Form>Languages>Esperanto?
From my experience at events and online, about 1/4 to 1/2 of Esperanto speakers are serious computer people/developers of some kind or other.
Would it be possible to create an Esperanto category in the Manjaro forum?
Promote Esperanto to Manjaro users/Manjaro to Esperanto speakers?
Thanks.
Please start posting in Esperanto in the #languages section and if you get enough traction, we’ll create a separate language section…
:bowing_man:
Thanks/Dankon :slight_smile:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
Low vision. That stuff is low contrast and I didn’t notice till you showed me. Thanks.
I’ve added the #esperanto tag. Post in #languages and use that tag for now.
