that’s what I found you do, later you add FONT= in /etc/vconsole.conf but bdf2psf doesn’t have /usr/share/bdf2psf/required.set - any ideas about howto?
That post also points to a How to in another post; and in that other post are links – one to a package file gohufont-bdf-2.0.tar.gz, and another to the download page for bdf2psf_1.223_all.deb.
Is it possible the required.set you seek may be in one of those packages?
Your responses are “end of discussion”, “it’s your fault”, strangely I anticipated this.
Perhaps yes, but I think you’re assuming wrong, the problem I’m facing is “how to make fonts in Alt-F? console larger” and “how to use another font in console”, text on my FHD computer’s screen is very small, not easy to read without eyestrain, I don’t think I’m only person that has/had that problem, and while it might be generic I’d say it’s quite common issue when using Manjaro on a modern computer and someone must know something about that or one should be able to find it in Manjaro wiki, it’s a problem that can occur to people as quickly as after installing Manjaro.
Run Pamac, enable AUR support, look for otf2bdf, look for bdf2psf - you don’t have to look far, and even if you searched on google it would find it readily :).
You did well, if you care to look at my reply you’ll see “Useful reading” - I happened to say that man, please don’t be so critical.
I’m going to delve into reply above, it could have data on this that would lead to solving.
There two more special character sets in the files required.set and useful.set. The first of them lists the symbols that every console font is obligated to support.
There two classes of obligatory symbols - the ASCII symbols and the symbols from the so called alternate character set.
These files are apparently found in the source code of fontconfig. Also, they may be simply internal references rather than actual files you need to acquire separately.
However, I don’t know specifically; you will need to do your own homework.
Note:- It should also be understood that using commands likely related to a Debian/Ubuntu implementation of bdf2psf will probably fail on an ArchLinux based distribution such as Manjaro.
We are all users GNU applications running atop of Manjaro compiled kernel - but none of us can is capable of reading what is not written.
Please don’t assume anyone to understand your thought process without explaining in detail what you are doing - how you arrived at the result - the result you are now asking for help to fix.
I apologize - no intention - possibly a mild frustration - nothing else.
Console fonts are limited to 256 or 512 chars - if I remember correct - perhaps the conversion you are doing caps the font - I am guessing … I may be complety of track …
I am thinking that you could use kmscon - as this will make it possible to use other unicode fonts e.g. with glyphs etc.
You obtained the binaries using custom packages from AUR.
If the usage of said custom packages is providing the expected result you should look at the upstream source as shown at the relevant AUR page.
Then look at the original authors pages for an answer - if none is found you likely have an option to create an issue at the source repo.
