Hello
My computer hangs randomly, i can still move the mouse but it doesn’t let me click anywhere, when i try to execute new programs it’s only showing black space.
The only way to do something is to go to the console via control + alt + F2 to restart.
What I normally do is suspend the computer and not turn it off. Freezing is not happening after resume from suspend, many days can go by without this happening.
I’ve updated the BIOS after hangs days ago but this keeps happening again and again.
Today this happened with kernel 5.15.81-1 but it happened with 6.0.11-1 days ago.
Here is my current state of inxi -Fxz
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: KDE Plasma v: 5.26.4 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7A38 v: 8.0
serial: <superuser required>
Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> UEFI: American Megatrends LLC. v: B.G0
date: 07/26/2022
Device-1: hidpp_battery_0 model: Logitech K370s/K375s Multi-Device Wireless
Keyboard charge: 100% (should be ignored) status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master
Info: quad core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64
type: MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB L2: 2 MiB
L3: 4 MiB
Speed (MHz): avg: 1310 high: 1468 min/max: 1400/3600 boost: enabled cores:
1: 1259 2: 1257 3: 1468 4: 1257 bogomips: 28756
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5 bus-ID: 2a:00.0 temp: 44.0 C
Device-2: KYE Systems (Mouse Systems) PC-LM1E Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu
unloaded: modesetting dri: radeonsi gpu: amdgpu resolution: 1: 1440x900~60Hz
2: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 14.0.6 DRM 3.42 5.15.81-1-MANJARO) direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 5-1:2 bus-ID: 2a:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2a:00.6
Device-3: KYE Systems (Mouse Systems) PC-LM1E Camera type: USB
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 25:00.0
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.48 TiB used: 329.99 GiB (21.8%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P1SSD8 size: 465.76 GiB
temp: 33.9 C
ID-2: /dev/sda vendor: Toshiba model: THNSNH128GCST size: 119.24 GiB
ID-3: /dev/sdb vendor: Western Digital model: WD10EZEX-08M2NA0
ID-1: / size: 49.43 GiB used: 15.35 GiB (31.1%) fs: ext4 dev: /dev/nvme0n1p7
ID-2: /boot/efi size: 399.2 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p9
ID-3: /home size: 56 GiB used: 5.24 GiB (9.4%) fs: ext4
dev: /dev/nvme0n1p8
ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p6
System Temperatures: cpu: 43.9 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 245 Uptime: 49m Memory: 13.58 GiB used: 3.88 GiB (28.6%)
Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1244 Shell: Zsh
v: 5.9 inxi: 3.3.24
journalctl -b-1 -p4 --no-pager
Dec 16 19:30:53 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 33152, resource id: 17826013, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:32:41 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 38298, resource id: 17826466, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:35:44 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 39636, resource id: 17826882, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:36:12 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 41063, resource id: 17826988, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:42:37 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 49873, resource id: 17827626, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:43:01 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 50942, resource id: 17827902, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:44:18 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 55777, resource id: 17828045, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:44:52 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 60388, resource id: 17828345, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:45:03 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 64620, resource id: 17828706, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:45:10 maint kwin_x11[613]: kwin_core: XCB error: 152 (BadDamage), sequence: 3319, resource id: 17829015, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19195, resource id: 17830778, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19264, resource id: 17830786, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19268, resource id: 17830787, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19325, resource id: 17830792, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19329, resource id: 17830793, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19359, resource id: 17830797, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19385, resource id: 17830800, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19407, resource id: 17830803, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19429, resource id: 17830806, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19454, resource id: 17830810, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19471, resource id: 17830812, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:28 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 19492, resource id: 17830815, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20351, resource id: 17830861, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20364, resource id: 17830862, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20375, resource id: 17830863, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20386, resource id: 17830864, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20397, resource id: 17830865, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20409, resource id: 17830866, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20420, resource id: 17830867, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20431, resource id: 17830868, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20442, resource id: 17830869, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:38 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20453, resource id: 17830870, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:39 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20471, resource id: 17830872, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:40 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20556, resource id: 17830873, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:40 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20564, resource id: 17830874, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:40 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20728, resource id: 17830876, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:40 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20758, resource id: 17830880, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:40 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20788, resource id: 17830884, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:40 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20814, resource id: 17830887, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:41 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20840, resource id: 17830890, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:46:41 maint kwin_x11[613]: kwin_core: XCB error: 136 (Unknown), sequence: 20866, resource id: 17830893, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 16 19:48:55 maint login[76407]: pam_systemd(login:session): Failed to release session: Interrupted system call
Dec 16 19:48:55 maint sddm[482]: Authentication error: "Process crashed"
Dec 16 19:48:55 maint sddm[482]: Auth: sddm-helper crashed (exit code 15)
Dec 16 19:48:55 maint sddm[482]: Auth: sddm-helper exited with 15
Dec 16 19:48:55 maint kglobalaccel5[651]: The X11 connection broke (error 1). Did the X11 server die?
Dec 16 19:48:55 maint ksmserver[610]: The X11 connection broke (error 1). Did the X11 server die?
Dec 16 19:48:55 maint kwin_x11[613]: The X11 connection broke (error 1). Did the X11 server die?
Dec 16 19:48:55 maint kwin_x11[613]: file:///usr/share/kwin/outline/plasma/outline.qml:14: TypeError: Cannot read property 'longDuration' of null
Dec 16 19:48:55 maint systemd[531]: plasma-ksmserver.service: Failed with result 'exit-code'.
Dec 16 19:48:55 maint systemd-coredump[76470]: Failed to connect to coredump service: Connection refused
Dec 16 19:48:55 maint systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Dec 16 19:48:55 maint systemd[1]: udisks2.service: Failed with result 'core-dump'.
Dec 16 19:48:55 maint kactivitymanagerd[682]: The X11 connection broke (error 1). Did the X11 server die?
Dec 16 19:48:55 maint systemd[531]: app-org.kde.konsole-9081f4c559854b95afbf4733310022a2.scope: Failed to kill control group /user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole-9081f4c559854b95afbf4733310022a2.scope, ignoring: Operation not permitted
Dec 16 19:48:55 maint systemd[531]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Dec 16 19:48:55 maint systemd[531]: obex.service: Failed with result 'exit-code'.
Dec 16 19:48:55 maint systemd[531]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Dec 16 19:48:55 maint pulseaudio[977]: Error opening PCM device front:1: No such file or directory
Dec 16 19:48:55 maint pulseaudio[977]: Failed to create sink input: sink is suspended.
Dec 16 19:48:55 maint pulseaudio[977]: Lost I/O connection in module "module-gsettings"
Dec 16 19:48:55 maint systemd-coredump[76586]: Failed to connect to coredump service: Connection refused
Dec 16 19:48:55 maint kded5[612]: kf.notifications: Failed to play sound with canberra: Invalid state
Dec 16 19:48:55 maint kded5[612]: The X11 connection broke (error 1). Did the X11 server die?
Dec 16 19:48:55 maint kded5[612]: kf.notifications: Had queued notifications on destruction. Was the eventloop running?
Dec 16 19:48:56 maint systemd[531]: plasma-kded.service: Failed with result 'exit-code'.
Dec 16 19:48:56 maint sddm[482]: Signal received: SIGTERM
Dec 16 19:48:56 maint systemd-logind[395]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (systemd-reboot.service has 'start' job queued, but 'stop' is included in transaction).
Dec 16 19:48:56 maint sddm[482]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Dec 16 19:48:58 maint kernel: watchdog: watchdog0: watchdog did not stop!
