Frequent Freezing
I have been using Manjaro for about a year now.
The freezes have been happening since last week or so. There are no performance issues as such. I am not quite sure what causes a sudden freeze of the laptop. I am also unable to access tty at that time. The only option is to hold down the power button and reboot. This happens multiple times in a single day and is hence very frustrating.
I have included info about my system. I am not quite sure which logs have to be checked in order to find the cause of the freezes. Also, my hardware is not old nor weak.
inxi -Fxxxza
  Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=28b729f7-23bc-4e3a-af1e-1f1ce900608b rw quiet splash apparmor=1
  Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 3.38.2.1
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter>
  UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
  ID-1: BAT0 charge: 38.3 Wh (98.7%) condition: 38.8/48.1 Wh (80.8%)
  volts: 12.6 min: 11.7 model: FX50442 type: Li-ion serial: N/A
  status: Unknown
  Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
  model-id: 18 (24) stepping: 1 microcode: 8108102 cache: L2: 2 MiB
  bogomips: 33552
  Speed: 1225 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
  1: 1225 2: 1225 3: 1225 4: 1226 5: 1224 6: 1227 7: 1339 8: 1395
  disabled, RSB filling
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
  driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f91 class-ID: 0300
  Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
  bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus-ID: 3-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
  loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
  alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
  5.10.26-1-MANJARO LLVM 11.1.0)
  v: 4.6 Mesa 21.0.1 direct render: Yes
  Device-1: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.24 running: no
  vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
  vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce
  port: d000 bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 1-4:2 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 193.57 GiB (40.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
  size: 476.94 GiB block-size: physical: 512 B logical: 512 B
  speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 002C
  temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 125 GiB size: 122.48 GiB (97.98%)
  used: 50.09 GiB (40.9%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
  System Temperatures: cpu: 64.0 C mobo: N/A gpu: amdgpu temp: 64.0 C
  Fan Speeds (RPM): cpu: 3200
  Processes: 306 Uptime: 5m wakeups: 1 Memory: 22.99 GiB
  used: 2.36 GiB (10.3%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 Packages: pacman: 1344 lib: 342 flatpak: 0 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.03
lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
	Subsystem: ASUSTeK Computer Inc. Device 18f1
	Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
	Subsystem: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
	Flags: bus master, fast devsel, latency 0, IRQ 25
	Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
	Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 26, IOMMU group 1
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 0000f000-0000ffff [size=4K]
	Memory behind bridge: f6000000-f70fffff [size=17M]
	Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
	Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 2
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 0000e000-0000efff [size=4K]
	Memory behind bridge: f7800000-f78fffff [size=1M]
	Prefetchable memory behind bridge: [disabled]
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 3
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: [disabled]
	Memory behind bridge: f7700000-f77fffff [size=1M]
00:01.7 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 4
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff [size=4K]
	Memory behind bridge: f7600000-f76fffff [size=1M]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
	Flags: fast devsel, IOMMU group 5
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 6
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
	I/O behind bridge: 0000c000-0000cfff [size=4K]
	Memory behind bridge: f7200000-f75fffff [size=4M]
	Prefetchable memory behind bridge: 00000000e0000000-00000000f01fffff [size=258M]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
	Flags: 66MHz, medium devsel, IOMMU group 7
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
	Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 7
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
	Flags: fast devsel, IOMMU group 8
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: ASUSTeK Computer Inc. Device 109f
	Flags: bus master, fast devsel, latency 0, IRQ 69, IOMMU group 9
	Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
	Memory at c0000000 (64-bit, prefetchable) [size=256M]
	Memory at d0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at f000 [size=128]
	Expansion ROM at f7000000 [virtual] [disabled] [size=512K]
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: ASUSTeK Computer Inc. Device 208f
	Flags: bus master, fast devsel, latency 0, IRQ 63, IOMMU group 10
	I/O ports at e000 [size=256]
	Memory at f7804000 (64-bit, non-prefetchable) [size=4K]
	Memory at f7800000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: r8169
	Kernel modules: r8169
03:00.0 Non-Volatile memory controller: Intel Corporation SSD 660P Series (rev 03) (prog-if 02 [NVM Express])
	DeviceName: Onboard LAN Brodcom
	Subsystem: Intel Corporation Device 390d
	Flags: bus master, fast devsel, latency 0, IRQ 31, NUMA node 0, IOMMU group 11
	Memory at f7700000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: nvme
04:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
	Subsystem: AzureWave Device 3750
	Flags: bus master, fast devsel, latency 0, IRQ 68, IOMMU group 12
	I/O ports at d000 [size=256]
	Memory at f7600000 (64-bit, non-prefetchable) [size=64K]
	Kernel driver in use: rtw_8822ce
	Kernel modules: rtw88_8822ce
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso (rev c2) (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 13
	Memory at e0000000 (64-bit, prefetchable) [size=256M]
	Memory at f0000000 (64-bit, prefetchable) [size=2M]
	I/O ports at c000 [size=256]
	Memory at f7500000 (32-bit, non-prefetchable) [size=512K]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Flags: bus master, fast devsel, latency 0, IRQ 60, IOMMU group 14
	Memory at f7400000 (32-bit, non-prefetchable) [size=1M]
	Memory at f7588000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: ccp
	Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1 (prog-if 30 [XHCI])
	Subsystem: ASUSTeK Computer Inc. Device 201f
	Flags: bus master, fast devsel, latency 0, IRQ 42, IOMMU group 14
	Memory at f7300000 (64-bit, non-prefetchable) [size=1M]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1 (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 14
	Memory at f7200000 (64-bit, non-prefetchable) [size=1M]
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
	DeviceName: HD Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 67, IOMMU group 14
	Memory at f7580000 (32-bit, non-prefetchable) [size=32K]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
video-hybrid-amd-nvidia-prime            2020.11.30               false            PCI
I suggest try disabling gnome extensions and make sure you are in xorg session and not wayland since you have a nvidia card.
If it freezes again post a journalctl log as described in the manjaro wiki, to see what process was running before the freeze.
Yes, I have already disabled Wayland in gdm conf.
I’ll try this over the coming few days. But how does that help in getting to know what the problem is?
Thats very strange. I have asus tuf gaming a17 with very similar hardware. Fresh install and about for week no freezes or crashes.
But i have installed latest bios update (february release) on my laptop.
I have updated to the latest BIOS as well.
I forgot to mention, i have installed xfce4 edition. Maybe this edition makes some changes to system when installing.
This will help you figure out what is going on…
I mentioned the gnome extensions because they typically break after an upgrade of gnome version if the maintainer is not on top of it. To my knowledge we are currently in the process of getting gnome upgraded to gnome 40, and you can expect problems with extensions.
@zircon34 I had the extensions turned off and faced a similar freezing issue just now. I rebooted using the power button and got the journalctl logs. I used the Manjaro Logs Helper package that was installed by default to get them. I have generated journalctl -b -0 as well as journalctl -b -1. The size of the logs is 3.3MB. Hence, I have uploaded them to Google Drive.
https://drive.google.com/file/d/1jpn-n2Lgdv5RH5B78P5-VwEmAczLBAeb/view?usp=sharing
Please pastbin the log url. I am not clicking on personal google drive links… just fyi so others read your log and can help.
e.g for the last boot and post the link via:
journalctl -b -0 > /tmp/journal
cat /tmp/journal | curl -F 'f:1=<-' ix.io
Or you could post log from past 10 min (or change to something else if you like), which might be easier for troubleshooting.
journalctl --since "10 minutes ago" > /tmp/journal
And output the link here. There must be a more detailed manjaro how to provide good info in the forum. @Fabby is helpful with that.
Sorry about that. I did try pastebin and hastebin earlier but they complained that the logs were too long. I found this paste service to allow long logs.
https://del.dog/oresuningu
I am having the same issue, on an amd system with integrated gpu.
Maybe this info will help narrow down the issue.
inxi -Fxxxza
System:    Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64 root=UUID=0bac4e38-8a3e-4538-ab25-2f8dbcf58537 rw quiet
           udev.log_priority=3 nvme_core.default_ps_max_latency_us=5500 acpi_backlight=none
           Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 3.38.2.1 Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Laptop System: Acer product: Aspire A315-23 v: V1.14 serial: <filter>
           Mobo: DL model: Lotus_DA v: V1.14 serial: <filter> UEFI: Insyde v: 1.14 date: 02/18/2021
Battery:   ID-1: BAT1 charge: 32.7 Wh (100.0%) condition: 32.7/36.7 Wh (89.2%) volts: 12.8 min: 11.3 model: LGC AC14B18J
           type: Li-ion serial: <filter> status: Full
CPU:       Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen/Zen+
           note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 cache: L2: 2 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33615
           Speed: 1227 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1227 2: 2064 3: 1227 4: 1229 5: 1233
           6: 1233 7: 1306 8: 1398
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: Acer Incorporated ALI driver: amdgpu v: kernel
           Device-2: Quanta VGA WebCam type: USB driver: uvcvideo bus-ID: 1-1:2 chip-ID: 0408:a031 class-ID: 0e02
           serial: <filter>
           Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver: loaded: amdgpu display-ID: :1 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
           OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.10.26-1-MANJARO LLVM 11.1.0) v: 4.6 Mesa 21.0.1
           direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Acer Incorporated ALI
           driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
           Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Acer Incorporated ALI
           driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
           Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
Network:   Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci v: kernel
           bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
           v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
           chip-ID: 04ca:3015 class-ID: e001
Drives:    Local Storage: total: 476.94 GiB used: 141.99 GiB (29.8%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPNUW-512G-1014 size: 476.94 GiB
           block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD serial: <filter> rev: 20110000
           temp: 50.9 C scheme: GPT
Partition: ID-1: / raw-size: 100 GiB size: 97.93 GiB (97.93%) used: 52.7 GiB (53.8%) fs: ext4 dev: /dev/nvme0n1p7
           maj-min: 259:7
           ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%) used: 55.2 MiB (10.8%) fs: vfat dev: /dev/nvme0n1p6
           maj-min: 259:6
           ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 480 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9
           maj-min: 259:9
           ID-4: /home raw-size: 116 GiB size: 113.18 GiB (97.57%) used: 89.24 GiB (78.8%) fs: ext4 dev: /dev/nvme0n1p8
           maj-min: 259:8
Swap:      Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5
Sensors:   System Temperatures: cpu: 69.6 C mobo: N/A gpu: amdgpu temp: 69.0 C
Info:      Processes: 253 Uptime: 2h 00m wakeups: 1 Memory: 5.8 GiB used: 2.25 GiB (38.8%) Init: systemd v: 247
           tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1592 pacman: 1568 lib: 366 flatpak: 24 Shell: fish
           v: 3.2.1 running-in: alacritty inxi: 3.3.03
lspci -v
	Subsystem: Acer Incorporated [ALI] Device 1456
	Flags: fast devsel
	I/O behind bridge: 00003000-00003fff [size=4K]
	Memory behind bridge: c0c00000-c0dfffff [size=2M]
	Prefetchable memory behind bridge: 00000000c0e00000-00000000c0ffffff [size=2M]
	Memory behind bridge: c0200000-c03fffff [size=2M]
	I/O behind bridge: 00002000-00002fff [size=4K]
	Memory behind bridge: c0b00000-c0bfffff [size=1M]
00:01.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Memory behind bridge: c0a00000-c0afffff [size=1M]
	I/O behind bridge: 00001000-00001fff [size=4K]
	Memory behind bridge: c0500000-c09fffff [size=5M]
	Prefetchable memory behind bridge: 00000000b0000000-00000000c01fffff [size=258M]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 7
	Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
	Memory behind bridge: c0400000-c04fffff [size=1M]
	Flags: 66MHz, medium devsel, IOMMU group 8
	Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 8
	Flags: fast devsel, IOMMU group 9
02:00.0 Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
	Subsystem: Lite-On Communications Inc Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
	Flags: bus master, fast devsel, latency 0, IRQ 76, IOMMU group 10
	Memory at c0200000 (64-bit, non-prefetchable) [size=2M]
	Kernel driver in use: ath10k_pci
	Kernel modules: ath10k_pci
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Flags: bus master, fast devsel, latency 0, IRQ 71, IOMMU group 11
	I/O ports at 2000 [size=256]
	Memory at c0b04000 (64-bit, non-prefetchable) [size=4K]
	Memory at c0b00000 (64-bit, non-prefetchable) [size=16K]
04:00.0 Non-Volatile memory controller: Sandisk Corp WD Black 2018 / PC SN520 NVMe SSD (rev 01) (prog-if 02 [NVM Express])
	Subsystem: Sandisk Corp WD Black 2018 / PC SN520 NVMe SSD
	Flags: bus master, fast devsel, latency 0, IRQ 32, NUMA node 0, IOMMU group 12
	Memory at c0a00000 (64-bit, non-prefetchable) [size=16K]
	Flags: bus master, fast devsel, latency 0, IRQ 61, IOMMU group 13
	Memory at b0000000 (64-bit, prefetchable) [size=256M]
	Memory at c0000000 (64-bit, prefetchable) [size=2M]
	I/O ports at 1000 [size=256]
	Memory at c0900000 (32-bit, non-prefetchable) [size=512K]
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 78, IOMMU group 14
	Memory at c09c8000 (32-bit, non-prefetchable) [size=16K]
	Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 14
	Memory at c0800000 (32-bit, non-prefetchable) [size=1M]
	Memory at c09ce000 (32-bit, non-prefetchable) [size=8K]
	Kernel modules: ccp
	Flags: bus master, fast devsel, latency 0, IRQ 52, IOMMU group 14
	Memory at c0700000 (64-bit, non-prefetchable) [size=1M]
	Flags: bus master, fast devsel, latency 0, IRQ 61, IOMMU group 14
	Memory at c0600000 (64-bit, non-prefetchable) [size=1M]
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
	Flags: fast devsel, IRQ 71, IOMMU group 14
	Memory at c0980000 (32-bit, non-prefetchable) [size=256K]
	Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x
	Subsystem: Acer Incorporated [ALI] Device 1457
	Flags: bus master, fast devsel, latency 0, IRQ 79, IOMMU group 14
	Memory at c09c0000 (32-bit, non-prefetchable) [size=32K]
05:00.7 Non-VGA unclassified device: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/Renoir Non-Sensor Fusion Hub KMDF driver
	Memory at c0500000 (32-bit, non-prefetchable) [size=1M]
	Memory at c09cc000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: i2c_amd_mp2
	Kernel modules: i2c_amd_mp2_pci
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 61) (prog-if 01 [AHCI 1.0])
	Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 15
	Memory at c0400000 (32-bit, non-prefetchable) [size=2K]
	Kernel driver in use: ahci
mhwd -li
Here you go:
http://ix.io/2Woc
Although it is of journalctl -b -1
I have no idea what’s wrong, because my laptop on ubuntu freezing. But on manjaro xfce edition runs stable.
Here are some infos, maybe you will find something interesting.
inxi -Fxxxza
  Kernel: 5.11.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.11-x86_64
  root=UUID=cb7b9eda-fdc2-4158-858b-2ded15c385f9 rw rootflags=subvol=@
  cryptdevice=UUID=9f3dece4-1712-4996-b8ac-f43672c61d2b:luks-9f3dece4-1712-4996-b8ac-f43672c61d2b
  root=/dev/mapper/luks-9f3dece4-1712-4996-b8ac-f43672c61d2b apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706II_FA706II
  Mobo: ASUSTeK model: FA706II v: 1.0 serial: <filter>
  UEFI: American Megatrends v: FA706II.315 date: 01/29/2021
  ID-1: BAT1 charge: 41.9 Wh (97.0%) condition: 43.2/48.1 Wh (89.9%)
  volts: 12.6 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
  status: Unknown
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
  status: Discharging
  Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600104 cache: L2: 4 MiB
  bogomips: 92657
  Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397
  10: 1602 11: 1729 12: 1397 13: 1397 14: 1397 15: 1397 16: 1397
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
  chip-ID: 10de:1f95 class-ID: 0300
  Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
  bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
  bus-ID: 1-4:4 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,nvidia
  unloaded: modesetting,nouveau failed: ati alternate: fbdev,nv,vesa
  display-ID: :0.0 screens: 1
  Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 128 size: 382x215mm (15.0x8.5")
  diag: 438mm (17.3")
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.10-1-MANJARO LLVM 11.1.0)
  Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
  bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: DekTec Digital Video B.V. driver: N/A
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.11.10-1-MANJARO running: yes
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  port: d000 bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  bus-ID: 3-1:2 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 80.39 GiB (16.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AB
  speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: ECFK52.3
  temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 475.93 GiB size: 475.93 GiB (100.00%)
  used: 80.39 GiB (16.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-9f3dece4-1712-4996-b8ac-f43672c61d2b
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
  used: 720 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 475.93 GiB size: 475.93 GiB (100.00%)
  System Temperatures: cpu: 37.5 C mobo: N/A gpu: amdgpu temp: 33.0 C
  Fan Speeds (RPM): cpu: 2400
  Processes: 383 Uptime: 2h 27m wakeups: 5 Memory: 15.13 GiB
  used: 3.47 GiB (22.9%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1418 lib: 434 flatpak: 0
  Shell: Bash v: 5.1.0 running-in: gnome-terminal inxi: 3.3.03
lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
	Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
	Flags: bus master, fast devsel, latency 0, IRQ -2147483648
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
	Memory behind bridge: fb000000-fc0fffff [size=17M]
	Prefetchable memory behind bridge: 00000000b0000000-00000000c1ffffff [size=288M]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
	Flags: fast devsel, IOMMU group 2
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 3
	Memory behind bridge: fc900000-fc9fffff [size=1M]
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 4
	Memory behind bridge: fc800000-fc8fffff [size=1M]
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 5
	Memory behind bridge: fc700000-fc7fffff [size=1M]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
	Flags: fast devsel, IOMMU group 6
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode])
	Memory behind bridge: fc200000-fc5fffff [size=4M]
	Prefetchable memory behind bridge: 00000000d0000000-00000000e01fffff [size=258M]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 6
	Memory behind bridge: fc600000-fc6fffff [size=1M]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
	Subsystem: ASUSTeK Computer Inc. Device 1e21
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: ASUSTeK Computer Inc. Device 16ef
	Flags: bus master, fast devsel, latency 0, IRQ 76, IOMMU group 9
	Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
	Memory at c0000000 (64-bit, prefetchable) [size=32M]
	Expansion ROM at fc000000 [virtual] [disabled] [size=512K]
	Flags: bus master, fast devsel, latency 0, IRQ 55, IOMMU group 10
	Memory at fc904000 (64-bit, non-prefetchable) [size=4K]
	Memory at fc900000 (64-bit, non-prefetchable) [size=16K]
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
	Memory at fc800000 (64-bit, non-prefetchable) [size=64K]
04:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500c (rev 01) (prog-if 02 [NVM Express])
	Subsystem: Kingston Technology Company, Inc. Device 500c
	Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0, IOMMU group 12
	Memory at fc700000 (64-bit, non-prefetchable) [size=16K]
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c6) (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 58, IOMMU group 6
	Memory at d0000000 (64-bit, prefetchable) [size=256M]
	Memory at e0000000 (64-bit, prefetchable) [size=2M]
	Memory at fc500000 (32-bit, non-prefetchable) [size=512K]
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637
	Flags: bus master, fast devsel, latency 0, IRQ 74, IOMMU group 6
	Memory at fc5c8000 (32-bit, non-prefetchable) [size=16K]
	Flags: bus master, fast devsel, latency 0, IRQ 55, IOMMU group 6
	Memory at fc400000 (32-bit, non-prefetchable) [size=1M]
	Memory at fc5cc000 (32-bit, non-prefetchable) [size=8K]
	Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 46, IOMMU group 6
	Memory at fc300000 (64-bit, non-prefetchable) [size=1M]
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 (prog-if 30 [XHCI])
	Memory at fc200000 (64-bit, non-prefetchable) [size=1M]
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
	Subsystem: DekTec Digital Video B.V. Device 1043
	Flags: fast devsel, IRQ 69, IOMMU group 6
	Memory at fc580000 (32-bit, non-prefetchable) [size=256K]
	Subsystem: ASUSTeK Computer Inc. Device 1a0e
	Flags: bus master, fast devsel, latency 0, IRQ 75, IOMMU group 6
	Memory at fc5c0000 (32-bit, non-prefetchable) [size=32K]
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81) (prog-if 01 [AHCI 1.0])
	Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 6
	Memory at fc601000 (32-bit, non-prefetchable) [size=2K]
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81) (prog-if 01 [AHCI 1.0])
	Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 6
	Memory at fc600000 (32-bit, non-prefetchable) [size=2K]
mhwd -li
Also i installed via xfce installer and installed kde over it. But yesterday i have uninstalled kde and returned to xfce. Also i use 5.11 kernel.
Gnome is gtk and kde qt, system freeze may be a different issue. Although nvidia can bring these problems. I actually had freezes with gnome and switched now to kde then xfce…
Trying another kernel could help. There were a couple of hick ups for nvidia on 5.10 or could be the driver for integrated gpu that may work better with another kernel.
@Syzygianinfern0 Manjaro has a gui to install/switch kernel, you could ad lts to try or newer kernel, and reboot.
Edit: make sure to backup you system if you have sensitive data
Someone can hopefully inspect your logs posted above. Next steps are a bit over my head.
Great! What was the approximate time of system freeze? Too many lines to go trough… :sweat_smile:
After a little research i found this thread. Maybe you guys affected too?
Because AMD CPU/GPU.
I have absolutely no idea. It was at the end though. The logs were taken right after the reboot. The next time this happens, I’ll take a 10 minute log.
same with amd cpu & gpu
I have recently started facing these freezing issues, after the latest update. So I used time shift to go back to the previous version. I will try updating the system again to see if I can recreate the issue.
For anyone ā€œhard resettingā€ their laptop after it freezes, please check out this post.
I’m having complete system freezes on GNOME with Intel graphics. There is nothing strange in the journal because the system is unable to save the journal to disk after it freezes.
