Freezing when using Zoom or Skype, only sound is looping
Hello,
sometimes when I am using Zoom or Skype suddenly the screen freezes and the system doesn’t react to anything I’m trying. The only solution I found to leave this state is to press the power button …
However, the last maybe two seconds of sound start to repeat and this won’t stop even if I wait for like 30 minutes.
Here is a log files created with Manjaro log-helper:
Generated on 2020-10-25 21:13:1603656838
#################### inxi -Fxzc0 ########################
System:    Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.14.2
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Acer product: Aspire F5-573G v: V1.27 serial: <filter>
           Mobo: Acer model: Captain_SK v: V1.27 serial: <filter> UEFI: Insyde v: 1.27
           date: 05/26/2017
Battery:   ID-1: BAT1 charge: 33.5 Wh condition: 33.5/62.2 Wh (54%) model: PANASONIC AS16B5J
           status: Full
CPU:       Topology: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber Lake
           rev: 9 L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23209
           Speed: 700 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 705 2: 738 3: 792 4: 752
Graphics:  Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915 v: kernel
           bus ID: 00:02.0
           Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: Acer Incorporated ALI
           driver: nouveau v: kernel bus ID: 01:00.0
           Device-3: Realtek HD WebCam type: USB driver: uvcvideo bus ID: 1-7:4
           Display: x11 server: X.Org 1.20.9 driver: intel,nouveau unloaded: modesetting
           s-res: 1920x1080
           OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.8
           direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
           driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k5.9.1-1-MANJARO
Network:   Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On
           driver: ath10k_pci v: kernel port: 4000 bus ID: 03:00.0
           vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000 bus ID: 04:00.1
           IF: enp4s0f1 state: down mac: <filter>
           Device-3: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
           bus ID: 1-5:3
Drives:    Local Storage: total: 1.14 TiB used: 195.38 GiB (16.7%)
           ID-1: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
           ID-2: /dev/sdb vendor: SK Hynix model: HFS256G39TND-N210A size: 238.47 GiB
Partition: ID-1: / size: 156.90 GiB used: 26.58 GiB (16.9%) fs: ext4 dev: /dev/sdb5
           ID-2: /home size: 732.36 GiB used: 168.78 GiB (23.0%) fs: ext4 dev: /dev/sda1
Swap:      ID-1: swap-1 type: file size: 16.00 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:   System Temperatures: cpu: 40.0 C mobo: N/A gpu: nouveau temp: 35 C
Info:      Processes: 205 Uptime: 1h 58m Memory: 7.65 GiB used: 2.03 GiB (26.5%) Init: systemd
           Compilers: gcc: 10.2.0 Packages: 1119 Client: Unknown Client: wrapper-2.0 inxi: 3.1.05
And here a sorted out result of
journalctl -x -p3 | sed -e "s/$HOSTNAME/HOST/gI" -e "s/$USER/USER/gI"
I also left in the 15 oktober, where I remember the same happened with zoom. Today it happened when I was using skype.
-- Logs begin at Fri 2020-10-09 14:01:27 CEST, end at Sun 2020-10-25 21:36:02 CET. --
Okt 15 13:39:58 HOST kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ IBUS ]
Okt 15 13:40:00 HOST systemd-coredump[948]: Process 570 (Xorg) of user 0 dumped core.
                                                Stack trace of thread 570:
                                                #0  0x00007fa2181e5615 raise (libc.so.6 + 0x3d615)
                                                #1  0x00007fa2181ce862 abort (libc.so.6 + 0x26862)
                                                #2  0x0000559aad9fc38a OsAbort (Xorg + 0x14a38a)
                                                #3  0x0000559aad9fde51 FatalError (Xorg + 0x14be51)
                                                #4  0x0000559aada03aa9 n/a (Xorg + 0x151aa9)
                                                #5  0x00007fa2181e56a0 __restore_rt (libc.so.6 + 0x3d6a0)
                                                #6  0x00007fa2181e5615 raise (libc.so.6 + 0x3d615)
                                                #7  0x00007fa2181ce862 abort (libc.so.6 + 0x26862)
                                                #8  0x00007fa2181ce747 __assert_fail_base.cold (libc.so.6 + 0x26747)
                                                #9  0x00007fa2181ddbf6 __assert_fail (libc.so.6 + 0x35bf6)
                                                #10 0x0000559aad947930 n/a (Xorg + 0x95930)
                                                #11 0x00007fa206ea4fb9 glamor_init (libglamoregl.so + 0xcfb9)
                                                #12 0x00007fa20700e04d n/a (modesetting_drv.so + 0x1404d)
                                                #13 0x0000559aad92b40e AddGPUScreen (Xorg + 0x7940e)
                                                #14 0x0000559aada37819 n/a (Xorg + 0x185819)
                                                #15 0x0000559aada56520 n/a (Xorg + 0x1a4520)
                                                #16 0x0000559aada6ce61 n/a (Xorg + 0x1bae61)
                                                #17 0x0000559aada6d462 n/a (Xorg + 0x1bb462)
                                                #18 0x0000559aad9fbfd1 n/a (Xorg + 0x149fd1)
                                                #19 0x0000559aad9f78a0 WaitForSomething (Xorg + 0x1458a0)
                                                #20 0x0000559aad8eb8e4 n/a (Xorg + 0x398e4)
                                                #21 0x00007fa2181d0152 __libc_start_main (libc.so.6 + 0x28152)
                                                #22 0x0000559aad8ec5ae _start (Xorg + 0x3a5ae)
                                                Stack trace of thread 632:
                                                #0  0x00007fa21809d6a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
                                                #1  0x00007fa21745ae60 n/a (intel_drv.so + 0xb4e60)
                                                #2  0x00007fa2180973e9 start_thread (libpthread.so.0 + 0x93e9)
                                                #3  0x00007fa2182a8293 __clone (libc.so.6 + 0x100293)
                                                Stack trace of thread 941:
                                                #1  0x00007fa1eac97cfc n/a (nouveau_dri.so + 0x4b0cfc)
                                                #2  0x00007fa1eac966f8 n/a (nouveau_dri.so + 0x4af6f8)
                                                #3  0x00007fa2180973e9 start_thread (libpthread.so.0 + 0x93e9)
                                                #4  0x00007fa2182a8293 __clone (libc.so.6 + 0x100293)
                                                Stack trace of thread 657:
                                                #1  0x00007fa216171b3c n/a (i965_dri.so + 0x51eb3c)
                                                #2  0x00007fa216170e58 n/a (i965_dri.so + 0x51de58)
                                                Stack trace of thread 658:
                                                Stack trace of thread 659:
                                                Stack trace of thread 660:
                                                Stack trace of thread 940:
                                                Stack trace of thread 942:
                                                Stack trace of thread 943:
░░ Subject: Speicherabbild für Prozess 570 (@COREDUMP_COMM) generiert
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Prozess 570 (Xorg) ist abgebrochen worden und
░░ ein Speicherabbild wurde generiert.
░░ Üblicherweise ist dies ein Hinweis auf einen Programmfehler und sollte
░░ als Fehler dem jeweiligen Hersteller gemeldet werden.
Okt 15 13:44:47 HOST lightdm[1021]: gkr-pam: unable to locate daemon control file
Okt 15 13:52:36 HOST kernel: irq 16: nobody cared (try booting with the "irqpoll" option)
Okt 15 13:52:36 HOST kernel: handlers:
Okt 15 13:52:36 HOST kernel: [<00000000f3e48925>] idma64_irq [idma64]
Okt 15 13:52:36 HOST kernel: [<00000000bb43db24>] i2c_dw_isr
Okt 15 13:52:36 HOST kernel: [<000000002f23fd09>] i801_isr [i2c_i801]
Okt 15 13:52:36 HOST kernel: Disabling IRQ #16
Okt 15 15:25:48 HOST lightdm[4941]: gkr-pam: unable to locate daemon control file
Okt 15 17:28:17 HOST lightdm[6884]: gkr-pam: unable to locate daemon control file
Okt 15 17:53:19 HOST lightdm[7520]: gkr-pam: unable to locate daemon control file
Okt 15 18:37:00 HOST lightdm[8226]: gkr-pam: unable to locate daemon control file
-- Reboot --
Okt 15 20:16:46 HOST kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ IBUS ]
Okt 15 20:16:50 HOST kernel: irq 16: nobody cared (try booting with the "irqpoll" option)
Okt 15 20:16:50 HOST kernel: handlers:
Okt 15 20:16:50 HOST kernel: [<00000000a0eac1b5>] i801_isr [i2c_i801]
Okt 15 20:16:50 HOST kernel: [<00000000a1f76337>] idma64_irq [idma64]
Okt 15 20:16:50 HOST kernel: [<000000007af3dbe6>] i2c_dw_isr
Okt 15 20:16:50 HOST kernel: Disabling IRQ #16
Okt 15 20:16:58 HOST lightdm[962]: gkr-pam: unable to locate daemon control file
Okt 15 21:02:12 HOST lightdm[2478]: gkr-pam: unable to locate daemon control file
-- Reboot --
Okt 15 22:12:18 HOST kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ IBUS ]
Okt 15 22:12:21 HOST systemd-coredump[949]: Process 623 (Xorg) of user 0 dumped core.
                                                Stack trace of thread 623:
                                                #0  0x00007fc188229615 raise (libc.so.6 + 0x3d615)
                                                #1  0x00007fc188212862 abort (libc.so.6 + 0x26862)
                                                #2  0x00005572bbf6c38a OsAbort (Xorg + 0x14a38a)
                                                #3  0x00005572bbf6de51 FatalError (Xorg + 0x14be51)
                                                #4  0x00005572bbf73aa9 n/a (Xorg + 0x151aa9)
                                                #5  0x00007fc1882296a0 __restore_rt (libc.so.6 + 0x3d6a0)
                                                #6  0x00007fc188229615 raise (libc.so.6 + 0x3d615)
                                                #7  0x00007fc188212862 abort (libc.so.6 + 0x26862)
                                                #8  0x00007fc188212747 __assert_fail_base.cold (libc.so.6 + 0x26747)
                                                #9  0x00007fc188221bf6 __assert_fail (libc.so.6 + 0x35bf6)
                                                #10 0x00005572bbeb7930 n/a (Xorg + 0x95930)
                                                #11 0x00007fc182ef3fb9 glamor_init (libglamoregl.so + 0xcfb9)
                                                #12 0x00007fc18307b04d n/a (modesetting_drv.so + 0x1404d)
                                                #13 0x00005572bbe9b40e AddGPUScreen (Xorg + 0x7940e)
                                                #14 0x00005572bbfa7819 n/a (Xorg + 0x185819)
                                                #15 0x00005572bbfc6520 n/a (Xorg + 0x1a4520)
                                                #16 0x00005572bbfdce61 n/a (Xorg + 0x1bae61)
                                                #17 0x00005572bbfdd462 n/a (Xorg + 0x1bb462)
                                                #18 0x00005572bbf6bfd1 n/a (Xorg + 0x149fd1)
                                                #19 0x00005572bbf678a0 WaitForSomething (Xorg + 0x1458a0)
                                                #20 0x00005572bbe5b8e4 n/a (Xorg + 0x398e4)
                                                #21 0x00007fc188214152 __libc_start_main (libc.so.6 + 0x28152)
                                                #22 0x00005572bbe5c5ae _start (Xorg + 0x3a5ae)
                                                Stack trace of thread 689:
                                                #0  0x00007fc1880e16a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
                                                #1  0x00007fc18749ee60 n/a (intel_drv.so + 0xb4e60)
                                                #2  0x00007fc1880db3e9 start_thread (libpthread.so.0 + 0x93e9)
                                                #3  0x00007fc1882ec293 __clone (libc.so.6 + 0x100293)
                                                Stack trace of thread 946:
                                                #1  0x00007fc165928cfc n/a (nouveau_dri.so + 0x4b0cfc)
                                                #2  0x00007fc1659276f8 n/a (nouveau_dri.so + 0x4af6f8)
                                                #3  0x00007fc1880db3e9 start_thread (libpthread.so.0 + 0x93e9)
                                                #4  0x00007fc1882ec293 __clone (libc.so.6 + 0x100293)
                                                Stack trace of thread 947:
                                                Stack trace of thread 945:
                                                Stack trace of thread 724:
                                                #1  0x00007fc1861b5b3c n/a (i965_dri.so + 0x51eb3c)
                                                #2  0x00007fc1861b4e58 n/a (i965_dri.so + 0x51de58)
                                                Stack trace of thread 725:
                                                Stack trace of thread 723:
                                                Stack trace of thread 726:
                                                Stack trace of thread 944:
░░ Subject: Speicherabbild für Prozess 623 (@COREDUMP_COMM) generiert
░░ Prozess 623 (Xorg) ist abgebrochen worden und
Okt 15 22:12:28 HOST lightdm[1009]: gkr-pam: unable to locate daemon control file
Okt 15 22:12:35 HOST kernel: irq 16: nobody cared (try booting with the "irqpoll" option)
Okt 15 22:12:35 HOST kernel: handlers:
Okt 15 22:12:35 HOST kernel: [<000000003686181f>] idma64_irq [idma64]
Okt 15 22:12:35 HOST kernel: [<000000006e72cd9e>] i2c_dw_isr
Okt 15 22:12:35 HOST kernel: [<00000000211cacbc>] i801_isr [i2c_i801]
Okt 15 22:12:35 HOST kernel: Disabling IRQ #16
Okt 15 22:27:55 HOST kernel: scsi 3:0:0:0: rejecting I/O to dead device
-- Reboot --
Okt 25 10:59:42 HOST kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ IBUS ]
Okt 25 10:59:48 HOST systemd-coredump[936]: Process 583 (Xorg) of user 0 dumped core.
                                                Stack trace of thread 583:
                                                #0  0x00007f24cafbc615 raise (libc.so.6 + 0x3d615)
                                                #1  0x00007f24cafa5862 abort (libc.so.6 + 0x26862)
                                                #2  0x00005617f999a38a OsAbort (Xorg + 0x14a38a)
                                                #3  0x00005617f999be51 FatalError (Xorg + 0x14be51)
                                                #4  0x00005617f99a1aa9 n/a (Xorg + 0x151aa9)
                                                #5  0x00007f24cafbc6a0 __restore_rt (libc.so.6 + 0x3d6a0)
                                                #6  0x00007f24cafbc615 raise (libc.so.6 + 0x3d615)
                                                #7  0x00007f24cafa5862 abort (libc.so.6 + 0x26862)
                                                #8  0x00007f24cafa5747 __assert_fail_base.cold (libc.so.6 + 0x26747)
                                                #9  0x00007f24cafb4bf6 __assert_fail (libc.so.6 + 0x35bf6)
                                                #10 0x00005617f98e5930 n/a (Xorg + 0x95930)
                                                #11 0x00007f24c6487fb9 glamor_init (libglamoregl.so + 0xcfb9)
                                                #12 0x00007f24c660f04d n/a (modesetting_drv.so + 0x1404d)
                                                #13 0x00005617f98c940e AddGPUScreen (Xorg + 0x7940e)
                                                #14 0x00005617f99d5819 n/a (Xorg + 0x185819)
                                                #15 0x00005617f99f4520 n/a (Xorg + 0x1a4520)
                                                #16 0x00005617f9a0ae61 n/a (Xorg + 0x1bae61)
                                                #17 0x00005617f9a0b0cb n/a (Xorg + 0x1bb0cb)
                                                #18 0x00005617f99bb045 InitInput (Xorg + 0x16b045)
                                                #19 0x00005617f9889768 n/a (Xorg + 0x39768)
                                                #20 0x00007f24cafa7152 __libc_start_main (libc.so.6 + 0x28152)
                                                #21 0x00005617f988a5ae _start (Xorg + 0x3a5ae)
                                                Stack trace of thread 671:
                                                #0  0x00007f24cae746a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
                                                #1  0x00007f24ca231e60 n/a (intel_drv.so + 0xb4e60)
                                                #2  0x00007f24cae6e3e9 start_thread (libpthread.so.0 + 0x93e9)
                                                #3  0x00007f24cb07f293 __clone (libc.so.6 + 0x100293)
                                                Stack trace of thread 702:
                                                #1  0x00007f24c8f48b3c n/a (i965_dri.so + 0x51eb3c)
                                                #2  0x00007f24c8f47e58 n/a (i965_dri.so + 0x51de58)
                                                #3  0x00007f24cae6e3e9 start_thread (libpthread.so.0 + 0x93e9)
                                                #4  0x00007f24cb07f293 __clone (libc.so.6 + 0x100293)
                                                Stack trace of thread 703:
                                                Stack trace of thread 701:
                                                Stack trace of thread 700:
                                                Stack trace of thread 932:
                                                #1  0x00007f24c508dcfc n/a (nouveau_dri.so + 0x4b0cfc)
                                                #2  0x00007f24c508c6f8 n/a (nouveau_dri.so + 0x4af6f8)
                                                Stack trace of thread 931:
                                                Stack trace of thread 933:
                                                Stack trace of thread 934:
░░ Subject: Speicherabbild für Prozess 583 (@COREDUMP_COMM) generiert
░░ Prozess 583 (Xorg) ist abgebrochen worden und
Okt 25 10:59:57 HOST lightdm[1030]: gkr-pam: unable to locate daemon control file
Okt 25 11:39:50 HOST kernel: irq 16: nobody cared (try booting with the "irqpoll" option)
Okt 25 11:39:50 HOST kernel: handlers:
Okt 25 11:39:50 HOST kernel: [<00000000cec9e7a0>] idma64_irq [idma64]
Okt 25 11:39:50 HOST kernel: [<00000000185c3d16>] i2c_dw_isr
Okt 25 11:39:50 HOST kernel: [<000000008f5c99e0>] i801_isr [i2c_i801]
Okt 25 11:39:50 HOST kernel: Disabling IRQ #16
Okt 25 17:38:43 HOST kernel: Bluetooth: hci0: Failed to send body at 4 of 1857 (-110)
Okt 25 17:38:48 HOST lightdm[9552]: gkr-pam: unable to locate daemon control file
Okt 25 19:02:08 HOST systemd-coredump[10792]: Process 10671 (skypeforlinux) of user 1000 dumped core.
                                                  Stack trace of thread 51:
                                                  #0  0x00007f34b9b34615 n/a (/usr/lib/x86_64-linux-gnu/libc-2.30.so + 0x39615)
                                                  #1  0x00007f343c0021a0 n/a (n/a + 0x0)
░░ Subject: Speicherabbild für Prozess 10671 (@COREDUMP_COMM) generiert
░░ Prozess 10671 (skypeforlinux) ist abgebrochen worden und
-- Reboot --
Okt 25 19:16:25 HOST kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ IBUS ]
Okt 25 19:16:27 HOST kernel: irq 16: nobody cared (try booting with the "irqpoll" option)
Okt 25 19:16:27 HOST kernel: handlers:
Okt 25 19:16:27 HOST kernel: [<00000000816de9bd>] idma64_irq [idma64]
Okt 25 19:16:27 HOST kernel: [<0000000067ee711e>] i2c_dw_isr
Okt 25 19:16:27 HOST kernel: [<00000000e03bf895>] i801_isr [i2c_i801]
Okt 25 19:16:27 HOST kernel: Disabling IRQ #16
Okt 25 19:16:31 HOST systemd-coredump[942]: Process 528 (Xorg) of user 0 dumped core.
                                                Stack trace of thread 528:
                                                #0  0x00007f9e89c5f615 raise (libc.so.6 + 0x3d615)
                                                #1  0x00007f9e89c48862 abort (libc.so.6 + 0x26862)
                                                #2  0x000055864439138a OsAbort (Xorg + 0x14a38a)
                                                #3  0x0000558644392e51 FatalError (Xorg + 0x14be51)
                                                #4  0x0000558644398aa9 n/a (Xorg + 0x151aa9)
                                                #5  0x00007f9e89c5f6a0 __restore_rt (libc.so.6 + 0x3d6a0)
                                                #6  0x00007f9e89c5f615 raise (libc.so.6 + 0x3d615)
                                                #7  0x00007f9e89c48862 abort (libc.so.6 + 0x26862)
                                                #8  0x00007f9e89c48747 __assert_fail_base.cold (libc.so.6 + 0x26747)
                                                #9  0x00007f9e89c57bf6 __assert_fail (libc.so.6 + 0x35bf6)
                                                #10 0x00005586442dc930 n/a (Xorg + 0x95930)
                                                #11 0x00007f9e8512afb9 glamor_init (libglamoregl.so + 0xcfb9)
                                                #12 0x00007f9e852b204d n/a (modesetting_drv.so + 0x1404d)
                                                #13 0x00005586442c040e AddGPUScreen (Xorg + 0x7940e)
                                                #14 0x00005586443cc819 n/a (Xorg + 0x185819)
                                                #15 0x00005586443eb520 n/a (Xorg + 0x1a4520)
                                                #16 0x0000558644401e61 n/a (Xorg + 0x1bae61)
                                                #17 0x0000558644402462 n/a (Xorg + 0x1bb462)
                                                #18 0x0000558644390fd1 n/a (Xorg + 0x149fd1)
                                                #19 0x000055864438c8a0 WaitForSomething (Xorg + 0x1458a0)
                                                #20 0x00005586442808e4 n/a (Xorg + 0x398e4)
                                                #21 0x00007f9e89c4a152 __libc_start_main (libc.so.6 + 0x28152)
                                                #22 0x00005586442815ae _start (Xorg + 0x3a5ae)
                                                #0  0x00007f9e89b176a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
                                                #1  0x00007f9e87bebb3c n/a (i965_dri.so + 0x51eb3c)
                                                #2  0x00007f9e87beae58 n/a (i965_dri.so + 0x51de58)
                                                #3  0x00007f9e89b113e9 start_thread (libpthread.so.0 + 0x93e9)
                                                #4  0x00007f9e89d22293 __clone (libc.so.6 + 0x100293)
                                                Stack trace of thread 644:
                                                #1  0x00007f9e88ed4e60 n/a (intel_drv.so + 0xb4e60)
                                                #2  0x00007f9e89b113e9 start_thread (libpthread.so.0 + 0x93e9)
                                                #3  0x00007f9e89d22293 __clone (libc.so.6 + 0x100293)
                                                Stack trace of thread 661:
                                                Stack trace of thread 662:
                                                Stack trace of thread 936:
                                                #1  0x00007f9e7d05dcfc n/a (nouveau_dri.so + 0x4b0cfc)
                                                #2  0x00007f9e7d05c6f8 n/a (nouveau_dri.so + 0x4af6f8)
                                                Stack trace of thread 663:
                                                Stack trace of thread 938:
                                                Stack trace of thread 937:
                                                Stack trace of thread 939:
░░ Subject: Speicherabbild für Prozess 528 (@COREDUMP_COMM) generiert
░░ Prozess 528 (Xorg) ist abgebrochen worden und
Okt 25 19:16:37 HOST lightdm[1006]: gkr-pam: unable to locate daemon control file
Okt 25 19:17:18 HOST bluetoothd[870]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Okt 25 19:17:18 HOST bluetoothd[870]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
It would be amazing if someone could read through this and help me stop this. Please let me know, if you need more information.
You appear to have an optimus (dual-gpu) system, but the nvidia is using ‘nouveau’ (which is also referenced in the error logs)
Is that on purpose? What driver profile are you using?
mhwd -l -d --pci
Thank you for your quick response!
No, I didn’t that on purpose.
Here’s
mhwd -l -d --pci
> PCI Device: /devices/pci0000:00/0000:00:1d.3/0000:04:00.1 (0200:10ec:8168)
  Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
  > AVAILABLE:
   ATTACHED:	PCI
   VERSION:	2016.04.20
   INFO:	RealTek RTL-8168 Gigabit Ethernet driver
   PRIORITY:	0
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0200
   VENDORIDS:	1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:1c.0/0000:01:00.0 (0302:10de:139a)
  Display controller nVidia Corporation GM107M [GeForce GTX 950M]
  > INSTALLED:
   ATTACHED:	PCI
   VERSION:	2018.05.04
   INFO:	Standard open source drivers.
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300 0380 0302
   VENDORIDS:	1002 8086 10de
  > AVAILABLE:
   ATTACHED:	PCI
   VERSION:	2020.10.04
   INFO:	Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
   PRIORITY:	18
   FREEDRIVER:	false
   DEPENDS:	video-modesetting
   CONFLICTS:	video*nvidia-*
   CLASSIDS:	0300 0302 0300
   VENDORIDS:	10de 8086
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	17
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	16
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	15
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   INFO:	Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
   PRIORITY:	14
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	13
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	12
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   INFO:	Closed source NVIDIA drivers for linux.
   PRIORITY:	10
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	9
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	8
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	7
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	6
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	5
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	4
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2018.05.04
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:5916)
  Display controller Intel Corporation HD Graphics 620
  > INSTALLED:
   ATTACHED:	PCI
   VERSION:	2018.05.04
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
  > AVAILABLE:
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	18
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	17
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	16
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	15
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	14
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	13
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	12
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2018.05.04
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   ATTACHED:	PCI
   VERSION:	2020.01.13
   INFO:	X.org modesetting video driver.
   PRIORITY:	1
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300
   VENDORIDS:	*
   ATTACHED:	PCI
   VERSION:	2017.03.12
   INFO:	X.org vesa video driver.
   PRIORITY:	0
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300
   VENDORIDS:	*
If I were you I would probably install this (I think the latest 455 series has some issues)
Also … nvidia doesnt work with 5.9 … so before doing that install/select/boot kernel 5.8
This can all be done in the GUI using manjaro-settings-manager.
Orin the terminal using mhwd and mhwd-kernel
Heres some more info:
I followed your advise. I trust you and I really believe this problem should be solved now.
Finishing this, I would be glad if you could answer two questions:
  • Where did you know from it is an driver issue?
  • Why this only happened sometimes?
I didnt for sure … but your inxi output looked less-than-optimal unless it was intentional:
nvidia cards are best supported by the proprietary driver. As they dont cooperate well with the opensource community the ‘nouveau’ driver is pretty much reverse-engineered.
Next to that your journalctl logs referred to nouveau:
Not sure … but it could have been something about the unconfigured drivers lapsing between eachother (maybe after suspend or similar) … the intel working fine, but nouveau not? I am not sure.
In any case, if everything is set correctly with the PRIME profile you should be using intel by default … and can call the nvidia with prime-run when its needed (like games).
(again refer to the wiki for more info)
Ok, thank you for helping me and answering my questions!
