I have hardware acceleration in Firefox enabled but frames are continuously dropped and the video stutters significantly. CPU load is around 60%. When I download the video as VP9 and play it with mpv the CPU load is 15% and the stuttering is gone.
Same goes for Chromium where hardware acceleration is not enabled. CPU load is then 80%.
The issue got even worse with my new 1440p monitor. There are no issues when playing videos with a lower frame rate. I’ve got a i7-7500U with an HD Graphics 620. Is my laptop already too old to play YouTube videos or may there be an other issue?
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2054e9c8-af3d-4dfc-9790-239bad706a1e rw
cryptdevice=UUID=f52949b9-30e6-4a9e-a565-429388691fbe:cryptroot acpi_osi=!
"acpi_osi=Windows 2019" udev.log_priority=3
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 20HQS03P00 v: ThinkPad X1 Carbon 5th
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20HQS03P00 serial: <filter> UEFI: LENOVO
v: N1MET64W (1.49 ) date: 10/14/2020
ID-1: BAT0 charge: 48.1 Wh (89.4%) condition: 53.8/57.0 Wh (94.3%)
volts: 12.4 min: 11.6 model: LGC 01AV429 type: Li-poly serial: <filter>
status: Unknown cycles: 365
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech M720 Triathlon Multi-Device Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 15.4 GiB used: 3.66 GiB (23.7%)
Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
microcode: EA cache: L2: 4 MiB bogomips: 23209
Speed: 1742 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 1742 2: 500
3: 500 4: 500
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Lenovo ThinkPad X1 Carbon 5th Gen
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 04f2:b5ce class-ID: 0e02
Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting unloaded: fbdev alternate: intel,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
s-diag: 987mm (38.8")
Monitor-1: XWAYLAND1 res: 3440x1440 hz: 50 dpi: 107
size: 820x340mm (32.3x13.4") diag: 888mm (34.9")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio
vendor: Lenovo ThinkPad X1 Carbon 5th Gen driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Device-2: GYROCOM C&C Fiio E10 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.2:4 chip-ID: 1852:7022
class-ID: 0102
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.37 running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo ThinkPad X1 Carbon 5th Gen
driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15d8
class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0
bus-ID: 04:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
bus-ID: 1-7:2 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Device-1: cryptroot maj-min: 254:0 type: LUKS dm: dm-0 size: 476.44 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 476.44 GiB
Local Storage: total: 596.02 GiB used: 304.44 GiB (51.1%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SC128 size: 119.08 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW512HMJP-000L7
lanes: 4 type: SSD serial: <filter> rev: 7L7QCXY7 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 476.44 GiB size: 467.96 GiB (98.22%)
used: 243.2 GiB (52.0%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: cryptroot label: N/A uuid: N/A
used: 2.6 MiB (0.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 769C-1F20
ID-3: /run/media/jens/SDcard raw-size: 119.08 GiB size: 116.71 GiB (98.01%)
used: 61.24 GiB (52.5%) fs: ext4 dev: /dev/mmcblk0p1 maj-min: 179:1
label: SDcard uuid: 98b70059-f3e2-4947-b984-3af1f327b68d
ID-1: swap-1 type: file size: 15.43 GiB used: 512 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-7:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-8:3 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b5ce
class-ID: 0e02
Device-3: 1-9:4 info: Validity Sensors type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 138a:0097
class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 3-1.1:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-1.2:4 info: GYROCOM C&C Fiio E10 type: HID,Audio
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 1852:7022 class-ID: 0102
Device-3: 3-1.3:5 info: LG USA USB Controls type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip-ID: 043e:9a39 class-ID: 0300 serial: <filter>
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 244 Uptime: 21h 21m wakeups: 38 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1870
lib: 457 flatpak: 0 Shell: Zsh v: 5.8 running-in: tilix inxi: 3.3.06
