Forum sometimes inaccessible?
When i need solutions for something, i look in a forum, but when its my pc that needs REAL HELP, i cant search on mobile, nor any type of search, but Forum and members just say:
ppl:“lol do $variable_for_random_commands it will work”
mod: "topic solved and closed’’
BUT i cant use terminal, any apps! i had many issues like this, and still have! NO ONE helps me, not even myself! My recommedation for here is: Add a tag like [NO-RESEARCH]$postname and ppl would actually help me and other people!
The forum does experience downtime at certain points, though they are not all that often and usually short-lived.
What does this mean?
The forum is accessible via mobile. Are you saying your mobile device cannot access the website?
Please stop paraphrasing with goofy extra language.
Your posts are hard to follow as it is.
But i will also mention that … solutions are usually marked correctly.
This sounds like a more specific problem.
Maybe you need to rethink your approach to whatever problem you have.
Maybe begin somewhere like this:
A terminal command is usually the most basic way of handling a problem, can be initiated even when a desktop is unavailable and no GUI is possible, and often why it is preferred.
What?
What do you actually mean here and how would it be helpful?
You have created a total of 3 threads in the last 2 hours and all of them have garnered responses. But you have not replied to a single one.
It would appear you are not helping yourself.
Extra note: Please try to revise your approach to creating threads like this.
Some thoughts may be: include concise and intelligible reporting of the situation, strive for legible formatting, and remember to be polite with other penguins.
Logs for forum server show no recent downtime
status.manjaro.org - Manjaro Forum
An interrobang ?!? is used for rhetorical questions, so forum users may not even read this post
Please do not add tags like this for troubleshooting posts, they will just be deleted
Forum Rules - How to Post
avoid extraneous phrases such as [HELP!], [URGENT]
Further reading: How To Ask Questions The Smart Way
That’s interesting…
Try installing Firefox on your mobile device.
Forum sometimes inaccessible?!?
I think this is a slightly weaker non-native speaker.
Accessiblity options for the forums involve foreign language speakers, though whichever language you decide to use would require some level of competency before communication can be effective.
Hence, I think I tend to agree with the title - the forum is obviously inaccessible to someone who cannot understand, or make themselves understood.
Im experience since yesterday really slow connection to the Forum… today is a little bid better but still slow, anyone else facing this problem?
No, haven’t experienced any sluggish behaviour of the forum for quite some time. On my side: average bandwidth, Firefox browser, rather old hardware
I’d just like to add my tuppence worth here: no actual downtime noticed but there have been some slowdowns (very occasionally, most likely due to the poor WiFi connection I was using) and delays in notifications (more frequently, but tends to happen after a sleep cycle).
I don’t have downtime, i just have really slow connection to the forum from germany.
While all other webpages that i visit running fast.
Many apparent slowdowns might be attributable to DNS issues, which are neither the fault of your client or the target server.
This is clearly… not very clear;
However, I think the OP might be asking for a standard tag of some kind to indicate that a user is either incapable of; or has no intention of; performing their own research to find a solution to an issue – perhaps this might also extend to providing requested information.
This tag would then also indicate that an issue should be magically solved with very little input from the user. Perhaps with Step by Step instructions given in response, thanks to an AI driven shared Crystal Ball, that we all utilise for just such an occasion.
For the OP;
If your Manjaro installation has a problem that prevents your computer from booting, you can instead boot using any Manjaro DVD/ISO/USB; boot into the Live environment that provides, and use the instance of Firefox in the Live environment to access the forum.
While in the Live environment, you can also provide information requested by others to help diagnose your issue and you can even use the terminal to initiate repair operations.
Performing research without using a phone is then also possible.
I hope this is helpful. Cheers.
Just now it got even worse, it took my 5 minutes to load Forum.manjaro.org and after another 3 minutes i finally can post this.
