Fonts in GTK4 apps are ugly
Fonts in GTK4 apps are ugly. Why?
Here is simple GTK3 app color picker.
And here is simple GTK4 app gtk4-demos
Here is my /etc/fonts/local.conf
<?xml version="1.0"?>
<!DOCTYPE fontconfig SYSTEM "fonts.dtd">
<fontconfig>
        per-user config    ~/.config/fontconfig/fonts.conf
        global config      /etc/fonts/local.conf
    <match target="font">
        <edit name="antialias"      mode="assign"><bool>true</bool></edit>
        <edit name="hinting"        mode="assign"><bool>true</bool></edit>
        <edit name="autohint"       mode="assign"><bool>false</bool></edit>
        <edit name="hintstyle"      mode="assign"><const>hintfull</const></edit>
        <!-- hintstyle = hintfull | hintmedium | hintslight | hintnone -->
        <edit name="rgba"           mode="assign"><const>none</const></edit>
    </match>
</fontconfig>
Do I miss something?
You should use hintslight not hintfull for hintstyle.
No, it didn’t help. Result is the same. :anguished:
To enable this use the following file and option
~/.config/gtk-4.0/settings.ini
[Settings]
gtk-hint-font-metrics=1
https://wiki.archlinux.org/title/GTK#Text_in_GTK_4_applications_is_blurry_or_renders_incorrectly
It is also noted in this issue:
That you may need to also set
gtk-font-rendering=manual
For the above to be effective.
The following options may or may not also be helpful
gtk-xft-hintstyle=hintslight
gtk-xft-hintstyle=hintfull
gtk-xft-antialias=0
gtk-xft-hinting=1
(obviously choose either hintslight or hintfull for the hintstyle, and either 0 or 1 for the others)
Notes for Gnomes
Gnome will override your settings. Because Gnome.
You must use gsettings to actually apply any of the options described above. ex;
gsettings set org.gnome.desktop.interface font-rendering 'manual'
This helped me
[Settings]
Thanks!
