Hello,
first bug report here, so please be nice^^
Since updating my system in the beginning of the year i’m getting frequent more or less random full freezes (not possible to get into tty2, or move the mouse), ocurring shortly after boot when i started working.
Sometimes it happens, sometimes it doesnt.
When I had this problem the first time, i thought it would have been solved after switching to kernel 5.10 (update included kernel update), but now after updating yesterday the problem seems to be back.
Really clueless here, but i guess im a noob, kindof…
Help would be appreciated much!
Greets
inxi -Fxz
Kernel: 5.10.102-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: KDE Plasma 5.24.2 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P8H77-V v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1603
date: 03/14/2013
Info: quad core model: Intel Core i5-3470 bits: 64 type: MCP
arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 1656 high: 1775 min/max: 1600/3600 cores: 1: 1775
2: 1600 3: 1651 4: 1600 bogomips: 25608
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
vendor: ASUSTeK P8H77-I driver: i915 v: kernel bus-ID: 00:02.0
Device-2: AMD Bonaire XT [Radeon HD 7790/8770 / R7 360 R9 260/360 OEM]
vendor: Micro-Star MSI driver: radeon v: kernel bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X:
loaded: ati,modesetting,radeon gpu: radeon resolution: 1: 1280x1024~60Hz
2: 1920x1080~60Hz
OpenGL: renderer: AMD BONAIRE (DRM 2.50.0 5.10.102-1-MANJARO LLVM 13.0.1)
v: 4.5 Mesa 21.3.7 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-3: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen type: USB
driver: snd-usb-audio bus-ID: 3-2:3
Sound Server-1: ALSA v: k5.10.102-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.47 running: no
Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK
driver: alx v: kernel port: d000 bus-ID: 03:00.0
Local Storage: total: 2.87 TiB used: 108.76 GiB (3.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZRX-00L4HB0
ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
ID-3: /dev/sdc vendor: SanDisk model: SSD PLUS 120GB size: 111.8 GiB
ID-4: /dev/sdd vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
ID-5: /dev/sde type: USB vendor: Kingston model: DataTraveler 2.0
ID-1: / size: 32.4 GiB used: 23.55 GiB (72.7%) fs: ext4 dev: /dev/sdc5
ID-2: /boot/efi size: 511 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sdc4
ID-3: /home size: 98.51 GiB used: 85.21 GiB (86.5%) fs: ext4
dev: /dev/sdd3
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
dev: /dev/sdd2
ID-2: swap-2 type: partition size: 3.96 GiB used: 0 KiB (0.0%)
dev: /dev/sdb7
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 35.0 C
Processes: 186 Uptime: 13m Memory: 17.46 GiB used: 3.1 GiB (17.7%)
Init: systemd Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1758
Shell: Bash v: 5.1.16 inxi: 3.3.13
journalctl --boot=-1 --priority=3 --catalog
Mär 06 06:44:21 joh-pc kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Mär 06 06:44:21 joh-pc systemd-udevd[238]: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:57 Unknown group 'uaccess', ignoring
Mär 06 07:45:04 joh-pc pulseaudio[647]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible ca>
Mär 06 07:57:11 joh-pc systemd-coredump[2724]: [🡕] Process 2289 (blender) of user 1000 dumped core.
Module /usr/bin/blender with build-id 536d01be9b154dac5a153918708c675a76118145
Stack trace of thread 2713:
#0 0x00007fe94957cb23 n/a (n/a + 0x0)
#1 0x00007fe9495ae368 n/a (n/a + 0x0)
░░ Subject: Speicherabbild für Prozess 2289 (blender) generiert
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Prozess 2289 (blender) ist abgebrochen worden und
░░ ein Speicherabbild wurde generiert.
░░ Üblicherweise ist dies ein Hinweis auf einen Programmfehler und sollte
░░ als Fehler dem jeweiligen Hersteller gemeldet werden.
Mär 06 08:22:11 joh-pc systemd-coredump[8164]: [🡕] Process 4754 (file:// Content) of user 1000 dumped core.
Module /usr/lib/firefox/liblgpllibs.so with build-id a4d0a07747ed629c7acf9abb13637ae2cf819d3b
Module linux-vdso.so.1 with build-id 0a3183f4bfd6d18e8697a77f1cac246cfcfc0940
Module libfreeblpriv3.so with build-id ff8e71be8b884b2ff950aef970eebc67672851b4
Module libsoftokn3.so with build-id ae0af3e0a39090b1e65e186f9196fabe41382643
Module libplds4.so with build-id e915f74a1aff6a20d65b5f03f5ee2e0197153a33
Module libX11-xcb.so.1 with build-id 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
Module libnssutil3.so with build-id 0d2b2fb3fdde7ea1ed8f4c95493516473435cdba
Module libnss3.so with build-id d2548c5d414574f214f87e4fd328d7a8bfc06931
Module libsmime3.so with build-id 78817b6406663629f3586cf4ff6dc4c32faa6785
Module libssl3.so with build-id a66542b0b26361679b5ebc0b5f06c53ad48f373b
Module libplc4.so with build-id 44dcd42fb72cc8aab586dbf4000293590bb19e67
Module libasound.so.2 with build-id b17fc1317a484842433c772360376623b64ec3d8
Module libxul.so with build-id 13ee2e9eb2029a228a56d306228f86ad92204682
Module libmozwayland.so with build-id acd9ed9b9b71141d7b7fcd0b5ba76ec1ae6c81c2
Module libgpg-error.so.0 with build-id 82524ee3d1c4c2244d7cfdcc1e6eea5f9855f6c6
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libcap.so.2 with build-id eb6dae97527fc89dbb0d5bb581a15acd02ae9f56
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module libsystemd.so.0 with build-id c9e19a3f6e503f05f60867b9240c1d59bf6c605e
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libzstd.so.1 with build-id 72f3511cba7db578f6a2647925f35664da6c838b
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id 9e4bb910a2e63ba71cae0e3b89c07fdd45033ff2
Module libxml2.so.2 with build-id 34aa03d6fadb52a051964f0e50a977efaea9482e
Module libjson-glib-1.0.so.0 with build-id 5865be5fcc01b48a0a113e0145ec45529bff89a6
Module libsqlite3.so.0 with build-id 132f0de53d66f5245cd1b1c863e1ec81f32ddebe
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libstemmer.so.0 with build-id aa44a40dfb223020ed8e49cd2d28fc3887128463
Module libatspi.so.0 with build-id de251156cf6f2f447c5e2b8721bd913d79995d4f
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Module libjpeg.so.8 with build-id 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
Module libexpat.so.1 with build-id 63a4ee083a938cbb472c2c4d32e1050474c94382
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libresolv.so.2 with build-id 46ffdf3d477a170314060c26927470d7399bc900
Module libmount.so.1 with build-id 765508fe9812e693ac41fd3d0aedd65d7a78b287
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libwayland-egl.so.1 with build-id 791e39283cdcc5a08cfd091b8cd4c59869a11278
Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a6474c
Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module librt.so.1 with build-id 4761858b348db8303e872e515aa8d56c046c921c
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id b0eee5a9b660fed5221ea15139e9608282320503
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
Module libatk-1.0.so.0 with build-id aacaa40363d304858b654728a893bc212a4ca119
Module libgdk_pixbuf-2.0.so.0 with build-id ca4beb15a30de8d8767f7bca8222038c61b58b36
Module libcairo-gobject.so.2 with build-id abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
Module libfontconfig.so.1 with build-id 9fdeb38479c4090d673efc2e8cb60176efe65da1
Module libpangoft2-1.0.so.0 with build-id 9b0353693557b4fb68124a9dffac9b07678d86a1
Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a8ad
Module libharfbuzz.so.0 with build-id 716df25c59c91f456ae107457e4250f7c32bde1b
Module libpango-1.0.so.0 with build-id f7a7e74f7ade4cbcf3840f685d760da19b0dc38c
Module libpangocairo-1.0.so.0 with build-id a47bf17ab99c1840764fca52a2d772800d81d6e1
Module libgio-2.0.so.0 with build-id c4e89ca22afc7f17db176d2063fe379dbc88d99b
Module libgobject-2.0.so.0 with build-id 6d7ff6c8e4e9c12caa92cf25a74d3ecdd9461c36
Module libglib-2.0.so.0 with build-id 24e675eddd4654b470e0a892f4a4aec012b04160
Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e61f6ac9e4
Module libgdk-3.so.0 with build-id 0d1048ff040bb420bc2b7da992590559226a1beb
Module libgtk-3.so.0 with build-id 237211b929fd493858b4269bbf63f407c24e0fb4
Module libmozgtk.so with build-id ef9373a19e9576b288ad15940aa9a9f82f27bc43
Module libmozsqlite3.so with build-id f8b46fc52c91a2df4c931a297aa20caa5dd56269
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libnspr4.so with build-id c5d12234f7975d11a11e67646533657d014d9540
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libmozsandbox.so with build-id f10268eb5777ce3b661c4f81aaeefaa840b35003
Module firefox with build-id 515ecd1ad22d030d63fa67e045f8466f18a228a4
Stack trace of thread 4754:
#0 0x000055cbc8f11bb6 mozalloc_abort (firefox + 0x65bb6)
#1 0x000055cbc8ecb8cd moz_xmalloc (firefox + 0x1f8cd)
#2 0x00007ff9fe0e08e0 n/a (libxul.so + 0x3d4d8e0)
#3 0x00007ff9fe1fa810 n/a (libxul.so + 0x3e67810)
#4 0x00007ff9ff4c3e35 n/a (libxul.so + 0x5130e35)
#5 0x00007ff9fe0d031f n/a (libxul.so + 0x3d3d31f)
#6 0x00007ff9fe906ec1 n/a (libxul.so + 0x4573ec1)
#7 0x00007ff9feea613e n/a (libxul.so + 0x4b1313e)
#8 0x00007ff9fee9527a n/a (libxul.so + 0x4b0227a)
#9 0x00007ff9fe1e51e5 n/a (libxul.so + 0x3e521e5)
#10 0x00007ff9fe1e6882 n/a (libxul.so + 0x3e53882)
#11 0x00007ff9fe1e48e4 n/a (libxul.so + 0x3e518e4)
#12 0x00007ff9fe1de6b2 n/a (libxul.so + 0x3e4b6b2)
#13 0x00007ff9fe1dc759 n/a (libxul.so + 0x3e49759)
#14 0x00007ff9fef77511 n/a (libxul.so + 0x4be4511)
#15 0x00007ffa012bd06d n/a (libxul.so + 0x6f2a06d)
#16 0x00007ff9fe1dc405 n/a (libxul.so + 0x3e49405)
#17 0x00007ff9fef77511 n/a (libxul.so + 0x4be4511)
#18 0x00007ff9ff190ba6 n/a (libxul.so + 0x4dfdba6)
#19 0x000055cbc8f01eb5 n/a (firefox + 0x55eb5)
#20 0x00007ffa0893d310 __libc_start_call_main (libc.so.6 + 0x2d310)
#21 0x00007ffa0893d3c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#22 0x000055cbc8f4d5a5 _start (firefox + 0xa15a5)
Stack trace of thread 4763:
#0 0x00007ffa0899a15a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007ffa0899c960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x000055cbc8f372ee _ZN7mozilla6detail21ConditionVariableImpl4waitERNS0_9MutexImplE (fire>
#3 0x00007ff9fe1ddad8 n/a (libxul.so + 0x3e4aad8)
#4 0x00007ff9fe86088a n/a (libxul.so + 0x44cd88a)
#5 0x00007ff9fef77511 n/a (libxul.so + 0x4be4511)
#6 0x00007ff9fef76fe0 n/a (libxul.so + 0x4be3fe0)
#7 0x00007ffa088f8008 n/a (libnspr4.so + 0x2b008)
#8 0x00007ffa0899d5c2 start_thread (libc.so.6 + 0x8d5c2)
#9 0x00007ffa08a22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 4760:
#2 0x00007ffa088f1469 PR_WaitCondVar (libnspr4.so + 0x24469)
#3 0x00007ff9ffe2cd73 n/a (libxul.so + 0x5a99d73)
#4 0x00007ffa088f8008 n/a (libnspr4.so + 0x2b008)
#5 0x00007ffa0899d5c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007ffa08a22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 4758:
#0 0x00007ffa08a1ba9d syscall (libc.so.6 + 0x10ba9d)
#1 0x00007ff9fe4c094a n/a (libxul.so + 0x412d94a)
#2 0x00007ff9fe4bfcfc n/a (libxul.so + 0x412ccfc)
#3 0x00007ff9fef77511 n/a (libxul.so + 0x4be4511)
#4 0x00007ff9ff51b619 n/a (libxul.so + 0x5188619)
#5 0x00007ffa032029ae n/a (libxul.so + 0x8e6f9ae)
#6 0x00007ffa0899d5c2 start_thread (libc.so.6 + 0x8d5c2)
#7 0x00007ffa08a22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 4759:
#0 0x00007ffa08a162af __poll (libc.so.6 + 0x1062af)
#1 0x00007ffa088f2edf n/a (libnspr4.so + 0x25edf)
#2 0x00007ff9fe45a866 n/a (libxul.so + 0x40c7866)
#3 0x00007ff9fe45a341 n/a (libxul.so + 0x40c7341)
#4 0x00007ff9fe1de96c n/a (libxul.so + 0x3e4b96c)
#5 0x00007ff9fe8607be n/a (libxul.so + 0x44cd7be)
#6 0x00007ff9fef77511 n/a (libxul.so + 0x4be4511)
#7 0x00007ff9fef76fe0 n/a (libxul.so + 0x4be3fe0)
#8 0x00007ffa088f8008 n/a (libnspr4.so + 0x2b008)
#9 0x00007ffa0899d5c2 start_thread (libc.so.6 + 0x8d5c2)
#10 0x00007ffa08a22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 4768:
Stack trace of thread 4761:
#1 0x00007ffa0899cc64 pthread_cond_timedwait@@GLIBC_2.3.2 (libc.so.6 + 0x8cc64)
#2 0x000055cbc8f3742f _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERK>
#3 0x00007ff9fe8b3cd6 n/a (libxul.so + 0x4520cd6)
Stack trace of thread 4779:
#3 0x00007ff9fe84ea1f n/a (libxul.so + 0x44bba1f)
Stack trace of thread 4762:
Stack trace of thread 4765:
Stack trace of thread 4766:
Stack trace of thread 4767:
Stack trace of thread 4771:
Stack trace of thread 4777:
Stack trace of thread 4778:
Stack trace of thread 4780:
Stack trace of thread 4795:
#2 0x00007ff9fee21d54 _ZN10rayon_core8registry12WorkerThread15wait_until_cold17h5993273167c>
#3 0x00007ff9ff1fff97 _ZN10rayon_core8registry13ThreadBuilder3run17hfa133bb9ad16cd1eE (libx>
#4 0x00007ff9ff1ff76e n/a (libxul.so + 0x4e6c76e)
#5 0x00007ff9ff1ff695 n/a (libxul.so + 0x4e6c695)
#6 0x00007ffa0313bc33 n/a (libxul.so + 0x8da8c33)
#7 0x00007ffa0899d5c2 start_thread (libc.so.6 + 0x8d5c2)
#8 0x00007ffa08a22584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 4796:
Stack trace of thread 4811:
#1 0x00007ffa07393066 n/a (libglib-2.0.so.0 + 0xab066)
#2 0x00007ffa0733a485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
#3 0x00007ffa0733a4d2 n/a (libglib-2.0.so.0 + 0x524d2)
#4 0x00007ffa0736c845 n/a (libglib-2.0.so.0 + 0x84845)
Stack trace of thread 6344:
#3 0x00007ff9ff4b91d5 n/a (libxul.so + 0x51261d5)
Stack trace of thread 4764:
Stack trace of thread 4794:
░░ Subject: Speicherabbild für Prozess 4754 (file:// Content) generiert
░░ Prozess 4754 (file:// Content) ist abgebrochen worden und
