The OP’s problem in the other thread seems to be freezing when sleep is initiated, not on wakeup. Even if it was the same problem it wouldn’t necessarily have the same solution.
I’ve had a similar issue with kernels 6.11, 6.12, and 6.13-rc. No suspend issue with 6.6.
The system shows the lockscreen (gray background as configured in swaylock), but freezes completely upon waking up.
System: 8-core AMD Ryzen 9 6900HX with Radeon Graphics
> journalctl --boot -1 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Dec 16 11:52:11 blade142022rz090427 systemd[1]: Starting System Suspend...
Dec 16 11:52:11 blade142022rz090427 systemd-sleep[4545]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
Dec 16 11:52:11 blade142022rz090427 systemd-sleep[4545]: This is not recommended, and might result in unexpected behavior, particularly
Dec 16 11:52:11 blade142022rz090427 systemd-sleep[4545]: in suspend-then-hibernate operations or setups with encrypted home directories.
Dec 16 11:52:11 blade142022rz090427 systemd-sleep[4545]: Performing sleep operation 'suspend'...
Dec 16 11:52:11 blade142022rz090427 kernel: PM: suspend entry (s2idle)
Dec 16 11:52:11 blade142022rz090427 kernel: Filesystems sync: 0.006 seconds
