Frequent desktop lock-ups when dragging smplayer window, since 2024-10-10
I wonder if anyone else has come across this and if so, if they’ve found a fix.
I hadn’t seen the problem before 2024-10-10, so it seems clear something in that update is triggering it.
When I drag an Smplayer window, the entire desktop freezes. Though the audio from Smplayer continues to play (so it’s very much screen-related). The whole thing seems un-recoverable; I’ve tried logging into a TTY and running plasmashell --replace, to no avail. Also tried sudo systemctl restart sddm, which does force another login (it’s configured to automatically log into my session) but that just brings up a broken desktop which is unresponsive, so the only way round it seems to be to reboot.
It only seems to be Smplayer, I haven’t seen the problem with any other software.
[Edit]: turns out it isn’t just Smplayer, as I’ve have the same problem when dragging a Thunderbird window. So evidentely that was just coincidence.
The journal doesn’t seem to give any useful clues; the only mention of Smplayer is multiple complaints from kmix - org.kde.kmix: No such icon "SMPlayer"
This is an AMD system running Plasma on Xorg, fully up-to-date with the latest upgrade.
Output of journal at the time of the problem:
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.830] [DBG] PwPipelineManager::on_registry_global: Stream/Output/Audio 67 SoX with serial 1462 has been added
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.832] [DBG] AppConfig::isAppBlocked: SoX is not blocked
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.833] [DBG] PwPipelineManager::on_registry_global: SoX port 81 is connected to jamesdsp_sink port 74
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.833] [DBG] PwPipelineManager::on_registry_global: SoX port 69 is connected to jamesdsp_sink port 63
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.833] [DBG] PwPipelineManager::on_metadata_property: new metadata property: 67, target.node, Spa:Id, 55
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.834] [DBG] PwPipelineManager::on_metadata_property: new metadata property: 67, target.object, Spa:Id, 1355
Oct 27 12:53:08 antwerp kmix[1768760]: org.kde.kmix: No such icon "SMPlayer"
Oct 27 12:53:08 antwerp kmix[1768760]: adding 3 mixers
Oct 27 12:53:08 antwerp kmix[1768760]: mixer "PulseAudio::Playback_Devices:1" "Playback Devices"
Oct 27 12:53:08 antwerp kmix[1768760]: PulseAudio adding 2 devices
Oct 27 12:53:08 antwerp kmix[1768760]: mixer "PulseAudio::Capture_Devices:1" "Capture Devices"
Oct 27 12:53:08 antwerp kmix[1768760]: PulseAudio adding 1 devices
Oct 27 12:53:08 antwerp kmix[1768760]: mixer "PulseAudio::Playback_Streams:1" "Playback Streams"
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.851] [DBG] PwPipelineManager::on_destroy_node_proxy: Stream/Output/Audio 67 SoX hasbeen removed
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.852] [DBG] PwPipelineManager::on_metadata_property: new metadata property: 67,
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.866] [DBG] PwPipelineManager::on_registry_global: Stream/Output/Audio 67 SoX with serial 1468 has been added
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.867] [DBG] AppConfig::isAppBlocked: SoX is not blocked
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.868] [DBG] PwPipelineManager::on_registry_global: SoX port 69 is connected to jamesdsp_sink port 74
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.868] [DBG] PwPipelineManager::on_registry_global: SoX port 79 is connected to jamesdsp_sink port 63
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.869] [DBG] PwPipelineManager::on_metadata_property: new metadata property: 67, target.node, Spa:Id, 55
Oct 27 12:53:08 antwerp jamesdsp[1768755]: [12:53:08.869] [DBG] PwPipelineManager::on_metadata_property: new metadata property: 67, target.object, Spa:Id, 1355
Oct 27 12:53:10 antwerp jamesdsp[1768755]: [12:53:10.841] [DBG] PwPipelineManager::on_destroy_node_proxy: Stream/Output/Audio 67 SoX hasbeen removed
Oct 27 12:53:10 antwerp jamesdsp[1768755]: [12:53:10.841] [DBG] PwPipelineManager::on_metadata_property: new metadata property: 67, , ,
Oct 27 12:53:10 antwerp kmix[1768760]: org.kde.kmix: No such icon "SMPlayer"
Oct 27 12:53:10 antwerp kmix[1768760]: adding 3 mixers
Oct 27 12:53:10 antwerp kmix[1768760]: mixer "PulseAudio::Playback_Devices:1" "Playback Devices"
Oct 27 12:53:10 antwerp kmix[1768760]: PulseAudio adding 2 devices
Oct 27 12:53:10 antwerp kmix[1768760]: mixer "PulseAudio::Capture_Devices:1" "Capture Devices"
Oct 27 12:53:10 antwerp kmix[1768760]: PulseAudio adding 1 devices
Oct 27 12:53:10 antwerp kmix[1768760]: mixer "PulseAudio::Playback_Streams:1" "Playback Streams"
output of inxi --full --admin --filter --width
Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=44065c64-593e-46ce-8be7-c07b0a031786 rw udev.log_priority=3
audit=0 consoleblank=0 sysrq_always_enabled=1 mitigations=off
amdgpu.noretry=0 idle=nomwait amd_iommu=on iommu=pt libata.force=noncq
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
wm: kwin_x11 tools: xscreensaver vt: 2 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
UEFI: American Megatrends v: 4011 date: 04/19/2018
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1374 min/max: 1600/3850 boost: disabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1374 2: 1374 3: 1374
4: 1374 bogomips: 30752
Type: retbleed status: Vulnerable
Type: spec_rstack_overflow status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK PRIME driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 07:00.0 chip-ID: 1002:15dd class-ID: 0300 temp: 52.0 C
Device-2: Realtek RTL2838 DVB-T driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 0bda:2838
class-ID: 0000 serial: <filter>
Device-3: Realtek RTL2838 DVB-T driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 0bda:2838
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung C24F390
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (radeonsi
raven LLVM 18.1.8 DRM 3.59 6.11.2-4-MANJARO) device-ID: 1002:15dd
memory: 1000 MiB unified: no
API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 24.2.4-arch1.0.1
device-ID: 1002:15dd surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off tools: jack_control
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Info: services: httpd, ntpd, sshd, systemd-timesyncd
Local Storage: total: 14.74 TiB used: 2.61 TiB (17.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000VN004-3CP101
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD30EZRX-00D8PB0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Intel model: SSDSC2BB080G4
size: 74.53 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0355 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Seagate model: OneTouch HDD
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1707 scheme: GPT
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-1: / raw-size: 29.3 GiB size: 28.67 GiB (97.86%) used: 20.29 GiB (70.8%)
fs: ext4 block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
used: 4.1 MiB (1.4%) fs: vfat block-size: 512 B dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 82.2 GiB size: 80.36 GiB (97.75%)
used: 35.03 GiB (43.6%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-4: /var/tmp raw-size: 150 GiB size: 146.59 GiB (97.72%)
used: 1.73 GiB (1.2%) fs: ext4 block-size: 4096 B dev: /dev/dm-9
maj-min: 254:9 mapped: 8T-vartmp
Kernel: swappiness: 0 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 14.65 GiB used: 0 KiB (0.0%) priority: 2
dev: /dev/sdb1 maj-min: 8:17
ID-2: swap-2 type: partition size: 13.67 GiB used: 0 KiB (0.0%)
priority: 200 dev: /dev/sdd4 maj-min: 8:52
System Temperatures: cpu: 51.2 C mobo: 37.0 C gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): cpu: 985 fan-2: 1430
Power: 12v: N/A 5v: N/A 3.3v: 3.27 vbat: 3.14
Memory: total: 32 GiB note: est. available: 30.29 GiB used: 4.82 GiB (15.9%)
Processes: 311 Power: uptime: 2h 33m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.1 GiB services: org_kde_powerdevil
Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1945 libs: 351 tools: octopi,pamac,yay
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.36
Does Wayland work OK on your setup, and if so, does smplayer behave? x11 isn’t getting a lot of support these days and bugs are creeping in which probably won’t get fixed.
Unfortunately not. I’ve tried it a few times but never managed to get it working properly.
I was hoping this wouldn’t be the case.
Maybe the logs will reveal something e.g. journalctl -b -1 | tail -200 or some other log? (I’ll probably need to defer to others for which ones).
I do wonder (though unlikely) if having swap split over 2 disks, one GPT and the other MBR, might have some effect.
Im using Smplayer on my Full AMD Laptop (Wayland) and also my Intel/Nvidia PC (X11) and both system with KDE. Smplayer working flawless for my systems under KDE :man_shrugging:
Maybe it depends on the content? Did you play a mp4 file or Video file and which Video codec are in use?
Which Engine are you using on SMPlayer? Im using other… /usr/bin/mpv
Try to choose the other Multimedia engines under General.
It would also interesting to see if this freeze happen with VLC also.
Here’s a thought: any desktop effects which might influence this? Try turning them off temporarily.
… Although I have “Wobbly Windows” and can jiggle a video window round while it’s playing …
I am on Wayland, though; it did work when I was still using x11 but that was well over a year ago.
Sanity check: same in a Live session?
As I mentioned, the only reference to smplayer in the journal was kmix complaining about a missing icon. Nothing else I could find.
A bit of a red herring, that one. I’ve actually got swap disabled at the moment (doing a bit of experimentation since doubling my RAM to 32G). But thanks for the suggestion.
That’s a very useful thought. Funnily enough, I tried disabling wobbly windows, to no effect. But I didn’t think of trying to switch all effects off. Thanks.
I’m playing Matroska files (DVD/Blue Ray ripped with Makemkv). Using the MPV driver too. No freeze with VLC - I may end up going back to that, although I was really liking the Smplayer interface.
Maybe it is actually one of the smplayer configurations. It would be worth moving its config file(s) temporarily e.g. start with this:
mv ~/.config/smplayerrc ~/.config/smplayerrc.bak
…after closing smplayer, then it should re-create it on re-launch.
This process is easily reversible.
You may also try the same with the ~/.config/smplayer directory but without the trailing / (remove it if present, if you use autocomplete) when moving, so it’s the whole directory.
I would recommend to use Reisub magic syskeys or how they called:
alt+print+f to free your memory, to restore your system.
Matroska is just the container, i think the codec should be h264 or h265 then?
Here’s a link to the REISUB guide for reference:
Also, something I forgot to ask:
Any difference in behaviour whether something is playing or not, when you move the window?
From your description it does seem perhaps compositing related.
That said, smplayer is my default on Manjaro KDE, and I’ve seen so issues (AMD graphics).
Perhaps see how it performs under Wayland.
Likely unrelated:-
If there is a later BIOS available it might be worth updating it:
Thanks for the suggestion. In the end it turns out to be un-necessary as since posting I’ve had a lockup when Smplayer wasn’t running, so it was evidently just a coincidence that I’d only seen problems with it.
Thanks. I’m trying running with compositing completely disabled and I’ll see how things go with that. As it is, it turns out that Smplayer was a red-herring, as I’ve had another lockup dragging a Thunderbird window when Smplayer wasn’t even running. So evidently it’s more general.
I have to admit to wimping out of BIOS updates as I’m terrified of not being able to recover my computer if something goes wrong. Sad, isn’t it?
Many seem to feel that way about using terminal commands.
Fear of the (as yet) unknown, I guess. :man_shrugging:
Updating BIOS is usually a straight-forward process, though it can vary from one manufacturer to another. The main thing to keep in mind is not to do something stupid; like randomly banging on the keyboard or powering off before the new BIOS software has finished being written. :grimacing:
Have you considered switching to Wayland?
I see you’re using AMD graphics which typically play better with Wayland. Perhaps it’s worth trying to see if the issue goes away. In fact, you might even find Wayland generally more performant.
Something else you could try is switching to Testing branch for a while, and seeing if the new Kernel 6.12 (LTS) makes a difference. It’s expected to be in Stable sometime in November, so you could switch back when that happens.
Nothing else comes to mind.
Good luck.
I think it’s the fact that I’m confident I can recover from pretty much any mess-up on my OS itself, but would be stuck if I bricked my motherboard with a BIOS update that went wrong.
I’ve tried Wayland a few times without any success. Though the fact that there’s still no way to remap my mouse keys as I can with Xorg means I’ve probably given up more quickly than I would otherwise.
However, since I had a similar lock-up today without Smplayer running (dragging a Thunderbird window) I’m trying with compositing disabled; so far without lock-ups. If this stays stable I’ll try disabling all my desktop effects then just re-enabling them one by one.
Sounds like a decent plan.
Maybe you have an older (still) incompatible widget somewhere; or perhaps old/unused settings under ~/.config that might be causing issues. Emptying/deleting the ~/.cache directory could possibly help (do that from a TTY while you’re at the SDDM login screen).
Cheers.
It’s already here for us Stable users:
mhwd-kernel -l
available kernels:
  • linux419
  • linux510
  • linux515
  • linux54
  • linux61
  • linux610
  • linux611
  • linux612
  • linux66
  • linux61-rt
  • linux610-rt
  • linux611-rt
  • linux66-rt"]
:smiley_cat:
Are you sure about that? I normally don’t consider release candidates to be “proper” releases:
mbn info linux612 -q
Branch         : unstable
Version        : 6.12.0rc5-1
Repository     : core
Build Date     : Mon 28 Oct 2024 12:37:50
Packager       : Manjaro Build Server <build@manjaro.org>
Branch         : testing
Version        : 6.12.0rc4-1
Repository     : core
Build Date     : Mon 21 Oct 2024 11:01:58
Branch         : stable
Version        : 6.12.0rc2-2
Repository     : core
Build Date     : Tue 08 Oct 2024 22:09:33
