So I have kde plasma with kernel 5.15.76-1. I followed some post that recommended to get libfprint. I think I almost got it working.
It says that my fingerprint login is not yet supported. I also already scanned it and when I restart my laptop and try to use my fingerprint, it just doesnt work.
I mostly followed this
post . Also my fingerprint is supported for sure. I am using the framewok laptop 12th gen and I also have windows 10 installed on the side. With windows the fingerprint works.
If anyone has some help, thanks. I am also newer.
kisun
9 November 2022 17:02
2
Hello @haShinui ,
the user from the other post uses gnome, which normaly user GDM as “Display Manager” (Login Screen). KDE uses SDDM as Display Manager as I know.
So you should take a look in the Arch Wiki for SDDM .
For more help the helpers have to know more about your system. So please post the output from these commands:
inxi --admin --verbosity=7 --filter --width
lsusb
Also I guess the package fprintdshould be installed! Is it?
Sorry I replied that late, I had family problems and didnt use my laptop for a long time. Yes I already installed fprintd. I am also looking into SDDM right now. Again really sorry for late responds
Also dual booting Windows and fingerprint reader is working there.
Kernel: 5.15.89-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=deb7b23b-3d28-43b9-b7f9-0749671210d9 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Framework product: Laptop (12th Gen Intel Core) v: A6
serial:
Mobo: Framework model: FRANGACP06 v: A6 serial:
UEFI: INSYDE v: 03.04 date: 07/15/2022
ID-1: BAT1 charge: 37.7 Wh (74.5%) condition: 50.6/55.0 Wh (92.0%)
volts: 15.9 min: 15.4 model: NVT Framewo type: Li-ion serial:
status: discharging cycles: 105
RAM: total: 15.34 GiB used: 5.82 GiB (38.0%)
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 841 high: 1398 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 450 2: 657 3: 1042 4: 676
5: 689 6: 642 7: 605 8: 938 9: 987 10: 1398 11: 1029 12: 553 13: 803
14: 736 15: 1136 16: 1115 bogomips: 79888
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:4626
class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63")
s-diag: 716mm (28.19")
Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res: 2256x1504
hz: 60 dpi: 201 gamma: 1.2 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
ratio: 3:2 modes: 2256x1504
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8
class-ID: 0403
Sound API: ALSA v: k5.15.89-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: a6:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp166s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 931.51 GiB used: 18.19 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P2SSD8
lanes: 4 type: SSD serial: rev: P2CR048 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 488.28 GiB size: 479.55 GiB (98.21%) used: 18.16 GiB (3.8%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: deb7b23b-3d28-43b9-b7f9-0749671210d9
used: 25.6 MiB (26.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: F41E-8FE4
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs:
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 442.62 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: 98EE739FEE7373FA
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 20 Gb/s
Device-1: 2-4:2 info: Silicon Motion - Taiwan (formerly Feiya ) USB DISK
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 504mA chip-ID: 090c:3350 class-ID: 0806 serial:
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Logitech USB Receiver type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c547 class-ID: 0300
Device-2: 3-9:3 info: Shenzhen Goodix USB2.0 MISC type:
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:609c class-ID: ef00 serial:
Device-3: 3-10:4 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 358 Uptime: 41m wakeups: 4464 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1290 libs: 325 tools: pamac,paru pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
Bus 003 Device 002: ID 046d:c547 Logitech, Inc. USB Receiver
Bus 003 Device 004: ID 8087:0032 Intel Corp. AX210 Bluetooth
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 090c:3350 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) USB DISK
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
On plasma you have to wait until fingerprint implementation is finished. Gnome already has support implemented.
Oh, so I got It up and running. I needed to change some things in the SDDM files and now I can log in with my fingerprint. So if someone has the same problem go to SDDM wiki at 2.9. That all thanks to @kisun who showed me where to look, thanks a lot
