My laptop (hp envy) worked fine with the docking station from a friend. 2 monitors under wayland and xorg. now i bought my own and it works with 2 monitors under wayland but only when i connect the dock when im already logged in. If im not logged in it frezzes on boot. If i connect the dock in xorg everything freezes and the monitors are black including the build-in screen.
logfile from xorg:
[ 32.637] (--) Log file renamed from "/home/elknsl/.local/share/xorg/Xorg.pid-1403.log" to "/home/lsdfsdf/.local/share/xorg/Xorg.0.log"
[ 32.639]
X.Org X Server 1.21.1.10
[ 32.639] Current Operating System: Linux askdjf-hpenvyx360convertible13ag0xxxlin 6.6.10-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Jan 5 17:38:36 UTC 2024 x86_64
[ 32.639] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=00bab9ff-676a-49ef-995e-c2b802d26e52 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 32.639]
[ 32.639] Current version of pixman: 0.43.0
[ 32.639] Before reporting problems, check http://wiki.x.org
[ 32.639] Markers: (--) probed, (**) from config file, (==) default setting,
[ 32.639] (==) Log file: "/home/sdfb/.local/share/xorg/Xorg.0.log", Time: Thu Jan 18 08:44:06 2024
[ 32.640] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 32.640] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 32.642] (==) ServerLayout "layout"
[ 32.642] (==) No screen section available. Using defaults.
[ 32.642] (**) |-->Screen "Default Screen Section" (0)
[ 32.642] (**) | |-->Monitor "<default monitor>"
[ 32.642] (==) No monitor specified for screen "Default Screen Section".
[ 32.642] (==) Automatically adding devices
[ 32.642] (==) Automatically enabling devices
[ 32.642] (==) Automatically adding GPU devices
[ 32.642] (==) Automatically binding GPU devices
[ 32.642] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 32.642] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 32.642] Entry deleted from font path.
[ 32.642] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 32.642] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 32.642] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 32.642] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 32.642] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 32.642] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 32.642] (==) FontPath set to:
[ 32.642] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 32.642] (II) The server relies on udev to provide the list of input devices.
[ 32.642] (II) Module ABI versions:
[ 32.642] X.Org ANSI C Emulation: 0.4
[ 32.642] X.Org Video Driver: 25.2
[ 32.642] X.Org XInput driver : 24.4
[ 32.642] X.Org Server Extension : 10.0
[ 32.642] (++) using VT number 2
[ 32.644] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 32.645] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 32.645] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:04:00.0/drm/card1
[ 32.646] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
[ 32.654] (--) PCI:*(4@0:0:0) 1002:15dd:103c:8496 rev 196, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfcc00000/524288, I/O @ 0x0000e000/256
[ 32.654] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 32.654] (II) LoadModule: "glx"
[ 32.655] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 32.659] (II) Module glx: vendor="X.Org Foundation"
[ 32.659] compiled for 1.21.1.10, module version = 1.0.0
[ 32.659] ABI class: X.Org Server Extension, version 10.0
[ 32.659] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[ 32.659] loading driver: amdgpu
[ 32.659] (==) Matched amdgpu as autoconfigured driver 0
[ 32.659] (==) Matched ati as autoconfigured driver 1
[ 32.659] (==) Matched modesetting as autoconfigured driver 2
[ 32.659] (==) Matched fbdev as autoconfigured driver 3
[ 32.659] (==) Matched vesa as autoconfigured driver 4
[ 32.659] (==) Assigned the driver to the xf86ConfigLayout
[ 32.659] (II) LoadModule: "amdgpu"
[ 32.659] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 32.661] (II) Module amdgpu: vendor="X.Org Foundation"
[ 32.661] compiled for 1.21.1.7, module version = 23.0.0
[ 32.661] Module class: X.Org Video Driver
[ 32.661] ABI class: X.Org Video Driver, version 25.2
[ 32.661] (II) LoadModule: "ati"
[ 32.661] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 32.661] (II) Module ati: vendor="X.Org Foundation"
[ 32.661] compiled for 1.21.1.8, module version = 22.0.0
[ 32.923] (II) LoadModule: "radeon"
[ 32.924] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 32.931] (II) Module radeon: vendor="X.Org Foundation"
[ 32.931] compiled for 1.21.1.8, module version = 22.0.0
[ 32.931] Module class: X.Org Video Driver
[ 32.931] ABI class: X.Org Video Driver, version 25.2
[ 32.931] (II) LoadModule: "modesetting"
[ 32.932] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 32.933] (II) Module modesetting: vendor="X.Org Foundation"
[ 32.933] compiled for 1.21.1.10, module version = 1.21.1
[ 32.933] Module class: X.Org Video Driver
[ 32.933] ABI class: X.Org Video Driver, version 25.2
[ 32.933] (II) LoadModule: "fbdev"
[ 32.933] (WW) Warning, couldn't open module fbdev
[ 32.933] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 32.933] (II) LoadModule: "vesa"
[ 32.933] (WW) Warning, couldn't open module vesa
[ 32.933] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 32.933] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 32.934] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 32.938] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 32.938] (WW) Falling back to old probe method for modesetting
[ 32.938] (EE) open /dev/dri/card0: No such file or directory
[ 32.938] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 32.938] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 32.938] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 32.938] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 32.938] (==) AMDGPU(0): Default visual is TrueColor
[ 32.938] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card1
[ 32.938] (==) AMDGPU(0): RGB weight 888
[ 32.938] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 32.938] (--) AMDGPU(0): Chipset: "AMD Radeon Vega 8 Graphics" (ChipID = 0x15dd)
[ 32.938] (II) Loading sub module "fb"
[ 32.938] (II) LoadModule: "fb"
[ 32.938] (II) Module "fb" already built-in
[ 32.938] (II) Loading sub module "dri2"
[ 32.938] (II) LoadModule: "dri2"
[ 32.938] (II) Module "dri2" already built-in
[ 32.992] (II) Loading sub module "glamoregl"
[ 32.992] (II) LoadModule: "glamoregl"
[ 32.993] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 32.999] (II) Module glamoregl: vendor="X.Org Foundation"
[ 32.999] compiled for 1.21.1.10, module version = 1.0.1
[ 32.999] ABI class: X.Org ANSI C Emulation, version 0.4
[ 33.038] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon Vega 8 Graphics (radeonsi, raven, LLVM 16.0.6, DRM 3.54, 6.6.10-1-MANJARO)
[ 33.038] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 33.038] (==) AMDGPU(0): TearFree property default: auto
[ 33.038] (==) AMDGPU(0): VariableRefresh: disabled
[ 33.038] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[ 33.038] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 33.040] (II) AMDGPU(0): Output eDP has no monitor section
[ 33.040] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 33.046] (II) AMDGPU(0): EDID for output eDP
[ 33.046] (II) AMDGPU(0): Manufacturer: LGD Model: 597 Serial#: 0
[ 33.046] (II) AMDGPU(0): Year: 2017 Week: 0
[ 33.046] (II) AMDGPU(0): EDID Version: 1.4
[ 33.046] (II) AMDGPU(0): Digital Display Input
[ 33.046] (II) AMDGPU(0): 6 bits per channel
[ 33.046] (II) AMDGPU(0): Digital interface is DisplayPort
[ 33.046] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 29 vert.: 17
[ 33.046] (II) AMDGPU(0): Gamma: 2.20
[ 33.046] (II) AMDGPU(0): No DPMS capabilities specified
[ 33.046] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[ 33.046] (II) AMDGPU(0): First detailed timing is preferred mode
[ 33.046] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 33.046] (II) AMDGPU(0): redX: 0.637 redY: 0.350 greenX: 0.333 greenY: 0.625
[ 33.046] (II) AMDGPU(0): blueX: 0.152 blueY: 0.040 whiteX: 0.313 whiteY: 0.329
[ 33.046] (II) AMDGPU(0): Manufacturer's mask: 0
[ 33.046] (II) AMDGPU(0): Supported detailed timing:
[ 33.046] (II) AMDGPU(0): clock: 138.7 MHz Image Size: 294 x 165 mm
[ 33.046] (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 33.046] (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1111 v_border: 0
[ 33.046] (II) AMDGPU(0): clock: 92.5 MHz Image Size: 294 x 165 mm
[ 33.046] (II) AMDGPU(0): Unknown vendor-specific block 2
[ 33.046] (II) AMDGPU(0): EDID (in hex):
[ 33.046] (II) AMDGPU(0): 00ffffffffffff0030e4970500000000
[ 33.046] (II) AMDGPU(0): 001b0104951d1178022415a35955a027
[ 33.046] (II) AMDGPU(0): 0a505400000001010101010101010101
[ 33.046] (II) AMDGPU(0): 0101010101012e3680a070381f403020
[ 33.046] (II) AMDGPU(0): 350026a5100000191f2480a070381f40
[ 33.046] (II) AMDGPU(0): 3020350026a510000019000000000000
[ 33.046] (II) AMDGPU(0): 00000000000000000000000000000002
[ 33.046] (II) AMDGPU(0): 000c33ff0a3c96121028960000000007
[ 33.046] (II) AMDGPU(0): Printing probed modes for output eDP
[ 33.046] (II) AMDGPU(0): Modeline "1920x1080"x60.0 138.70 1920 1968 2000 2080 1080 1083 1088 1111 -hsync -vsync (66.7 kHz eP)
[ 33.046] (II) AMDGPU(0): Modeline "1920x1080"x40.0 92.47 1920 1968 2000 2080 1080 1083 1088 1111 -hsync -vsync (44.5 kHz e)
[ 33.046] (II) AMDGPU(0): Modeline "1680x1050"x60.0 138.70 1680 1968 2000 2080 1050 1083 1088 1111 -hsync -vsync (66.7 kHz e)
[ 33.046] (II) AMDGPU(0): Modeline "1280x1024"x60.0 138.70 1280 1968 2000 2080 1024 1083 1088 1111 -hsync -vsync (66.7 kHz e)
[ 33.046] (II) AMDGPU(0): Modeline "1440x900"x60.0 138.70 1440 1968 2000 2080 900 1083 1088 1111 -hsync -vsync (66.7 kHz e)
[ 33.046] (II) AMDGPU(0): Modeline "1280x800"x60.0 138.70 1280 1968 2000 2080 800 1083 1088 1111 -hsync -vsync (66.7 kHz e)
[ 33.046] (II) AMDGPU(0): Modeline "1280x720"x60.0 138.70 1280 1968 2000 2080 720 1083 1088 1111 -hsync -vsync (66.7 kHz e)
[ 33.046] (II) AMDGPU(0): Modeline "1024x768"x60.0 138.70 1024 1968 2000 2080 768 1083 1088 1111 -hsync -vsync (66.7 kHz e)
[ 33.046] (II) AMDGPU(0): Modeline "800x600"x60.0 138.70 800 1968 2000 2080 600 1083 1088 1111 -hsync -vsync (66.7 kHz e)
[ 33.046] (II) AMDGPU(0): Modeline "640x480"x60.0 138.70 640 1968 2000 2080 480 1083 1088 1111 -hsync -vsync (66.7 kHz e)
[ 33.046] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 33.046] (II) AMDGPU(0): Output eDP connected
[ 33.046] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 33.046] (II) AMDGPU(0): Using exact sizes for initial modes
[ 33.046] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[ 33.046] (II) AMDGPU(0): mem size init: gart size :1d24ed000 vram size: s:3dfa6000 visible:3dfa6000
[ 33.046] (==) AMDGPU(0): DPI set to (96, 96)
[ 33.046] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 33.046] (II) Loading sub module "ramdac"
[ 33.046] (II) LoadModule: "ramdac"
[ 33.046] (II) Module "ramdac" already built-in
[ 33.046] (II) UnloadModule: "radeon"
[ 33.046] (II) Unloading radeon
[ 33.047] (II) UnloadModule: "modesetting"
[ 33.047] (II) Unloading modesetting
[ 33.047] (II) AMDGPU(0): [DRI2] Setup complete
[ 33.047] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 33.047] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 33.065] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[ 33.066] (II) AMDGPU(0): SYNC extension fences enabled
[ 33.066] (II) AMDGPU(0): Present extension enabled
[ 33.066] (==) AMDGPU(0): DRI3 enabled
[ 33.066] (==) AMDGPU(0): Backing store enabled
[ 33.066] (II) AMDGPU(0): Direct rendering enabled
[ 33.080] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 33.080] (II) AMDGPU(0): Acceleration enabled
[ 33.080] (==) AMDGPU(0): DPMS enabled
[ 33.080] (==) AMDGPU(0): Silken mouse enabled
[ 33.080] (II) AMDGPU(0): Set up textured video (glamor)
[ 33.095] (WW) AMDGPU(0): Option "HotplugDriver" is not used
[ 33.095] (II) Initializing extension Generic Event Extension
[ 33.095] (II) Initializing extension SHAPE
[ 33.095] (II) Initializing extension MIT-SHM
[ 33.095] (II) Initializing extension XInputExtension
[ 33.095] (II) Initializing extension XTEST
[ 33.095] (II) Initializing extension BIG-REQUESTS
[ 33.095] (II) Initializing extension SYNC
[ 33.096] (II) Initializing extension XKEYBOARD
[ 33.096] (II) Initializing extension XC-MISC
[ 33.096] (II) Initializing extension SECURITY
[ 33.096] (II) Initializing extension XFIXES
[ 33.096] (II) Initializing extension RENDER
[ 33.096] (II) Initializing extension RANDR
[ 33.096] (II) Initializing extension COMPOSITE
[ 33.097] (II) Initializing extension DAMAGE
[ 33.097] (II) Initializing extension MIT-SCREEN-SAVER
[ 33.097] (II) Initializing extension DOUBLE-BUFFER
[ 33.097] (II) Initializing extension RECORD
[ 33.097] (II) Initializing extension DPMS
[ 33.097] (II) Initializing extension Present
[ 33.097] (II) Initializing extension DRI3
[ 33.097] (II) Initializing extension X-Resource
[ 33.097] (II) Initializing extension XVideo
[ 33.098] (II) Initializing extension XVideo-MotionCompensation
[ 33.098] (II) Initializing extension GLX
[ 33.106] (II) AIGLX: Loaded and initialized radeonsi
[ 33.106] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 33.106] (II) Initializing extension XFree86-VidModeExtension
[ 33.107] (II) Initializing extension XFree86-DGA
[ 33.107] (II) Initializing extension XFree86-DRI
[ 33.107] (II) Initializing extension DRI2
[ 33.107] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[ 33.225] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 33.225] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 33.225] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 33.225] (**) Power Button: Applying InputClass "system-keyboard"
[ 33.225] (II) LoadModule: "libinput"
[ 33.226] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 33.230] (II) Module libinput: vendor="X.Org Foundation"
[ 33.230] compiled for 1.21.1.8, module version = 1.4.0
[ 33.230] Module class: X.Org XInput Driver
[ 33.230] ABI class: X.Org XInput driver, version 24.4
[ 33.230] (II) Using input driver 'libinput' for 'Power Button'
[ 33.231] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 28 paused 0
[ 33.231] (**) Power Button: always reports core events
[ 33.231] (**) Option "Device" "/dev/input/event2"
[ 33.234] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 33.235] (II) event2 - Power Button: device is a keyboard
[ 33.235] (II) event2 - Power Button: device removed
[ 33.235] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 33.235] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 33.235] (**) Option "xkb_layout" "de"
[ 33.278] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 33.278] (II) event2 - Power Button: device is a keyboard
[ 33.280] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[ 33.280] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 33.280] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 33.280] (**) Video Bus: Applying InputClass "system-keyboard"
[ 33.280] (II) Using input driver 'libinput' for 'Video Bus'
[ 33.281] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 31 paused 0
[ 33.281] (**) Video Bus: always reports core events
[ 33.281] (**) Option "Device" "/dev/input/event13"
[ 33.283] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 33.283] (II) event13 - Video Bus: device is a keyboard
[ 33.283] (II) event13 - Video Bus: device removed
[ 33.283] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:14/LNXVIDEO:02/input/input16/event13"
[ 33.283] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 33.283] (**) Option "xkb_layout" "de"
[ 33.285] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 33.285] (II) event13 - Video Bus: device is a keyboard
[ 33.286] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 33.286] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 33.286] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 33.286] (**) Power Button: Applying InputClass "system-keyboard"
[ 33.286] (II) Using input driver 'libinput' for 'Power Button'
[ 33.287] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 32 paused 0
[ 33.287] (**) Power Button: always reports core events
[ 33.287] (**) Option "Device" "/dev/input/event0"
[ 33.289] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 33.289] (II) event0 - Power Button: device is a keyboard
[ 33.289] (II) event0 - Power Button: device removed
[ 33.289] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 33.289] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 33.289] (**) Option "xkb_layout" "de"
[ 33.291] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 33.291] (II) event0 - Power Button: device is a keyboard
[ 33.292] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 33.292] (II) No input driver specified, ignoring this device.
[ 33.292] (II) This device may have been added with another device file.
[ 33.293] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event16)
[ 33.293] (II) No input driver specified, ignoring this device.
[ 33.293] (II) This device may have been added with another device file.
[ 33.294] (II) config/udev: Adding input device Dell Computer Corp Dell Universal Receiver (/dev/input/event4)
[ 33.294] (**) Dell Computer Corp Dell Universal Receiver: Applying InputClass "evdev keyboard catchall"
[ 33.294] (**) Dell Computer Corp Dell Universal Receiver: Applying InputClass "libinput keyboard catchall"
[ 33.294] (**) Dell Computer Corp Dell Universal Receiver: Applying InputClass "system-keyboard"
[ 33.294] (II) Using input driver 'libinput' for 'Dell Computer Corp Dell Universal Receiver'
[ 33.295] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[ 33.295] (**) Dell Computer Corp Dell Universal Receiver: always reports core events
[ 33.295] (**) Option "Device" "/dev/input/event4"
[ 33.297] (II) event4 - Dell Computer Corp Dell Universal Receiver: is tagged by udev as: Keyboard
[ 33.298] (II) event4 - Dell Computer Corp Dell Universal Receiver: device is a keyboard
[ 33.298] (II) event4 - Dell Computer Corp Dell Universal Receiver: device removed
[ 33.298] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0/0003:413C:2514.0001/input/input5/event4"
[ 33.298] (II) XINPUT: Adding extended input device "Dell Computer Corp Dell Universal Receiver" (type: KEYBOARD, id 9)
[ 33.298] (**) Option "xkb_layout" "de"
[ 33.301] (II) event4 - Dell Computer Corp Dell Universal Receiver: is tagged by udev as: Keyboard
[ 33.301] (II) event4 - Dell Computer Corp Dell Universal Receiver: device is a keyboard
[ 33.302] (II) config/udev: Adding input device Dell Computer Corp Dell Universal Receiver Mouse (/dev/input/event5)
[ 33.302] (**) Dell Computer Corp Dell Universal Receiver Mouse: Applying InputClass "evdev pointer catchall"
[ 33.302] (**) Dell Computer Corp Dell Universal Receiver Mouse: Applying InputClass "libinput pointer catchall"
[ 33.302] (II) Using input driver 'libinput' for 'Dell Computer Corp Dell Universal Receiver Mouse'
[ 33.304] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 34 paused 0
[ 33.304] (**) Dell Computer Corp Dell Universal Receiver Mouse: always reports core events
[ 33.304] (**) Option "Device" "/dev/input/event5"
[ 33.306] (II) event5 - Dell Computer Corp Dell Universal Receiver Mouse: is tagged by udev as: Mouse
[ 33.306] (II) event5 - Dell Computer Corp Dell Universal Receiver Mouse: device is a pointer
[ 33.307] (II) event5 - Dell Computer Corp Dell Universal Receiver Mouse: device removed
[ 33.307] (II) libinput: Dell Computer Corp Dell Universal Receiver Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 33.307] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1/0003:413C:2514.0002/input/input6/event5"
[ 33.307] (II) XINPUT: Adding extended input device "Dell Computer Corp Dell Universal Receiver Mouse" (type: MOUSE, id 10)
[ 33.307] (**) Option "AccelerationScheme" "none"
[ 33.307] (**) Dell Computer Corp Dell Universal Receiver Mouse: (accel) selected scheme none/0
[ 33.307] (**) Dell Computer Corp Dell Universal Receiver Mouse: (accel) acceleration factor: 2.000
[ 33.307] (**) Dell Computer Corp Dell Universal Receiver Mouse: (accel) acceleration threshold: 4
[ 33.309] (II) event5 - Dell Computer Corp Dell Universal Receiver Mouse: is tagged by udev as: Mouse
[ 33.309] (II) event5 - Dell Computer Corp Dell Universal Receiver Mouse: device is a pointer
[ 33.311] (II) config/udev: Adding input device Dell Computer Corp Dell Universal Receiver Mouse (/dev/input/mouse0)
[ 33.311] (II) No input driver specified, ignoring this device.
[ 33.311] (II) This device may have been added with another device file.
[ 33.313] (II) config/udev: Adding input device Dell Computer Corp Dell Universal Receiver Consumer Control (/dev/input/event6)
[ 33.313] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 33.313] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 33.313] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 33.313] (II) Using input driver 'libinput' for 'Dell Computer Corp Dell Universal Receiver Consumer Control'
[ 33.314] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
[ 33.314] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: always reports core events
[ 33.314] (**) Option "Device" "/dev/input/event6"
[ 33.316] (II) event6 - Dell Computer Corp Dell Universal Receiver Consumer Control: is tagged by udev as: Keyboard
[ 33.317] (II) event6 - Dell Computer Corp Dell Universal Receiver Consumer Control: device is a keyboard
[ 33.317] (II) event6 - Dell Computer Corp Dell Universal Receiver Consumer Control: device removed
[ 33.317] (II) libinput: Dell Computer Corp Dell Universal Receiver Consumer Control: needs a virtual subdevice
[ 33.317] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1/0003:413C:2514.0002/input/input7/event6"
[ 33.317] (II) XINPUT: Adding extended input device "Dell Computer Corp Dell Universal Receiver Consumer Control" (type: MOUSE, id 11)
[ 33.317] (**) Option "AccelerationScheme" "none"
[ 33.317] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: (accel) selected scheme none/0
[ 33.317] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: (accel) acceleration factor: 2.000
[ 33.317] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: (accel) acceleration threshold: 4
[ 33.320] (II) event6 - Dell Computer Corp Dell Universal Receiver Consumer Control: is tagged by udev as: Keyboard
[ 33.320] (II) event6 - Dell Computer Corp Dell Universal Receiver Consumer Control: device is a keyboard
[ 33.322] (II) config/udev: Adding input device Dell Computer Corp Dell Universal Receiver System Control (/dev/input/event7)
[ 33.322] (**) Dell Computer Corp Dell Universal Receiver System Control: Applying InputClass "evdev keyboard catchall"
[ 33.322] (**) Dell Computer Corp Dell Universal Receiver System Control: Applying InputClass "libinput keyboard catchall"
[ 33.322] (**) Dell Computer Corp Dell Universal Receiver System Control: Applying InputClass "system-keyboard"
[ 33.322] (II) Using input driver 'libinput' for 'Dell Computer Corp Dell Universal Receiver System Control'
[ 33.323] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 36 paused 0
[ 33.323] (**) Dell Computer Corp Dell Universal Receiver System Control: always reports core events
[ 33.323] (**) Option "Device" "/dev/input/event7"
[ 33.326] (II) event7 - Dell Computer Corp Dell Universal Receiver System Control: is tagged by udev as: Keyboard
[ 33.326] (II) event7 - Dell Computer Corp Dell Universal Receiver System Control: device is a keyboard
[ 33.327] (II) event7 - Dell Computer Corp Dell Universal Receiver System Control: device removed
[ 33.327] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1/0003:413C:2514.0002/input/input8/event7"
[ 33.327] (II) XINPUT: Adding extended input device "Dell Computer Corp Dell Universal Receiver System Control" (type: KEYBOARD, id 12)
[ 33.327] (**) Option "xkb_layout" "de"
[ 33.330] (II) event7 - Dell Computer Corp Dell Universal Receiver System Control: is tagged by udev as: Keyboard
[ 33.330] (II) event7 - Dell Computer Corp Dell Universal Receiver System Control: device is a keyboard
[ 33.331] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event18)
[ 33.331] (II) No input driver specified, ignoring this device.
[ 33.331] (II) This device may have been added with another device file.
[ 33.331] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event19)
[ 33.332] (II) config/udev: Adding input device ELAN0732:00 04F3:2719 (/dev/input/event10)
[ 33.332] (**) ELAN0732:00 04F3:2719: Applying InputClass "evdev touchscreen catchall"
[ 33.333] (**) ELAN0732:00 04F3:2719: Applying InputClass "libinput touchscreen catchall"
[ 33.333] (II) Using input driver 'libinput' for 'ELAN0732:00 04F3:2719'
[ 33.334] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 37 paused 0
[ 33.334] (**) ELAN0732:00 04F3:2719: always reports core events
[ 33.334] (**) Option "Device" "/dev/input/event10"
[ 33.336] (II) event10 - ELAN0732:00 04F3:2719: is tagged by udev as: Touchscreen
[ 33.336] (II) event10 - ELAN0732:00 04F3:2719: device is a touch device
[ 33.337] (II) event10 - ELAN0732:00 04F3:2719: device removed
[ 33.337] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:00/i2c-0/i2c-ELAN0732:00/0018:04F3:2719.0004/input/input20/event10"
[ 33.337] (II) XINPUT: Adding extended input device "ELAN0732:00 04F3:2719" (type: TOUCHSCREEN, id 13)
[ 33.337] (**) Option "AccelerationScheme" "none"
[ 33.337] (**) ELAN0732:00 04F3:2719: (accel) selected scheme none/0
[ 33.337] (**) ELAN0732:00 04F3:2719: (accel) acceleration factor: 2.000
[ 33.337] (**) ELAN0732:00 04F3:2719: (accel) acceleration threshold: 4
[ 33.339] (II) event10 - ELAN0732:00 04F3:2719: is tagged by udev as: Touchscreen
[ 33.339] (II) event10 - ELAN0732:00 04F3:2719: device is a touch device
[ 33.340] (II) config/udev: Adding input device ELAN0732:00 04F3:2719 (/dev/input/mouse1)
[ 33.340] (II) No input driver specified, ignoring this device.
[ 33.341] (II) This device may have been added with another device file.
[ 33.341] (II) config/udev: Adding input device ELAN0732:00 04F3:2719 UNKNOWN (/dev/input/event11)
[ 33.342] (II) No input driver specified, ignoring this device.
[ 33.342] (II) This device may have been added with another device file.
[ 33.342] (II) config/udev: Adding input device ELAN0732:00 04F3:2719 UNKNOWN (/dev/input/event12)
[ 33.343] (II) config/udev: Adding input device ELAN0732:00 04F3:2719 Stylus (/dev/input/event15)
[ 33.343] (**) ELAN0732:00 04F3:2719 Stylus: Applying InputClass "evdev tablet catchall"
[ 33.343] (**) ELAN0732:00 04F3:2719 Stylus: Applying InputClass "libinput tablet catchall"
[ 33.343] (II) Using input driver 'libinput' for 'ELAN0732:00 04F3:2719 Stylus'
[ 33.345] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 38 paused 0
[ 33.345] (**) ELAN0732:00 04F3:2719 Stylus: always reports core events
[ 33.345] (**) Option "Device" "/dev/input/event15"
[ 33.347] (II) event15 - ELAN0732:00 04F3:2719 Stylus: is tagged by udev as: Tablet
[ 33.390] (II) event15 - ELAN0732:00 04F3:2719 Stylus: tablet 'ELAN0732:00 04F3:2719 Stylus' unknown to libwacom
[ 33.390] (II) event15 - ELAN0732:00 04F3:2719 Stylus: device is a tablet
[ 33.390] (II) event15 - ELAN0732:00 04F3:2719 Stylus: device removed
[ 33.390] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:00/i2c-0/i2c-ELAN0732:00/0018:04F3:2719.0004/input/input23/event15"
[ 33.390] (II) XINPUT: Adding extended input device "ELAN0732:00 04F3:2719 Stylus" (type: TABLET, id 14)
[ 33.392] (II) event15 - ELAN0732:00 04F3:2719 Stylus: is tagged by udev as: Tablet
[ 33.418] (II) event15 - ELAN0732:00 04F3:2719 Stylus: tablet 'ELAN0732:00 04F3:2719 Stylus' unknown to libwacom
[ 33.419] (II) event15 - ELAN0732:00 04F3:2719 Stylus: device is a tablet
[ 33.420] (II) config/udev: Adding input device ELAN0732:00 04F3:2719 Stylus (/dev/input/mouse2)
[ 33.420] (II) No input driver specified, ignoring this device.
[ 33.420] (II) This device may have been added with another device file.
[ 33.420] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 33.420] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 33.420] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 33.421] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 33.421] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 33.422] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 40 paused 0
[ 33.422] (**) AT Translated Set 2 keyboard: always reports core events
[ 33.422] (**) Option "Device" "/dev/input/event3"
[ 33.423] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 33.424] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 33.425] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 33.425] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 33.425] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 15)
[ 33.425] (**) Option "xkb_layout" "de"
[ 33.426] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 33.426] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 33.429] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event17)
[ 33.429] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 33.429] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 33.429] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 33.430] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 41 paused 0
[ 33.430] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 33.430] (**) Option "Device" "/dev/input/event17"
[ 33.431] (II) event17 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 33.432] (II) event17 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[ 33.434] (II) event17 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 33.435] (II) event17 - SynPS/2 Synaptics TouchPad: device removed
[ 33.435] (II) libinput: SynPS/2 Synaptics TouchPad: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 33.435] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input18/event17"
[ 33.435] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 16)
[ 33.437] (**) Option "AccelerationScheme" "none"
[ 33.437] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 33.437] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 33.437] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 33.439] (II) event17 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 33.439] (II) event17 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[ 33.442] (II) event17 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 33.443] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse3)
[ 33.443] (II) No input driver specified, ignoring this device.
[ 33.443] (II) This device may have been added with another device file.
[ 33.443] (II) config/udev: Adding input device PC Speaker (/dev/input/event14)
[ 33.448] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event9)
[ 33.448] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 33.448] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 33.448] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[ 33.448] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 33.449] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 42 paused 0
[ 33.449] (**) HP WMI hotkeys: always reports core events
[ 33.449] (**) Option "Device" "/dev/input/event9"
[ 33.450] (II) event9 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 33.450] (II) event9 - HP WMI hotkeys: device is a keyboard
[ 33.450] (II) event9 - HP WMI hotkeys: device is a switch device
[ 33.451] (II) event9 - HP WMI hotkeys: device removed
[ 33.451] (**) Option "config_info" "udev:/sys/devices/virtual/input/input19/event9"
[ 33.451] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 17)
[ 33.451] (**) Option "xkb_layout" "de"
[ 33.452] (II) event9 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 33.452] (II) event9 - HP WMI hotkeys: device is a keyboard
[ 33.452] (II) event9 - HP WMI hotkeys: device is a switch device
[ 33.453] (II) config/udev: Adding input device Wireless hotkeys (/dev/input/event8)
[ 33.453] (**) Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[ 33.453] (**) Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
[ 33.453] (**) Wireless hotkeys: Applying InputClass "system-keyboard"
[ 33.453] (II) Using input driver 'libinput' for 'Wireless hotkeys'
[ 33.454] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 43 paused 0
[ 33.454] (**) Wireless hotkeys: always reports core events
[ 33.454] (**) Option "Device" "/dev/input/event8"
[ 33.455] (II) event8 - Wireless hotkeys: is tagged by udev as: Keyboard
[ 33.455] (II) event8 - Wireless hotkeys: device is a keyboard
[ 33.455] (II) event8 - Wireless hotkeys: device removed
[ 33.456] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event8"
[ 33.456] (II) XINPUT: Adding extended input device "Wireless hotkeys" (type: KEYBOARD, id 18)
[ 33.456] (**) Option "xkb_layout" "de"
[ 33.457] (II) event8 - Wireless hotkeys: is tagged by udev as: Keyboard
[ 33.457] (II) event8 - Wireless hotkeys: device is a keyboard
[ 33.466] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 33.466] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 33.466] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 33.466] (II) Using input driver 'libinput' for 'Dell Computer Corp Dell Universal Receiver Consumer Control'
[ 33.466] (II) systemd-logind: returning pre-existing fd for /dev/input/event6 13:70
[ 33.466] (**) Dell Computer Corp Dell Universal Receiver Consumer Control: always reports core events
[ 33.466] (**) Option "Device" "/dev/input/event6"
[ 33.466] (II) libinput: Dell Computer Corp Dell Universal Receiver Consumer Control: is a virtual subdevice
[ 33.466] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1/0003:413C:2514.0002/input/input7/event6"
[ 33.466] (II) XINPUT: Adding extended input device "Dell Computer Corp Dell Universal Receiver Consumer Control" (type: KEYBOARD, id 19)
[ 33.466] (**) Option "xkb_layout" "de"
[ 34.411] (II) AMDGPU(0): EDID vendor "LGD", prod id 1431
[ 34.411] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 34.411] (II) AMDGPU(0): Modeline "1920x1080"x0.0 138.70 1920 1968 2000 2080 1080 1083 1088 1111 -hsync -vsync (66.7 kHz eP)
[ 34.411] (II) AMDGPU(0): Modeline "1920x1080"x0.0 92.47 1920 1968 2000 2080 1080 1083 1088 1111 -hsync -vsync (44.5 kHz e)
[ 52.233] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 52.233] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 52.396] (**) Option "fd" "28"
[ 52.396] (II) event2 - Power Button: device removed
[ 52.396] (**) Option "fd" "31"
[ 52.396] (II) event13 - Video Bus: device removed
[ 52.396] (**) Option "fd" "32"
[ 52.396] (II) event0 - Power Button: device removed
[ 52.396] (**) Option "fd" "33"
[ 52.396] (II) event4 - Dell Computer Corp Dell Universal Receiver: device removed
[ 52.397] (**) Option "fd" "34"
[ 52.397] (II) event5 - Dell Computer Corp Dell Universal Receiver Mouse: device removed
[ 52.397] (**) Option "fd" "35"
[ 52.397] (**) Option "fd" "36"
[ 52.397] (II) event7 - Dell Computer Corp Dell Universal Receiver System Control: device removed
[ 52.397] (**) Option "fd" "37"
[ 52.397] (II) event10 - ELAN0732:00 04F3:2719: device removed
[ 52.397] (**) Option "fd" "38"
[ 52.397] (II) event15 - ELAN0732:00 04F3:2719 Stylus: device removed
[ 52.397] (**) Option "fd" "40"
[ 52.397] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 52.397] (**) Option "fd" "41"
[ 52.397] (II) event17 - SynPS/2 Synaptics TouchPad: device removed
[ 52.397] (**) Option "fd" "42"
[ 52.397] (II) event9 - HP WMI hotkeys: device removed
[ 52.397] (**) Option "fd" "43"
[ 52.397] (II) event8 - Wireless hotkeys: device removed
[ 52.397] (II) event6 - Dell Computer Corp Dell Universal Receiver Consumer Control: device removed
[ 52.399] (II) UnloadModule: "libinput"
[ 52.399] (II) systemd-logind: not releasing fd for 13:70, still in use
[ 52.399] (II) systemd-logind: releasing fd for 13:72
[ 52.405] (II) UnloadModule: "libinput"
[ 52.406] (II) systemd-logind: releasing fd for 13:73
[ 52.407] (II) UnloadModule: "libinput"
[ 52.407] (II) systemd-logind: releasing fd for 13:81
[ 52.433] (II) UnloadModule: "libinput"
[ 52.433] (II) systemd-logind: releasing fd for 13:67
[ 52.434] (II) UnloadModule: "libinput"
[ 52.434] (II) systemd-logind: releasing fd for 13:79
[ 52.435] (II) UnloadModule: "libinput"
[ 52.435] (II) systemd-logind: releasing fd for 13:74
[ 52.435] (II) systemd-logind: releasing fd for 13:71
[ 52.436] (II) UnloadModule: "libinput"
[ 52.436] (II) systemd-logind: releasing fd for 13:70
[ 52.437] (II) systemd-logind: releasing fd for 13:69
[ 52.437] (II) UnloadModule: "libinput"
[ 52.437] (II) systemd-logind: releasing fd for 13:68
[ 52.438] (II) UnloadModule: "libinput"
[ 52.438] (II) systemd-logind: releasing fd for 13:64
[ 52.438] (II) systemd-logind: releasing fd for 13:77
[ 52.441] (II) UnloadModule: "libinput"
[ 52.441] (II) systemd-logind: releasing fd for 13:66
[ 52.452] (II) Server terminated successfully (0). Closing log file.
