Freezing after resuming from Sleep
Hello,
I’ve just installed manjaro on a new Asus ExpertBook B1500 laptop and it seems everytime I resume from sleep, an window appears showing me the clock and mouse but it is frozen and I need to reboot the PC.
inxi information:
Summary
  Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=bb5cd968-5031-4496-a6ff-8e41d5c03283 rw quiet splash
    resume=UUID=03eb7d66-06e1-4e8a-ae6b-3d3e9799dac8 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
  Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B1500CBA_B1500CBA
    v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: B1500CBA v: 1.0 serial: <filter> UEFI: American
    Megatrends LLC. v: B1500CBA.307 date: 08/15/2022
  ID-1: BAT0 charge: 40.2 Wh (93.9%) condition: 42.8/42.1 Wh (101.8%)
    volts: 13.2 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: charging
  RAM: total: 31.05 GiB used: 3.03 GiB (9.7%)
  Array-1: capacity: 64 GiB slots: 2 EC: None max-module-size: 32 GiB
    note: est.
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: SK Hynix
    part-no: HMAA2GS6CJR8N-XN serial: <filter>
  Device-2: Controller1-ChannelA type: DDR4 detail: synchronous size: 16 GiB
    speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
    total: 64 manufacturer: SK Hynix part-no: HMAB2GS6CMR6N-XN serial: N/A
  Info: model: 12th Gen Intel Core i7-1255U socket: U3E1 bits: 64
    type: MST AMCP arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x429
  Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
    cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
    L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1453 high: 2600 min/max: 400/4700:3500
    base/boost: 3960/4700 scaling: driver: intel_pstate governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 2600 2: 545 3: 537 4: 625 5: 711
    6: 722 7: 642 8: 2600 9: 658 10: 2600 11: 2600 12: 2600 bogomips: 62688
    bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
    monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
    smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
    umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
    xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 0000:00:02.0
    chip-ID: 8086:46a8 class-ID: 0300
  Device-2: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-5:3 chip-ID: 322e:210f class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: Najing CEC Panda 0x0046 built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.1 renderer: Mesa Intel Graphics (ADL GT2)
    direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 3-9:5
    chip-ID: 0b05:6220 bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0300
    class-ID: 0401
  Device-2: ASUSTek C-Media Audio type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  API: ALSA v: k6.1.21-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.67 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    tools: pacat,pactl
  Device-1: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
    bus-ID: 0000:00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
  IF: eno2 state: down mac: <filter>
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: AzureWave driver: mt7921e v: kernel bus-ID: 0000:2c:00.0
    chip-ID: 14c3:7961 class-ID: 0280
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 3-10:6 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 1.38 TiB used: 18.5 GiB (1.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA512TFK
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: V5MA010 temp: 43.9 C scheme: GPT
  SMART: yes health: PASSED on: 88 hrs cycles: 32
    read-units: 255,289 [130 GB] written-units: 440,356 [225 GB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.3
    speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2J temp: 34 C
  SMART: yes state: enabled health: PASSED on: 89 hrs cycles: 28
  ID-1: / raw-size: 438.54 GiB size: 430.59 GiB (98.19%) used: 18.5 GiB (4.3%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: bb5cd968-5031-4496-a6ff-8e41d5c03283
    used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: DE9E-0057
  ID-1: swap-1 type: partition size: 38.1 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 03eb7d66-06e1-4e8a-ae6b-3d3e9799dac8
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 20 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-4:2 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-2: 3-5:3 info: Sonix USB2.0 HD UVC WebCam type: Video
  Device-3: 3-7:4 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 04f3:0c6c class-ID: 0000
  Device-4: 3-9:5 info: ASUSTek C-Media Audio type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 0b05:6220 class-ID: 0300
  Device-5: 3-10:6 info: IMC Networks Wireless_Device type: Bluetooth
    driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: N/A mobo: N/A
  Fan Speeds (RPM): cpu: 2500
  Processes: 261 Uptime: 11m wakeups: 2523 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1147 libs: 326 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.26
journal log info
Summary
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: [Firmware Bug]: TSC ADJUST: CPU0: -926211919 force to 0
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel:   #2  #3  #4
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel:   #5  #6  #7  #8  #9 #10 #11
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: hpet_acpi_add: no address or irqs in _CRS
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: pci 10000:e0:06.0: Primary bus is hard wired to 0
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT D
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: pcieport 10000:e0:06.0: PCI INT D: no GSI
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ahci 10000:e0:17.0: can't derive routing for PCI INT A
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ahci 10000:e0:17.0: PCI INT A: no GSI
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT A
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: nvme 10000:e1:00.0: PCI INT A: no GSI
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: usb 3-7: device descriptor read/64, error -71
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba systemd-journald[359]: File /var/log/journal/4589c5052aff4f9793f07afc0a0d0899/system.journal corrupted or uncleanly shut down, renaming and replacing.
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcffff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: caller igen6_probe+0x19d/0x7e0 [igen6_edac] mapping multiple BARs
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\CTDP], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Warning: \_SB.IETM._TRT: Return Package has no elements (empty) (20220331/nsprepkg-94)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._CRT.S1CT], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._CRT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._HOT.S1HT], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._HOT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._PSV.S1PT], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._PSV due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._AC0.S1AT], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._AC0 due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._CRT.S2CT], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._CRT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._HOT.S2HT], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._HOT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._PSV.S2PT], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._PSV due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._AC0.S2AT], AE_NOT_FOUND (20220331/psargs-330)
apr 04 13:00:32 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._AC0 due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba kernel: mt7921e 0000:2c:00.0: sar cnt = 0
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[531]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[531]: src/plugin.c:plugin_init() Failed to init vcp plugin
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[531]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[531]: src/plugin.c:plugin_init() Failed to init mcp plugin
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[531]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
apr 04 13:00:33 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[531]: src/plugin.c:plugin_init() Failed to init bap plugin
apr 04 13:00:34 bmsan-asusexpertbookb1500cbab1500cba kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
apr 04 13:00:34 bmsan-asusexpertbookb1500cbab1500cba kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
apr 04 13:00:35 bmsan-asusexpertbookb1500cbab1500cba systemd[645]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
apr 04 13:00:35 bmsan-asusexpertbookb1500cbab1500cba systemd[645]: Failed to start Update XDG user dir configuration.
apr 04 13:00:35 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[654]: QFont::fromString: Invalid description '(empty)'
apr 04 13:00:35 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[654]: QObject: Cannot create children for a parent that is in a different thread.
        (Parent is QGuiApplication(0x7ffc72ea3980), parent's thread is QThread(0x56545cc077d0), current thread is QThread(0x56545cd64900)
apr 04 13:00:35 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[654]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
apr 04 13:00:36 bmsan-asusexpertbookb1500cbab1500cba kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
apr 04 13:00:36 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[654]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
apr 04 13:00:36 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[654]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
apr 04 13:00:36 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[654]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
apr 04 13:00:36 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[654]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
apr 04 13:00:36 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[654]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.22'
apr 04 13:00:38 bmsan-asusexpertbookb1500cbab1500cba wpa_supplicant[641]: bgscan simple: Failed to enable signal strength monitoring
apr 04 13:00:39 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 51 callbacks suppressed
apr 04 13:00:55 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 117 callbacks suppressed
apr 04 13:00:55 bmsan-asusexpertbookb1500cbab1500cba systemd-journald[359]: File /var/log/journal/4589c5052aff4f9793f07afc0a0d0899/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
apr 04 13:00:55 bmsan-asusexpertbookb1500cbab1500cba ksplashqml[909]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
apr 04 13:00:55 bmsan-asusexpertbookb1500cbab1500cba ksplashqml[909]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
apr 04 13:00:55 bmsan-asusexpertbookb1500cbab1500cba ksmserver[978]: Qt: Session management error: networkIdsList argument is NULL
apr 04 13:00:55 bmsan-asusexpertbookb1500cbab1500cba ksmserver[978]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
apr 04 13:00:55 bmsan-asusexpertbookb1500cbab1500cba kwin_x11[981]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
apr 04 13:00:55 bmsan-asusexpertbookb1500cbab1500cba kwin_x11[981]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
apr 04 13:00:56 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
apr 04 13:00:56 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
apr 04 13:00:56 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: Checking screens: available: (QScreen(0x562885263320, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x562885263320, name="eDP-1"))
apr 04 13:00:56 bmsan-asusexpertbookb1500cbab1500cba pipewire[1190]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
apr 04 13:00:56 bmsan-asusexpertbookb1500cbab1500cba pipewire[1190]: mod.rt: found session bus but no portal
apr 04 13:00:56 bmsan-asusexpertbookb1500cbab1500cba kded5[980]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
apr 04 13:00:56 bmsan-asusexpertbookb1500cbab1500cba org_kde_powerdevil[1090]: org.kde.powerdevil: Handle button events action could not check for screen configuration
apr 04 13:00:56 bmsan-asusexpertbookb1500cbab1500cba wireplumber[1195]: <WpPortalPermissionStorePlugin:0x555ab1c306e0> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba kioslave5[1400]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x562886141080)
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x562886141d30)
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x562886141f80)
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x562886149be0)
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x562886141c10)
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x562886141960)
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba pulseaudio[1435]: Failed to find a working profile.
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba pulseaudio[1435]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_00_1f.3-platform-skl_hda_dsp_generic" card_name="alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba pulseaudio[1435]: stat('/etc/pulse/default.pa.d'): No such file or directory
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x562886f5ba90) QQmlContext(0x562885ec7c00) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
apr 04 13:00:57 bmsan-asusexpertbookb1500cbab1500cba pulseaudio[1435]: Tried to configure /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1 (alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic) more often than 5 times in 10s
apr 04 13:00:59 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 04 13:01:00 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 04 13:01:01 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 04 13:01:02 bmsan-asusexpertbookb1500cbab1500cba plasmashell[1048]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 04 13:01:03 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 8 callbacks suppressed
apr 04 13:01:40 bmsan-asusexpertbookb1500cbab1500cba konsole[1483]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
apr 04 13:01:40 bmsan-asusexpertbookb1500cbab1500cba konsole[1483]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Any help on how to try to tackle this issue would be welcomed!
I’ve also tried two experiments:
  • Updated to kernel 6.2.8-1 from 6.1.21-1 using Manjaro settings manager
  • Tried to enter sleep from the linux live cd used from the installation, loaded with the open source drivers
In both cases the result was the same.
I’d also note that sometimes the screen is completly black or I only see the mouse on a black screen but cannot move it.
being on RAID, instead of AHCI, can cause issues with sleep/suspend/hibernation…
so switch in bios to ahci and test… however if you are dual booting with windows, dont switch because you will not be able to boot into windows…
Thanks @brahma !
I followed your suggestion, unfortunately even with AHCI I am getting the same behavior.
A third experiment that I did was to try hibernate instead of sleep. That seems to actually work without issues.
So the issue I am seeing is affecting only sleep but not hibernation.
ok, keep AHCI and dont switch back to raid…
so try with different kernels, the 5.15 and 6.2 and see if it helps;
if not, suspend, resume, reboot and post logs from the freeze:
journalctl -b-1 -p4 --no-pager
@brahma Thanks !
I’m keeping AHCI enabled as you suggested.
I’m attaching the journal log captured after a freeze.
(With kernel 6.2)
journalctl -b-1 -p4 --no-pager details here click to expand
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: [Firmware Bug]: TSC ADJUST: CPU0: -1195078545 force to 0
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:   #2  #3  #4
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:   #5  #6  #7  #8  #9 #10 #11
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: hpet_acpi_add: no address or irqs in _CRS
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: unchecked MSR access error: WRMSR to 0xd10 (tried to write 0x000000000000ffff) at rIP: 0xffffffffa908a238 (native_write_msr+0x8/0x30)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: Call Trace:
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  <TASK>
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  cat_wrmsr+0x41/0x60
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  resctrl_online_cpu+0x301/0x3a0
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  ? __pfx_resctrl_online_cpu+0x10/0x10
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  cpuhp_invoke_callback+0xf5/0x460
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  ? __pfx_smpboot_thread_fn+0x10/0x10
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  cpuhp_thread_fun+0xe8/0x170
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  smpboot_thread_fn+0xd9/0x1d0
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  kthread+0xdb/0x110
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  ? __pfx_kthread+0x10/0x10
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  ret_from_fork+0x29/0x50
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel:  </TASK>
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba systemd-journald[305]: File /var/log/journal/4589c5052aff4f9793f07afc0a0d0899/system.journal corrupted or uncleanly shut down, renaming and replacing.
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: caller igen6_probe+0x1a6/0x8d0 [igen6_edac] mapping multiple BARs
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._CRT.S1CT], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._CRT due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._HOT.S1HT], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._HOT due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._PSV.S1PT], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._PSV due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._AC0.S1AT], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._AC0 due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._CRT.S2CT], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._CRT due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._HOT.S2HT], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._HOT due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._PSV.S2PT], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._PSV due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._AC0.S2AT], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._AC0 due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI BIOS Error (bug): Could not resolve symbol [\CTDP], AE_NOT_FOUND (20221020/psargs-330)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: ACPI Warning: \_SB.IETM._TRT: Return Package has no elements (empty) (20221020/nsprepkg-94)
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
apr 05 20:09:27 bmsan-asusexpertbookb1500cbab1500cba kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
apr 05 20:09:28 bmsan-asusexpertbookb1500cbab1500cba kernel: mt7921e 0000:2d:00.0: sar cnt = 0
apr 05 20:09:28 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[446]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
apr 05 20:09:28 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[446]: src/plugin.c:plugin_init() Failed to init vcp plugin
apr 05 20:09:28 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[446]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
apr 05 20:09:28 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[446]: src/plugin.c:plugin_init() Failed to init mcp plugin
apr 05 20:09:28 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[446]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
apr 05 20:09:28 bmsan-asusexpertbookb1500cbab1500cba bluetoothd[446]: src/plugin.c:plugin_init() Failed to init bap plugin
apr 05 20:09:29 bmsan-asusexpertbookb1500cbab1500cba kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
apr 05 20:09:29 bmsan-asusexpertbookb1500cbab1500cba kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba systemd[558]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba systemd[558]: Failed to start Update XDG user dir configuration.
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[567]: QFont::fromString: Invalid description '(empty)'
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[567]: QObject: Cannot create children for a parent that is in a different thread.
        (Parent is QGuiApplication(0x7ffe600296e0), parent's thread is QThread(0x55db551be7d0), current thread is QThread(0x55db5531b520)
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[567]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[567]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[567]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
apr 05 20:09:30 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[567]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
apr 05 20:09:31 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[567]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
apr 05 20:09:31 bmsan-asusexpertbookb1500cbab1500cba sddm-greeter[567]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
apr 05 20:09:32 bmsan-asusexpertbookb1500cbab1500cba wpa_supplicant[552]: bgscan simple: Failed to enable signal strength monitoring
apr 05 20:09:34 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 42 callbacks suppressed
apr 05 20:09:57 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 117 callbacks suppressed
apr 05 20:09:59 bmsan-asusexpertbookb1500cbab1500cba sddm-helper[786]: [PAM] authenticate: Authentication failure
apr 05 20:09:59 bmsan-asusexpertbookb1500cbab1500cba sddm[510]: Authentication error: "Authentication failure"
apr 05 20:09:59 bmsan-asusexpertbookb1500cbab1500cba sddm[510]: Auth: sddm-helper exited with 1
apr 05 20:10:12 bmsan-asusexpertbookb1500cbab1500cba systemd-journald[305]: File /var/log/journal/4589c5052aff4f9793f07afc0a0d0899/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba ksplashqml[820]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba ksplashqml[820]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba ksmserver[889]: Qt: Session management error: networkIdsList argument is NULL
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba ksmserver[889]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba kwin_x11[892]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba kwin_x11[892]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: Checking screens: available: (QScreen(0x55db3c2ac320, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x55db3c2ac320, name="eDP-1"))
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba pipewire[1115]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba pipewire[1115]: mod.rt: found session bus but no portal
apr 05 20:10:13 bmsan-asusexpertbookb1500cbab1500cba kded5[891]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
apr 05 20:10:14 bmsan-asusexpertbookb1500cbab1500cba wireplumber[1117]: <WpPortalPermissionStorePlugin:0x55cef6c60950> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
apr 05 20:10:14 bmsan-asusexpertbookb1500cbab1500cba org_kde_powerdevil[1003]: org.kde.powerdevil: Handle button events action could not check for screen configuration
apr 05 20:10:14 bmsan-asusexpertbookb1500cbab1500cba kioslave5[1311]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55db3d18c8c0)
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55db3d18d600)
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55db3d18d850)
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55db3d1955b0)
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55db3d18d510)
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55db3d18d260)
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba pulseaudio[1334]: Failed to find a working profile.
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba pulseaudio[1334]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_00_1f.3-platform-skl_hda_dsp_generic" card_name="alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba pulseaudio[1334]: stat('/etc/pulse/default.pa.d'): No such file or directory
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba pulseaudio[1334]: Tried to configure /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1 (alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic) more often than 5 times in 10s
apr 05 20:10:15 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55db3df1b190) QQmlContext(0x55db3d47f200) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
apr 05 20:10:16 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 05 20:10:17 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 05 20:10:18 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 05 20:10:19 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 05 20:10:20 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 05 20:10:22 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 8 callbacks suppressed
apr 05 20:11:20 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
apr 05 20:11:35 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
apr 05 20:11:36 bmsan-asusexpertbookb1500cbab1500cba konsole[1853]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
apr 05 20:11:36 bmsan-asusexpertbookb1500cbab1500cba konsole[1853]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
apr 05 20:11:59 bmsan-asusexpertbookb1500cbab1500cba kwin_x11[892]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
apr 05 20:13:09 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 18 callbacks suppressed
apr 05 20:14:29 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 74 callbacks suppressed
apr 05 20:15:27 bmsan-asusexpertbookb1500cbab1500cba kernel: kauditd_printk_skb: 22 callbacks suppressed
apr 05 20:17:01 bmsan-asusexpertbookb1500cbab1500cba kded5[891]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
apr 05 20:17:02 bmsan-asusexpertbookb1500cbab1500cba kscreenlocker_greet[13635]: Qt: Session management error: networkIdsList argument is NULL
apr 05 20:17:02 bmsan-asusexpertbookb1500cbab1500cba kscreenlocker_greet[13635]: kf.kirigami: Failed to find a Kirigami platform plugin
apr 05 20:17:02 bmsan-asusexpertbookb1500cbab1500cba kscreenlocker_greet[13635]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
apr 05 20:17:02 bmsan-asusexpertbookb1500cbab1500cba plasmashell[970]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
  • Experiment also on kernel 6-2: I’ve also started a ssh server to see if I can access it after the freeze(to see if only the UI is frozen, but it seems that the ssh server is inacessible after I try to resume from the sleep process.
  • With kernel 5.15 it seems I get out of the suspend on the first try but the system is really slow (I can login but Firefox never launches) airplane mode is enabled. If I enter sleep again, the system just logs out and becomes extremely slow (one key in the password box gets updated once every 5-10 seconds).
    • Running journalctl/dmesg while in this state never produces anything (the command hangs).
    • Htop shows CPU/mem/IO usage as being low. Nothing hogging resources
Just a summary of things tried so far related to resume after sleep:
  • System up to date with all updates: system freeze
  • Raid vs AHCI : in both cases system freeze
  • kernel 6.2.8-1: system freeze
  • kernel 6.1.21-1: system freeze
  • kernel 5.15.104-2: gets out of sleep but the system is extremely laggy and cannot reenter sleep.
  • resume after hibernation: works
  • Checked if there is a newer asus firmware available for the laptop but it seems I have the latest one
  • Manjaro live usb(used for the installation) booted with open source drivers: system freeze
are those logs from when your pc froze, and you rebooted? if so, theres really nothing there…
post output from:
cat /sys/power/mem_sleep
@brahma thanks for all your support so far!
Yes. 1 Enter sleep 2. Try to wake up 3. Power off/on from button 4. Generate the logs
[s2idle] deep
Please note I have disabled temporarely Sleep in the Energy Saving - System settings, not sure if that interferes with the last command output.
you are on s2idle, even though you have available deep sleep, and that could be the reason for your issue…
so change it to deep:
kate /etc/default/grub
and inside this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
mem_sleep_default=deep
dont remove anything, just add it to existing parameters; save the file, update grub:
sudo update-grub
reboot and test
That actually worked! Thank you @brahma
I had lost all hope at this point.
