Jan 02 21:38:54 office-manjaro kernel: amdgpu 0000:01:00.0: [drm] *ERROR* [CRTC:57:crtc-3] flip_done timed out
Jan 02 21:38:54 office-manjaro kernel: amdgpu 0000:01:00.0: [drm] *ERROR* [CRTC:55:crtc-2] flip_done timed out
Jan 02 21:38:54 office-manjaro kernel: [drm:amdgpu_dm_atomic_check [amdgpu]] *ERROR* [CRTC:55:crtc-2] hw_done or flip_done timed out
Jan 02 21:39:04 office-manjaro kernel: amdgpu 0000:01:00.0: [drm] *ERROR* [CRTC:53:crtc-1] flip_done timed out
Jan 02 21:39:04 office-manjaro kernel: [drm:amdgpu_dm_atomic_check [amdgpu]] *ERROR* [CRTC:53:crtc-1] hw_done or flip_done timed out
Jan 02 21:39:14 office-manjaro kernel: amdgpu 0000:01:00.0: [drm] *ERROR* [CRTC:51:crtc-0] flip_done timed out
Once this happens I need to do a hard reset.
office-manjaro
description: Desktop Computer
product: System Product Name (SKU)
vendor: ASUS
version: System Version
serial: System Serial Number
width: 64 bits
capabilities: smbios-3.5.0 dmi-3.5.0 smp vsyscall32
configuration: boot=normal chassis=desktop family=To be filled by O.E.M. sku=SKU uuid=1BAAF3F1-BE72-9D9A-45B8-A036BCAD66BF
*-core
description: Motherboard
product: ROG STRIX B650-A GAMING WIFI
vendor: ASUSTeK COMPUTER INC.
physical id: 0
version: Rev 1.xx
serial: 220909543103148
slot: Default string
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 1001
date: 11/29/2022
capacity: 32MiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17printer int10video acpi usb biosbootspecification uefi
*-cache:0
description: L1 cache
physical id: c
slot: L1 - Cache
capacity: 768KiB
clock: 1GHz (1.0ns)
capabilities: pipeline-burst internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: d
slot: L2 - Cache
capacity: 12MiB
clock: 1GHz (1.0ns)
configuration: level=2
*-cache:2
description: L3 cache
physical id: e
slot: L3 - Cache
capacity: 64MiB
clock: 1GHz (1.0ns)
configuration: level=3
*-cpu
description: CPU
product: AMD Ryzen 9 7900X 12-Core Processor
vendor: Advanced Micro Devices [AMD]
physical id: f
bus info: cpu@0
version: AMD Ryzen 9 7900X 12-Core Processor
serial: Unknown
slot: AM5
capacity: 5732MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp x86-64 constant_tsc rep_good amd_lbr_v2 nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba perfmon_v2 ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local avx512_bf16 clzero irperf xsaveerptr rdpru wbnoinvd cppc arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif x2avic v_spec_ctrl avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid overflow_recov succor smca fsrm flush_l1d cpufreq
configuration: cores=12 enabledcores=12 threads=24
*-memory
description: System Memory
physical id: 11
slot: System board or motherboard
*-bank:0
description: DIMM Synchronous Unbuffered (Unregistered) 4800 MHz (0.2 ns)
product: CMK32GX5M2B5600C36
vendor: Unknown
physical id: 0
serial: 00000000
slot: DIMM 0
width: 64 bits
clock: 505MHz (2.0ns)
*-bank:1
vendor: Unknown
physical id: 1
serial: 00000000
slot: DIMM 1
width: 64 bits
*-bank:2
vendor: Unknown
physical id: 2
serial: 00000000
slot: DIMM 0
width: 64 bits
*-bank:3
vendor: Unknown
physical id: 3
serial: 00000000
slot: DIMM 1
width: 64 bits
*-pci:0
description: Host bridge
product: Advanced Micro Devices, Inc. [AMD]
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 100
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 33MHz
*-generic UNCLAIMED
description: IOMMU
physical id: 0.2
bus info: pci@0000:00:00.2
version: 00
width: 32 bits
clock: 33MHz
capabilities: msi ht bus_master cap_list
configuration: latency=0
*-pci:0
description: PCI bridge
physical id: 1.1
bus info: pci@0000:00:01.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:27 ioport:f000(size=4096) memory:fcf00000-fcffffff ioport:fb00000000(size=4297064448)
*-display
description: VGA compatible controller
product: Baffin [Radeon Pro WX 4100]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=amdgpu latency=0 mode=2560x1440 visual=truecolor xres=2560 yres=1440
resources: iomemory:fb0-faf iomemory:fc0-fbf irq:101 memory:fb00000000-fbffffffff memory:fc00000000-fc001fffff ioport:f000(size=256) memory:fcf00000-fcf3ffff memory:fcf40000-fcf5ffff
*-multimedia
description: Audio device
product: Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
physical id: 0.1
bus info: pci@0000:01:00.1
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:96 memory:fcf60000-fcf63fff
*-pci:1
physical id: 2.1
bus info: pci@0000:00:02.1
version: 00
width: 32 bits
clock: 33MHz
resources: irq:28 memory:fc300000-fc8fffff
*-pci
physical id: 0
bus info: pci@0000:02:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pci msi pm pciexpress normal_decode bus_master cap_list
resources: irq:32 memory:fc300000-fc8fffff
*-pci:0
physical id: 0
bus info: pci@0000:03:00.0
version: 01
width: 32 bits
clock: 33MHz
resources: irq:33
*-pci:1
physical id: 8
bus info: pci@0000:03:08.0
version: 01
width: 32 bits
clock: 33MHz
resources: irq:34
*-pci:2
physical id: 9
bus info: pci@0000:03:09.0
version: 01
width: 32 bits
clock: 33MHz
resources: irq:36
*-pci:3
physical id: a
bus info: pci@0000:03:0a.0
version: 01
width: 32 bits
clock: 33MHz
resources: irq:38 memory:fc500000-fc6fffff
*-network
description: Ethernet interface
product: Ethernet Controller I225-V
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:07:00.0
logical name: eno1
version: 03
serial: a0:36:bc:ad:66:bf
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=igc driverversion=6.1.1-1-MANJARO duplex=full firmware=1082:8770 ip=192.168.80.183 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:37 memory:fc500000-fc5fffff memory:fc600000-fc603fff
*-pci:4
physical id: b
bus info: pci@0000:03:0b.0
version: 01
width: 32 bits
clock: 33MHz
resources: irq:40 memory:fc300000-fc4fffff
*-network
description: Wireless interface
product: MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: MEDIATEK Corp.
physical id: 0
bus info: pci@0000:08:00.0
logical name: wlp8s0
version: 00
serial: 66:a6:a1:6b:5d:74
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=mt7921e driverversion=6.1.1-1-MANJARO firmware=____000000-20220908203253 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:100 memory:fc300000-fc3fffff memory:fc400000-fc407fff
*-pci:5
physical id: c
bus info: pci@0000:03:0c.0
version: 01
width: 32 bits
clock: 33MHz
resources: irq:41 memory:fc800000-fc8fffff
*-usb
description: USB controller
physical id: 0
bus info: pci@0000:09:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: msi msix pm pciexpress xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:24 memory:fc800000-fc807fff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 6.1.1-1-MANJARO xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 6.01
capabilities: usb-2.00
configuration: driver=hub slots=12 speed=480Mbit/s
*-usb:0
product: USB Audio
vendor: Generic
physical id: 6
bus info: usb@1:6
version: 0.02
capabilities: usb-2.00 audio-control
configuration: driver=snd-usb-audio maxpower=100mA speed=480Mbit/s
*-usb:1
description: Human interface device
product: AURA LED Controller
vendor: AsusTek Computer Inc.
physical id: 7
bus info: usb@1:7
version: 1.00
serial: 9876543210
configuration: driver=usbhid maxpower=16mA speed=12Mbit/s
*-usb:2
description: USB hub
product: USB2.0 Hub
vendor: Genesys Logic, Inc.
physical id: 8
bus info: usb@1:8
version: 60.90
configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
*-usb:0
product: NZXT USB Device
vendor: NZXT. - Inc.
physical id: 1
bus info: usb@1:8.1
version: 2.01
serial: 00000000001A
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usb:1
physical id: 4
bus info: usb@1:8.4
version: 2.00
*-usb:3
product: Schiit Bifrost 2 Unison USB
vendor: Schiit Audio
physical id: a
bus info: usb@1:a
version: 1.00
*-usb:4
description: Bluetooth wireless interface
product: Wireless_Device
vendor: MediaTek Inc.
physical id: b
bus info: usb@1:b
version: 1.00
serial: 000000000
capabilities: usb-2.10 bluetooth
configuration: driver=btusb maxpower=100mA speed=480Mbit/s
*-usb:5
product: USB2.0 Hub
vendor: VIA Labs, Inc.
physical id: c
bus info: usb@1:c
version: b.e0
configuration: driver=hub slots=4 speed=480Mbit/s
*-usb:0
product: Yeti Stereo Microphone
vendor: Blue Microphones
physical id: 1
bus info: usb@1:c.1
version: 1.00
serial: REV8
capabilities: usb-1.10 audio-control
*-usb:1
product: USB2.0 Hub
physical id: 4
bus info: usb@1:c.4
version: b.e0
*-usb:0
description: Video
product: Logitech BRIO
vendor: Logitech, Inc.
physical id: 1
bus info: usb@1:c.4.1
version: 0.17
serial: 14008137
configuration: driver=snd-usb-audio maxpower=500mA speed=480Mbit/s
*-usb:1
description: Mass storage device
product: easystore 2647
vendor: Western Digital
physical id: 2
bus info: usb@1:c.4.2
version: 10.20
serial: 575836324438304854305846
capabilities: usb-2.10 scsi
configuration: driver=usb-storage maxpower=500mA speed=480Mbit/s
*-usb:2
product: USB2.0 Hub
physical id: 4
bus info: usb@1:c.4.4
version: b.e0
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 6.01
capabilities: usb-3.10
configuration: driver=hub slots=5 speed=10000Mbit/s
*-pci:6
physical id: d
bus info: pci@0000:03:0d.0
version: 01
width: 32 bits
clock: 33MHz
resources: irq:42 memory:fc700000-fc7fffff
*-sata
description: SATA controller
physical id: 0
bus info: pci@0000:0a:00.0
logical name: scsi0
version: 01
width: 32 bits
clock: 33MHz
capabilities: sata msi pm pciexpress ahci_1.0 bus_master cap_list rom emulated
configuration: driver=ahci latency=0
resources: irq:43 memory:fc780000-fc7803ff memory:fc700000-fc77ffff
*-disk
description: ATA Disk
product: Samsung SSD 860
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 3B6Q
serial: S597NE0M905713N
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=ee32f57d-a473-1643-925e-fac897a00647 logicalsectorsize=512 sectorsize=512
*-volume:0
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /Projects
version: 1.0
serial: 715a3b6d-4df5-4b0e-a88b-6124a3aef364
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2019-12-15 23:34:00 filesystem=ext4 label=Projects lastmountpoint=/etc/mysql/conf.d/mysqld_charset.cnf modified=2023-01-02 21:41:08 mount.fstype=ext4 mount.options=rw,nosuid,nodev,relatime mounted=2023-01-02 21:41:08 state=mounted
*-volume:1
vendor: Linux
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /mnt/staging
version: 1.0
serial: b0369d3d-cb8e-4cb3-9e54-1e62a32a8ee5
capacity: 1723GiB
configuration: created=2021-01-23 19:44:25 filesystem=ext4 label=Staging lastmountpoint=/mnt/staging modified=2023-01-02 21:41:08 mount.fstype=ext4 mount.options=rw,nosuid,nodev,relatime mounted=2023-01-02 21:41:08 state=mounted
*-pci:2
physical id: 2.2
bus info: pci@0000:00:02.2
version: 00
width: 32 bits
clock: 33MHz
resources: irq:29 memory:fce00000-fcefffff
*-nvme
description: NVMe device
product: Sabrent Rocket 4.0 1TB
vendor: Phison Electronics Corporation
physical id: 0
bus info: pci@0000:0b:00.0
logical name: /dev/nvme0
version: EGFM11.1
serial: 0546079704F377160167
width: 64 bits
clock: 33MHz
capabilities: nvme pciexpress msix msi pm nvm_express bus_master cap_list
configuration: driver=nvme latency=0 nqn=nqn.2014.08.org.nvmexpress:198719870546079704F377160167Sabrent Rocket 4.0 1TB state=live
resources: irq:24 memory:fce00000-fce03fff
*-namespace:0
description: NVMe disk
physical id: 0
logical name: hwmon0
*-namespace:1
physical id: 2
logical name: /dev/ng0n1
*-namespace:2
physical id: 1
bus info: nvme@0:1
logical name: /dev/nvme0n1
configuration: guid=25e445fe-fe46-b046-8047-00ad921b1d21 logicalsectorsize=512 sectorsize=512 wwid=nvme.1987-3035343630373937303446333737313630313637-53616272656e7420526f636b657420342e3020315442-00000001
*-volume:0
description: Windows FAT volume
vendor: mkfs.fat
physical id: 1
bus info: nvme@0:1,1
logical name: /dev/nvme0n1p1
logical name: /boot/efi
version: FAT32
serial: e0dd-80b5
capacity: 299MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro state=mounted
*-volume:1
vendor: Linux
physical id: 2
bus info: nvme@0:1,2
logical name: /dev/nvme0n1p2
logical name: /
version: 1.0
serial: 2b825d20-feff-4925-980b-28445fd750d1
capacity: 931GiB
configuration: created=2023-01-02 16:35:11 filesystem=ext4 lastmountpoint=/ modified=2023-01-02 21:41:06 mount.fstype=ext4 mount.options=rw,noatime mounted=2023-01-02 21:41:06 name=root state=mounted
*-pci:3
physical id: 8.1
bus info: pci@0000:00:08.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi normal_decode bus_master cap_list
resources: irq:30 ioport:e000(size=4096) memory:fc900000-fccfffff ioport:fc10000000(size=270532608)
*-display
product: Raphael
physical id: 0
bus info: pci@0000:0c:00.0
version: c2
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list
configuration: driver=amdgpu latency=0
resources: iomemory:fc0-fbf iomemory:fc0-fbf irq:70 memory:fc10000000-fc1fffffff memory:fc20000000-fc201fffff ioport:e000(size=256) memory:fcc00000-fcc7ffff
*-multimedia
product: Rembrandt Radeon High Definition Audio Controller
physical id: 0.1
bus info: pci@0000:0c:00.1
version: 00
width: 32 bits
clock: 33MHz
resources: irq:98 memory:fcc80000-fcc83fff
*-generic
description: Encryption controller
product: VanGogh PSP/CCP
physical id: 0.2
bus info: pci@0000:0c:00.2
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi msix bus_master cap_list
configuration: driver=ccp latency=0
resources: irq:87 memory:fcb00000-fcbfffff memory:fcc84000-fcc85fff
*-usb:0
physical id: 0.3
bus info: pci@0000:0c:00.3
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix xhci cap_list
resources: irq:61 memory:fca00000-fcafffff
*-usbhost:0
physical id: 0
bus info: usb@3
logical name: usb3
version: 6.01
configuration: driver=hub slots=2 speed=480Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@4
logical name: usb4
version: 6.01
configuration: driver=hub slots=2 speed=10000Mbit/s
*-usb:1
physical id: 0.4
bus info: pci@0000:0c:00.4
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix xhci bus_master cap_list
resources: irq:70 memory:fc900000-fc9fffff
*-usbhost:0
physical id: 0
bus info: usb@5
logical name: usb5
version: 6.01
*-usb:0
product: SMSL USB AUDIO
vendor: SMSL
physical id: 1
bus info: usb@5:1
version: 2.06
configuration: driver=usbhid speed=480Mbit/s
*-usb:1
product: 4-Port USB 2.0 Hub
vendor: Generic
physical id: 2
bus info: usb@5:2
version: 1.36
*-usb:0
product: Griffin PowerMate
vendor: Griffin Technology Inc.
physical id: 2
bus info: usb@5:2.2
version: 0.08
configuration: driver=powermate maxpower=100mA speed=2Mbit/s
*-usb:1
vendor: Generic
physical id: 4
bus info: usb@5:2.4
version: 1.36
*-usb:0
description: Keyboard
product: Moonlander Mark I
vendor: ZSA
physical id: 1
bus info: usb@5:2.4.1
version: 0.01
configuration: driver=usbhid maxpower=500mA speed=12Mbit/s
*-usb:1
description: Mouse
product: Kensington Slimblade Trackball
vendor: Kensington
physical id: 2
bus info: usb@5:2.4.2
version: 1.10
configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
*-usb:2
product: MT1887
physical id: 3
bus info: usb@5:2.4.3
logical name: scsi7
version: 0.00
serial: KO2KBPE3223
capabilities: usb-2.00 atapi emulated scsi-host
*-cdrom
description: DVD-RAM writer
product: DVDRAM GP70NS50
vendor: HL-DT-ST
physical id: 0.0.0
bus info: scsi@7:0.0.0
logical name: /dev/cdrom
logical name: /dev/sr0
version: 1.01
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: status=ready
*-medium
physical id: 0
*-usbhost:1
physical id: 1
bus info: usb@6
logical name: usb6
version: 6.01
*-usb
product: 4-Port USB 3.0 Hub
vendor: Generic
physical id: 2
bus info: usb@6:2
version: 1.36
configuration: driver=hub slots=4 speed=5000Mbit/s
*-usb:0
product: USB3.0 Card Reader
vendor: Generic
physical id: 1
bus info: usb@6:2.1
logical name: scsi6
version: 15.35
serial: 000000001536
capabilities: usb-3.10 scsi emulated scsi-host
configuration: driver=usb-storage maxpower=896mA speed=5000Mbit/s
*-disk:0
description: SCSI Disk
product: MassStorageClass
vendor: Generic
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sdb
version: 1536
configuration: ansiversion=6 logicalsectorsize=512 sectorsize=512
*-medium
physical id: 0
*-disk:1
vendor: Generic
physical id: 0.0.1
bus info: scsi@6:0.0.1
logical name: /dev/sdc
version: 1536
*-medium
physical id: 0
*-usb:1
vendor: Generic
physical id: 4
bus info: usb@6:2.4
version: 1.36
*-pci:4
physical id: 8.3
bus info: pci@0000:00:08.3
version: 00
width: 32 bits
clock: 33MHz
resources: irq:31 memory:fcd00000-fcdfffff
*-usb
physical id: 0
bus info: pci@0000:0d:00.0
version: 00
width: 64 bits
clock: 33MHz
resources: irq:24 memory:fcd00000-fcdfffff
*-usbhost:0
physical id: 0
bus info: usb@7
logical name: usb7
version: 6.01
configuration: driver=hub slots=1 speed=480Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@8
logical name: usb8
version: 6.01
capabilities: usb-3.00
configuration: speed=5000Mbit/s
*-serial
description: SMBus
product: FCH SMBus Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 71
width: 32 bits
clock: 66MHz
configuration: driver=piix4_smbus latency=0
resources: irq:0
*-isa
description: ISA bridge
product: FCH LPC Bridge
physical id: 14.3
bus info: pci@0000:00:14.3
version: 51
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
*-pci:1
physical id: 101
bus info: pci@0000:00:01.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:2
physical id: 102
bus info: pci@0000:00:02.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
physical id: 103
bus info: pci@0000:00:03.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
physical id: 104
bus info: pci@0000:00:04.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:5
physical id: 105
bus info: pci@0000:00:08.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:6
physical id: 106
bus info: pci@0000:00:18.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:7
physical id: 107
bus info: pci@0000:00:18.1
version: 00
width: 32 bits
clock: 33MHz
*-pci:8
physical id: 108
bus info: pci@0000:00:18.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:9
physical id: 109
bus info: pci@0000:00:18.3
version: 00
width: 32 bits
clock: 33MHz
configuration: driver=k10temp
resources: irq:0
*-pci:10
physical id: 10a
bus info: pci@0000:00:18.4
version: 00
width: 32 bits
clock: 33MHz
*-pci:11
physical id: 10b
bus info: pci@0000:00:18.5
version: 00
width: 32 bits
clock: 33MHz
*-pci:12
physical id: 10c
bus info: pci@0000:00:18.6
version: 00
width: 32 bits
clock: 33MHz
*-pci:13
physical id: 10d
bus info: pci@0000:00:18.7
version: 00
width: 32 bits
clock: 33MHz
*-pnp00:00
product: System Board
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: Motherboard registers
physical id: 2
capabilities: pnp
*-pnp00:02
product: AT Real-Time Clock
physical id: 3
capabilities: pnp
configuration: driver=rtc_cmos
*-pnp00:03
physical id: 4
capabilities: pnp
*-pnp00:04
physical id: 5
capabilities: pnp
*-scsi
physical id: 6
bus info: usb@1:12.4.2
logical name: scsi8
capabilities: emulated scsi-host
*-disk
vendor: WD
physical id: 0.0.0
bus info: scsi@8:0.0.0
logical name: /dev/sdd
version: 1020
serial: WX62D80HT0XF
configuration: ansiversion=6 guid=023edff7-ac85-46f5-9dd7-7ecfce675df2 logicalsectorsize=512 sectorsize=4096
*-volume
vendor: Linux
physical id: 1
bus info: scsi@8:0.0.0,1
logical name: /dev/sdd1
logical name: /mnt/music
version: 1.0
serial: d61c7d29-7a40-4bfc-9a9e-1f1b1a7a8144
configuration: created=2021-01-23 14:36:58 filesystem=ext4 label=Music (HDD) lastmountpoint=/mnt/music modified=2023-01-02 21:41:16 mount.fstype=ext4 mount.options=rw,nosuid,nodev,relatime mounted=2023-01-02 21:41:16 state=mounted
*-enclosure UNCLAIMED
description: SCSI Enclosure
product: SES Device
vendor: WD
physical id: 0.0.1
bus info: scsi@8:0.0.1
version: 1020
I should note that I just did a fresh install of Manjaro.
