I have a dual-SSD rig that has started unmounting the drives on reboot.
How can I force each drive to mount on boot and stick to their assignment ie. sda1
I’ll answer the second part of your question first. You cannot. This is exactly the reason why UUID
and LABEL
support was added to mount
, because due to electrical glitches, the enumeration of storage devices can change between reboots ─ /dev/sda
can become /dev/sdb
and vice versa.
As for the first part of your question, that’s what /etc/fstab
is for. See the following man
pages…
man mount
man fstab
If you need any more information, then you’re also going to have to provide us with more information yourself. We have no idea what your setup is, what filesystems are involved, which mountpoints, and so on.
I ran lsblk --fs
and have the UUIDs of the 2 SSDs:
sda1
needs to mount to /mnt/usb
sdb1
needs to mount to /mnt/backup
so I edit /etc/fstab
to this?
UUID=UUID_OF_SDA1 /mnt/usb ext4 defaults
UUID=UUID_OF_SDB1 /mnt/backup ext4 defaults
Almost.
Add 0 0
to the end of each line. I would also add the nofail
option if these are removable drives, or else your system will refuse to boot if they’re not attached.
UUID=UUID_OF_SDA1 /mnt/usb ext4 defaults,nofail 0 0
UUID=UUID_OF_SDB1 /mnt/backup ext4 defaults,nofail 0 0
Thanks. They are Internal SSD that are storing data - boot partition is on eMMC.
Looks like setting drives to specific /sd_
is possible with udev
rules.
The program I am using relies on sda1
as main drive & sdb1
as backup.
https://wiki.archlinux.org/index.php/Persistent_block_device_naming
Added the lines to /etc/fstab
but the drives didn’t mount on boot.
Maybe add auto
to the mount options? But strictly speaking, that should not be necessary, as the defaults
value for hard disk partitions normally already includes the auto
option.
