$ inxi --admin --verbosity=8 --filter --no-host --width
Kernel: 6.11.2-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=46731c0c-15da-451b-a25b-a0a6439e3a7b rw nowatchdog nvme_load=YES
loglevel=3 nvidia-drm.modeset=1 nvidia_drm.fbdev=1
nvidia.NVreg_EnableGpuFirmware=0
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: MECHREVO product: Yilong15Pro Series GM5HG0A v: Standard
serial: <superuser required>
Mobo: MECHREVO model: GM5HG0A v: Standard serial: <superuser required>
part-nu: 0001 uuid: <superuser required> UEFI: American Megatrends LLC.
v: N.1.08MRO15 date: 07/30/2024
ID-1: BAT0 charge: 80.1 Wh (100.0%) condition: 80.1/80.1 Wh (100.0%)
volts: 17.1 min: 15.4 model: standard type: Li-ion serial: <filter>
status: full
System RAM: total: 32 GiB available: 30.64 GiB used: 2.16 GiB (7.0%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 5600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT16G56C46S5.M8D1 serial: <filter>
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 8845H w/ Radeon 780M Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705203
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/5137 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 bogomips: 121420
Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv
lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes
vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic
xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
affected
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: AIstone Global driver: nvidia v: 560.35.03
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:28a0 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix3 vendor: AIstone Global
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-2, DP-3, DP-4, DP-5, DP-6, Writeback-1, eDP-2 bus-ID: 06:00.0
chip-ID: 1002:1900 class-ID: 0300 temp: 52.0 C
Device-3: SunplusIT HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:4 chip-ID: 2b7e:b651
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa dri: radeonsi
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1280x800 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 560.35.03
device-ID: 10de:28a0 surfaces: xcb,xlib,wayland
Device-1: NVIDIA AD107 High Definition Audio vendor: AIstone Global
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: AIstone Global driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640
class-ID: 0403
Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: AIstone Global driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: AIstone Global driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.2-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: AIstone Global driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7922 class-ID: 0280
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:5 chip-ID: 13d3:3585
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: N/A
Local Storage: total: 953.87 GiB used: 48.91 GiB (5.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Hynix model: YMTC PC411-1024GB-B
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: YM3603B0 temp: 36.9 C
scheme: GPT
ID-1: / raw-size: 29.71 GiB size: 29.61 GiB (99.67%) used: 9.79 GiB (33.1%)
fs: xfs dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A
uuid: 46731c0c-15da-451b-a25b-a0a6439e3a7b
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: D1D0-D285
ID-3: /run/media/wux/b88c8036-2134-4244-9b28-5e59f87d0a01 raw-size: 400 GiB
size: 399.8 GiB (99.95%) used: 39.12 GiB (9.8%) fs: xfs dev: /dev/nvme0n1p7
maj-min: 259:7 label: N/A uuid: b88c8036-2134-4244-9b28-5e59f87d0a01
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: DE86-EC07
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 200.01 GiB fs: ntfs label: N/A
uuid: D89E88439E881BDE
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 226.49 GiB fs: ntfs label: N/A
uuid: C69888B59888A611
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 900 MiB fs: ntfs label: N/A
uuid: 86D68967D6895877
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 300 MiB fs: vfat label: N/A
uuid: 8E12-8733
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
Device-1: 1-1:2 info: Telink G3M PRO type: mouse driver: hid-generic,usbhid
power: 400mA chip-ID: 320f:706e class-ID: 0301
Device-2: 1-2:3 info: CX 2.4G Wireless Receiver type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3554:fa09 class-ID: 0301
Device-3: 1-3:4 info: SunplusIT HD Webcam type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 2b7e:b651 class-ID: 0e02 serial: <filter>
Device-4: 1-5:5 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3585 class-ID: e001 serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-5: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-7: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-9: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Hub-10: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-11: 8-1:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
System Temperatures: cpu: 60.5 C mobo: 54.5 C gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 992 libs: 239 tools: yay
Active pacman repo servers in: /etc/pacman.d/endeavouros-mirrorlist
1: https://mirrors.jlu.edu.cn/endeavouros/repo/$repo/$arch
2: https://mirror.funami.tech/endeavouros/repo/$repo/$arch
3: https://mirror.sjtu.edu.cn/endeavouros/repo/$repo/$arch
4: https://md.mirrors.hacktegic.com/endeavouros/repo/$repo/$arch
5: https://www.miraa.jp/endeavouros/repo/$repo/$arch
6: https://ftp.belnet.be/mirror/endeavouros/repo/$repo/$arch
7: https://mirror.archlinux.tw/EndeavourOS/repo/$repo/$arch
8: https://mirror.freedif.org/EndeavourOS/repo/$repo/$arch
9: https://mirrors.urbanwave.co.za/endeavouros/repo/$repo/$arch
10: https://mirror.alpix.eu/endeavouros/repo/$repo/$arch
11: https://fastmirror.pp.ua/endeavouros/repo/$repo/$arch
12: https://mirrors.gigenet.com/endeavouros/repo/$repo/$arch
13: https://mirror.rznet.fr/endeavouros/repo/$repo/$arch
14: https://mirror.accum.se/mirror/endeavouros/repo/$repo/$arch
15: https://mirrors.nxtgen.com/endeavouros-mirror/repo/$repo/$arch
16: https://mirror.moson.org/endeavouros/repo/$repo/$arch
17: https://mirrors.c0urier.net/linux/endeavouros/repo/$repo/$arch
18: https://fosszone.csd.auth.gr/endeavouros/repo/$repo/$arch
19: https://ftp.rz.tu-bs.de/pub/mirror/endeavouros/repo/$repo/$arch
20: https://mirror.albony.xyz/endeavouros/repo/$repo/$arch
1: http://sg.mirrors.cicku.me/archlinux/$repo/os/$arch
2: http://arch.niranjan.co/$repo/os/$arch
3: http://mirror.xeonbd.com/archlinux/$repo/os/$arch
4: http://mirror.xtom.com.hk/archlinux/$repo/os/$arch
5: https://mirror.cyberbits.asia/archlinux/$repo/os/$arch
6: https://mirror.funami.tech/arch/$repo/os/$arch
7: http://jp.mirrors.cicku.me/archlinux/$repo/os/$arch
8: http://ch.mirrors.cicku.me/archlinux/$repo/os/$arch
9: https://sg.mirrors.cicku.me/archlinux/$repo/os/$arch
10: http://mirrors.tuna.tsinghua.edu.cn/archlinux/$repo/os/$arch
11: https://sydney.mirror.pkgbuild.com/$repo/os/$arch
12: http://at.mirrors.cicku.me/archlinux/$repo/os/$arch
13: http://ftp.rnl.tecnico.ulisboa.pt/pub/archlinux/$repo/os/$arch
14: http://ca.mirrors.cicku.me/archlinux/$repo/os/$arch
15: http://nl.mirrors.cicku.me/archlinux/$repo/os/$arch
16: http://mirror.twds.com.tw/archlinux/$repo/os/$arch
17: https://it.mirrors.cicku.me/archlinux/$repo/os/$arch
18: http://it.mirrors.cicku.me/archlinux/$repo/os/$arch
19: http://gsl-syd.mm.fcix.net/archlinux/$repo/os/$arch
20: https://mirror.twds.com.tw/archlinux/$repo/os/$arch
21: http://mirror.funami.tech/arch/$repo/os/$arch
22: https://mirror.xtom.com.hk/archlinux/$repo/os/$arch
23: https://ftp.rnl.tecnico.ulisboa.pt/pub/archlinux/$repo/os/$arch
24: https://nl.mirrors.cicku.me/archlinux/$repo/os/$arch
25: http://arch.jensgutermuth.de/$repo/os/$arch
26: https://mirrors.celianvdb.fr/archlinux/$repo/os/$arch
27: https://arch.yhtez.xyz/$repo/os/$arch
28: http://al.arch.niranjan.co/$repo/os/$arch
29: http://mirrors.ustc.edu.cn/archlinux/$repo/os/$arch
30: https://jp.mirrors.cicku.me/archlinux/$repo/os/$arch
31: http://md.mirrors.hacktegic.com/archlinux/$repo/os/$arch
32: https://mirrors.dotsrc.org/archlinux/$repo/os/$arch
33: http://ru.mirrors.cicku.me/archlinux/$repo/os/$arch
34: http://es.mirrors.cicku.me/archlinux/$repo/os/$arch
35: http://mirror.sahil.world/archlinux/$repo/os/$arch
36: http://de.arch.niranjan.co/$repo/os/$arch
37: https://europe.mirror.pkgbuild.com/$repo/os/$arch
38: https://arch.mirror.zachlge.org/$repo/os/$arch
39: https://mirrors.uni-plovdiv.net/archlinux/$repo/os/$arch
40: https://arch.sakamoto.pl/$repo/os/$arch
41: https://mirror.2degrees.nz/archlinux/$repo/os/$arch
42: https://mirrors.reitarovskyi.tech/archlinux/$repo/os/$arch
43: http://us.arch.niranjan.co/$repo/os/$arch
44: http://mirror.2degrees.nz/archlinux/$repo/os/$arch
45: https://london.mirror.pkgbuild.com/$repo/os/$arch
46: http://repository.su/archlinux/$repo/os/$arch
47: http://nova.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
48: http://super.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
49: http://archlinux.iskon.hr/$repo/os/$arch
50: http://ftp.myrveln.se/pub/linux/archlinux/$repo/os/$arch
51: http://mirrors.reitarovskyi.tech/archlinux/$repo/os/$arch
52: http://br.mirrors.cicku.me/archlinux/$repo/os/$arch
53: http://mirrors.atviras.lt/archlinux/$repo/os/$arch
54: https://mirrors.pidginhost.com/arch/$repo/os/$arch
55: http://mirrors.xtom.ee/archlinux/$repo/os/$arch
56: http://mirrors.uni-plovdiv.net/archlinux/$repo/os/$arch
57: http://archlinux.mirror.kangaroot.net/$repo/os/$arch
58: http://arch.yhtez.xyz/$repo/os/$arch
59: https://mirror.qctronics.com/archlinux/$repo/os/$arch
60: https://edgeuno-bog2.mm.fcix.net/archlinux/$repo/os/$arch
61: http://mirror.cspacehostings.com/archlinux/$repo/os/$arch
62: http://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
63: http://mirrors.dotsrc.org/archlinux/$repo/os/$arch
64: http://arlm.tyzoid.com/$repo/os/$arch
65: https://mirror.tux.si/arch/$repo/os/$arch
66: https://al.arch.niranjan.co/$repo/os/$arch
67: https://mirrors.urbanwave.co.za/archlinux/$repo/os/$arch
68: http://arch.sakamoto.pl/$repo/os/$arch
69: https://mirror.ufscar.br/archlinux/$repo/os/$arch
70: http://mirror.tux.si/arch/$repo/os/$arch
71: https://md.mirrors.hacktegic.com/archlinux/$repo/os/$arch
72: https://theswissbay.ch/archlinux/$repo/os/$arch
73: http://mirrors.urbanwave.co.za/archlinux/$repo/os/$arch
74: http://mirrors.celianvdb.fr/archlinux/$repo/os/$arch
75: http://edgeuno-bog2.mm.fcix.net/archlinux/$repo/os/$arch
76: https://nox.panibrez.com/archlinux/$repo/os/$arch
77: https://mirror.anquan.cl/archlinux/$repo/os/$arch
78: http://ftp.sh.cvut.cz/arch/$repo/os/$arch
Processes:
CPU top: 5 of 384
1: cpu: 31.7% command: kwin_wayland pid: 892 mem: 343.8 MiB (1.0%)
2: cpu: 8.0% command: konsole pid: 1773 mem: 153.3 MiB (0.4%)
3: cpu: 5.7% command: Xorg pid: 799 mem: 145.2 MiB (0.4%)
4: cpu: 5.5% command: kate pid: 1760 mem: 160.4 MiB (0.5%)
5: cpu: 2.4% command: thumbnail.so started-by: kioworker pid: 1746
mem: 111.2 MiB (0.3%)
Memory top: 5 of 384
1: mem: 344.0 MiB (1.0%) command: plasmashell pid: 1051 cpu: 2.1%
2: mem: 343.8 MiB (1.0%) command: kwin_wayland pid: 892 cpu: 31.7%
3: mem: 185.4 MiB (0.5%) command: dolphin pid: 1621 cpu: 1.7%
4: mem: 174.1 MiB (0.5%) command: polkit-kde-authentication-agent-1
pid: 1093 cpu: 0.3%
5: mem: 160.4 MiB (0.5%) command: kate pid: 1760 cpu: 5.5%
Processes: 384 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
image: 12.21 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.36
Mod Note: Formatted for you. <3
