I can make the partition on the pen drive easily enough in gparted butvi need to mount it to copy files to it which means I need ownership of that directory after it is mounted BUT
chown -R clowdyallday:clowdyallday ~/Public
Spitsout errors. Clearly I mounted /dev/sdb1 to ~/Public & clowdyallday is both a user and group name that I am using and belong to. The error says operation not permitted.
I am not using mfstdata flags but esp which also enabled boot.
My pi4b8gb with manjaro is my only PC.
The pen drive shows in gparted without errors dosfstools and mtools are installed…
Tried to sudo mv files in terminal to no avail. Some errors about failing to preserve ownership of the files and folders and finally reporting operation not permitted. Though I did get a few things copied over it seem, just not all of them. Plenty of free space too.
So I finally set my flag back to mtfsdata, copied the files and set it back to esp after. I follow instructions given, except when they suck. ;). People on the internet should know what they are doing before creating how tos… Now I’m hitting the bullseye. Nothing but net. Thanks for your help. Sorry if I frustrated you.
