i want change to English .
and there is no snap and flatpak only AUR
can you simply type commands please? i am helping my brother after install manjaro kde
The commands are in the tutorial. If you’re not going to read it, then you’ll never learn anything.
and what about pamac only aur?
I’m afraid I cannot help you with that. I don’t use the Pamac GUI, and I also don’t ever use any Snaps, FlatPaks or AppImages.
Basically:
pamac install flatpak libpamac-flatpak-plugin snapd libpamac-snap-plugin
sudo systemctl enable --now snapd.socket
