerialNumber: 01.00.00
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-3: new high-speed USB device number 3 using xhci_hcd
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-3: New USB device found, idVendor=27c6, idProduct=55b4, bcdDevice= 1.00
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-3: Product: Goodix FingerPrint Device
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-3: Manufacturer: Generic
Okt 10 13:15:54 bernhard-82ra kernel: device-mapper: uevent: version 1.0.3
Okt 10 13:15:54 bernhard-82ra kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
Okt 10 13:15:54 bernhard-82ra kernel: EXT4-fs (nvme0n1p5): re-mounted a9d48c06-1874-4312-bea0-70a2c1ae4c53 r/w. Quota mode: none.
Okt 10 13:15:54 bernhard-82ra kernel: fuse: init (API version 7.38)
Okt 10 13:15:54 bernhard-82ra kernel: loop: module loaded
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-4: new high-speed USB device number 4 using xhci_hcd
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-4: New USB device found, idVendor=0489, idProduct=e0cd, bcdDevice= 1.00
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-4: New USB device strings: Mfr=5, Product=6, SerialNumber=7
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-4: Product: Wireless_Device
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-4: Manufacturer: MediaTek Inc.
Okt 10 13:15:54 bernhard-82ra kernel: usb 3-4: SerialNumber: 000000000
Okt 10 13:15:54 bernhard-82ra kernel: Adding 8388604k swap on /swapfile.  Priority:-2 extents:232 across:249004032k SSFS
Okt 10 13:15:54 bernhard-82ra kernel: piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
Okt 10 13:15:54 bernhard-82ra kernel: piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
Okt 10 13:15:54 bernhard-82ra kernel: piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
Okt 10 13:15:54 bernhard-82ra kernel: pcie_mp2_amd 0000:04:00.7: enabling device (0000 -> 0002)
Okt 10 13:15:54 bernhard-82ra kernel: ccp 0000:04:00.2: enabling device (0000 -> 0002)
Okt 10 13:15:54 bernhard-82ra kernel: ccp 0000:04:00.2: ccp: unable to access the device: you might be running a broken BIOS.
Okt 10 13:15:54 bernhard-82ra kernel: hid-generic 0020:1022:0001.0001: hidraw0: SENSOR HUB HID v0.00 Device [hid-amdsfh 1022:0001] on pcie_mp2_amd
Okt 10 13:15:54 bernhard-82ra kernel: input: PC Speaker as /devices/platform/pcspkr/input/input3
Okt 10 13:15:54 bernhard-82ra kernel: ccp 0000:04:00.2: tee enabled
Okt 10 13:15:54 bernhard-82ra kernel: ccp 0000:04:00.2: psp enabled
Okt 10 13:15:54 bernhard-82ra kernel: mc: Linux media interface: v0.10
Okt 10 13:15:54 bernhard-82ra kernel: RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
Okt 10 13:15:54 bernhard-82ra kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
Okt 10 13:15:54 bernhard-82ra kernel: input: JIAYZMicro Wavo POD as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2:1.3/0003:31B2:0011.0002/input/input4
Okt 10 13:15:54 bernhard-82ra kernel: hid-generic 0003:31B2:0011.0002: input,hidraw1: USB HID v1.10 Device [JIAYZMicro Wavo POD] on usb-0000:04:00.4-2/input3
Okt 10 13:15:54 bernhard-82ra kernel: usbcore: registered new interface driver usbhid
Okt 10 13:15:54 bernhard-82ra kernel: usbhid: USB HID core driver
Okt 10 13:15:54 bernhard-82ra kernel: input: SYNA2BA6:00 06CB:CE78 Mouse as /devices/platform/AMDI0010:03/i2c-1/i2c-SYNA2BA6:00/0018:06CB:CE78.0003/input/input5
Okt 10 13:15:54 bernhard-82ra kernel: input: SYNA2BA6:00 06CB:CE78 Touchpad as /devices/platform/AMDI0010:03/i2c-1/i2c-SYNA2BA6:00/0018:06CB:CE78.0003/input/input6
Okt 10 13:15:54 bernhard-82ra kernel: hid-generic 0018:06CB:CE78.0003: input,hidraw2: I2C HID v1.00 Mouse [SYNA2BA6:00 06CB:CE78] on i2c-SYNA2BA6:00
Okt 10 13:15:54 bernhard-82ra kernel: input: WACF2200:00 056A:52CC Touchscreen as /devices/platform/AMDI0010:00/i2c-0/i2c-WACF2200:00/0018:056A:52CC.0004/input/input8
Okt 10 13:15:54 bernhard-82ra kernel: input: WACF2200:00 056A:52CC as /devices/platform/AMDI0010:00/i2c-0/i2c-WACF2200:00/0018:056A:52CC.0004/input/input9
Okt 10 13:15:54 bernhard-82ra kernel: input: WACF2200:00 056A:52CC Stylus as /devices/platform/AMDI0010:00/i2c-0/i2c-WACF2200:00/0018:056A:52CC.0004/input/input10
Okt 10 13:15:54 bernhard-82ra kernel: input: WACF2200:00 056A:52CC as /devices/platform/AMDI0010:00/i2c-0/i2c-WACF2200:00/0018:056A:52CC.0004/input/input11
Okt 10 13:15:54 bernhard-82ra kernel: input: WACF2200:00 056A:52CC Mouse as /devices/platform/AMDI0010:00/i2c-0/i2c-WACF2200:00/0018:056A:52CC.0004/input/input12
Okt 10 13:15:54 bernhard-82ra kernel: hid-generic 0018:056A:52CC.0004: input,hidraw3: I2C HID v1.00 Mouse [WACF2200:00 056A:52CC] on i2c-WACF2200:00
Okt 10 13:15:54 bernhard-82ra kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
Okt 10 13:15:54 bernhard-82ra kernel: sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
Okt 10 13:15:54 bernhard-82ra kernel: sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
Okt 10 13:15:54 bernhard-82ra kernel: ACPI: video: Video Device [VGA] (multi-head: yes  rom: no  post: no)
Okt 10 13:15:54 bernhard-82ra kernel: cryptd: max_cpu_qlen set to 1000
Okt 10 13:15:54 bernhard-82ra kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:10/LNXVIDEO:00/input/input13
Okt 10 13:15:54 bernhard-82ra kernel: snd_rn_pci_acp3x 0000:04:00.5: enabling device (0000 -> 0002)
Okt 10 13:15:54 bernhard-82ra kernel: AVX2 version of gcm_enc/dec engaged.
Okt 10 13:15:54 bernhard-82ra kernel: AES CTR mode by8 optimization enabled
Okt 10 13:15:54 bernhard-82ra kernel: videodev: Linux video capture interface: v2.00
Okt 10 13:15:54 bernhard-82ra kernel: input: Lenovo Yoga Tablet Mode Control switch as /devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/06129D99-6083-4164-81AD-F092F9D773A6/input/input14
Okt 10 13:15:54 bernhard-82ra kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Okt 10 13:15:54 bernhard-82ra kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: Core ver 2.22
Okt 10 13:15:54 bernhard-82ra kernel: NET: Registered PF_BLUETOOTH protocol family
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: HCI device and connection manager initialized
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: HCI socket layer initialized
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: L2CAP socket layer initialized
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: SCO socket layer initialized
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_intel 0000:04:00.1: enabling device (0000 -> 0002)
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_intel 0000:04:00.6: enabling device (0000 -> 0002)
Okt 10 13:15:54 bernhard-82ra kernel: usb 1-4: Found UVC 1.50 device Integrated Camera (5986:214d)
Okt 10 13:15:54 bernhard-82ra kernel: input: Ideapad extra buttons as /devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input15
Okt 10 13:15:54 bernhard-82ra kernel: usbcore: registered new interface driver uvcvideo
Okt 10 13:15:54 bernhard-82ra kernel: ucsi_acpi USBC000:00: unknown error 0
Okt 10 13:15:54 bernhard-82ra kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Okt 10 13:15:54 bernhard-82ra kernel: input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input16
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_codec_realtek hdaudioC1D0:    inputs:
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_codec_realtek hdaudioC1D0:      Headset Mic=0x19
Okt 10 13:15:54 bernhard-82ra kernel: snd_hda_codec_realtek hdaudioC1D0:      Internal Mic=0x12
Okt 10 13:15:54 bernhard-82ra kernel: usbcore: registered new interface driver btusb
Okt 10 13:15:54 bernhard-82ra kernel: kvm_amd: TSC scaling supported
Okt 10 13:15:54 bernhard-82ra kernel: kvm_amd: Nested Virtualization enabled
Okt 10 13:15:54 bernhard-82ra kernel: kvm_amd: Nested Paging enabled
Okt 10 13:15:54 bernhard-82ra kernel: kvm_amd: Virtual VMLOAD VMSAVE supported
Okt 10 13:15:54 bernhard-82ra kernel: kvm_amd: Virtual GIF supported
Okt 10 13:15:54 bernhard-82ra kernel: kvm_amd: LBR virtualization supported
Okt 10 13:15:54 bernhard-82ra kernel: input: SYNA2BA6:00 06CB:CE78 Mouse as /devices/platform/AMDI0010:03/i2c-1/i2c-SYNA2BA6:00/0018:06CB:CE78.0003/input/input18
Okt 10 13:15:54 bernhard-82ra kernel: MCE: In-kernel MCE decoding enabled.
Okt 10 13:15:54 bernhard-82ra kernel: input: HD-Audio Generic Headset Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input21
Okt 10 13:15:54 bernhard-82ra kernel: input: SYNA2BA6:00 06CB:CE78 Touchpad as /devices/platform/AMDI0010:03/i2c-1/i2c-SYNA2BA6:00/0018:06CB:CE78.0003/input/input19
Okt 10 13:15:54 bernhard-82ra kernel: input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input17
Okt 10 13:15:54 bernhard-82ra kernel: input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input22
Okt 10 13:15:54 bernhard-82ra kernel: mt7921e 0000:02:00.0: enabling device (0000 -> 0002)
Okt 10 13:15:54 bernhard-82ra kernel: mt7921e 0000:02:00.0: ASIC revision: 79610010
Okt 10 13:15:54 bernhard-82ra kernel: hid-multitouch 0018:06CB:CE78.0003: input,hidraw0: I2C HID v1.00 Mouse [SYNA2BA6:00 06CB:CE78] on i2c-SYNA2BA6:00
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: hci0: Device setup in 147274 usecs
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Okt 10 13:15:54 bernhard-82ra kernel: usbcore: registered new interface driver snd-usb-audio
Okt 10 13:15:54 bernhard-82ra kernel: mousedev: PS/2 mouse device common for all mice
Okt 10 13:15:54 bernhard-82ra kernel: input: Wacom HID 52CC Pen as /devices/platform/AMDI0010:00/i2c-0/i2c-WACF2200:00/0018:056A:52CC.0004/input/input23
Okt 10 13:15:54 bernhard-82ra kernel: input: Wacom HID 52CC Finger as /devices/platform/AMDI0010:00/i2c-0/i2c-WACF2200:00/0018:056A:52CC.0004/input/input24
Okt 10 13:15:54 bernhard-82ra kernel: wacom 0018:056A:52CC.0004: hidraw2: I2C HID v1.00 Mouse [WACF2200:00 056A:52CC] on i2c-WACF2200:00
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: hci0: AOSP extensions version v1.00
Okt 10 13:15:54 bernhard-82ra kernel: Bluetooth: hci0: AOSP quality report is supported
Okt 10 13:15:54 bernhard-82ra kernel: mt7921e 0000:02:00.0: HW/SW Version: 0x8a108a10, Build Time: 20230526130917a
Okt 10 13:15:54 bernhard-82ra kernel: mt7921e 0000:02:00.0: WM Firmware Version: ____010000, Build Time: 20230526130958
Okt 10 13:15:56 bernhard-82ra kernel: intel_rapl_common: Found RAPL domain package
Okt 10 13:15:56 bernhard-82ra kernel: intel_rapl_common: Found RAPL domain core
Okt 10 13:15:56 bernhard-82ra kernel: mt7921e 0000:02:00.0 wlp2s0: renamed from wlan0
Okt 10 13:15:56 bernhard-82ra kernel: [drm] amdgpu kernel modesetting enabled.
Okt 10 13:15:56 bernhard-82ra kernel: amdgpu: CRAT table disabled by module option
Okt 10 13:15:56 bernhard-82ra kernel: amdgpu: Virtual CRAT table created for CPU
Okt 10 13:15:56 bernhard-82ra kernel: amdgpu: Topology: Add CPU node
Okt 10 13:15:56 bernhard-82ra kernel: amdgpu 0000:04:00.0: enabling device (0006 -> 0007)
Okt 10 13:15:56 bernhard-82ra kernel: [drm] initializing kernel modesetting (RENOIR 0x1002:0x164C 0x17AA:0x3806 0xC2).
Okt 10 13:15:56 bernhard-82ra kernel: [drm] register mmio base: 0xFD400000
Okt 10 13:15:56 bernhard-82ra kernel: [drm] register mmio size: 524288
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 0 <soc15_common>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 1 <gmc_v9_0>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 2 <vega10_ih>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 3 <psp>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 4 <smu>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 5 <dm>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 6 <gfx_v9_0>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 7 <sdma_v4_0>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 8 <vcn_v2_0>
Okt 10 13:15:56 bernhard-82ra kernel: [drm] add ip block number 9 <jpeg_v2_0>
Okt 10 13:15:56 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: Fetched VBIOS from VFCT
Okt 10 13:15:56 bernhard-82ra kernel: amdgpu: ATOM BIOS: 113-LUCIENNE-019
Okt 10 13:15:56 bernhard-82ra kernel: [drm] VCN decode is enabled in VM mode
Okt 10 13:15:56 bernhard-82ra kernel: [drm] VCN encode is enabled in VM mode
Okt 10 13:15:56 bernhard-82ra kernel: [drm] JPEG decode is enabled in VM mode
Okt 10 13:15:56 bernhard-82ra kernel: [drm] MCBP is enabled
Okt 10 13:15:56 bernhard-82ra kernel: Console: switching to colour dummy device 80x25
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: vgaarb: deactivate vga console
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: MODE2 reset
Okt 10 13:15:57 bernhard-82ra kernel: [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
Okt 10 13:15:57 bernhard-82ra kernel: [drm] Detected VRAM RAM=512M, BAR=512M
Okt 10 13:15:57 bernhard-82ra kernel: [drm] RAM width 128bits LPDDR4
Okt 10 13:15:57 bernhard-82ra kernel: [drm] amdgpu: 512M of VRAM memory ready
Okt 10 13:15:57 bernhard-82ra kernel: [drm] amdgpu: 7664M of GTT memory ready.
Okt 10 13:15:57 bernhard-82ra kernel: [drm] GART: num cpu pages 262144, num gpu pages 262144
Okt 10 13:15:57 bernhard-82ra kernel: [drm] PCIE GART of 1024M enabled.
Okt 10 13:15:57 bernhard-82ra kernel: [drm] PTB located at 0x000000F41FC00000
Okt 10 13:15:57 bernhard-82ra kernel: [drm] Loading DMUB firmware via PSP: version=0x01010027
Okt 10 13:15:57 bernhard-82ra kernel: [drm] Found VCN firmware Version ENC: 1.20 DEC: 6 VEP: 0 Revision: 0
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: Will use PSP to load VCN firmware
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: BNEP filters: protocol multicast
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: BNEP socket layer initialized
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: MGMT ver 1.22
Okt 10 13:15:57 bernhard-82ra kernel: NET: Registered PF_ALG protocol family
Okt 10 13:15:57 bernhard-82ra NetworkManager[465]: <info>  [1696936557.1419] manager[0x558f508f6040]: monitoring kernel firmware directory '/lib/firmware'.
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: hci0: Device setup in 139641 usecs
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Okt 10 13:15:57 bernhard-82ra kernel: NET: Registered PF_QIPCRTR protocol family
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: hci0: AOSP extensions version v1.00
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: hci0: AOSP quality report is supported
Okt 10 13:15:57 bernhard-82ra kernel: Bluetooth: hci0: Bad flag given (0x1) vs supported (0x0)
Okt 10 13:15:57 bernhard-82ra kernel: [drm] reserve 0x400000 from 0xf41f400000 for PSP TMR
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
Okt 10 13:15:57 bernhard-82ra kernel: [drm] psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
Okt 10 13:15:57 bernhard-82ra kernel: [drm] psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: Secure display: Generic Failure.
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Okt 10 13:15:57 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SMU is initialized successfully!
Okt 10 13:15:57 bernhard-82ra kernel: [drm] Display Core v3.2.241 initialized on DCN 2.1
Okt 10 13:15:57 bernhard-82ra kernel: [drm] DP-HDMI FRL PCON supported
Okt 10 13:15:57 bernhard-82ra kernel: [drm] DMUB hardware initialized: version=0x01010027
Okt 10 13:15:57 bernhard-82ra kernel: snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Okt 10 13:15:57 bernhard-82ra kernel: [drm] kiq ring mec 2 pipe 1 q 0
Okt 10 13:15:57 bernhard-82ra kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Okt 10 13:15:57 bernhard-82ra kernel: [drm] JPEG decode initialized successfully.
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu: HMM registered 512MB device memory
Okt 10 13:15:58 bernhard-82ra kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Okt 10 13:15:58 bernhard-82ra kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu: Virtual CRAT table created for GPU
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu: Topology: Add dGPU node [0x164c:0x1002]
Okt 10 13:15:58 bernhard-82ra kernel: kfd kfd: amdgpu: added device 1002:164c
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 8, active_cu_number 7
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring gfx_low uses VM inv eng 1 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring gfx_high uses VM inv eng 4 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 5 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 6 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 7 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 8 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 9 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 10 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 11 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 12 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 13 on hub 0
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 8
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 8
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 8
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 8
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 8
Okt 10 13:15:58 bernhard-82ra kernel: [drm] Initialized amdgpu 3.54.0 20150101 for 0000:04:00.0 on minor 1
Okt 10 13:15:58 bernhard-82ra kernel: fbcon: amdgpudrmfb (fb0) is primary device
Okt 10 13:15:58 bernhard-82ra kernel: [drm] DSC precompute is not needed.
Okt 10 13:15:58 bernhard-82ra kernel: Console: switching to colour frame buffer device 160x50
Okt 10 13:15:58 bernhard-82ra kernel: amdgpu 0000:04:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Okt 10 13:16:00 bernhard-82ra kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Okt 10 13:16:00 bernhard-82ra kernel: Bridge firewalling registered
Okt 10 13:16:00 bernhard-82ra dockerd[622]: time="2023-10-10T13:16:00.664578047+02:00" level=warning msg="Not using native diff for overlay2, this may cause degraded performance for building images: kernel has CONFIG_OVERLAY_FS_REDIRECT_DIR enabled" storage-driver=overlay2
Okt 10 13:16:00 bernhard-82ra systemd[1]: Startup finished in 4.069s (firmware) + 8.975s (loader) + 1.212s (kernel) + 8.543s (userspace) = 22.800s.
Okt 10 13:16:00 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:16:00 bernhard-82ra kernel: kwin_wayland[709]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Okt 10 13:16:01 bernhard-82ra kernel: warning: `QSampleCache::L' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Okt 10 13:16:02 bernhard-82ra org_kde_powerdevil[1025]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Okt 10 13:16:03 bernhard-82ra kernel: Bluetooth: RFCOMM TTY layer initialized
Okt 10 13:16:03 bernhard-82ra kernel: Bluetooth: RFCOMM socket layer initialized
Okt 10 13:16:03 bernhard-82ra kernel: Bluetooth: RFCOMM ver 1.11
Okt 10 13:16:03 bernhard-82ra org_kde_powerdevil[1025]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Okt 10 13:16:03 bernhard-82ra kernel: ntfs3: Max link count 4000
Okt 10 13:16:03 bernhard-82ra kernel: ntfs3: Enabled Linux POSIX ACLs support
Okt 10 13:16:03 bernhard-82ra kernel: ntfs3: Read-only LZX/Xpress compression included
Okt 10 13:16:03 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:16:04 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:16:04 bernhard-82ra kernel: wlp2s0: authenticate with 44:4e:6d:9c:40:76
Okt 10 13:16:05 bernhard-82ra kernel: wlp2s0: send auth to 44:4e:6d:9c:40:76 (try 1/3)
Okt 10 13:16:05 bernhard-82ra kernel: wlp2s0: authenticated
Okt 10 13:16:05 bernhard-82ra kernel: wlp2s0: associate with 44:4e:6d:9c:40:76 (try 1/3)
Okt 10 13:16:05 bernhard-82ra kernel: wlp2s0: RX AssocResp from 44:4e:6d:9c:40:76 (capab=0x1511 status=0 aid=1)
Okt 10 13:16:05 bernhard-82ra kernel: wlp2s0: associated
Okt 10 13:16:05 bernhard-82ra kernel: wlp2s0: Limiting TX power to 20 (23 - 3) dBm as advertised by 44:4e:6d:9c:40:76
Okt 10 13:16:10 bernhard-82ra kwin_wayland[709]: kwin_libinput: Libinput: event10 - SYNA2BA6:00 06CB:CE78 Touchpad: kernel bug: Touch jump detected and discarded.
Okt 10 13:16:13 bernhard-82ra plasmashell[1712]: blackbox: 2023-10-10T11:16:13.988Z 5 Sentry report: {"sdk":{"name":"sentry.javascript.electron","packages":[{"name":"npm:@sentry/electron","version":"4.12.0"}],"version":"4.12.0","integrations":["SentryMinidump","ElectronBreadcrumbs","Net","MainContext","ChildProcess","OnUncaughtException","PreloadInjection","AdditionalContext","Screenshots","InboundFilters","FunctionToString","Console","Http","Undici","OnUnhandledRejection","ContextLines","LocalVariables","Modules","RequestData","LinkedErrors"]},"contexts":{"trace":{"trace_id":"9be78695405242258eb235bfa5d5eba4","span_id":"807c340c85869a9f"},"app":{"app_name":"discord","app_version":"0.0.31","app_start_time":"2023-10-10T11:16:12.954Z"},"os":{"kernel_version":"6.5.5-1-MANJARO","name":"Ubuntu Linux","version":"\"23.0.3\""},"browser":{"name":"Chrome"},"chrome":{"name":"Chrome","type":"runtime","version":"108.0.5359.215"},"device":{"arch":"x64","family":"Desktop","language":"en-US","screen_density":2,"screen_resolution":"3414x2134","memory_size":16073560064,"free_memory":11158376448,"processor_count":12,"cpu_description":"AMD Ryzen 5 5500U with Radeon Graphics","processor_frequency":2381},"node":{"name":"Node","type":"runtime","version":"16.17.1"},"runtime":{"name":"Electron","version":"22.3.25"}},"environment":"stable","release":"0.0.31","user":{"ip_address":"{{auto}}"},"tags":{"event.origin":"electron","event.environment":"native","event.process":"browser","event_type":"native"},"level":"fatal","platform":"native","breadcrumbs":[{"timestamp":1696936573.461,"category":"console","level":"log","message":"Discord 0.0.31"},{"timestamp":1696936573.614,"category":"electron","message":"app.will-finish-launching","type":"ui"},{"timestamp":1696936573.626,"category":"electron","message":"app.ready","type":"ui"},{"timestamp":1696936573.651,"category":"electron","message":"app.session-created","type":"ui"},{"timestamp":1696936573.651,"category":"console","level":"log","message":"Starting app."},{"timestamp":1696936573.668,"category":"console","level":"log","message":"Removing old directory  0.0.30"},{"timestamp":1696936573.676,"category":"console","level":"log","message":"Starting updater."},{"timestamp":1696936573.677,"category":"console","level":"log","message":"2023-10-10T11:16:13.677Z [Modules] Modules initializing"},{"timestamp":1696936573.678,"category":"console","level":"log","message":"2023-10-10T11:16:13.678Z [Modules] Distribution: remote"},{"timestamp":1696936573.678,"category":"console","level":"log","message":"2023-10-10T11:16:13.678Z [Modules] Host updates: disabled"},{"timestamp":1696936573.678,"category":"console","level":"log","message":"2023-10-10T11:16:13.678Z [Modules] Module updates: enabled"},{"timestamp":1696936573.679,"category":"console","level":"log","message":"2023-10-10T11:16:13.679Z [Modules] Module install path: /home/bernhard/.config/discord/0.0.31/modules"},{"timestamp":1696936573.679,"category":"console","level":"log","message":"2023-10-10T11:16:13.679Z [Modules] Module installed file path: /home/bernhard/.config/discord/0.0.31/modules/installed.json"},{"timestamp":1696936573.679,"category":"console","level":"log","message":"2023-10-10T11:16:13.679Z [Modules] Module download path: /home/bernhard/.config/discord/0.0.31/modules/pending"},{"timestamp":1696936573.683,"category":"console","level":"log","message":"splashScreen.initSplash(false)"},{"timestamp":1696936573.698,"category":"electron","message":"app.web-contents-created","type":"ui"},{"timestamp":1696936573.699,"category":"electron","message":"app.browser-window-created","type":"ui"},{"timestamp":1696936573.712,"category":"electron","message":"renderer.load-url","type":"ui","data":{}},{"timestamp":1696936573.743,"category":"console","level":"log","message":"blackbox: 2023-10-10T11:16:13.743Z 0 \n\n----------------------------------------------"},{"timestamp":1696936573.768,"category":"electron","message":"app.gpu-info-update","type":"ui"},{"timestamp":1696936573.461,"category":"console","level":"log","message":"Discord 0.0.31"},{"timestamp":1696936573.614,"category":"electron","message":"app.will-finish-launching","type":"ui"},{"timestamp":1696936573.626,"category":"electron","message":"app.ready","type":"ui"},{"timestamp":1696936573.651,"category":"electron","message":"app.session-created","type":"ui"},{"timestamp":1696936573.651,"category":"console","level":"log","message":"Starting app."},{"timestamp":1696936573.668,"category":"console","level":"log","message":"Removing old directory  0.0.30"},{"timestamp":1696936573.676,"category":"console","level":"log","message":"Starting updater."},{"timestamp":1696936573.677,"category":"console","level":"log","message":"2023-10-10T11:16:13.677Z [Modules] Modules initializing"},{"timestamp":1696936573.678,"category":"console","level":"log","message":"2023-10-10T11:16:13.678Z [Modules] Distribution: remote"},{"timestamp":1696936573.678,"category":"console","level":"log","message":"2023-10-10T11:16:13.678Z [Modules] Host updates: disabled"},{"timestamp":1696936573.678,"category":"console","level":"log","message":"2023-10-10T11:16:13.678Z [Modules] Module updates: enabled"},{"timestamp":1696936573.679,"category":"console","level":"log","message":"2023-10-10T11:16:13.679Z [Modules] Module install path: /home/bernhard/.config/discord/0.0.31/modules"},{"timestamp":1696936573.679,"category":"console","level":"log","message":"2023-10-10T11:16:13.679Z [Modules] Module installed file path: /home/bernhard/.config/discord/0.0.31/modules/installed.json"},{"timestamp":1696936573.679,"category":"console","level":"log","message":"2023-10-10T11:16:13.679Z [Modules] Module download path: /home/bernhard/.config/discord/0.0.31/modules/pending"},{"timestamp":1696936573.683,"category":"console","level":"log","message":"splashScreen.initSplash(false)"},{"timestamp":1696936573.698,"category":"electron","message":"app.web-contents-created","type":"ui"},{"timestamp":1696936573.699,"category":"electron","message":"app.browser-window-created","type":"ui"},{"timestamp":1696936573.712,"category":"electron","message":"renderer.load-url","type":"ui","data":{}},{"timestamp":1696936573.743,"category":"console","level":"log","message":"blackbox: 2023-10-10T11:16:13.743Z 0 \n\n----------------------------------------------"},{"timestamp":1696936573.768,"category":"electron","message":"app.gpu-info-update","type":"ui"},{"timestamp":1696936573.793,"category":"console","level":"log","message":"blackbox: 2023-10-10T11:16:13.793Z 1 Discord starting: {\"releaseChannel\":\"stable\",\"version\":\"0.0.31\"}, modulepath: /home/bernhard/.config/discord/0.0.31/modules"},{"timestamp":1696936573.815,"category":"console","level":"log","message":"blackbox: 2023-10-10T11:16:13.814Z 2 ✅ webContents.created web1 \"\""}],"modules":{"mkdirp":"0.5.5","rimraf":"2.7.1","glob":"7.1.7","fs.realpath":"1.0.0","minimatch":"3.1.2","brace-expansion":"1.1.11","concat-map":"0.0.1","balanced-match":"1.0.2","inherits":"2.0.4","path-is-absolute":"1.0.1","inflight":"1.0.6","wrappy":"1.0.2","once":"1.4.0","yauzl":"2.10.0","fd-slicer":"1.1.0","pend":"1.2.0","buffer-crc32":"0.2.13","request":"2.88.0","extend":"3.0.2","tough-cookie":"2.4.3","psl":"1.8.0","json-stringify-safe":"5.0.1","safe-buffer":"5.2.1","aws-sign2":"0.7.0","aws4":"1.11.0","http-signature":"1.2.0","assert-plus":"1.0.0","sshpk":"1.16.1","safer-buffer":"2.1.2","asn1":"0.2.4","ecc-jsbn":"0.1.2","jsbn":"0.1.1","tweetnacl":"0.14.5","jsprim":"1.4.1","extsprintf":"1.3.0","verror":"1.10.0","core-util-is":"1.0.2","json-schema":"0.2.3","mime-types":"2.1.32","mime-db":"1.49.0","caseless":"0.12.0","forever-agent":"0.6.1","form-data":"2.3.3","combined-stream":"1.0.8","delayed-stream":"1.0.0","asynckit":"0.4.0","isstream":"0.1.2","is-typedarray":"1.0.0","qs":"6.5.3","har-validator":"5.1.5","ajv":"6.12.6","uri-js":"4.4.1","fast-deep-equal":"3.1.3","json-schema-traverse":"0.4.1","fast-json-stable-stringify":"2.1.0","har-schema":"2.0.0","uuid":"3.4.0","oauth-sign":"0.9.0","tunnel-agent":"0.6.0","performance-now":"2.1.0","https-proxy-agent":"5.0.1","ms":"2.1.2","agent-base":"6.0.2","lru_map":"0.3.3","cookie":"0.4.2","deepmerge":"4.3.0"},"event_id":"75e483eff0074be1a4fb018f2dd18625","timestamp":1696936573.829,"extra":{"release_channel":"stable","sentry":{"environment":"stable","release":"0.0.31"},"wm":"KDE,unknown","distro":"\"Manjaro Linux\""}}
Okt 10 13:16:37 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_low timeout, signaled seq=2933, emitted seq=2935
Okt 10 13:16:37 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Discord pid 1834 thread Discord:cs0 pid 1840
Okt 10 13:16:37 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset begin!
Okt 10 13:16:37 bernhard-82ra kernel: [drm] psp gfx command UNLOAD_TA(0x2) failed and response status is (0x117)
Okt 10 13:16:37 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: MODE2 reset
Okt 10 13:16:37 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset succeeded, trying to resume
Okt 10 13:16:37 bernhard-82ra kernel: [drm] PCIE GART of 1024M enabled.
Okt 10 13:16:37 bernhard-82ra kernel: [drm] PTB located at 0x000000F41FC00000
Okt 10 13:16:37 bernhard-82ra kernel: [drm] PSP is resuming...
Okt 10 13:16:37 bernhard-82ra kwin_wayland[709]: kwin_libinput: Libinput: event10 - SYNA2BA6:00 06CB:CE78 Touchpad: kernel bug: Touch jump detected and discarded.
Okt 10 13:16:38 bernhard-82ra kernel: [drm] reserve 0x400000 from 0xf41f400000 for PSP TMR
Okt 10 13:16:38 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
Okt 10 13:16:38 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
Okt 10 13:16:38 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Okt 10 13:16:38 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
Okt 10 13:16:38 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
Okt 10 13:16:38 bernhard-82ra kernel: [drm] DMUB hardware initialized: version=0x01010027
Okt 10 13:16:38 bernhard-82ra kernel: [drm] kiq ring mec 2 pipe 1 q 0
Okt 10 13:16:39 bernhard-82ra kernel: amdgpu 0000:04:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
Okt 10 13:16:39 bernhard-82ra kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <gfx_v9_0> failed -110
Okt 10 13:16:39 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset(2) failed
Okt 10 13:16:39 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset end with ret = -110
Okt 10 13:16:39 bernhard-82ra kernel: [drm] Skip scheduling IBs!
Okt 10 13:16:39 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* GPU Recovery Failed: -110
Okt 10 13:16:49 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_low timeout, signaled seq=2935, emitted seq=2938
Okt 10 13:16:49 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Discord pid 1834 thread Discord:cs0 pid 1840
Okt 10 13:16:49 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset begin!
Okt 10 13:16:49 bernhard-82ra kernel: ------------[ cut here ]------------
Okt 10 13:16:49 bernhard-82ra kernel: WARNING: CPU: 4 PID: 10 at drivers/gpu/drm/amd/amdgpu/amdgpu_irq.c:615 amdgpu_irq_put+0x46/0x70 [amdgpu]
Okt 10 13:16:49 bernhard-82ra kernel: Modules linked in: ccm ntfs3 rfcomm snd_seq_dummy snd_hrtimer snd_seq xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter br_netfilter bridge stp llc overlay qrtr cmac algif_hash algif_skcipher af_alg bnep joydev intel_rapl_msr mousedev intel_rapl_common amdgpu snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp edac_mce_amd snd_sof_pci mt7921e snd_sof_xtensa_dsp mt7921_common snd_ctl_led snd_sof btusb kvm_amd mt76_connac_lib snd_hda_codec_realtek snd_sof_utils btrtl hid_sensor_accel_3d snd_soc_core mt76 snd_hda_codec_generic hid_sensor_trigger btbcm industrialio_triggered_buffer btintel kvm snd_compress amdxcp ledtrig_audio irqbypass drm_buddy snd_hda_codec_hdmi btmtk kfifo_buf ac97_bus snd_hda_intel gpu_sched crct10dif_pclmul mac80211 snd_usb_audio uvcvideo snd_pcm_dmaengine hid_sensor_iio_common crc32_pclmul snd_intel_dspcfg i2c_algo_bit snd_usbmidi_lib snd_pci_ps bluetooth videobuf2_vmalloc
Okt 10 13:16:49 bernhard-82ra kernel:  polyval_clmulni snd_intel_sdw_acpi drm_suballoc_helper industrialio libarc4 uvc snd_rpl_pci_acp6x polyval_generic snd_ump drm_ttm_helper snd_hda_codec gf128mul snd_acp_pci vfat videobuf2_memops wacom ttm hid_multitouch ecdh_generic lenovo_ymc videobuf2_v4l2 hid_sensor_hub wmi_bmof snd_rawmidi snd_pci_acp6x snd_hda_core ghash_clmulni_intel fat snd_seq_device cfg80211 snd_pci_acp5x snd_hwdep sha512_ssse3 ideapad_laptop drm_display_helper videodev aesni_intel sparse_keymap snd_rn_pci_acp3x snd_pcm ucsi_acpi cec platform_profile crypto_simd snd_acp_config videobuf2_common typec_ucsi snd_timer cryptd sp5100_tco video snd_soc_acpi rapl mc usbhid snd pcspkr typec rfkill ccp amd_sfh k10temp snd_pci_acp3x soundcore i2c_piix4 roles soc_button_array wmi i2c_hid_acpi amd_pmc i2c_hid mac_hid uinput crypto_user loop fuse dm_mod bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 sdhci_pci vivaldi_fmap nvme cqhci sdhci crc32c_intel nvme_core xhci_pci i8042 xhci_pci_renesas
Okt 10 13:16:49 bernhard-82ra kernel:  mmc_core nvme_common serio
Okt 10 13:16:49 bernhard-82ra kernel: CPU: 4 PID: 10 Comm: kworker/u24:0 Not tainted 6.5.5-1-MANJARO #1 e9399f16590e7769efcdcd9f039e557ef90af6c1
Okt 10 13:16:49 bernhard-82ra kernel: Hardware name: LENOVO 82RA/LNVNB161216, BIOS JCCN36WW 06/09/2023
Okt 10 13:16:49 bernhard-82ra kernel: Workqueue: amdgpu-reset-dev drm_sched_job_timedout [gpu_sched]
Okt 10 13:16:49 bernhard-82ra kernel: RIP: 0010:amdgpu_irq_put+0x46/0x70 [amdgpu]
Okt 10 13:16:49 bernhard-82ra kernel: Code: c0 74 33 48 8b 4e 10 48 83 39 00 74 29 89 d1 48 8d 04 88 8b 08 85 c9 74 11 f0 ff 08 74 07 31 c0 e9 3f b4 a2 dc e9 5a fd ff ff <0f> 0b b8 ea ff ff ff e9 2e b4 a2 dc b8 ea ff ff ff e9 24 b4 a2 dc
Okt 10 13:16:49 bernhard-82ra kernel: RSP: 0018:ffffb661000d3c80 EFLAGS: 00010246
Okt 10 13:16:49 bernhard-82ra kernel: RAX: ffff954787ba2dc8 RBX: ffff954796f80000 RCX: 0000000000000000
Okt 10 13:16:49 bernhard-82ra kernel: RDX: 0000000000000000 RSI: ffff954796fa78b8 RDI: ffff954796f80000
Okt 10 13:16:49 bernhard-82ra kernel: RBP: ffff954796f80000 R08: 000000000003ac80 R09: 0000000000000006
Okt 10 13:16:49 bernhard-82ra kernel: R10: 0000000000000100 R11: 0000000000000000 R12: 0000000000001050
Okt 10 13:16:49 bernhard-82ra kernel: R13: ffff954796fc1230 R14: ffff9548b463d400 R15: 0000000000000000
Okt 10 13:16:49 bernhard-82ra kernel: FS:  0000000000000000(0000) GS:ffff954a7e700000(0000) knlGS:0000000000000000
Okt 10 13:16:49 bernhard-82ra kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Okt 10 13:16:49 bernhard-82ra kernel: CR2: 00001f150088713c CR3: 0000000218620000 CR4: 0000000000350ee0
Okt 10 13:16:49 bernhard-82ra kernel: Call Trace:
Okt 10 13:16:49 bernhard-82ra kernel:  <TASK>
Okt 10 13:16:49 bernhard-82ra kernel:  ? amdgpu_irq_put+0x46/0x70 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel:  ? __warn+0x81/0x130
Okt 10 13:16:49 bernhard-82ra kernel:  ? report_bug+0x171/0x1a0
Okt 10 13:16:49 bernhard-82ra kernel:  ? handle_bug+0x3c/0x80
Okt 10 13:16:49 bernhard-82ra kernel:  ? exc_invalid_op+0x17/0x70
Okt 10 13:16:49 bernhard-82ra kernel:  ? asm_exc_invalid_op+0x1a/0x20
Okt 10 13:16:49 bernhard-82ra kernel:  gfx_v9_0_hw_fini+0x35/0x710 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel:  amdgpu_device_ip_suspend_phase2+0x107/0x1a0 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel:  ? amdgpu_device_ip_suspend_phase1+0x71/0xe0 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel:  amdgpu_device_ip_suspend+0x36/0x70 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel:  amdgpu_device_pre_asic_reset+0xd3/0x2a0 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel:  amdgpu_device_gpu_recover+0x4c6/0xd70 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel:  amdgpu_job_timedout+0x186/0x270 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel:  ? finish_task_switch.isra.0+0x94/0x2f0
Okt 10 13:16:49 bernhard-82ra kernel:  drm_sched_job_timedout+0x7a/0x110 [gpu_sched c371f8587b46705e7af25f071221e66748dc0e99]
Okt 10 13:16:49 bernhard-82ra kernel:  process_one_work+0x1e1/0x3f0
Okt 10 13:16:49 bernhard-82ra kernel:  worker_thread+0x51/0x390
Okt 10 13:16:49 bernhard-82ra kernel:  ? __pfx_worker_thread+0x10/0x10
Okt 10 13:16:49 bernhard-82ra kernel:  kthread+0xe8/0x120
Okt 10 13:16:49 bernhard-82ra kernel:  ? __pfx_kthread+0x10/0x10
Okt 10 13:16:49 bernhard-82ra kernel:  ret_from_fork+0x34/0x50
Okt 10 13:16:49 bernhard-82ra kernel:  ret_from_fork_asm+0x1b/0x30
Okt 10 13:16:49 bernhard-82ra kernel:  </TASK>
Okt 10 13:16:49 bernhard-82ra kernel: ---[ end trace 0000000000000000 ]---
Okt 10 13:16:49 bernhard-82ra kernel: CPU: 4 PID: 10 Comm: kworker/u24:0 Tainted: G        W          6.5.5-1-MANJARO #1 e9399f16590e7769efcdcd9f039e557ef90af6c1
Okt 10 13:16:49 bernhard-82ra kernel: RAX: ffff954787ba2dd0 RBX: ffff954796f80000 RCX: 0000000000000000
Okt 10 13:16:49 bernhard-82ra kernel: RDX: 0000000000000000 RSI: ffff954796fa78d0 RDI: ffff954796f80000
Okt 10 13:16:49 bernhard-82ra kernel:  gfx_v9_0_hw_fini+0x46/0x710 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel: RSP: 0018:ffffb661000d3c98 EFLAGS: 00010246
Okt 10 13:16:49 bernhard-82ra kernel: RAX: ffff95478129fd68 RBX: ffff954796f80000 RCX: 0000000000000000
Okt 10 13:16:49 bernhard-82ra kernel: RDX: 0000000000000000 RSI: ffff954796f80c60 RDI: ffff954796f80000
Okt 10 13:16:49 bernhard-82ra kernel: RBP: ffff954796f80000 R08: 0000000000000000 R09: 0000000000000000
Okt 10 13:16:49 bernhard-82ra kernel: R10: 0000000000000001 R11: 0000000000000100 R12: 0000000000001050
Okt 10 13:16:49 bernhard-82ra kernel:  ? srso_return_thunk+0x5/0x10
Okt 10 13:16:49 bernhard-82ra kernel:  gmc_v9_0_hw_fini+0x6d/0x90 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Okt 10 13:16:49 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: MODE2 reset
Okt 10 13:16:49 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset succeeded, trying to resume
Okt 10 13:16:49 bernhard-82ra kernel: [drm] PCIE GART of 1024M enabled.
Okt 10 13:16:49 bernhard-82ra kernel: [drm] PTB located at 0x000000F41FC00000
Okt 10 13:16:49 bernhard-82ra kernel: [drm] PSP is resuming...
Okt 10 13:16:50 bernhard-82ra kernel: [drm] reserve 0x400000 from 0xf41f400000 for PSP TMR
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
Okt 10 13:16:50 bernhard-82ra kernel: [drm] DMUB hardware initialized: version=0x01010027
Okt 10 13:16:50 bernhard-82ra kernel: [drm] kiq ring mec 2 pipe 1 q 0
Okt 10 13:16:50 bernhard-82ra kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Okt 10 13:16:50 bernhard-82ra kernel: [drm] JPEG decode initialized successfully.
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring gfx_low uses VM inv eng 1 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring gfx_high uses VM inv eng 4 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 5 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 6 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 7 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 8 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 9 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 10 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 11 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 12 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 13 on hub 0
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 8
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 8
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 8
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 8
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 8
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: recover vram bo from shadow start
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: recover vram bo from shadow done
Okt 10 13:16:50 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: GPU reset(4) succeeded!
Okt 10 13:16:50 bernhard-82ra kernel: [drm] Skip scheduling IBs!
Okt 10 13:16:51 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:16:52 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:16:57 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:02 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:07 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:12 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:17 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:22 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:27 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:32 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:37 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:42 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:47 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:52 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:17:57 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
Okt 10 13:18:00 bernhard-82ra kwin_wayland[709]: Linux kernel version:                   6.5.5
That is dmesg of the Kernel. I don’t see where the error that is related to this issue.
Remember my post:
Or install journalctl-desktop-notification-git from AUR, it help to notify you automatically when any error log appears.
Do not forget to configure KDE setting → Autostart → Add a application journalctl-desktop-notification, then reboot.
If you get a notification of error log, then you can investigate what problem.
this yields
$ journalctl -b err -b
Failed to add match 'err': Invalid argument
I should imagine it was an err in syntax…
After that ad-lib, I might just skulk away, cheers.
Okay I did some Googling and found the solution to show the log (the first parameter is -p):
$journalctl -p err -b
Okt 11 03:32:50 bernhard-82ra systemd-modules-load[256]: Failed to find module 'acpi_call'
Okt 11 03:32:52 bernhard-82ra kernel: ucsi_acpi USBC000:00: error -EBUSY: PPM init failed
Okt 11 03:32:55 bernhard-82ra bluetoothd[467]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
Okt 11 03:32:55 bernhard-82ra bluetoothd[467]: Failed to clear UUIDs: Failed (0x03)
Okt 11 03:32:55 bernhard-82ra bluetoothd[467]: Failed to add UUID: Failed (0x03)
Okt 11 03:32:55 bernhard-82ra bluetoothd[467]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
Okt 11 03:32:55 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: Secure display: Generic Failure.
Okt 11 03:32:55 bernhard-82ra kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Okt 11 03:32:59 bernhard-82ra kwin_wayland[655]: kwin_wayland_drm: Atomic modeset commit failed! Invalid argument
Okt 11 03:33:02 bernhard-82ra bluetoothd[467]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Okt 11 03:33:03 bernhard-82ra plasmashell[991]: inotify_add_watch(/var/lib/samba/usershares) failed: (Permission denied)
Okt 11 03:33:10 bernhard-82ra wpa_supplicant[559]: bgscan simple: Failed to enable signal strength monitoring
Okt 11 03:34:34 bernhard-82ra kwin_wayland[655]: kwin_libinput: Libinput: event10 - SYNA2BA6:00 06CB:CE78 Touchpad: kernel bug: Touch jump detected and discarded.
                                                 See https://wayland.freedesktop.org/libinput/doc/1.24.0/touchpad-jumping-cursors.html for details
Okt 11 03:35:04 bernhard-82ra kwin_wayland[655]: kwin_libinput: Libinput: event10 - SYNA2BA6:00 06CB:CE78 Touchpad: kernel bug: Touch jump detected and discarded.
Okt 11 03:35:49 bernhard-82ra dolphin[3129]: inotify_add_watch(/var/lib/samba/usershares) failed: (Permission denied)
Okt 11 03:36:16 bernhard-82ra kwin_wayland[655]: kwin_libinput: Libinput: event10 - SYNA2BA6:00 06CB:CE78 Touchpad: kernel bug: Touch jump detected and discarded.
Okt 11 03:38:44 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_low timeout, signaled seq=46708, emitted seq=46710
Okt 11 03:38:44 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Discord pid 5039 thread Discord:cs0 pid 5044
Okt 11 03:38:46 bernhard-82ra kernel: amdgpu 0000:04:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
Okt 11 03:38:46 bernhard-82ra kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <gfx_v9_0> failed -110
Okt 11 03:38:46 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* GPU Recovery Failed: -110
Okt 11 03:38:56 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_low timeout, signaled seq=46710, emitted seq=46713
Okt 11 03:38:56 bernhard-82ra kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process plasmashell pid 991 thread plasmashel:cs0 pid 1012
Okt 11 03:38:58 bernhard-82ra bluetoothd[467]: Failed to remove UUID: Failed (0x03)
Okt 11 03:39:03 bernhard-82ra bluetoothd[467]: Failed to add UUID: Failed (0x03)
EDIT:
Turns out this has already been addressed upstream and will be fixed in some upcoming kernel update:
https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/commit/drivers/gpu/drm/amd?h=linux-6.5.y&id=2c4cc4d787a5f332f2c61f12cdb31e01da386439
